Hot Valid 1z1-076 Guide Files | Latest 1z1-076: Oracle Database 19c: Data Guard
Posted at 1/20/2026 15:15:06
P.S. Free 2026 Oracle 1z1-076 dumps are available on Google Drive shared by DumpsKing: https://drive.google.com/open?id=1vKFcMIZ4vU0vnOrQZqiiguWnfq3pfGjd
Sharp tools make good work. Our 1z1-076 study quiz is the best weapon to help you pass the exam. After a survey of the users as many as 99% of the customers who purchased our 1z1-076 preparation questions have successfully passed the exam. And it is hard to find in the market. The pass rate is the test of a material. Such a high pass rate is sufficient to prove that 1z1-076 Guide materials has a high quality.
Everyone has different learning habits, 1z1-076 exam simulation provide you with different system versions. Based on your specific situation, you can choose the version that is most suitable for you, or use multiple versions at the same time. After all, each version of 1z1-076 Preparation questions have its own advantages. If you are very busy, you can only use some of the very fragmented time to use our 1z1-076 study materials.
1z1-076 Real Exam Answers - Hottest 1z1-076 CertificationWe know that the standard for most workers become higher and higher; so we also set higher goal on our 1z1-076 guide questions. Different from other practice materials in the market our training materials put customers’ interests in front of other points, committing us to the advanced learning materials all along. Until now, we have simplified the most complicated 1z1-076 Guide questions and designed a straightforward operation system, with the natural and seamless user interfaces of 1z1-076 exam question grown to be more fluent, we assure that our practice materials provide you a total ease of use.
Oracle 1z1-076 Exam Syllabus Topics:| Topic | Details | | Topic 2 | - Oracle Data Guard Basics: This topic covers the essential architecture and concepts of Oracle Data Guard. It includes sub-topics such as the physical and logical standby database comparison, benefits of Data Guard, and its integration with multi-tenant databases.
| | Topic 4 | - Managing Physical Standby Files After Structural Changes on the Primary Database: The topic covers managing structural changes in the primary database and their impact on physical standby files.
| | Topic 5 | - Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
| | Topic 6 | - Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
| | Topic 7 | - Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
Oracle Database 19c: Data Guard Administration Sample Questions (Q90-Q95):NEW QUESTION # 90
You have a Data Guard broker configuration consisting of:
A primary database
One local physical standby database
One far sync instance
A remote physical standby database
The broker configuration was created with the DGMGRL utility after creating all the databases and the far sync instance with command-line tools.
What is the correct way to add this configuration to Enterprise Manager Cloud Control assuming all the nodes have been discovered already as Enterprise Manager targets?
- A. Use the DGMGRL utility to register the configuration with the Enterprise Manager Cloud Control agent on the primary database node. This will enable the discovery of all the other databases in the configuration as targets which will be ready to be monitored.
- B. Discover either of the physical standby databases as a target by refreshing the node on which they run, and the other databases and instances in the Data Guard Broker configuration will be discovered as targets automatically and be ready to be monitored.
- C. Discover the primary database as a target in Enterprise Manager Cloud Control. Then discover the existing Data Guard Broker configuration for the primary and all the other databases in the configuration will be discovered as targets and be ready to be monitored.
- D. Discover the primary as a target by refreshing the node on which it runs, and the other databases and instances in the Data Guard broker configuration will be discovered as targets automatically and be ready to be monitored.
- E. Delete the Data Guard Broker configuration using DGMGRL and then re-create it using Enterprise Manager Cloud Control to enable all the databases in the configuration to be discovered as targets and to be ready to be monitored.
NEW QUESTION # 91
Your Data Guard environment contains a primary database and three standby databases with these attributes:
1. prod : Primary database
2. prod_prq : Physical standby database with real-time query enabled used by reporting applications
3. prod_lsby: Logical standby database used by DSS
4. PROD_SSBY: Snapshot standby database used for Real Application Testing Which TWO can be used to prevent clients from connecting to the wrong database instance?
- A. Create role based services with the si vet] utility when using clusterware for Oracle RAC databases or Oracle Restart for single instance Oracle databases.
- B. Create database services for each database and use event triggers to make sure that services are activated only when the database is in the correct role.
- C. Create a static service for each of the databases, register it with the local listener of each database instance, and add connection descriptors on clients to connect to those services.
- D. Create database services on each of the standby databases, start the services, and add connection descriptors on the clients to connect to those services.
- E. Establish Oracle Net connectivity to the primary database instance from all the standby database instances.
Creating dedicated database services for each database instance (Option D) and utilizing event triggers to manage these services based on the role of the database (Option E) ensure that clients connect to the appropriate database instance based on its current role and state. This approach leverages the flexibility and control provided by Oracle Net services and database event management to direct client connections to the suitable primary or standby instance, enhancing the overall robustness and reliability of the Data Guard environment. References: Based on Oracle Database 19c best practices for managing connectivity and services in a Data Guard setup, including the use of role-based services and event-driven service management.
NEW QUESTION # 92
You created the PRODSBY1 physical standby database for the PROD primary database using gql and RMAN.
You are planning to create a Data Guard Broker configuration. You execute the command:
Which three statements are true regarding the execution of the command?
- A. The command will execute successfully only if Oracle Net connectivity to the PROD and PRODSBYl database instances are defined on the primary host.
- B. The PRODSBY1 standby database is automatically added to the configuration if DG_BROKER_START is TRUE for PRODSBYl.
- C. The command will execute successfully only if Oracle Net connectivity to the PROD database instance is defined on the primary host.
- D. The command will execute successfully only if the DG_BROKER_START initialization parameter is set to TRUE for the PROD database instance.
- E. The Data Guard Broker configuration files is automatically created in the destinations specified by the DG_BROKER_CONFIG_FILEn initialization parameters on the primary database.
- F. The PRODSBYI standby database is automatically added to the configuration if Oracle Net connectivity to the PRODSBYl database instance is defined on the primary host.
Answer: C,D,E
The command executed (CREATE CONFIGURATION 'DGConfig' AS PRIMARY DATABASE IS ' PROD' CONNECT IDENTIFIER IS PROD;) is used to create a Data Guard Broker configuration named
'DGConfig'. The successful execution of this command depends on several conditions:
* A: The DG_BROKER_START parameter must be set to TRUE on the primary database to start the Data Guard Broker processes. Without the broker processes running, the configuration cannot be created.
* D: Oracle Net connectivity to the PROD database instance must be established on the primary host. This is because the Data Guard Broker requires network accessibility to communicate with the primary database and manage the configuration.
* E: When the configuration is created, the Data Guard Broker configuration files are indeed automatically created in the locations specified by the DG_BROKER_CONFIG_FILEn parameters on the primary database.
It's important to note that the command will not automatically add the PRODSBY1 standby database to the configuration (thus B and C are not correct), and there is no requirement for the standby database to have Oracle Net connectivity defined on the primary host for the execution of this command (making F incorrect as well).
References: This information can be validated in Oracle's Data Guard Broker documentation, which outlines the requirements for setting up and managing a Data Guard configuration using the Data Guard Broker.
NEW QUESTION # 93
You have a Data Guard Broker configuration called 'Somewhere' as shown:
DGMGRL> SHOW CONFIGURATION;
Configuration - Somewhere
Protection Mode: MaxPerformance
Databases:
Nearby - Primary database
FS - Far Sync
Farout - Physical standby database
Fast-Start Failover: DISABLED
Configuration Status:
SUCCESS
You then run this command:
DGMGRL> SHOW DATABASE 'Nearby' 'InconsistentProperties';
Which two are true about the output of this DGMGRL command?
- A. A far sync instance cannot have inconsistent properties because it has no database.
- B. It shows all properties whose broker configuration values for database Nearby are inconsistent with the values in the corresponding server parameter file or the runtime values for database instance Nearby.
- C. Any inconsistency reported is on an instance-specific basis.
- D. It shows all properties whose broker configuration values for database Nearby are inconsistent with the broker configuration values for database Farout.
NEW QUESTION # 94
Examine the Data Guard configuration: DGMGRL> show configuration;
Configuration - Animals
Databases:
dogs- Primary database
sheep - Physical standby database
cats- Snapshot standby database
Configuration Status: SUCCESS
You receive an error while attempting to raise the protection mode to Maximum Protection:
DGMGRL> edit configuration set protection mode as maxprotection;
Error: ORA-16627: operation disallowed since no standby databases would remain to support protection mode Failed.
What can you conclude based on this error?
- A. The redo transport mode is set to async for the standby database Sheep.
- B. The redo transport mode is set to asyn: for the standby database Cats.
- C. Cats is a snapshot standby database.
- D. The redo transport mode is set to async for both standby databases.
Comprehensive Detailed Explanation:
In an Oracle Data Guard environment, the Maximum Protection mode requires that all redo data be transmitted synchronously to at least one standby database, ensuring no data loss even in the event of a primary database failure. However, a snapshot standby database, by its nature, allows read-write access and is temporarily disconnected from the redo stream, which makes it unable to participate in the synchronous redo transport required by Maximum Protection mode. The presence of a snapshot standby database in the Data Guard configuration thus prevents the activation of Maximum Protection mode, as it cannot guarantee zero data loss without a standby database capable of receiving redo data synchronously.
Oracle Data Guard documentation clearly outlines the requirements and restrictions of different protection modes, including the necessity for standby databases to participate in synchronous redo transport to enable Maximum Protection mode. The inability of snapshot standby databases to fulfill this requirement is a key consideration when planning Data Guard configurations and protection levels.
The error indicates that switching the protection mode to Maximum Protection is not possible due to the presence of a snapshot standby database in the Data Guard configuration, which cannot participate in synchronous redo transport required by the Maximum Protection mode. Therefore, the correct answer is:
NEW QUESTION # 95
Many clients may worry that their privacy information will be disclosed while purchasing our 1z1-076 quiz torrent. We promise to you that our system has set vigorous privacy information protection procedures and measures and we won’t sell your privacy information. Before you buy our product, you can download and try out it freely so you can have a good understanding of our 1z1-076 Quiz prep. Please feel safe to purchase our 1z1-076 exam torrent any time as you like. We provide the best service to the client and hope the client can be satisfied.
1z1-076 Real Exam Answers: https://www.dumpsking.com/1z1-076-testking-dumps.html
- Free PDF Valid 1z1-076 Guide Files – The Best Real Exam Answers for 1z1-076 - Authoritative Hottest 1z1-076 Certification 🕋 Search for ➤ 1z1-076 ⮘ and download it for free immediately on ➽ [url]www.vce4dumps.com 🢪 🌄Valid Braindumps 1z1-076 Book[/url]
- 2026 Oracle 1z1-076: Oracle Database 19c: Data Guard Administration –Valid Valid Guide Files 🙋 Easily obtain ➽ 1z1-076 🢪 for free download through ➥ [url]www.pdfvce.com 🡄 💰Valid Exam 1z1-076 Braindumps[/url]
- www.examcollectionpass.com Oracle 1z1-076 Exam Questions in PDF Format 👹 Immediately open ➤ [url]www.examcollectionpass.com ⮘ and search for ⮆ 1z1-076 ⮄ to obtain a free download 🕺Latest 1z1-076 Test Practice[/url]
- 1z1-076 Sample Questions Pdf 🛑 Online 1z1-076 Training 🪂 1z1-076 Free Exam 🐢 Simply search for ▛ 1z1-076 ▟ for free download on { [url]www.pdfvce.com } 🤢1z1-076 Pass4sure Exam Prep[/url]
- 1z1-076 Learning Question Materials Make You More Prominent Than Others - [url]www.pdfdumps.com 🎃 Open website “ www.pdfdumps.com ” and search for “ 1z1-076 ” for free download 🐆1z1-076 Best Practice[/url]
- 1z1-076 Latest Test Prep 🐽 1z1-076 Exam Format 📲 Exam 1z1-076 Torrent 🎳 Open ▛ [url]www.pdfvce.com ▟ enter ➡ 1z1-076 ️⬅️ and obtain a free download ➡️New 1z1-076 Practice Materials[/url]
- Valid Braindumps 1z1-076 Book 💼 Formal 1z1-076 Test 🆕 1z1-076 Latest Dumps Questions 😉 Easily obtain 《 1z1-076 》 for free download through ▶ [url]www.pass4test.com ◀ 🕤Formal 1z1-076 Test[/url]
- 1z1-076 Actualtest 🧺 1z1-076 Sample Questions Pdf 🐭 Formal 1z1-076 Test 🕑 Download ➡ 1z1-076 ️⬅️ for free by simply searching on { [url]www.pdfvce.com } 👊Latest 1z1-076 Test Practice[/url]
- Valid Exam 1z1-076 Braindumps 😋 Valid Braindumps 1z1-076 Book 🏕 New 1z1-076 Practice Materials 🏮 ▷ [url]www.exam4labs.com ◁ is best website to obtain ➽ 1z1-076 🢪 for free download 😼Formal 1z1-076 Test[/url]
- 1z1-076 Detailed Study Plan 😧 Valid Exam 1z1-076 Braindumps 🤠 Valid Braindumps 1z1-076 Book 👻 Search for ▶ 1z1-076 ◀ and obtain a free download on 「 [url]www.pdfvce.com 」 🔓1z1-076 Latest Dumps Questions[/url]
- 1z1-076 Test Discount 🍊 1z1-076 Detailed Study Plan 🦮 1z1-076 Free Exam 🎩 Search for ☀ 1z1-076 ️☀️ on ➥ [url]www.dumpsquestion.com 🡄 immediately to obtain a free download 😐1z1-076 Exam Format[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, hhi.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest DumpsKing 1z1-076 PDF Dumps and 1z1-076 Exam Engine Free Share: https://drive.google.com/open?id=1vKFcMIZ4vU0vnOrQZqiiguWnfq3pfGjd
