1z0-1093-25證照指南 & 1z0-1093-25下載
Posted at 1/20/2026 15:09:12
P.S. KaoGuTi在Google Drive上分享了免費的、最新的1z0-1093-25考試題庫:https://drive.google.com/open?id=1gcsPkhw6gneC-fk3cEPm_0TJJyt2MpnU
KaoGuTi是個能夠加速你通過Oracle 1z0-1093-25認證考試的網站。我們的Oracle 1z0-1093-25 認證考試的考古題是KaoGuTi的專家不斷研究出來的。當你還在為通過Oracle 1z0-1093-25 認證考試而奮鬥時,選擇KaoGuTi的Oracle 1z0-1093-25 認證考試的最新考古題將給你的復習備考帶來很大的幫助。
Oracle 1z0-1093-25 考試大綱:| 主題 | 簡介 | | 主題 1 | - Exadata Database Service (ExaDB): This section of the exam measures the skills of a Database Infrastructure Engineer and focuses on the advanced Exadata Database Service. It includes the provisioning of Exadata systems, management of Exadata Cloud Infrastructure, and VM Cluster administration. It also evaluates knowledge of lifecycle management tasks and how to interact with various Exadata management utilities and interfaces.
| | 主題 2 | - Base Database Service - VM (BaseDB): This section of the exam measures the skills of a Cloud Database Administrator and covers the foundational elements of Oracle’s Base Database Service. It includes understanding what the BaseDB service is, how to provision and manage it, and lifecycle operations such as backups, recovery, patching, and upgrades. It also tests familiarity with monitoring and management interfaces used to control and observe the BaseDB environment.
| | 主題 3 | - NoSQL Database Service Technical Overview: This section of the exam measures the skills of a NoSQL Developer and explores Oracle’s NoSQL Database Service. It includes understanding the basics of NoSQL architecture, handling table-level security, rate limiting, and data modeling. It also covers concepts like provisioned throughput and the usage of language SDKs for interacting with NoSQL services on Oracle Cloud.
| | 主題 4 | - Oracle Cloud Infrastructure Database Management Service: This section of the exam measures the skills of a Cloud Operations Analyst and provides insight into Oracle’s Database Management Service on OCI. It focuses on enabling the service for databases, monitoring their performance, and performing diagnostic and tuning activities. It also covers tasks related to the administration of databases running on Oracle Cloud Infrastructure.
| | 主題 5 | - MySQL HeatWave Technical Overview: This section of the exam measures the skills of a MySQL Cloud Specialist and introduces MySQL HeatWave, Oracle’s high-performance analytics engine for MySQL. It includes provisioning, migrating existing MySQL databases to HeatWave, and working with its analytical and machine-learning capabilities. It also covers day-to-day operational activities within the MySQL HeatWave environment.
最實用的1z0-1093-25認證考試的實用考古題匯總Oracle的1z0-1093-25考試認證一直都是IT人士從不缺席的認證,因為它可以關係著他們以後的命運將如何。Oracle的1z0-1093-25考試培訓資料是每個考生必備的考前學習資料,有了這份資料,考生們就可以義無反顧的去考試,這樣考試的壓力也就不用那麼大,而KaoGuTi這個網站裏的培訓資料是考生們最想要的獨一無二的培訓資料,有了KaoGuTi Oracle的1z0-1093-25考試培訓資料,還有什麼過不了。
最新的 Oracle Cloud 1z0-1093-25 免費考試真題 (Q77-Q82):問題 #77
Which two requirements must be met first to create an Exadata Database Service Instance?
- A. You need to define the VCN, Private Client subnet, and Private Backup subnet.
- B. You only need a VCN and Universal Cloud Credits.
- C. You need to define the VCN, Private Client subnet, and Service Backup subnet.
- D. You need to create an Exadata Infrastructure and VM Cluster resource.
- E. There are no prerequisites for creating an Exadata Database Service instance.
答案:A,D
解題說明:
C: Define VCN, Private Client subnet, and Private Backup subnet:
* These network components are necessary to ensure secure connectivity and backup configurations.
* TheVCN (Virtual Cloud Network)provides network isolation.
* ThePrivate Client subnetenables secure client connections.
* ThePrivate Backup subnetis required for secure access toOCI Object Storagefor backups.
E: Create Exadata Infrastructure and VM Cluster resource:
* Exadata Infrastructure represents the physical hardware.
* VM Cluster resource defines compute and storage resources for the databases.
* Both must be set up before provisioning the actual database instance.
* A. VCN and Universal Cloud Credits:Insufficient; more configuration is needed.
* B. Service Backup subnet:Incorrect, it should be aPrivate Backup subnet.
* D. No prerequisites:Incorrect; prerequisites include both network and infrastructure setup.
問題 #78
Which aspect of NoSQL Database Cloud Service is LEAST impacted by the choice of SDK used in an application?
- A. Syntax for querying data.
- B. Method for authenticating with the service.
- C. Underlying database architecture and scalability characteristics.
- D. Error handling mechanisms.
答案:C
解題說明:
C: Underlying database architecture and scalability characteristics:
* Thearchitecture and scalabilityof Oracle NoSQL Database Cloud Service are inherent to the platform and do not change based on the SDK.
* SDKs are designed to providelanguage-specific interfacesfor data interaction but do not alter the core architecture.
* Whether using Java, Python, or another SDK, the database'ssharding, replication, and consistency characteristics remain constant.
Why the other options are impacted:
* A. Query syntax:SDKs may offer different syntax or query formats.
* B. Authentication method:Varies between SDKs, e.g., API keys vs. IAM tokens.
* D. Error handling:Each SDK may implement error handling differently, influencing how exceptions are processed.
問題 #79
You are tasked with checking the status of the Exadata Database Service (ExaDB) components using the dcli utility. You need to gather information about the health and status of the database servers and storage cells across the ExaDB infrastructure. Which dcli command, combined with appropriate commands run across the nodes, will provide the most comprehensive overview?
- A. dcli -g cell_group "list cell attributes name, status" combined with dcli -g dbnodes "srvctl status database -d dbname"
- B. dcli -g dbnodes "list dbnodes"
- C. dcli -g all "list status"
- D. dcli -g cell_group "list cell attributes name, status, metriccurrent"
答案:A
解題說明:
A: dcli -g cell_group "list cell attributes name, status" combined with dcli -g dbnodes "srvctl status database -d dbname" dcli Utility:
* dcli(Distributed Command Line Interface) allows you to run commands on multiple nodes simultaneously.
* cell_group: A group configuration file listing all storage cells.
* dbnodes: A group configuration file listing all database nodes.
Commands Explanation:
* dcli -g cell_group "list cell attributes name, status":
* Retrieves the name and current status of each storage cell.
* dcli -g dbnodes "srvctl status database -d dbname":
* Checks the status of the database instances on the compute nodes.
* Combining these commands provides a complete picture of both storage and compute components.
* B. Including metriccurrent roduces excessive output, not suitable for a quick health check.
* C. Listing dbnodes only:Insufficient as it lacks storage cell status.
* D. dcli -g all "list status":Invalid syntax and lacks specificity.
問題 #80
When enabling Database Management Service for a cloud database, which of the following is typically NOT a configurable parameter specific to the Database Management Service itself?
- A. The database version.
- B. The frequency at which performance metrics are collected.
- C. The maximum amount of storage space allocated for collected metrics.
- D. The specific metrics that are collected from the database.
答案:A
解題說明:
D: The database version:
* Thedatabase versionis not configurable through the Database Management Service.
* The version is determined during the database instance provisioning and is independent of the management service.
* The management service can monitor and manage databases of various versions, but it does not control or alter the version itself.
Why the other options are configurable:
* A. Frequency of metric collection:Can be adjusted to balance performance and data granularity.
* B. Specific metrics collected:Can be customized based on monitoring requirements.
* C. Storage space for metrics:Some configurations allow defining the retention and storage capacity for collected data.
問題 #81
A critical query running on your HeatWave cluster is experiencing significant performance degradation.
Which tool or service should you use to identify and analyze the specific query causing the bottleneck?
- A. OCI Bastion for secure access to the query execution environment.
- B. MySQL Slow Query Log and OCI Logging Analytics.
- C. OCI Events for tracking query start and end times.
- D. OCI Network Visualizer for analyzing network latency.
- E. OCI Vault for auditing query execution.
答案:B
解題說明:
MySQL Slow Query Log:
TheMySQL Slow Query Logrecords queries that exceed a specified execution time threshold. It is essential for identifyinglong-running queriesthat may be causing performance bottlenecks.
OCI Logging Analytics:
By integrating the slow query log withOCI Logging Analytics, users can visualize query performance patterns, generate alerts, and identify the root cause of slow performance. This combination is powerful for detecting and addressingquery-specific issues.
* A:OCI Vault is used for managing encryption keys, not query performance.
* B:OCI Events track general occurrences, not detailed query performance.
* D:Network latency analysis is useful but not directly related to query analysis.
* E:OCI Bastion provides secure access, not performance analytics.
問題 #82
永遠不要說你已經盡力了。這個對每個人的忠告,就算你認為自己沒有能力通過苛刻的Oracle的1z0-1093-25考試認證。因為就算你沒有通過Oracle的1z0-1093-25考試認證,你可以找一個快捷又方便省時又不費力的培訓工具,來幫助你通過Oracle的1z0-1093-25考試認證,KaoGuTi Oracle的1z0-1093-25考試培訓資料就是個很不錯的黃金培訓資料,它可以幫助你順利通過考試,保證100%通過,而且價格很合理,保證你利用了它會受益匪淺,所以說永遠不要說自己已經盡力了,不放棄下一秒就是希望,趕緊抓住你的希望吧,就在KaoGuTi Oracle的1z0-1093-25考試培訓資料裏。
1z0-1093-25下載: https://www.kaoguti.com/1z0-1093-25_exam-pdf.html
- 1z0-1093-25最新考古題 🛂 1z0-1093-25證照信息 🌺 1z0-1093-25下載 🛷 立即打開✔ tw.fast2test.com ️✔️並搜索▷ 1z0-1093-25 ◁以獲取免費下載1z0-1093-25套裝
- 1z0-1093-25證照信息 🪀 最新1z0-1093-25題庫 🍄 1z0-1093-25最新題庫 🌏 來自網站➠ [url]www.newdumpspdf.com 🠰打開並搜索[ 1z0-1093-25 ]免費下載1z0-1093-25題庫最新資訊[/url]
- 1z0-1093-25證照指南有效通過Oracle Cloud Database Services 2025 Professional考试 🧿 ⮆ [url]www.newdumpspdf.com ⮄是獲取【 1z0-1093-25 】免費下載的最佳網站最新1z0-1093-25題庫[/url]
- 1z0-1093-25證照指南:Oracle Cloud Database Services 2025 Professional壹次通過考試,Oracle 1z0-1093-25 🧲 請在▷ [url]www.newdumpspdf.com ◁網站上免費下載《 1z0-1093-25 》題庫1z0-1093-25通過考試[/url]
- 最好的的1z0-1093-25證照指南,全面覆蓋1z0-1093-25考試知識點 🌱 “ [url]www.vcesoft.com ”最新➠ 1z0-1093-25 🠰問題集合1z0-1093-25試題[/url]
- 最受歡迎的1z0-1093-25證照指南,提前為Oracle Cloud Database Services 2025 Professional 1z0-1093-25考試做好準備 🌙 到⇛ [url]www.newdumpspdf.com ⇚搜索⇛ 1z0-1093-25 ⇚輕鬆取得免費下載1z0-1093-25考試大綱[/url]
- 最好的的1z0-1093-25證照指南,全面覆蓋1z0-1093-25考試知識點 🤒 透過➠ tw.fast2test.com 🠰搜索☀ 1z0-1093-25 ️☀️免費下載考試資料1z0-1093-25認證考試解析
- 1z0-1093-25題庫更新資訊 🕎 1z0-1093-25最新題庫 😒 1z0-1093-25熱門題庫 💃 到「 [url]www.newdumpspdf.com 」搜尋“ 1z0-1093-25 ”以獲取免費下載考試資料1z0-1093-25更新[/url]
- 最好的的1z0-1093-25證照指南,全面覆蓋1z0-1093-25考試知識點 🕸 請在▶ tw.fast2test.com ◀網站上免費下載➥ 1z0-1093-25 🡄題庫1z0-1093-25題庫更新資訊
- 1z0-1093-25更新 🚡 1z0-1093-25熱門題庫 🐰 1z0-1093-25題庫最新資訊 🧒 到☀ [url]www.newdumpspdf.com ️☀️搜索⇛ 1z0-1093-25 ⇚輕鬆取得免費下載1z0-1093-25熱門認證[/url]
- 1z0-1093-25熱門認證 📚 1z0-1093-25題庫更新資訊 🤚 1z0-1093-25更新 🥱 開啟⏩ [url]www.pdfexamdumps.com ⏪輸入{ 1z0-1093-25 }並獲取免費下載1z0-1093-25考試題庫[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, oremasters.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. KaoGuTi在Google Drive上分享了免費的2026 Oracle 1z0-1093-25考試題庫:https://drive.google.com/open?id=1gcsPkhw6gneC-fk3cEPm_0TJJyt2MpnU
