Arch-302 Reliable Test Questions | Real Arch-302 Dumps Free
Posted at 1/20/2026 14:11:12
Our Arch-302 practice questions are carfully compiled by our professional experts to be sold all over the world. So the content should be easy to be understood. The difficult questions of the Arch-302 exam materials will have vivid explanations. So you will have a better understanding after you carefully see the explanations. At the same time, our Arch-302 Real Exam just needs to cost you a few spare time. After about twenty to thirty hours’ practice, you can completely master all knowledge.
If you want to constantly improve yourself and realize your value, if you are not satisfied with your current state of work, if you still spend a lot of time studying and waiting for Arch-302 qualification examination, then you need our Arch-302 material, which can help solve all of the above problems. I can guarantee that our study materials will be your best choice. Our Arch-302 Study Materials have three different versions, including the PDF version, the software version and the online version.
Arch-302 exam dumps, prep4sure Arch-302 real test, Salesforce Arch-302 prepOur Salesforce Arch-302 practice materials compiled by the most professional experts can offer you with high quality and accuracy Salesforce Certified B2C Solution Architect Arch-302 practice materials for your success. Up to now, we have more than tens of thousands of customers around the world supporting our Salesforce exam torrent.
Salesforce Certified B2C Solution Architect Sample Questions (Q62-Q67):NEW QUESTION # 62
A company has been using B2C Commerce for many years and recently decided to implement Service Cloud and Marketing Cloud. Currently, there are many issues with the integration between B2C Commerce and the legacy CRM, which means data is often out of Sav sync. Agencies currently manage the Marketing communication, and B2C Commerce is sending the messages. The main goal is to ensure Catksion that B2C Commerce can trigger multi-channel messaging via Marketing Cloud, leveraging the data the company has on customers to personalize the communication.
Which three considerations should a Solution Architect keep in mind when recommending a migration strategy from the existing setup to the new one?
Choose 3 answers
- A. Customer data can be imported into Service Cloud from B2C Commerce and the legacy CRM without deduplication since Salesforce CDP can automatically merge duplicate records upon insert.
- B. Service Cloud should be implemented before Marketing Cloud to ensure that the Salesforce Contact IDs can be used in Marketing Cloud as unique identifiers. Written
- C. Marketing Cloud Connect should be configured to use an alternate external ID from Salesforce as the Contact Key to avoid duplicate contacts in Marketing Cloud.
- D. Customer data from B2C Commerce and the legacy CRM should be deduplicated before being imported into Service Cloud. Materials
- E. Custom development work is required to connect B2C Commerce to Marketing Cloud and use the Salesforce Contact ID.
Answer: B,D,E
B: Service Cloud should be implemented before Marketing Cloud to ensure that the Salesforce Contact IDs can be used in Marketing Cloud as unique identifiers. This allows for a consistent and unified view of the customer across the Salesforce products and avoids duplicate contacts in Marketing Cloud. C. Customer data from B2C Commerce and the legacy CRM should be deduplicated before being imported into Service Cloud.
This ensures that there are no duplicate contacts in Service Cloud that could cause data quality issues or conflicts when syncing with Marketing Cloud. D. Custom development work is required to connect B2C Commerce to Marketing Cloud and use the Salesforce Contact ID. This involves creating a service definition in B2C Commerce that points to Marketing Cloud's REST API and passing the Salesforce Contact ID as the contact key when triggering journeys or updating contact data. References: https://help.salesforce.com/s/ar ... tion.htm&type=5 https://developer.salesforce.com ... g-cloud-integration
NEW QUESTION # 63
A company, currently using B2C Commerce and Service Cloud, has recently purchased and integrated Salesforce Order Management into its order flow. One of the first projects the company would like to complete is to allow its customers to purchase online and pick up their order in the store.
What flow should a Solution Architect suggest to facilitate this request'
- A. B2C Commerce exports the order to Salesforce Order Management. Salesforce Order Management passes the order information to Service Cloud. Once the order is picked up by the customer, Service Cloud updates the final status in Salesforce Order Management.
- B. B2C Commerce exports the order to Salesforce Order Management. Salesforce Order Management passes the order information to Service Cloud. Once the order is picked up by the customer, Service Cloud sends the final status to B2C Commerce.
- C. B2C Commerce exports the order to Service Cloud. Service Cloud passes the order information to Salesforce Order Management. Once the order is picked up by the customer, Salesforce Order Management updates the final status in Service Cloud.
- D. B2C Commerce exports the order to Service Cloud and Salesforce Order Management at the same time.Once the order is picked up by the customer, Service Cloud sends the final status to Salesforce Order Management and B2C Commerce.
This flow allows the customer to purchase online and pick up their order in the store using B2C Commerce, Salesforce Order Management, and Service Cloud. B2C Commerce exports the order to Salesforce Order Management, which handles the order orchestration and fulfillment. Salesforce Order Management passes the order information to Service Cloud, which can be used by the store staff to check the order details and availability. Once the order is picked up by the customer, Service Cloud updates the final status in Salesforce Order Management, which can trigger notifications or invoices. References: https://help.salesforce.com/s
/articleView?id=sf.order_mgmt_overview.htm&type=5 https://help.salesforce.com/s/ar ... tion.htm&type=5
NEW QUESTION # 64
An organization is considering using the Lead object in Sales Cloud to track customers who have signed up for their newsletter. The goal is to add these customers to a Marketing Cloud nurture campaign. Once they make a purchase, the suggested design is to convert the Lead to a Contact record and associate the resulting Contact with a Marketing Cloud Subscriber.
What recommendation should a Solution Architect make to avoid implementation challenges?
- A. Ensure that the Marketing Cloud Contact associated with the Lead is updated to reference the Contact after conversion.
- B. Delete the Marketing Cloud Contact associated with the Lead object after conversion.
- C. Avoid using the Lead object by creating Contacts with different Record Types for prospects.
- D. Add prospects who have not created an account or made a purchase to Marketing Cloud directly without creating a Lead.
This option ensures that the Marketing Cloud Contact is linked to the correct Salesforce record after the Lead is converted to a Contact, and that the contact utilization is not affected by duplicate records. The other options can result in data loss, inconsistent reporting, or unnecessary complexity.
NEW QUESTION # 65
Universal Containers (UC) is in the process of implementing a B2C Commerce site for their storefront, and Experience Cloud for their support and help desk. UC wants to ensure that there is a single login and data experience between the two sites while also being relatively seamless.
Given the need for a single login experience, what should the primary system be for all authentication?
- A. B2C Commerce
- B. Experience Cloud
- C. Salesforce Identity
- D. Service Cloud
This answer is correct because it is the primary system that should be used for all authentication between B2C Commerce site and Experience Cloud site. Salesforce Identity can act as an identity provider (IDP) for both B2C Commerce and Experience Cloud, and it can provide a single login and data experience between the two sites. Salesforce Identity can also store customer profile data in a single place and sync it across systems.
NEW QUESTION # 66
Northern Trail Outfitters (NTO) wants to upgrade its customer service by providing the opportunity for customers to engage using social messaging channels such as Facebook, WhatsApp, and SMS to resolve issues and ask questions. They already use Marketing Cloud Mobile Connect and Social Studio. Alongside these, the Solution Architect also recommends implementing Digita I Engagement features in Service Cloud.
Which two reasons should a Solution Architect use to justify those recommendations?
Choose 2 answers
- A. Mobile Connect lacks integration with the service agent console without Digital Engagement
- B. Mobile Connect only supports outbound messaging in selected countries
- C. Social Studio is limited to listening to social channel and not responding
- D. Social Studio does not support 1:1 messaging on the apps listed in the scenario
Digital Engagement is a set of features in Service Cloud that enables agents to communicate with customers using social messaging channels such as Facebook, WhatsApp, and SMS. To justify the recommendation of implementing Digital Engagement, a Solution Architect can use the following reasons:
* Mobile Connect lacks integration with the service agent console without Digital Engagement. Mobile Connect is a feature in Marketing Cloud that allows sending and receiving SMS messages. However, without Digital Engagement, Mobile Connect messages cannot be handled by Service Cloud agents in the service console or omnichannel routing.
* Social Studio does not support 1:1 messaging on the apps listed in the scenario. Social Studio is a feature in Marketing Cloud that allows listening and engaging with customers on social media platforms. However, Social Studio does not support direct messaging on Facebook or WhatsApp, which are popular social messaging channels.
Option B is incorrect because Mobile Connect supports outbound messaging in more than 200 countries.
Option D is incorrect because Social Studio can respond to public posts or comments on social media platforms. References:
* https://help.salesforce.com/s/ar ... view.htm&type=5
* https://help.salesforce.com/s/ar ... nect.htm&type=5
* https://help.salesforce.com/s/ar ... ries.htm&type=5
NEW QUESTION # 67
our advanced operation system on the Arch-302 learning guide will automatically encrypt all of the personal information on our Arch-302 practice dumps of our buyers immediately, and after purchasing, it only takes 5 to 10 minutes before our operation system sending our Arch-302 Study Materials to your email address, there is nothing that you need to worry about, and we will spear no effort to protect your interests from any danger and ensure you the fastest delivery.
Real Arch-302 Dumps Free: https://www.vcetorrent.com/Arch-302-valid-vce-torrent.html
VCETorrent Real Arch-302 Dumps Free provides you with the best preparation material, Salesforce Arch-302 Reliable Test Questions The good news for you is that during the whole year, our operation system will automatically sent the latest version of our study materials to your e-mail which you used for payment, Efforts have been made in our experts to help our candidates successfully pass Arch-302 exam, Multiple Formats for Arch-302 Exam Practice Test - Desktop & Online Versions.
Which command can be used to see the status of an EtherChannel's links, The Arch-302 Valid Test Prep Venture Capitalizaton of Belonging Fast Company's Social clubs died out in America, VCETorrent provides you with the best preparation material.
100% Pass Arch-302 - Professional Salesforce Certified B2C Solution Architect Reliable Test QuestionsThe good news for you is that during the whole year, our operation Arch-302 system will automatically sent the latest version of our study materials to your e-mail which you used for payment.
Forget buying your prep materials separately at three time the price of our unlimited access plan - skip the Arch-302 audio exams and select the one package that gives it all to you at your discretion: Arch-302 Study Materials featuring the exam engine.
- Arch-302 Reliable Test Questions | Valid Real Arch-302 Dumps Free: Salesforce Certified B2C Solution Architect 100% Pass 🧳 Download ☀ Arch-302 ️☀️ for free by simply entering ⇛ [url]www.troytecdumps.com ⇚ website 🦚
ractice Arch-302 Exam Fee[/url] - Tips to Crack Salesforce Arch-302 Exam Easily 🚴 { [url]www.pdfvce.com } is best website to obtain ✔ Arch-302 ️✔️ for free download 🍛Arch-302 Reliable Test Voucher[/url]
- Arch-302 Detailed Study Dumps 🤼 Visual Arch-302 Cert Test ⬜ Valid Arch-302 Exam Test 🌭 Search on 【 [url]www.troytecdumps.com 】 for “ Arch-302 ” to obtain exam materials for free download 🏑Arch-302 Detailed Study Dumps[/url]
- Pass Guaranteed 2026 Salesforce Arch-302 –High Pass-Rate Reliable Test Questions ⏸ Download ( Arch-302 ) for free by simply searching on { [url]www.pdfvce.com } 🏳Free Arch-302 Updates[/url]
- Arch-302 Detailed Study Dumps 🏀 Arch-302 Vce Files 🤘 Visual Arch-302 Cert Test 🍢 Search for ⏩ Arch-302 ⏪ and download it for free immediately on “ [url]www.testkingpass.com ” 🏘Arch-302 Latest Study Guide[/url]
- Reliable Arch-302 Test Materials 🐢 Arch-302 Detailed Study Dumps 😞 Arch-302 Exam Questions Vce 📆 The page for free download of ☀ Arch-302 ️☀️ on ✔ [url]www.pdfvce.com ️✔️ will open immediately 😸Arch-302 Reliable Test Vce[/url]
- Pass Guaranteed 2026 Salesforce Arch-302 –High Pass-Rate Reliable Test Questions 🤱 Go to website ➠ [url]www.prep4sures.top 🠰 open and search for 【 Arch-302 】 to download for free 🎉Arch-302 Exam Vce Format[/url]
- Arch-302 Reliable Test Vce 🐳 Visual Arch-302 Cert Test 🏭 Free Arch-302 Updates 👺 The page for free download of ⇛ Arch-302 ⇚ on 《 [url]www.pdfvce.com 》 will open immediately 🕙Reliable Arch-302 Test Price[/url]
- Tips to Crack Salesforce Arch-302 Exam Easily 🍂 Open website ➠ [url]www.exam4labs.com 🠰 and search for 「 Arch-302 」 for free download 🐳Certified Arch-302 Questions[/url]
- Most Recent Salesforce Arch-302 Exam Questions – Verified By Salesforce Experts 🍗 Search for ⏩ Arch-302 ⏪ and download it for free immediately on ✔ [url]www.pdfvce.com ️✔️ 🤧Valuable Arch-302 Feedback[/url]
- Reliable Arch-302 Braindumps Files 🦊 Arch-302 Exam Vce Format 🦨 Reliable Arch-302 Test Materials 🧹 Enter ➽ [url]www.examcollectionpass.com 🢪 and search for ⏩ Arch-302 ⏪ to download for free 🕊
ractice Arch-302 Exam Fee[/url] - www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
