Sample AZ-120 Questions, AZ-120 Pdf Files
Posted at 1/20/2026 07:45:51
What's more, part of that TestPassed AZ-120 dumps now are free: https://drive.google.com/open?id=1LR2VxBSLk_yU39i_v2j7qSUVm5obyvI3
If you purchasing our AZ-120 simulating questions, you will get a comfortable package services afforded by our considerate after-sales services. We respect your needs toward the useful AZ-120practice materials by recommending our AZ-120 Guide preparations for you. And we give you kind and professional supports by 24/7, as long as you can have problems on our AZ-120 study guide, then you can contact with us.
Microsoft AZ-120 certification exam is designed for professionals who are interested in planning and administering Microsoft Azure for SAP workloads. Planning and Administering Microsoft Azure for SAP Workloads certification exam is ideal for individuals who have experience working with SAP applications and want to expand their knowledge of Azure cloud services. By passing the AZ-120 Exam, candidates can demonstrate their proficiency in implementing, managing, and monitoring Azure resources for SAP workloads.
AZ-120 Pdf Files | New AZ-120 Exam NameIt is essential to get the Microsoft AZ-120 exam material because you have no other option to understand the subject. Planning and Administering Microsoft Azure for SAP Workloads AZ-120 have latest exam answers, latest exam book and latest exam collection. TestPassed offers valid exam book and valid exam collection help you pass the AZ-120 Exam successfully.
Microsoft Planning and Administering Microsoft Azure for SAP Workloads Sample Questions (Q142-Q147):NEW QUESTION # 142
https://www.suse.com/media/guide/sap_hana_on_azure_101.pdf
NEW QUESTION # 143
You have an on-premises SAP environment.
Backups are performed by using tape backups. There are SO TB of backups.
A Windows file server has BMP images of checks used by SAP Finance. There are 9 IB of images.
You need to recommend a method to migrate the images and the tape backups to Azure. The solution must maintain continuous replication of the images.
What should you include in the recommendation? To answer, select the appropriate options in the answer area.
Tape Backups - Azure Databox
File Server - Azure Storage Explorer
NEW QUESTION # 144
For each of the following statements, select Yes if the statement is true. Otherwise, select No. NOTE: Each correct selection is worth one point.
NEW QUESTION # 145
You have an on-premises SAP environment hosted on VMware VSphere that uses Microsoft SQL Server as the database platform.
You plan to migrate the environment to Azure. The database platform will remain the same.
You need gather information to size the target Azure environment for the migration.
What should you use?
- A. the SAP EarlyWatch report
- B. the SAP HANA sizing report
- C. Azure Advisor
- D. Azure Monitor
Azure Advisor provides recommendations for Application Gateway, App Services, availability sets, Azure Cache, Azure Data Factory, Azure Database for MySQL, Azure Database for PostgreSQL, Azure Database for MariaDB, Azure ExpressRoute, Azure Cosmos DB, Azure public IP addresses, SQL Data Warehouse, SQL servers, storage accounts, Traffic Manager profiles, and virtual machines.
Note: Advisor is a personalized cloud consultant that helps you follow best practices to optimize your Azure deployments. It analyzes your resource configuration and usage telemetry and then recommends solutions that can help you improve the cost effectiveness, performance, high availability, and security of your Azure resources.
With Advisor, you can:
Get proactive, actionable, and personalized best practices recommendations.
Improve the performance, security, and high availability of your resources, as you identify opportunities to reduce your overall Azure spend.
Get recommendations with proposed actions inline.
Incorrect Answers:
A: The SAP EarlyWatch report is a monitoring tool that monitors the essential administrative areas of SAP components and keeps you up to date on their performance and stability. SAP EarlyWatch Alert runs automatically to keep you informed, so you can react to issues proactively, before they become critical.
https://docs.microsoft.com/en-us/azure/advisor/advisor-overview
Design an Azure Solution to Support SAP Workloads
Testlet 1
Case Study
This is a case study. Case studies are not timed separately. You can use as much exam time as you would like to complete each case. However, there may be additional case studies and sections on this exam. You must manage your time to ensure that you are able to complete all questions included on this exam in the time provided.
To answer the questions included in a case study, you will need to reference information that is provided in the case study. Case studies might contain exhibits and other resources that provide more information about the scenario that is described in the case study. Each question is independent of the other questions in this case study.
At the end of this case study, a review screen will appear. This screen allows you to review your answers and to make changes before you move to the next section of the exam. After you begin a new section, you cannot return to this section.
To start the case study
To display the first question in this case study, click the Next button. Use the buttons in the left pane to explore the content of the case study before you answer the questions. Clicking these buttons displays information such as business requirements, existing environment, and problem statements. If the case study has an All Information tab, note that the information displayed is identical to the information displayed on the subsequent tabs. When you are ready to answer a question, click the Question button to return to the question.
Overview
Litware, Inc. is an international manufacturing company that has 3,000 employees.
Litware has two main offices. The offices are located in Miami, FL, and Madrid, Spain.
Existing Environment
Infrastructure
Litware currently uses a third-party provider to host a datacenter in Miami and a disaster recovery datacenter in Chicago, IL.
The network contains an Active Directory domain named litware.com. Litware has two third-party applications hosted in Azure.
Litware already implemented a site-to-site VPN connection between the on-premises network and Azure.
SAP Environment
Litware currently runs the following SAP products:
* Enhancement Pack6 for SAP ERP Central Component 6.0 (SAP ECC 6.0)
* SAP Extended Warehouse Management (SAP EWM)
* SAP Supply Chain Management (SAP SCM)
* SAP NetWeaver Process Integration (PI)
* SAP Business Warehouse (SAP BW)
* SAP Solution Manager
All servers run on the Windows Server platform. All databases use Microsoft SQL Server. Currently, you have
20 production servers.
You have 30 non-production servers including five testing servers, five development servers, five quality assurance (QA) servers, and 15 pre-production servers.
Currently, all SAP applications are in the litware.com domain.
Problem Statements
The current version of SAP ECC has a transaction that, when run in batches overnight, takes eight hours to complete. You confirm that upgrading to SAP Business Suite on HANA will improve performance because of code changes and the SAP HANA database platform.
Litware is dissatisfied with the performance of its current hosted infrastructure vendor. Litware experienced several hardware failures and the vendor struggled to adequately support its 24/7 business operations.
Requirements
Business Goals
Litware identifies the following business goals:
* Increase the performance of SAP ECC applications by moving to SAP HANA. All other SAP databases will remain on SQL Server.
* Move away from the current infrastructure vendor to increase the stability and availability of the SAP services.
* Use the new Environment, Health and Safety (EH&S) in Recipe Management function.
* Ensure that any migration activities can be completed within a 48-hour period during a weekend.
Planned Changes
Litware identifies the following planned changes:
* Migrate SAP to Azure.
* Upgrade and migrate SAP ECC to SAP Business Suite on HANA Enhancement Pack 8.
Technical Requirements
Litware identifies the following technical requirements:
* Implement automated backups.
* Support load testing during the migration.
* Identify opportunities to reduce costs during the migration.
* Continue to use the litware.com domain for all SAP landscapes.
* Ensure that all SAP applications and databases are highly available.
* Establish an automated monitoring solution to avoid unplanned outages.
* Remove all SAP components from the on-premises network once the migration is complete.
* Minimize the purchase of additional SAP licenses. SAP HANA licenses were already purchased.
* Ensure that SAP can provide technical support for all the SAP landscapes deployed to Azure.
NEW QUESTION # 146
You plan to migrate an SAP database from Oracle to Microsoft SQL Server by using the SQL Server Migration Assistant (SSMA).
You are configuring a Proof of Concept (PoC) for the database migration You plan to perform the migration multiple times as part of the PoC.
You need to ensure that you can perform the migrations as quickly as possible. The solution must ensure that all Oracle schemas are migrated.
Which migration method and migration mode should you use? To answer, select the appropriate options in the answer area NOTE: Each correct selection is worth one point.
NEW QUESTION # 147
The data for our AZ-120 practice materials that come up with our customers who have bought our AZ-120 actual exam and provided their scores show that our high pass rate is 98% to 100%. This is hard to find and compare with in the market. And numerous enthusiastic feedbacks from our worthy clients give high praises not only on our AZ-120 Study Guide, but also on our sincere and helpful 24 hours customer services online. You will feel grateful to choose our AZ-120 learning quiz!
AZ-120 Pdf Files: https://www.testpassed.com/AZ-120-still-valid-exam.html
- Sample AZ-120 Questions 100% Pass | High Pass-Rate Microsoft Planning and Administering Microsoft Azure for SAP Workloads Pdf Files Pass for sure 🧤 Open website ▷ [url]www.practicevce.com ◁ and search for ▷ AZ-120 ◁ for free download 🏍AZ-120 Testking Exam Questions[/url]
- AZ-120 Trustworthy Source 💛 AZ-120 Practice Test Engine 🏤 Sample AZ-120 Questions 🐂 Open 「 [url]www.pdfvce.com 」 and search for ➡ AZ-120 ️⬅️ to download exam materials for free 🟦Valid AZ-120 Exam Prep[/url]
- Exam AZ-120 Passing Score 😣 AZ-120 Test Questions Vce 🕵 New AZ-120 Test Objectives 🥴 Search for ⮆ AZ-120 ⮄ on { [url]www.pdfdumps.com } immediately to obtain a free download 🧡AZ-120 Test Questions Vce[/url]
- Valid Microsoft AZ-120 Exam Questions are Conveniently Available in PDF Format 🌺 Download ⇛ AZ-120 ⇚ for free by simply searching on ▛ [url]www.pdfvce.com ▟ 🌾AZ-120 Test Questions Vce[/url]
- Microsoft AZ-120 Exam Dumps in PDF Format 🏥 Easily obtain ➡ AZ-120 ️⬅️ for free download through ▶ [url]www.dumpsmaterials.com ◀ 💒Valid AZ-120 Exam Prep[/url]
- AZ-120 Exam Discount Voucher 🍂 AZ-120 Testking Learning Materials 🍸 AZ-120 Latest Exam Format 💎 Search for ➽ AZ-120 🢪 and easily obtain a free download on ▶ [url]www.pdfvce.com ◀ 🔌Test AZ-120 Tutorials[/url]
- Sample AZ-120 Questions 100% Pass | High Pass-Rate Microsoft Planning and Administering Microsoft Azure for SAP Workloads Pdf Files Pass for sure 🕠 Easily obtain ▷ AZ-120 ◁ for free download through ➥ [url]www.examcollectionpass.com 🡄 🦅AZ-120 Trustworthy Source[/url]
- Test AZ-120 Tutorials 📍 AZ-120 Trustworthy Source 🎆 Best AZ-120 Study Material 🚌 Search on 《 [url]www.pdfvce.com 》 for ➥ AZ-120 🡄 to obtain exam materials for free download 🌀Valid AZ-120 Exam Prep[/url]
- AZ-120 Test Questions Vce 🧺 AZ-120 Trustworthy Source 🌜 New AZ-120 Test Objectives ⛰ Search for ➥ AZ-120 🡄 and download it for free immediately on ⏩ [url]www.prepawaypdf.com ⏪ 📖AZ-120 Practice Test Engine[/url]
- Sample AZ-120 Questions 100% Pass | High Pass-Rate Microsoft Planning and Administering Microsoft Azure for SAP Workloads Pdf Files Pass for sure 👩 Go to website ▶ [url]www.pdfvce.com ◀ open and search for ➥ AZ-120 🡄 to download for free 🍲Valid AZ-120 Exam Materials[/url]
- Sample AZ-120 Questions 100% Pass | High Pass-Rate Microsoft Planning and Administering Microsoft Azure for SAP Workloads Pdf Files Pass for sure 🕎 Go to website ▶ [url]www.examcollectionpass.com ◀ open and search for [ AZ-120 ] to download for free 🟡Study AZ-120 Demo[/url]
DOWNLOAD the newest TestPassed AZ-120 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1LR2VxBSLk_yU39i_v2j7qSUVm5obyvI3
