[General] ARA-C01 Reliable Test Topics | ARA-C01 Valid Exam Fee
94
General ARA-C01 Reliable Test Topics | ARA-C01 Valid Exam Fee
Posted at 1/20/2026 14:18:46      View183 | Replies2        Print      Only Author   [Copy Link] 1#
What's more, part of that DumpsTests ARA-C01 dumps now are free: https://drive.google.com/open?id=1ZgA9WOmG-Ja_lm40z4zNdW2H1G1ABiwd
First and foremost, our company has prepared ARA-C01 free demo in this website for our customers. Second, it is convenient for you to read and make notes with our PDF version. Last but not least, we will provide considerate on line after sale service for you in twenty four hours a day, seven days a week. So let our ARA-C01 practice materials to be your learning partner in the course of preparing for the exam, especially the PDF version is really a wise choice for you.
Snowflake ARA-C01 (SnowPro Advanced Architect Certification) Certification Exam is a highly sought-after certification for professionals who work with the Snowflake cloud data platform. It is designed to test the expertise of architects who design and build complex data solutions on the Snowflake platform. SnowPro Advanced Architect Certification certification is an advanced level certification exam and requires a solid understanding of Snowflake's architecture, data modeling, and programming concepts.
ARA-C01 Valid Exam Fee & ARA-C01 Practice Test FeeWe provide the update freely of ARA-C01 exam questions within one year and 50% discount benefits if buyers want to extend service warranty after one year. The old client enjoys some certain discount when buying other exam materials. We update the ARA-C01 guide torrent frequently and provide you the latest study materials which reflect the latest trend in the theory and the practice. So you can master the SnowPro Advanced Architect Certification test guide well and pass the exam successfully. While you enjoy the benefits we bring you can pass the exam. Dont be hesitated and buy our ARA-C01 Guide Torrent immediately!
Snowflake SnowPro Advanced Architect Certification Sample Questions (Q162-Q167):NEW QUESTION # 162
When using the copy into <table> command with the CSV file format, how does the match_by_column_name parameter behave?
  • A. It expects a header to be present in the CSV file, which is matched to a case-sensitive table column name.
  • B. The parameter will be ignored.
  • C. The command will return a warning stating that the file has unmatched columns.
  • D. The command will return an error.
Option B is the best design to meet the requirements because it uses Snowpipe to ingest the data continuously and efficiently as new records arrive in the object storage, leveraging event notifications. Snowpipe is a service that automates the loading of data from external sources into Snowflake tables1. It also uses streams and tasks to orchestrate transformations on the ingested data. Streams are objects that store the change history of a table, and tasks are objects that execute SQL statements on a schedule or when triggered by another task2.
Option B also uses an external function to do model inference with Amazon Comprehend and write the final records to a Snowflake table. An external function is a user-defined function that calls an external API, such as Amazon Comprehend, to perform computations that are not natively supported by Snowflake3. Finally, option B uses the Snowflake Marketplace to make the de-identified final data set available publicly for advertising companies who use different cloud providers in different regions. The Snowflake Marketplace is a platform that enables data providers to list and share their data sets with data consumers, regardless of the cloud platform or region they use4.
Option A is not the best design because it uses copy into to ingest the data, which is not as efficient and continuous as Snowpipe. Copy into is a SQL command that loads data from files into a table in a single transaction. It also exports the data into Amazon S3 to do model inference with Amazon Comprehend, which adds an extra step and increases the operational complexity and maintenance of the infrastructure.
Option C is not the best design because it uses Amazon EMR and PySpark to ingest and transform the data, which also increases the operational complexity and maintenance of the infrastructure. Amazon EMR is a cloud service that provides a managed Hadoop framework to process and analyze large-scale data sets.
PySpark is a Python API for Spark, a distributed computing framework that can run on Hadoop. Option C also develops a python program to do model inference by leveraging the Amazon Comprehend text analysis API, which increases the development effort.
Option D is not the best design because it is identical to option A, except for the ingestion method. It still exports the data into Amazon S3 to do model inference with Amazon Comprehend, which adds an extra step and increases the operational complexity and maintenance of the infrastructure.
References: 1: Snowpipe Overview 2: Using Streams and Tasks to Automate Data Pipelines 3: External Functions Overview 4: Snowflake Data Marketplace Overview : [Loading Data Using COPY INTO] : [What is Amazon EMR?] : [PySpark Overview]
* The copy into <table> command is used to load data from staged files into an existing table in Snowflake. The command supports various file formats, such as CSV, JSON, AVRO, ORC, PARQUET, and XML1.
* The match_by_column_name parameter is a copy option that enables loading semi-structured data into separate columns in the target table that match corresponding columns represented in the source data. The parameter can have one of the following values2:
* CASE_SENSITIVE: The column names in the source data must match the column names in the target table exactly, including the case. This is the default value.
* CASE_INSENSITIVE: The column names in the source data must match the column names in the target table, but the case is ignored.
* NONE: The column names in the source data are ignored, and the data is loaded based on the order of the columns in the target table.
* The match_by_column_name parameter only applies to semi-structured data, such as JSON, AVRO, ORC, PARQUET, and XML. It does not apply to CSV data, which is considered structured data2.
* When using the copy into <table> command with the CSV file format, the match_by_column_name parameter behaves as follows2:
* It expects a header to be present in the CSV file, which is matched to a case-sensitive table column name. This means that the first row of the CSV file must contain the column names, and they must match the column names in the target table exactly, including the case. If the header is missing or does not match, the command will return an error.
* The parameter will not be ignored, even if it is set to NONE. The command will still try to match the column names in the CSV file with the column names in the target table, and will return an error if they do not match.
* The command will not return a warning stating that the file has unmatched columns. It will either load the data successfully if the column names match, or return an error if they do not match.
* 1: COPY INTO <table> | Snowflake Documentation
* 2: MATCH_BY_COLUMN_NAME | Snowflake Documentation
NEW QUESTION # 163
Consider the following scenario where a masking policy is applied on the CREDICARDND column of the CREDITCARDINFO table. The masking policy definition Is as follows:
Sample data for the CREDITCARDINFO table is as follows:
NAME EXPIRYDATE CREDITCARDNO
JOHN DOE 2022-07-23 4321 5678 9012 1234
if the Snowflake system rotes have not been granted any additional roles, what will be the result?
  • A. The owner of the table will see the CREDICARDND column data in clear text.
  • B. Anyone with the Pl_ANALYTICS role will see the last 4 characters of the CREDICARDND column data in dear text.
  • C. The sysadmin can see the CREDICARDND column data in clear text.
  • D. Anyone with the Pl_ANALYTICS role will see the CREDICARDND column as*** 'MASKED* **'.
* The masking policy defined in the image indicates that if a user has the PI_ANALYTICS role, they will be able to see the last 4 characters of the CREDITCARDNO column data in clear text. Otherwise, they will see 'MASKED'. Since Snowflake system roles have not been granted any additional roles, they won't have the PI_ANALYTICS role and therefore cannot view the last 4 characters of credit card numbers.
* To apply a masking policy on a column in Snowflake, you need to use the ALTER TABLE ... ALTER COLUMN command or the ALTER VIEW command and specify the policy name. For example, to apply the creditcardno_mask policy on the CREDITCARDNO column of the CREDITCARDINFO table, you can use the following command:
ALTER TABLE CREDITCARDINFO ALTER COLUMN CREDITCARDNO SET MASKING POLICY creditcardno_mask;
* For more information on how to create and use masking policies in Snowflake, you can refer to the following resources:
CREATE MASKING POLICY: This document explains the syntax and usage of the CREATE MASKING POLICY command, which allows you to create a new masking policy or replace an existing one.
Using Dynamic Data Masking: This guide provides instructions on how to configure and use dynamic data masking in Snowflake, which is a feature that allows you to mask sensitive data based on the execution context of the user.
ALTER MASKING POLICY: This document explains the syntax and usage of the ALTER MASKING POLICY command, which allows you to modify the properties of an existing masking policy.
References: 1: https://docs.snowflake.com/en/sq ... eate-masking-policy 2:
https://docs.snowflake.com/en/user-guide/security-column-ddm-use 3:
https://docs.snowflake.com/en/sq ... lter-masking-policy
NEW QUESTION # 164
How can an Architect enable optimal clustering to enhance performance for different access paths on a given table?
  • A. Create super projections that will automatically create clustering.
  • B. Create a clustering key that contains all columns used in the access paths.
  • C. Create multiple materialized views with different cluster keys.
  • D. Create multiple clustering keys for a table.
According to the SnowPro Advanced: Architect documents and learning resources, the best way to enable optimal clustering to enhance performance for different access paths on a given table is to create multiple materialized views with different cluster keys. A materialized view is a pre-computed result set that is derived from a query on one or more base tables. A materialized view can be clustered by specifying a clustering key, which is a subset of columns or expressions that determines how the data in the materialized view is co-located in micro-partitions. By creating multiple materialized views with different cluster keys, an Architect can optimize the performance of queries that use different access paths on the same base table. For example, if a base table has columns A, B, C, and D, and there are queries that filter on A and B, or on C and D, or on A and C, the Architect can create three materialized views, each with a different cluster key: (A, B), (C, D), and (A, C). This way, each query can leverage the optimal clustering of the corresponding materialized view and achieve faster scan efficiency and better compression.
* Snowflake Documentation: Materialized Views
* Snowflake Learning: Materialized Views
https://www.snowflake.com/blog/u ... rformance-problems/
NEW QUESTION # 165
The diagram shows the process flow for Snowpipe auto-ingest with Amazon Simple Notification Service (SNS) with the following steps:
Step 1: Data files are loaded in a stage.
Step 2: An Amazon S3 event notification, published by SNS, informs Snowpipe - by way of Amazon Simple Queue Service (SQS) - that files are ready to load. Snowpipe copies the files into a queue.
Step 3: A Snowflake-provided virtual warehouse loads data from the queued files into the target table based on parameters defined in the specified pipe.
If an AWS Administrator accidentally deletes the SQS subscription to the SNS topic in Step 2, what will happen to the pipe that references the topic to receive event messages from Amazon S3?
  • A. The pipe will continue to receive the messages as Snowflake will automatically restore the subscription by creating a new SNS topic. Snowflake will then recreate the pipe by specifying the new SNS topic name in the pipe definition.
  • B. The pipe will continue to receive the messages as Snowflake will automatically restore the subscription to the same SNS topic and will recreate the pipe by specifying the same SNS topic name in the pipe definition.
  • C. The pipe will no longer be able to receive the messages. To restore the system immediately, the user needs to manually create a new SNS topic with a different name and then recreate the pipe by specifying the new SNS topic name in the pipe definition.
  • D. The pipe will no longer be able to receive the messages and the user must wait for 24 hours from the time when the SNS topic subscription was deleted. Pipe recreation is not required as the pipe will reuse the same subscription to the existing SNS topic after 24 hours.
If an AWS Administrator accidentally deletes the SQS subscription to the SNS topic in Step 2, the pipe that references the topic to receive event messages from Amazon S3 will no longer be able to receive the messages.
This is because the SQS subscription is the link between the SNS topic and the Snowpipe notification channel.
Without the subscription, the SNS topic will not be able to send notifications to the Snowpipe queue, and the pipe will not be triggered to load the new files. To restore the system immediately, the user needs to manually create a new SNS topic with a different name and then recreate the pipe by specifying the new SNS topic name in the pipe definition. This will create a new notification channel and a new SQS subscription for the pipe. Alternatively, the user can also recreate the SQS subscription to the existing SNS topic and then alter the pipe to use the same SNS topic name in the pipe definition. This will also restore the notification channel and the pipe functionality. References:
* Automating Snowpipe for Amazon S3
* Enabling Snowpipe Error Notifications for Amazon SNS
* HowTo: Configuration steps for Snowpipe Auto-Ingest with AWS S3 Stages
NEW QUESTION # 166
When activating Tri-Secret Secure in a hierarchical encryption model in a Snowflake account, at what level is the customer-managed key used?
  • A. At the micro-partition level
  • B. At the account level (AMK)
  • C. At the table level (TMK)
  • D. At the root level (HSM)
Tri-Secret Secure is a feature that allows customers to use their own key, called the customer-managed key (CMK), in addition to the Snowflake-managed key, to create a composite master key that encrypts the data in Snowflake. The composite master key is also known as the account master key (AMK), as it is unique for each account and encrypts the table master keys (TMKs) that encrypt the file keys that encrypt the data files.
The customer-managed key is used at the account level, not at the root level, the table level, or the micro- partition level. The root level is protected by a hardware security module (HSM), the table level is protected by the TMKs, and the micro-partition level is protected by the file keys12. References:
* Understanding Encryption Key Management in Snowflake
* Tri-Secret Secure FAQ for Snowflake on AWS
NEW QUESTION # 167
Different from other similar education platforms, the ARA-C01 study materials will allocate materials for multi-plate distribution, rather than random accumulation without classification. How users improve their learning efficiency is greatly influenced by the scientific and rational design and layout of the learning platform. The ARA-C01 study materials are absorbed in the advantages of the traditional learning platform and realize their shortcomings, so as to develop the ARA-C01 Study Materials more suitable for users of various cultural levels. If just only one or two plates, the user will inevitably be tired in the process of learning on the memory and visual fatigue, and the ARA-C01 study materials provided many study parts of the plates is good enough to arouse the enthusiasm of the user, allow the user to keep attention of highly concentrated.
ARA-C01 Valid Exam Fee: https://www.dumpstests.com/ARA-C01-latest-test-dumps.html
P.S. Free & New ARA-C01 dumps are available on Google Drive shared by DumpsTests: https://drive.google.com/open?id=1ZgA9WOmG-Ja_lm40z4zNdW2H1G1ABiwd
Posted at 2/17/2026 13:18:01        Only Author  2#
Your article was a pleasant surprise, thank you for sharing it. Free Reliable test 300-835 registration resourcesunlock promotions and salary increases today!
Posted at 3/7/2026 15:48:01        Only Author  3#
θǤϡPassTestϤYδu򲩤ΤҡϤĤYԇYեȤ_k뤫ǤСҡΤ褯kӤƤSAPC_S4CPR_2508ԇYեȤϴԇY}ؤоˤä뤳ȤǤԇYʧȫ~Ƿ𤹤ȤZȤԤƷäۤȤɤYԇY˺ϸ񤷤ޤ
