[General] XSOAR-Engineer New Dumps Ebook, Reliable XSOAR-Engineer Test Syllabus
78
General XSOAR-Engineer New Dumps Ebook, Reliable XSOAR-Engineer Test Syllabus
Posted at 1/20/2026 06:58:51      View212 | Replies1        Print      Only Author   [Copy Link] 1#
Desktop-based practice exam software XSOAR-Engineer is the first format that ExamBoosts provides to its customers. It helps track the progress of the candidate from beginning to end and provides a progress report that is easily accessible. This Palo Alto Networks XSOAR-Engineer Practice Questions is customizable and mimics the real exam, with the same format, and is easy to use on Windows-based computers. The product support staff is available to assist with any issues that may arise.
With both XSOAR-Engineer exam practice test software you can understand the Palo Alto Networks XSOAR Engineer (XSOAR-Engineer) exam format and polish your exam time management skills. Having experience with XSOAR-Engineer exam dumps environment and structure of exam questions greatly help you to perform well in the final XSOAR-Engineer Exam. The desktop practice test software is supported by Windows. Our web-based practice exam is compatible with all browsers and operating systems.
Reliable XSOAR-Engineer Test Syllabus, Standard XSOAR-Engineer AnswersIf you do not have extraordinary wisdom, do not want to spend too much time on learning, but want to reach the pinnacle of life through XSOAR-Engineer exam, then you must have XSOAR-Engineer question torrent. The goal of XSOAR-Engineer exam torrent is to help users pass the exam with the shortest possible time and effort. With XSOAR-Engineer Exam Torrent, you neither need to keep yourself locked up in the library for a long time nor give up a rare vacation to review. You will never be frustrated by the fact that you can't solve a problem.
Palo Alto Networks XSOAR-Engineer Exam Syllabus Topics:
  • Threat Intelligence Management: This domain focuses on threat intelligence operations including indicator creation and configuration, indicator relationships, enrichment with source reliability, external intelligence sharing, and exclusion list management.
  • Playbook Development: This domain addresses automation through playbook creation including task configuration, context data manipulation, various task types, sub-playbooks with looping, filters and transformers, debugger usage, built-ins and scripts, automation script creation, and job management.
  • Use Case Planning and Development: This domain focuses on designing security use cases through incident and indicator lifecycle management, field and layout customization, classifier and mapper configuration, incident creation methods, pre
  • post-processing, and incident type configuration with playbooks, layouts, SLAs, and lists.
  • Incident Interactions and Reporting: This domain covers incident operations including states and actions, War Room activities, incident relationships, and dashboard and report configuration for metrics and visualization.
Topic 5
  • Planning, Installation, and Maintenance: This domain covers system setup and administration including authentication configuration, engine deployment, dev
  • prod environment planning, Marketplace pack management, integration instance configuration, and system maintenance.
Palo Alto Networks XSOAR Engineer Sample Questions (Q120-Q125):NEW QUESTION # 120
A SOC analyst needs to retrieve the list of all open phishing incidents in the last 30 days. What is the correct query to use?
  • A. status:closed -category:jobandtypehishing created:>="30 days ago"
  • B. -status:closed -category:job typehishing created:>="30 days ago"
  • C. -status:closed -category:jobandtypehishing created:<="30 days ago"
  • D. -status:closed -category:job typehishing created:="30 days ago"
NEW QUESTION # 121
What are the three ways to add/mark entries as evidence inside the Evidence Board? (Choose three.)
  • A. Manually from the playbook task (mark as entry icon)
  • B. By running the command !MarkAsEvidence
  • C. Manually directly from the War Room with the Actions drop-down
  • D. Automatically from playbook tasks when the option is selected on the Advanced tab
  • E. From the Notes section (mark as entry icon)
Answer: C,D,E
NEW QUESTION # 122
Which of the following is a prerequisite to editing out-of-the-box (OOTB) content?
  • A. Detach the content item you want to edit from the Marketplace.
  • B. Register a user account with support.paloaltonetworks.com .
  • C. Download the content from the Marketplace.
  • D. Go to Settings > About >Troubleshooting and set a flag to allow custom content.
NEW QUESTION # 123
An engineer adds a new "Forensics" tab that includes several sections for detailed artifact analysis to the
"Malware Incident" layout. However, junior analysts report they cannot see this tab, while senior analysts can.
Which configuration setting is the most likely reason for this discrepancy?.
  • A. The tab was marked as read-only in the layout configuration for the junior analyst roles.
  • B. The tab was not added to the junior analyst role group.
  • C. A display filter was applied to the tab in the layout editor.
  • D. The underlying fields within the tab sections was incorrectly mapped.
According to the Cortex XSOAR Admin Guide, visibility of layout tabs is controlled byrole-based access permissions (RBAC). When customizing layouts, administrators can assign tabs, fields, and components to specific user roles. If the "Forensics" tab appears for senior analysts but not junior analysts, this indicates that the tab has been assigned only to certain roles through the "Roles" field in the layout editor.
XSOAR does not hide layout tabs due to incorrect field mappings (option A). If a field is unmapped, it simply appears empty, not invisible. Likewise, marking a tab as "read-only" (option C) still makes it visible; it only restricts editing. Display filters (option D) apply to list widgets, dashboards, and incidents-not layout tab visibility.
The documentation clearly states thata tab will not appear to a user unless their assigned role is included in the tab's role permissions. Therefore, junior analysts cannot view the tab becausethe tab was not assigned to their role, making optionBthe correct explanation based on XSOAR's RBAC-controlled layout behavior.
NEW QUESTION # 124
You need to retrieve a list of all malicious hashes over the last 30 days. What is the correct query to use?
  • A. type:File verdict:Malicious sourcetimestamp:<="30 days ago"
  • B. type:File reputation:Malicious sourcetimestamp:="30 days ago"
  • C. type:File reputation:Malicious sourcetimestamp:"30 days ago"
  • D. type:File verdict:Malicious sourcetimestamp:>="30 days ago"
NEW QUESTION # 125
We provide online customer service to the customers for 24 hours per day and we provide professional personnel to assist the client in the long distance online. If you have any questions and doubts about the Palo Alto Networks XSOAR Engineer guide torrent we provide before or after the sale, you can contact us and we will send the customer service and the professional personnel to help you solve your issue about using XSOAR-Engineer Exam Materials. The client can contact us by sending mails or contact us online. We will solve your problem as quickly as we can and provide the best service. Our after-sales service is great as we can solve your problem quickly and wont let your money be wasted. If you arent satisfied with our XSOAR-Engineer exam torrent you can return back the product and refund you in full.
Reliable XSOAR-Engineer Test Syllabus: https://www.examboosts.com/Palo-Alto-Networks/XSOAR-Engineer-practice-exam-dumps.html
Posted at 2/6/2026 04:33:52        Only Author  2#
This article has helped me understand many complex concepts, and Ive gained a lot. Free Terraform-Associate-003 valid test format test questionsunlock promotions and salary growth today!
