[General] Latest Amazon AWS-Solutions-Associate Test Materials, AWS-Solutions-Associate Tr
83
General Latest Amazon AWS-Solutions-Associate Test Materials, AWS-Solutions-Associate Tr
Posted at 1/20/2026 10:11:21      View186 | Replies4        Print      Only Author   [Copy Link] 1#
P.S. Free & New AWS-Solutions-Associate dumps are available on Google Drive shared by Prep4sureGuide: https://drive.google.com/open?id=1D9WnGuCKkZ9ycURk6dT1NO6KcKBshHF6
If you are one of them buying our AWS-Solutions-Associate exam prep will help you pass the exam successfully and easily. Our Amazon guide torrent provides free download and tryout before the purchase and our purchase procedures are safe. Our AWS-Solutions-Associate exam torrent carries no viruses. We provide free update and online customer service which works on the line whole day. Our study materials provide varied versions for you to choose and the learning costs you little time and energy. You can use our AWS-Solutions-Associate Exam Prep immediately after you purchase them, we will send our product within 5-10 minutes to you.
The AWS-Solutions-Associate Certification Exam consists of 65 multiple-choice and multiple-response questions and must be completed within 130 minutes. AWS-Solutions-Associate exam is available in English, Japanese, Korean, and Simplified Chinese. Candidates who pass the exam are awarded the AWS Certified Solutions Architect - Associate certification, which is valid for two years.
Amazon AWS-Solutions-Architect-Associate (AWS Certified Solutions Architect - Associate (SAA-C02)) Certification Exam is a professional-level certification exam offered by Amazon Web Services (AWS) for individuals who want to validate their expertise in designing and deploying scalable, fault-tolerant systems on AWS. AWS Certified Solutions Architect - Associate (SAA-C03) certification is designed for solution architects who are responsible for designing and deploying applications on AWS, as well as for developers who want to gain a deeper understanding of AWS services and architectures.
AWS-Solutions-Associate Training Courses | AWS-Solutions-Associate Testing CenterWe offer you free update for one year after you purchase AWS-Solutions-Associate study guide from us, namely, in the following year, you can get the update version for free. And our system will automatically send the latest version to your email address. Moreover, AWS-Solutions-Associate exam dumps of us are compiled by experienced experts of the field, and they are quite familiar with dynamics of the exam center, therefore the quality and accuracy of the AWS-Solutions-Associate Study Guide can be guaranteed. You just need to choose us, and we will help you pass the exam successfully.
Amazon AWS Certified Solutions Architect - Associate (SAA-C03) Sample Questions (Q168-Q173):NEW QUESTION # 168
For which of the following use cases are Simple Workflow Service (SWF) and Amazon EC2 an appropriate solution? Choose 2 answers
  • A. Using as an endpoint to collect thousands of data points per hour from a distributed fleet of sensors
  • B. Managing a multi-step and multi-decision checkout process of an e-commerce website
  • C. Using as a distributed session store for your web application
  • D. Using as an SNS (Simple Notification Service) endpoint to trigger execution of video transcoding jobs
  • E. Orchestrating the execution of distributed and auditable business processes
NEW QUESTION # 169
How many g2.2xlarge on-demand instances can a user run in one region without taking any limit increase approval from AWS?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Explanation/Reference:
Generally, AWS EC2 allows running 20 on-demand instances and 100 spot instances at a time. This limit can be increased by requesting at https://aws.amazon.com/contact-us/ec2-request. Excluding certain types of instances, the limit is lower than mentioned above. For g2.2xlarge, the user can run only 5 on- demand instance at a time.
http://docs.aws.amazon.com/gener ... its.html#limits_ec2
NEW QUESTION # 170
A company wants to provide a third-party system that runs in a private data center with access to its AWS account. The company wants to call AWS APIs directly from the third-party system. The company has an existing process for managing digital certificates. The company does not want to use SAML or OpenID Connect (OIDC) capabilities and does not want to store long-term AWS credentials.
Which solution will meet these requirements?
  • A. Configure AWS Identity and Access Management (IAM) Roles Anywhere to exchange X.509 certificates for AWS credentials to interact with AWS APIs.
  • B. Configure mutual TLS to allow authentication of the client and server sides of the communication channel.
  • C. Configure AWS Signature Version 4 to authenticate incoming HTTPS requests to AWS APIs.
  • D. Configure Kerberos to exchange tickets for assertions that can be validated by AWS APIs.
A). Mutual TLSrovides secure communication but does not integrate with AWS credential exchange.
B). AWS Signature v4:Requires direct integration with AWS and is less secure for external systems.
C). Kerberos:Not natively supported for AWS API authentication.
D). IAM Roles Anywhere:Enables AWS API access using X.509 certificates without long-term credentials.
References:IAM Roles Anywhere
NEW QUESTION # 171
A security team needs to enforce rotation of all IAM users' access keys every 90 days. Keys older than 90 days must be automatically deactivated and removed. A solutions architect must create a remediation solution with minimal operational effort.
Which solution meets these requirements?
  • A. Create an AWS Config rule to check key age. Define an EventBridge rule that schedules an AWS Lambda function to remove the key.
  • B. Create an Amazon EventBridge rule to check key age. Configure it to run an AWS Batch job to remove the key.
  • C. Create an AWS Config rule to check key age. Configure the rule to run an AWS Batch job to remove the key.
  • D. Create an EventBridge rule to check key age. Define a second EventBridge rule to run an AWS Batch job to remove the key.
AWS Config has a built-in managed rule (access-keys-rotated) that evaluates IAM access key age. Config rules detect non-compliant resources automatically, without building custom logic.
After Config identifies old keys, EventBridge can trigger an AWS Lambda function to disable and delete the keys. Lambda provides a fully managed compute layer requiring no servers or batch environments.
Using AWS Batch (Options A, B, and D) adds unnecessary operational overhead for a simple automation task.
NEW QUESTION # 172
Someone has recommended a new client to you and you know he is into online gaming and you are almost certain he will want to set up an online gaming site which will require a database service that provides fast and predictable performance with seamless scalability.
Which of the following AWS databases would be best suited to an online gaming site?
  • A. Amazon DynamoDB
  • B. Amazon SimpleDB
  • C. Amazon Redshift
  • D. Amazon ElastiCache
Amazon DynamoDB is a fully managed NoSQL database service that provides fast and predictable performance with seamless scalability. You can use Amazon DynamoDB to create a database table that can store and retrieve any amount of data, and serve any level of request traffic. Amazon DynamoDB automatically spreads the data and traffic for the table over a sufficient number of servers to handle the request capacity specified by the customer and the amount of data stored, while maintaining consistent and fast performance.
http://aws.amazon.com/documentation/dynamodb/
NEW QUESTION # 173
After clients pay for our AWS-Solutions-Associate exam torrent successfully, they will receive the mails sent by our system in 5-10 minutes. Then the client can dick the links and download and then you can use our AWS-Solutions-Associate questions torrent to learn. Because time is very important for the people who prepare for the exam, the client can download immediately after paying is the great advantage of our AWS-Solutions-Associate Guide Torrent. So it is very convenient for the client to use and study with our AWS-Solutions-Associate exam questions.
AWS-Solutions-Associate Training Courses: https://www.prep4sureguide.com/AWS-Solutions-Associate-prep4sure-exam-guide.html
Posted at 1/24/2026 07:09:53        Only Author  2#
The article is easy to understand, and I have benefited a lot from it. Boost your IT abilities with free Reliable study guide MB-800 ebook. Wishing you all the best!
Posted at 1/31/2026 09:51:58        Only Author  3#
Thank you for your article; it truly broadened my horizons! The B2C-Commerce-Architect free exam questions questions are shared for free. Good luck on your exams!
Posted at 2/3/2026 11:05:26        Only Author  4#
This article is incredibly thought-provoking, thank you for sharing! Im sharing the SAFe-SPC reliable vce test simulator resources for freebest of luck to you!
Posted at 2/8/2026 11:21:43        Only Author  5#
I am genuinely inspired by this article, thank you for sharing! I hope the Professional-Data-Engineer latest test dumps questions material helps, and it's entirely free.
