[Hardware] SDIO Interface Voltage
87
Hardware SDIO Interface Voltage
Posted at 9/29/2023 07:36:28      View3721 | Replies4        Print      Only Author   [Copy Link] 1#
Hi!
I have connected a WiFi module to Core-3308Y using the SDIO interface.
The module itself is detected as SDR50 device:
[    3.329205] mmc2: new ultra high speed SDR50 SDIO card at address 0001
According to the SDIO standard, SDR50 mode uses 1.8v signaling.
I have looked at the interface levels by scope before and after the WiFi module detection, and in all cases they seem to be 3.3v, not 1.8v.
Which volatge is used by SDIO interface on Core-3308Y? Can it somehow be switched to 1.8v?
BTW The interface seem to work at 3.3v, but I had no chance to test the communication quality yet.
administrator
Rank: 9Rank: 9Rank: 9
Posted at 10/7/2023 16:52:02        Only Author  2#
Hello, please check this specification: https://download.t-firefly.com/% ... on.pdf?v=1696668643
Posted at 10/9/2023 07:10:58        Only Author  3#
According to RK3308 datasheet, SDIO signals correspond to VCCIO4 domain. Its specified voltage is 1.8v. But it seems that on Core-3308Y VCCIO4 is fed by 3.3v by default.
The question is: could the voltage be somehow switched to 1.8v by software (gpio-regulator in terms of Device Tree)?
BTW the MMC interface has this functionality, as it is described in the module datasheet.
administrator
Posted at 10/9/2023 10:45:37        Only Author  4#
ivan.p Posted at 10/9/2023 07:10
According to RK3308 datasheet, SDIO signals correspond to VCCIO4 domain. Its specified voltage is 1. ...
No, you can only turn on or off the I/O via software. Switching SDIO voltage needs to change the hardware.
restricted members
Posted at 1/12/2026 03:51:59        Only Author  5#
Im amazed by this article, thank you for sharing it. The Virginia-Real-Estate-Salesperson latest test guide helped me with a promotion and raise. Now its free to everyone. May your career progression be swift!
