Exam Salesforce Advanced-Administrator Pass Guide, Advanced-Administrator Actual
Posted at 1/20/2026 14:59:02
BTW, DOWNLOAD part of Pass4cram Advanced-Administrator dumps from Cloud Storage: https://drive.google.com/open?id=1qCSuSVldq51pVTYCHbGfXzwBizORPI2X
Advanced-Administrator practice exam will provide you with wholehearted service throughout your entire learning process. This means that unlike other products, the end of your payment means the end of the entire transaction our Advanced-Administrator learning materials will provide you with perfect services until you have successfully passed the Advanced-Administrator Exam. And if you have any questions, just feel free to us and we will give you advice on Advanced-Administrator study guide as soon as possible.
To become a Salesforce Certified Advanced Administrator, candidates must have already obtained the Salesforce Administrator Certification and have at least two years of experience working with the Salesforce platform. Advanced-Administrator exam consists of 60 multiple-choice questions and must be completed within 105 minutes. Advanced-Administrator exam covers a wide range of advanced topics, including managing data and records, automating complex business processes, configuring advanced security settings, and creating custom reports and dashboards. Passing the exam requires a score of at least 65%, and successful candidates will receive a certificate that is recognized by employers and clients as an indication of their advanced skills and knowledge of the Salesforce platform.
To be eligible to take the Salesforce Advanced-Administrator Certification Exam, candidates must have a minimum of two years of experience as a Salesforce Administrator. They should also have a deep understanding of Salesforce configuration and customization, security and access, data management, and analytics. Additionally, candidates should have strong problem-solving skills and be able to apply Salesforce best practices to real-world scenarios.
Advanced-Administrator Actual Dumps, Download Advanced-Administrator FeeIf you are finding a study material to prepare your exam, our material will end your search. Our Advanced-Administrator exam torrent has a high quality that you can't expect. I think our Salesforce Certified Advanced Administrator prep torrent will help you save much time, and you will have more free time to do what you like to do. I can guarantee that you will have no regrets about using our Advanced-Administrator Test Braindumps When the time for action arrives, stop thinking and go in, try our Advanced-Administrator exam torrent, you will find our products will be a very good choice for you to pass your exam and get you certificate in a short time.
Salesforce Certified Advanced Administrator Sample Questions (Q98-Q103):NEW QUESTION # 98
A manager wants a report that shows the following:
1. All Accounts with Opportunities having a Closed-Won status.
2. All Accounts having Closed Cases status.
What can you do as a system administrator to meet this requirement? * (1 Point)
- A. Create a custom report type
- B. Create a Standard report type with crossfilter
- C. Analytic Snapshots
- D. Create a joined report
NEW QUESTION # 99
AW Computing uses a custom Invoice object to track invoices related to accounts. The administrator wants to use roll-up summary fields to view high-level information at a glance on the account record.
Which two considerations should an administrator remember about roll-up summary fields?
Choose 2 answers
- A. Roll-up summary fields are created on the master side of a master-detail relationship.
- B. Roll-up summary fields prevent the conversion of a master-detail relationship to a lookup.
- C. Rollup fields are calculated prior to save.
- D. Roll-up types include COUNT, SUM, and AVG.
Two considerations that the administrator should remember about roll-up summary fields are:
* Roll-up types include COUNT, SUM, and AVG. A roll-up type is a function that determines how the data from the child records is aggregated and displayed on the parent record. The available roll-up types are COUNT, which counts the number of child records; SUM, which adds up the values of a numeric field on the child records; AVG, which calculates the average value of a numeric field on the child records; MIN, which displays the lowest value of a field on the child records; and MAX, which displays the highest value of a field on the child records.
* Roll-up summary fields are created on the master side of a master-detail relationship. A master-detail relationship is a type of relationship that links two objects together such that the master object controls certain behaviors of the detail object, such as security and deletion. A roll-up summary field is a type of field that displays a value that is calculated from child records related to a parent record. Roll-up summary fields can only be created on the master object of a master-detail relationship or on a lookup relationship if it is set as required.
The other two options are incorrect because:
* Roll-up summary fields do not prevent the conversion of a master-detail relationship to a lookup. They only prevent it if they reference a formula field that includes another relationship.
* Rollup fields are not calculated prior to save. They are calculated after save and may take some time to update.
References: https://help.salesforce.com/s/ar ... elds.htm&type=5
https://help.salesforce.com/s/ar ... ions.htm&type=5
NEW QUESTION # 100
AW Computing has a 4-hour SLA in its support guarantee. The company recently received feed that customers art reporting long wait times before an agent responds to a new case after it has been submitted.
How should an administrator ensure cases are properly prioritized?
- A. Auto-Response Rules
- B. Escalation Rules
- C. Assignment Rules
- D. Workflow Rules
Escalation rules are rules that automatically escalate cases if they have not been resolved within a certain time frame or meet certain criteria such as priority or status. Escalation rules can perform actions such as changing ownership of cases, sending email notifications, or creating tasks for users or queues. By using escalation rules, AW Computing can ensure that cases are properly prioritized and handled within their SLA time limit.
References: https://help.salesforce.com/s/ar ... view.htm&type=5
NEW QUESTION # 101
Universal Containers has a requirement to report on opportunities where the probability has dropped beneath 50%. The administrator has created a custom checkbox as a way to identify these records. What else should the administrator do to meet this requirement?
- A. Create an approval process that submits the opportunity for approval when the custom checkbox is true.
- B. Create a workflow rule that updates the field when the probability drops below 50%
- C. Build a validation rule that displays an error when the user enters the probability to less than 50%
- D. Enable field history tracking on the field and include the history in the report filter
NEW QUESTION # 102
DreamHouse Realty has a rental team and a real estate team. The two teams have different safes processes and capture different client information on their opportunities.
How should an administrator extend the Opportunity object to meet the teams' different needs?
- A. Leverage Opportunities for the Real Estate Team and create a new custom object for the Rental Team Opportunities.
- B. Use separate record types, page layouts, and sales processes for the Rental and Real Estate Teams.
- C. Add a section for Rental and a section for Real Estate on the Opportunity Master Record Type to keep the information separate.
- D. Create Opportunity Teams for the Rental and Real Estate Teams and make appropriate fields visible to only the necessary team.
Use separate record types, page layouts, and sales processes for the Rental and Real Estate Teams is how the administrator should extend the Opportunity object to meet the teams' different needs. Record types are a way to offer different business processes, picklist values, and page layouts to different users based on their profiles or permission sets. Page layouts are a way to control the layout and organization of fields, buttons, related lists, and other components on a record page. Sales processes are a way to define the stages that an opportunity goes through from creation to close. By using separate record types, page layouts, and sales processes for each team, the administrator can customize the opportunity object according to their different requirements and preferences.
NEW QUESTION # 103
Have you been many years at your position but haven't got a promotion? Or are you a new comer in your company and eager to make yourself outstanding? Our Advanced-Administrator exam materials can help you. With our Advanced-Administrator exam questions, you can study the most latest and specialized knowledge to deal with the problems in you daily job as well as get the desired Advanced-Administrator Certification. You can lead a totally different and more successfully life latter on.
Advanced-Administrator Actual Dumps: https://www.pass4cram.com/Advanced-Administrator_free-download.html
- Valid Advanced-Administrator Test Guide 🗨 New Advanced-Administrator Test Practice 🏙 Advanced-Administrator Valid Exam Pass4sure 🏁 Search for ➤ Advanced-Administrator ⮘ and obtain a free download on ➠ [url]www.examdiscuss.com 🠰 📲Reliable Advanced-Administrator Test Camp[/url]
- Authentic Advanced-Administrator Exam Braindumps present you first-grade Learning Guide - Pdfvce Ⓜ Enter { [url]www.pdfvce.com } and search for { Advanced-Administrator } to download for free 🅰Advanced-Administrator Test Objectives Pdf[/url]
- Exam Advanced-Administrator Pass Guide - How to Download for Salesforce Advanced-Administrator Actual Dumps 🌽 Search for ▛ Advanced-Administrator ▟ on ⇛ [url]www.prepawayexam.com ⇚ immediately to obtain a free download 🧍New Advanced-Administrator Test Practice[/url]
- How Can You Pass The Salesforce Advanced-Administrator Exam? 🤏 Open ☀ [url]www.pdfvce.com ️☀️ enter ( Advanced-Administrator ) and obtain a free download 🏣Advanced-Administrator Exam Dump[/url]
- Fantastic Exam Advanced-Administrator Pass Guide | Easy To Study and Pass Exam at first attempt - The Best Salesforce Salesforce Certified Advanced Administrator 🤪 Go to website ▶ [url]www.pdfdumps.com ◀ open and search for ⮆ Advanced-Administrator ⮄ to download for free 👼Advanced-Administrator Valid Test Cost[/url]
- Avail Useful Exam Advanced-Administrator Pass Guide to Pass Advanced-Administrator on the First Attempt 🐈 Easily obtain ➥ Advanced-Administrator 🡄 for free download through ⮆ [url]www.pdfvce.com ⮄ 🚟Advanced-Administrator Reliable Exam Cram[/url]
- Authentic Advanced-Administrator Exam Braindumps present you first-grade Learning Guide - [url]www.prepawayete.com 😸 Easily obtain free download of ➠ Advanced-Administrator 🠰 by searching on 「 www.prepawayete.com 」 🚓Valid Dumps Advanced-Administrator Questions[/url]
- Authentic Advanced-Administrator Exam Braindumps present you first-grade Learning Guide - Pdfvce 🐧 Open 「 [url]www.pdfvce.com 」 enter 【 Advanced-Administrator 】 and obtain a free download 🧵New Advanced-Administrator Test Practice[/url]
- New Advanced-Administrator Test Labs 🤕 New Advanced-Administrator Test Labs 🐓 Advanced-Administrator Valid Test Cost 🦄 Simply search for ➡ Advanced-Administrator ️⬅️ for free download on ( [url]www.validtorrent.com ) ❣Advanced-Administrator Valid Exam Pass4sure[/url]
- Quiz Salesforce - Advanced-Administrator - Salesforce Certified Advanced Administrator –The Best Exam Pass Guide 🐋 Easily obtain ➤ Advanced-Administrator ⮘ for free download through ▷ [url]www.pdfvce.com ◁ 🌴Advanced-Administrator Book Pdf[/url]
- Exam Advanced-Administrator Pass Guide - How to Download for Salesforce Advanced-Administrator Actual Dumps 🕜 Search for [ Advanced-Administrator ] and download it for free immediately on ➡ [url]www.troytecdumps.com ️⬅️ 🚆Valid Dumps Advanced-Administrator Questions[/url]
DOWNLOAD the newest Pass4cram Advanced-Administrator PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1qCSuSVldq51pVTYCHbGfXzwBizORPI2X
