New Topic
Dual Camera RK3568 with linux-5.1 sdk
30
Posted at 11/6/2023 15:50:58      View2913 | Replies11        Print      Only Author   [Copy Link] 1#
I Compiled Linux 5.10 fireware
using rk3568-firefly-roc-pc-cam-2ms2m.dtsi.
(i use CAM-2MS2MF Binocular camera module )
but i can't see camera caputred data,
there are only error debug messages.
please help me.
Posted at 11/8/2023 10:21:42        Only Author  2#
there is no rk3568-firefly-roc-pc-cam-2ms2m.dtsi, please use rk3568-firefly-roc-pc-se-cam-2ms2m.dtsi.
Posted at 11/15/2023 15:27:31        Only Author  3#
Thank you for your help.
using rk3568-firefly-roc-pc-se-cam-2ms2m.dtsi then dual cam working.
and now i want use gc5035 cam
like sensor2->csi_dphy2->mipi_csi2->vicap->isp_vir1
i change i2c4 in dts
        gc5035: gc5035@3f {
                status = "okay";
                compatible = "galaxycore,gc5035";
                reg = <0x3f>;
                clocks = <&pmucru CLK_WIFI>;
                clock-names = "xvclk";
                power-domains = <&power RK3568_PD_VI>;
                pinctrl-names = "default";
                pinctrl-0 = <&refclk_pins>;
                reset-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
                pwdn-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
                firefly,clkout-enabled-index = <1>;
                rockchip,camera-module-index = <1>;
                rockchip,camera-module-facing = "front";
                rockchip,camera-module-name = "DW-RV5035-V1.0";
                rockchip,camera-module-lens-name = "JZ-7070AS-A3";
                port {
                        gc5035_out: endpoint {
                                remote-endpoint = <&mipi_in_gc2053_ir>;
                                data-lanes = <1 2>;
and my board detect camera.
but when running 'camera_rkisp_test.sh'
after
'[  482.694081] rkisp_hw fdff0000.rkisp: set isp clk = 297000000Hz'
nothing captuer.
do you know what is wrong?
Posted at 1/8/2026 20:45:27        Only Author  4#
The points mentioned in the article are very useful and have helped me a lot. MB-280 dumps questions provides great materials, and they're offered at no charge.
Posted at 1/13/2026 06:40:45        Only Author  5#
Thank you for your article, it was incredibly enlightening. Elevate your IT skills and grab free COBIT-2019 reliable test book. Good luck with everything!
Posted at 1/14/2026 09:42:09        Only Author  6#
This article is superb, thank you for sharing such a masterpiece. The New PRINCE2Foundation test pdf test papers are now available for free. Wishing you all the best!
Posted at 1/15/2026 15:56:20        Only Author  7#
I really appreciate your article, it had a profound effect on me. Strengthen your IT skills with free L4M4 reliable test questions pdf. Wishing you the best of luck!
restricted members
Posted at 1/15/2026 21:23:38        Only Author  8#
Die Prfungsunterlagen zur GIAC GCIH Zertifizierungsprfung von ZertPruefung werden von der Praxis berprft. Wir können breite Erforschungen sowie Erfahrungen in der realen Welt bieten. Unser ZertPruefung hat mehr als zehnjährige Erfahrungen ber Ausbildung, und zwar Fragen und Antworten zur GIAC GCIH Zertifizierungsprfung. Die Fragenkataloge zur GCIH Zertifizierungsprfung von ZertPruefung sind die besten Schulungsunterlagen. Wir bieten Ihnen die umfassendesten Zertifizierungsfragen und Antworten und einen einjährigen kostenlosen Update-Service.
Posted at 1/22/2026 21:13:50        Only Author  9#
Cant resist liking this great content. Best of luck! Heres the free Valid 200-201 test dumps sheet material to help you.
Posted at 1/25/2026 03:37:21        Only Author  10#
Sind Sie mit Ihrer Arbeit zufrieden? Sind Sie damit Zufrieden, was Sie jetzt machen? Wollen Sie Ihre Arbeitsfähigkeit erhöhen? Dann mssen Sie zuerst mehr ntzliche Fähigkeiten fr Ihre Arbeit beherrschen. Und das wichtigste ist, dass Arbietsgeber wissen, Sie mehr Arbeitsfähigkeiten beherrschen. Dann legen Sie Amazon SCS-C02 Prfung ab. SCS-C02 Prfung kann Ihren Wunsch erreichen. Und es macht nichts, wenn Sie die Prfungsfragen nicht genug kennen, weil Sie die Hilfe und die Vorbereitungswerkzeuge an PrfungFrage finden können. Die Prfungsfragen und-antworten können Ihnen helfen, Amazon SCS-C02 Zertifikat zu bekommen.
Return to List
12
