[General] Free 1z0-1077-25 Learning Cram | Latest 1z0-1077-25 Study Guide
62
General Free 1z0-1077-25 Learning Cram | Latest 1z0-1077-25 Study Guide
Posted at 1/20/2026 10:15:21      View147 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest TestkingPass 1z0-1077-25 PDF Dumps and 1z0-1077-25 Exam Engine Free Share: https://drive.google.com/open?id=10dMInYFK4M5xKFjpQLE_19COkmIIFCZN
You can avoid this mess by selecting a trusted brand such as Exams. To buy real 1z0-1077-25 Exam Dumps. The credible platform offers a product that is accessible in 3 formats: Oracle 1z0-1077-25 Dumps PDF, desktop practice exam software, and a web-based practice test. Any applicant of the 1z0-1077-25 examination can choose from these preferable formats.
If you are applying for the 1z0-1077-25 certification exam, it is great to show your dedication to it. You cannot take it for granted because the Oracle Order Management Cloud Order to Cash 2025Implementation Professional (1z0-1077-25) certification test is tough and you have to pay a good sum for appearing in it. You will lose money and time by studying with 1z0-1077-25 Exam Preparation material that is not updated. So, to avoid your loss and failure in the 1z0-1077-25 exam, you must prepare with actual Oracle 1z0-1077-25 questions from TestkingPass.
Latest Oracle 1z0-1077-25 Study Guide, Real 1z0-1077-25 TorrentWe keep a close watch at the change of the popular trend among the industry and the latest social views so as to keep pace with the times and provide the clients with the newest study materials resources. Our service philosophy and tenet is that clients are our gods and the clients satisfaction with our 1z0-1077-25 Study Materials is the biggest resource of our happiness. So why you still hesitated? Go and buy our 1z0-1077-25 study materials now.
Oracle Order Management Cloud Order to Cash 2025Implementation Professional Sample Questions (Q81-Q86):NEW QUESTION # 81
What will happen in the Configurator runtime UI when the LX-Luxury Package option is selected that has the following constraint rules?
. 'LX-Luxury Package' IMPLIES '8-way Power Driver Seat'
. 'LX-Luxury Package' IMPLIES '8-way Power Passenger Seat'
. 'LX-Luxury Package' IMPLIES 'Cloth'
  • A. All the options after the IMPLIES keyword will be selected.
  • B. '8-way Power Driver Seat' and 'Cloth' will be selected but '8-way Power Passenger Seat' will be excluded.
  • C. All the options after the IMPLIES keyword will be excluded.
  • D. 8-way Power Driver Seat' will be selected but '8-way Power Passenger Seat' and 'Cloth' will be excluded.
  • E. '8-way Power Driver Seat' and '8-way Power Passenger Seat' will be selected but 'Cloth' will be excluded.
The IMPLIES keyword is used to create a configurator rule that specifies a logical implication between two expressions. The syntax of the IMPLIES keyword is:
expression1 IMPLIES expression2
This means that if expression1 is true, then expression2 must also be true.However, if expression1 is false, then expression2 can be either true or false1. In the Configurator runtime UI, the IMPLIES keyword can be used to show or hide options based on the selection of features. For example, the following rule:
means that if the LX-Luxury Package feature is selected, then the 8-way Power Driver Seat option must also be selected. However, if the LX-Luxury Package feature is not selected, then the 8-way Power Driver Seat option can be either selected or not selected.
Therefore, when the LX-Luxury Package option is selected, all the options after the IMPLIES keyword will be selected, according to the constraint rules. This means that the 8-way Power Driver Seat, the 8-way Power Passenger Seat, and the Cloth options will be selected.
How to Use the IMPLIES Keyword
NEW QUESTION # 82
Which task requires manual execution of the Process Supply Chain Orchestration Interface process so that a supply order gets created?
  • A. Drop Shipment
  • B. Planned Order Releases
  • C. Min-Max planning replenishing a purchase request
  • D. Back-to-Back Procurement
  • E. Back-to-Back Contract Manufacturing
Min-Max planning replenishing a purchase request is the task that requires manual execution of the Process Supply Chain Orchestration Interface process so that a supply order gets created. Min-Max planning is a method of inventory replenishment that maintains a minimum and maximum quantity of each item in a warehouse or subinventory.When the quantity of an item falls below the minimum level, a purchase request is generated to replenish the item to the maximum level1. The purchase request is then sent to the Supply Chain Orchestration Interface table, where it waits for the Process Supply Chain Orchestration Interface scheduled process to run.This process creates a supply order based on the purchase request and sends it to the supplier2.
You must run this process manually or schedule it to run periodically3.
Min-Max Planning
Orchestrate Supply Requests from Replenishment Planning
NEW QUESTION # 83
Your company is importing orders from an e-commerce system where a sales order is created for a laptop.
The ship-to-site of the customer determines the type of power cord to be shipped along with the laptop.
How will you enrich the sales order during import to append the item number corresponding to the particular model of the power cord?
  • A. Create an External Interface Routing Rule.
  • B. Create a Compensation Pattern Rule.
  • C. Create a Post Transformation Rule.
  • D. Create a Pre Transformation Rule.
  • E. Create a Product Transformation Rule.
Answer: E
NEW QUESTION # 84
How can split fulfillment lines in Order Management be managed independently?
  • A. Split fulfillment lines cannot be managed independently.
  • B. Split fulfillment lines can be managed independently because they are often being shipped from different warehouses.
  • C. Split fulfillment lines can be managed with an orchestration process instance that has been created for them.
  • D. Split fulfillment lines can be managed independently because they have different attributes.
NEW QUESTION # 85
Your company is using Order Management Cloud to capture orders, and has integrated with a legacy inventory application for order fulfillment. A fulfillment request needs to be aggregated and sent to an external inventory application.
What step would you perform to aggregate the request?
  • A. Create a new custom task by using the Fulfillment Task Layer.
  • B. Create a new custom task by using the Supply Task Layer.
  • C. Configure a fulfillment task routing rule with aggregation criteria based on time limit or total number of lines.
  • D. Create a new custom task by using the Shipment Task Layer.
https://docs.oracle.com/cd/E5661 ... F1171442AN11B74.htm
NEW QUESTION # 86
The study material is available in three easy-to-access formats. The first one is PDF format which is printable and portable. You can access it anywhere with your smart devices like smartphones, tablets, and laptops. In addition, you can even print PDF questions in order to study anywhere and pass Oracle Order Management Cloud Order to Cash 2025Implementation Professional (1z0-1077-25) certification exam.
Latest 1z0-1077-25 Study Guide: https://www.testkingpass.com/1z0-1077-25-testking-dumps.html
Our TestkingPass Latest 1z0-1077-25 Study Guide is willing to help those active people like you to achieve their goals, Are you ready to take control of your future and achieve the scores you want to get in the Oracle Order Management Cloud Order to Cash 2025Implementation Professional (1z0-1077-25) certification exam, In fact, a number of qualifying exams and qualifications will improve your confidence and sense of accomplishment to some extent, so our 1z0-1077-25 test practice question can be your new target, In addition, the price of our 1z0-1077-25 examination material is reasonable and affordable for all of you.
Studio MX: Choosing Your Tools, We ve covered the growth of private talent 1z0-1077-25 clouds and it s clear their use is expanding, Our TestkingPass is willing to help those active people like you to achieve their goals.
Free PDF Quiz 2026 1z0-1077-25: Oracle Order Management Cloud Order to Cash 2025Implementation Professional C Efficient Free Learning CramAre you ready to take control of your future and achieve the scores you want to get in the Oracle Order Management Cloud Order to Cash 2025Implementation Professional (1z0-1077-25) certification exam, In fact, a number of qualifying exams and qualifications will improve your confidence and sense of accomplishment to some extent, so our 1z0-1077-25 test practice question can be your new target.
In addition, the price of our 1z0-1077-25 examination material is reasonable and affordable for all of you, If you want to be a leader in some industry, you have to continuously expand your knowledge resource.
BTW, DOWNLOAD part of TestkingPass 1z0-1077-25 dumps from Cloud Storage: https://drive.google.com/open?id=10dMInYFK4M5xKFjpQLE_19COkmIIFCZN
Posted at 1/22/2026 10:47:46        Only Author  2#
What an incredible read, thank you for sharing this wonderful article. I advanced with the Study C-THR88-2505 group, earning a promotion and salary increase. Now, its free for everyone. Best of luck with your own promotions!
