[General] Latest 312-50v13 Study Plan, 312-50v13 Test Pattern
【General】 Latest 312-50v13 Study Plan, 312-50v13 Test Pattern
Posted at 1/20/2026 08:46:46      View:78 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest FreePdfDump 312-50v13 PDF Dumps and 312-50v13 Exam Engine Free Share: https://drive.google.com/open?id=1YzQxjHp09kPNvfXe_wiIKZgC-Fq1yjD-
As the most important element that almost all the candidates will take into consider, the pass rate of our 312-50v13 exam questions is high as 98% to 100%, which is unique in the market and no one has made it. And also the exam passing guarantee that makes our 312-50v13 Study Guide superior in the market. As the best seller, our 312-50v13 learning braindumps are very popular among the candidates. Many of the loyal customers are introduced by their friends or classmates.
Compared with other training materials, why FreePdfDump's ECCouncil 312-50v13 exam training materials is more welcomed by the majority of candidates? First, this is the problem of resonance. We truly understand the needs of the candidates, and comprehensively than any other site. Second, focus. In order to do the things we decided to complete, we have to give up all the unimportant opportunities. Third, the quality of the product. People always determine a good or bad thing based on the surface. We may have the best products of the highest quality, but if we shows it with a shoddy manner, it naturally will be as shoddy product. However, if we show it with both creative and professional manner, then we will get the best result. The FreePdfDump's ECCouncil 312-50v13 Exam Training materials is so successful training materials. It is most suitable for you, quickly select it please.
312-50v13 Test Pattern - 312-50v13 Popular ExamsTo be well-prepared, you require trustworthy and reliable FreePdfDump practice material. You also require accurate FreePdfDump study material to polish your capabilities and improve your chances of passing the 312-50v13 Certification Exam. FreePdfDump facilitates your study with updated ECCouncil 312-50v13 exam dumps.
ECCouncil Certified Ethical Hacker Exam (CEHv13) Sample Questions (Q760-Q765):NEW QUESTION # 760
In order to tailor your tests during a web-application scan, you decide to determine which web-server version is hosting the application. On using the sV flag with Nmap. you obtain the following response:
80/tcp open http-proxy Apache Server 7.1.6
what Information-gathering technique does this best describe?
  • A. WhOiS lookup
  • B. Brute forcing
  • C. Dictionary attack
  • D. Banner grabbing
Banner grabbing is a technique wont to gain info about a computer system on a network and the services running on its open ports. administrators will use this to take inventory of the systems and services on their network. However, an to find will use banner grabbing so as to search out network hosts that are running versions of applications and operating systems with known exploits.
Some samples of service ports used for banner grabbing are those used by Hyper Text Transfer Protocol (HTTP), File Transfer Protocol (FTP), and Simple Mail Transfer Protocol (SMTP); ports 80, 21, and 25 severally. Tools normally used to perform banner grabbing are Telnet, nmap and Netcat.
For example, one may establish a connection to a target internet server using Netcat, then send an HTTP request. The response can usually contain info about the service running on the host:
Graphical user interface, text, application Description automatically generated
This information may be used by an administrator to catalog this system, or by an intruder to narrow down a list of applicable exploits.To prevent this, network administrators should restrict access to services on their networks and shut down unused or unnecessary services running on network hosts. Shodan is a search engine for banners grabbed from portscanning the Internet.
NEW QUESTION # 761
When considering how an attacker may exploit a web server, what is web server footprinting?
  • A. When an attacker gathers system-level data, including account details and server names
  • B. When an attacker creates a complete profile of the site's external links and file structures
  • C. When an attacker uses a brute-force attack to crack a web-server password
  • D. When an attacker implements a vulnerability scanner to identify weaknesses
Web server footprinting is part of the reconnaissance phase in ethical hacking. It involves gathering detailed information about a web server's structure, external links, available directories, scripts, and technologies in use.
Techniques include:
* Spidering the site to map all accessible URLs and file paths
* Identifying hidden directories or backup files
* Analyzing page structures and URL patterns
This information helps attackers identify areas to target for further scanning or exploitation.
Incorrect Options:
* A. Vulnerability scanning is active testing, not passive footprinting.
* C. System-level data is gathered in OS or network footprinting.
* D. Brute-force attacks are exploitation techniques, not reconnaissance.
Reference - CEH v13 Official Courseware:
Module 02: Footprinting and Reconnaissance
Section: "Web Server Footprinting Techniques"
Tool Reference: HTTrack, Burp Spider, OWASP ZAP
NEW QUESTION # 762
You are tasked to configure the DHCP server to lease the last 100 usable IP addresses in subnet 10.1.4.0/23.
Which of the following IP addresses could be leased as a result of the new configuration?
  • A. 10.1.4.254
  • B. 10.1.5.200
  • C. 10.1.4.156
  • D. 210.1.55.200
Subnet 10.1.4.0/23 includes addresses from:
10.1.4.0 to 10.1.5.255
Total = 512 IPs (510 usable)
Last 100 usable IPs would be:
Start: 10.1.5.155 to 10.1.5.254
Only option C (10.1.5.200) falls within that range.
From CEH v13 Courseware:
Module 3: Subnetting & IP Addressing
Reference:IP Subnet Calculators and RFC 950
NEW QUESTION # 763
The security administrator of ABC needs to permit Internet traffic in the host 10.0.0.2 and UDP traffic in the host
10.0.0.3. He also needs to permit all FTP traffic to the rest of the network and deny all other traffic. After he applied his ACL configuration in the router, nobody can access the ftp, and the permitted hosts cannot access the Internet. According to the next configuration, what is happening in the network?
access-list 102 deny tcp any any
access-list 104 permit udp host 10.0.0.3 any
access-list 110 permit tcp host 10.0.0.2 eq www any
access-list 108 permit tcp any eq ftp any
  • A. The first ACL is denying all TCP traffic and the other ACLs are being ignored by the router
  • B. The ACL 104 needs to be first because is UDP
  • C. The ACL for FTP must be before the ACL 110
  • D. The ACL 110 needs to be changed to port 80
https://www.cisco.com/c/en/us/su ... 448-ACLsamples.html Since the first line prohibits any TCP traffic (access-list 102 deny tcp any any), the lines below will simply be ignored by the router. Below you will find the example from CISCO documentation.
This figure shows that FTP (TCP, port 21) and FTP data (port 20) traffic sourced from NetB destined to NetA is denied, while all other IP traffic is permitted.
FTP uses port 21 and port 20. TCP traffic destined to port 21 and port 20 is denied and everything else is explicitly permitted.
* access-list 102 deny tcp any any eq ftp
* access-list 102 deny tcp any any eq ftp-data
* access-list 102 permit ip any any
NEW QUESTION # 764
What is the most plausible attack vector an APT group would use to compromise an IoT-based environmental control system?
  • A. Using stolen user credentials
  • B. DDoS attack
  • C. Encrypted MitM attack
  • D. Exploiting zero-day firmware vulnerabilities
According to CEH v13 Mobile, IoT, and OT Hacking, Advanced Persistent Threat (APT) groups prioritize stealth, persistence, and long-term control. In IoT environments, the most attractive and effective entry point is firmware-level zero-day vulnerabilities.
IoT devices often:
* Run outdated or proprietary firmware
* Lack regular patching mechanisms
* Operate with high privileges
* Have minimal monitoring
Exploiting a zero-day vulnerability in firmware allows attackers to gain deep, persistent access that survives reboots and avoids traditional security controls. This aligns directly with APT objectives.
Credential theft (Option B) is common but less reliable for IoT systems. Encrypted MitM (Option C) is complex and less persistent. DDoS (Option D) disrupts services but does not provide control.
CEH v13 explicitly identifies firmware exploitation as the primary APT vector in IoT and OT environments. Therefore, Option A is correct.
NEW QUESTION # 765
Do you often feel that your ability does not match your ambition?Are you dissatisfied with the ordinary and boring position? If your answer is yes, you can try to get the 312-50v13 certification that you will find there are so many chances wait for you. You can get a better job; you can get more salary. But if you are trouble with the difficult of 312-50v13 Exam, you can consider choose 312-50v13 guide question to improve your knowledge to pass 312-50v13 exam, which is your testimony of competence. We believe our latest 312-50v13 exam torrent will be the best choice for you.
312-50v13 Test Pattern: https://www.freepdfdump.top/312-50v13-valid-torrent.html
Choosing an accurate and valid 312-50v13 exam preparation is time-saving and money-saving action, ECCouncil Latest 312-50v13 Study Plan Do not believe it, see it and then you will know, So if you don't want to be eliminated in the competition, to pass 312-50v13 exam is a necessary for you, If you study with our 312-50v13 exam questions, you are bound to get the certification, ECCouncil Latest 312-50v13 Study Plan And evey button on our website is easy, fast and convenient to use.
Architecture Description Languages, Leveraging the nativeDragUpdate Event, Choosing an accurate and valid 312-50v13 Exam Preparation is time-saving and money-saving action.
Do not believe it, see it and then you will 312-50v13 know, So if you don't want to be eliminated in the competition, to pass 312-50v13 exam is a necessary for you, If you study with our 312-50v13 exam questions, you are bound to get the certification.
ECCouncil 312-50v13 Exam Questions For Guaranteed SuccessAnd evey button on our website is easy, fast and convenient to use.
BONUS!!! Download part of FreePdfDump 312-50v13 dumps for free: https://drive.google.com/open?id=1YzQxjHp09kPNvfXe_wiIKZgC-Fq1yjD-
