Valid Test 1Z0-1042-25 Test | Visual 1Z0-1042-25 Cert Exam
Posted at 1/20/2026 13:13:38
P.S. Free & New 1Z0-1042-25 dumps are available on Google Drive shared by LatestCram: https://drive.google.com/open?id=1fOp_WWor0UElYuSzC4yCHft8Ufi5eLzK
If you choose to buy our 1Z0-1042-25 study pdf torrent, it is no need to purchase anything else or attend extra training. We promise you can pass your 1Z0-1042-25 actual test at first time with our Oracle free download pdf. 1Z0-1042-25 questions and answers are created by our certified senior experts, which can ensure the high quality and high pass rate. In addition, you will have access to the updates of 1Z0-1042-25 Study Material for one year after the purchase date.
As we all know, a good 1Z0-1042-25 Exam Torrent can win the support and fond of the customers, 1Z0-1042-25 exam dumps of are just the product like this. With high pass rate and high quality, we have received good reputation in different countries in the world. We are a professional enterprise in this field, with rich experience and professional spirits, we have help many candidates pass the exam. What’s more, the free update is also provided.
Visual 1Z0-1042-25 Cert Exam - Test 1Z0-1042-25 Questions PdfHowever, preparing for the Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam is not an easy job until they have real Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam questions that are going to help them achieve this target. They have to find a trusted source such as LatestCram to reach their goals. Get Oracle 1Z0-1042-25 Certified, and then apply for jobs or get high-paying job opportunities.
Oracle 1Z0-1042-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
| | Topic 2 | - Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
| | Topic 3 | - Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
| | Topic 4 | - Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OIC’s integration capabilities.
| | Topic 5 | - Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q19-Q24):NEW QUESTION # 19
In an Oracle Integration (OIC) project, you are asked to leverage a custom JavaScript library function to be used within an Application pattern integration flow. Which set of steps should you follow to handle this requirement?
- A. Import the JavaScript library file to the project, then use the JavaScript action within the integration flow to reference the library function.
- B. Import the JavaScript library file into your OIC instance's database schema, then use a Local Invoke action to call the function.
- C. Copy and paste the JavaScript function code into a new JavaScript stage within the integration flow, then map the inbound and outbound data elements in the corresponding Map action.
- D. Use the Function Call action within the integration flow to reference the external URL that is hosting the JavaScript library function.
JS Library:
B:True-import and reference is standard.
NEW QUESTION # 20
Oracle Integration Cloud (OIC) Service is available in two editions, Standard and Enterprise. Which two OIC Enterprise Edition capabilities are ALSO available in OIC Standard Edition?
- A. B2B Trading Partner Agreements
- B. File Server
- C. Enterprise Application adapters (such as EBS, JDE, SAP, and Siebel)
- D. Integration Insight
- E. Visual Builder
Answer: B,E
OIC comes in two editions: Standard and Enterprise, with the latter offering advanced features.However, some capabilities are shared:
File Server (A):Both editions include the embedded SFTP File Server, enabling secure file transfers without an external server.
Visual Builder (B):This low-code tool for creating custom UIs and extensions is available in both editions, enhancing integration workflows.
The other options are exclusive to Enterprise Edition:
Integration Insight (C) rovides real-time analytics and monitoring, unavailable in Standard.
B2B Trading Partner Agreements (D):Supports EDI-based B2B transactions, an Enterprise-only feature.
Enterprise Application adapters (E):Adapters for complex systems like EBS, JDE, SAP, and Siebel are restricted to Enterprise, while Standard supports basic SaaS and REST/SOAP adapters.
This distinction reflects Oracle's tiered licensing model, balancing cost and functionality.
NEW QUESTION # 21
Which Oracle Integration Cloud (OIC) XPath function can be used to retrieve data from an OIC lookup within the Data Mapper tool?
- A. get-content-as-string
- B. lookupValue
- C. getLookup
- D. get-value-from-lookup
In OIC's Data Mapper, XPath functions handle transformations:
Option B:lookupValue is the correct function to retrieve values from a lookup table, taking parameters like lookup name and key.
Option A:Not a valid OIC function.
Option C:get-content-as-string processes content, not lookups.
Option D:getLookup doesn't exist; the function is lookupValue.
B is the standard method for lookup access.
NEW QUESTION # 22
Which are valid considerations when leveraging the Oracle Integration Cloud (OIC) connectivity agent for high availability on-premises environments? Select TWO.
- A. File adapter is not supported in high availability environments. When using file adapter and if some groups have multiple instances, use a dedicated agent group (with one agent only).
- B. You should install the connectivity agents on the same host as the target application, and then specify different agent group identifiers for each agent during its installation.
- C. Each host on which the agent is installed must be configured on separate subnets and assigned to the same OIC agent group.
- D. You need to have the OIC ServiceDeployer role permissions to download and install the OIC on- premises connectivity agent.
- E. You cannot have more than two agent instances per agent group. Attempting to include a third agent instance in the same group during installation results in an error.
Answer: A,E
HA Agent:
C, D:True-limit of two agents and File adapter restriction.
NEW QUESTION # 23
Which JNDI name value must be provided when configuring the properties of a new database adapter outbound connection pool to support dependent SOA composite applications?
- A. The corresponding XA datasource configuration deployed to the same WebLogic cluster.
- B. The corresponding XA enterprise resource adapter application deployed to the same WebLogic cluster.
- C. The defined XA database adapter connection factory configured for this WebLogic domain.
- D. The associated XA database adapter plan deployed with this database adapter outbound connection pool.
The correct JNDI name value for the database adapter outbound connection pool is the JNDI name of the corresponding XA datasource configuration deployed to the WebLogic cluster. This ensures that the SOA composite application can access the required database resources.
NEW QUESTION # 24
Many students did not perform well before they use Oracle Cloud Infrastructure 2025 Application Integration Professional actual test. They did not like to study, and they disliked the feeling of being watched by the teacher. They even felt a headache when they read a book. There are also some students who studied hard, but their performance was always poor. Basically, these students have problems in their learning methods. 1Z0-1042-25 prep torrent provides students with a new set of learning modes which free them from the rigid learning methods. You can be absolutely assured about the high quality of our products, because the content of Oracle Cloud Infrastructure 2025 Application Integration Professional actual test has not only been recognized by hundreds of industry experts, but also provides you with high-quality after-sales service.
Visual 1Z0-1042-25 Cert Exam: https://www.latestcram.com/1Z0-1042-25-exam-cram-questions.html
- Unlimited 1Z0-1042-25 Exam Practice 🔌 Minimum 1Z0-1042-25 Pass Score 🧱 1Z0-1042-25 Passed 📲 Simply search for ➤ 1Z0-1042-25 ⮘ for free download on ➡ [url]www.troytecdumps.com ️⬅️ 🦊Valid 1Z0-1042-25 Exam Papers[/url]
- Valid 1Z0-1042-25 Exam Papers 📙 Valid 1Z0-1042-25 Test Simulator 🧫 Minimum 1Z0-1042-25 Pass Score 🚨 Easily obtain free download of ▷ 1Z0-1042-25 ◁ by searching on ⇛ [url]www.pdfvce.com ⇚ 👊1Z0-1042-25 Latest Examprep[/url]
- Exam 1Z0-1042-25 Material 🏦 Most 1Z0-1042-25 Reliable Questions 🐤 1Z0-1042-25 Exam Test 🦈 Search for 「 1Z0-1042-25 」 and download it for free on ✔ [url]www.examcollectionpass.com ️✔️ website 💦Most 1Z0-1042-25 Reliable Questions[/url]
- Choose The Valid Test 1Z0-1042-25 Test, Pass The Oracle Cloud Infrastructure 2025 Application Integration Professional 🐫 Search for ⏩ 1Z0-1042-25 ⏪ and easily obtain a free download on ☀ [url]www.pdfvce.com ️☀️ 📊Reliable 1Z0-1042-25 Dumps Questions[/url]
- 1Z0-1042-25 Hottest Certification 🏏 1Z0-1042-25 Latest Examprep ➿ 1Z0-1042-25 Valid Test Registration 🔉 Easily obtain free download of ⏩ 1Z0-1042-25 ⏪ by searching on ✔ [url]www.examcollectionpass.com ️✔️ 🐏1Z0-1042-25 Valid Test Registration[/url]
- Exam 1Z0-1042-25 Material 🚕 1Z0-1042-25 Passed 🚡 New 1Z0-1042-25 Exam Pattern 🐼 Search for 【 1Z0-1042-25 】 and easily obtain a free download on 「 [url]www.pdfvce.com 」 🦹Reliable 1Z0-1042-25 Exam Tutorial[/url]
- Quiz 2026 Efficient Oracle Valid Test 1Z0-1042-25 Test 💓 Easily obtain { 1Z0-1042-25 } for free download through ⮆ [url]www.verifieddumps.com ⮄ 🛫1Z0-1042-25 Exam Test[/url]
- Oracle 1Z0-1042-25 PDF Questions - Pass Your Exam With Ease 🤰 Easily obtain free download of ☀ 1Z0-1042-25 ️☀️ by searching on ➠ [url]www.pdfvce.com 🠰 ⚓Valid 1Z0-1042-25 Exam Papers[/url]
- Reliable 1Z0-1042-25 Test Dumps 👮 1Z0-1042-25 Exam Dumps 💔 1Z0-1042-25 Latest Examprep ✍ Search for [ 1Z0-1042-25 ] and easily obtain a free download on ➥ [url]www.troytecdumps.com 🡄 🤮Most 1Z0-1042-25 Reliable Questions[/url]
- Pass Guaranteed 2026 Professional 1Z0-1042-25: Valid Test Oracle Cloud Infrastructure 2025 Application Integration Professional Test 👊 Simply search for ✔ 1Z0-1042-25 ️✔️ for free download on ( [url]www.pdfvce.com ) 🔊Sample 1Z0-1042-25 Questions Pdf[/url]
- Pass Guaranteed 2026 Professional 1Z0-1042-25: Valid Test Oracle Cloud Infrastructure 2025 Application Integration Professional Test 🧯 Copy URL ✔ [url]www.testkingpass.com ️✔️ open and search for ▛ 1Z0-1042-25 ▟ to download for free 🕐Reliable 1Z0-1042-25 Exam Tutorial[/url]
- www.notebook.ai, www.stes.tyc.edu.tw, ycs.instructure.com, bbs.t-firefly.com, kemono.im, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest LatestCram 1Z0-1042-25 PDF Dumps and 1Z0-1042-25 Exam Engine Free Share: https://drive.google.com/open?id=1fOp_WWor0UElYuSzC4yCHft8Ufi5eLzK
