[General] 2026 Juniper Authoritative JN0-105: Junos, Associate (JNCIA-Junos) Exam Sims
135
【General】 2026 Juniper Authoritative JN0-105: Junos, Associate (JNCIA-Junos) Exam Sims
Posted at 1/20/2026 16:36:55      View:132 | Replies:5        Print      Only Author   [Copy Link] 1#
2026 Latest DumpTorrent JN0-105 PDF Dumps and JN0-105 Exam Engine Free Share: https://drive.google.com/open?id=1qP4IQMeaAb50Byzs7Qh1ByM8FQC8hAtZ
Based on a return visit to students who purchased our JN0-105 actual exam, we found that over 99% of the customers who purchased our JN0-105 learning materials successfully passed the exam. Advertisements can be faked, but the scores of the students cannot be falsified. JN0-105 Study Guide’s good results are derived from the intensive research and efforts of our experts. And we have become a popular brand in this field.
To help you prepare for JN0-105 examination certification, we provide you with a sound knowledge and experience. The questions designed by DumpTorrent can help you easily pass the exam. The DumpTorrent Juniper JN0-105 practice including JN0-105 exam questions and answers, JN0-105 test, JN0-105 books, JN0-105 study guide.
Get Fantastic JN0-105 Exam Sims and Pass Exam in First AttemptBy these three versions of JN0-105 practice materials we have many repeat orders in a long run. The PDF version helps you read content easier at your process of studying with clear arrangement, and the PC Test Engine version of JN0-105 practice materials allows you to take stimulation exam to check your process of exam preparing, which support windows system only. Moreover, there is the APP version of JN0-105 practice materials, you can learn anywhere at any time with it at your cellphones without the limits of installation.
Juniper JN0-105 Exam Syllabus Topics:
  • Operational Monitoring and Maintenance: Different methods of monitoring or maintaining Junos devices are identified in this topic. Lastly, it discusses monitoring or maintenance procedures for a Junos device.
  • Junos OS Fundamentals: It covers concepts, benefits, and functionality of the core elements of the Junos OS.
  • User Interfaces: This topic delves into identifying the concepts, operation, or functionality of the Junos user interface.
  • Routing Fundamentals: This topic discusses pointing out basic routing concepts or functionality for Junos devices. Moreover, the topic also describes configuring or monitoring basic routing elements for a Junos device.
Topic 5
  • Configuration Basics: Identification of the main elements for configuring Junos devices is discussed in this topic. Moreover, it describes configuring basic components of a Junos device
Juniper Junos, Associate (JNCIA-Junos) Sample Questions (Q15-Q20):NEW QUESTION # 15
Which statement is correct about the candidate configuration in the Junos OS?
  • A. It contains changes that have not been committed
  • B. It is created when you execute a commit from the CLI
  • C. It is only used to restore the configuration to factory default settings
  • D. It contains the most recent rescue configuration
In Junos OS, there are two main configuration databases:
* Candidate configuration: a working copy of the configuration that holds any uncommitted changes.
All configuration edits are made here.
* Active configuration: the running configuration that the system currently uses.
When you issue a commit command, the candidate configuration is promoted to active, replacing the previous configuration. Until that happens, all changes remain in the candidate configuration and do not affect device operation.
From Junos Fundamentals Guide:
"The candidate configuration is a separate copy of the configuration database. All changes are made to the candidate configuration and do not take effect until they are committed." References:
Juniper TechLibrary - Junos Configuration Fundamentals
JNCIA-Junos Exam Objective: Configuration Basics
NEW QUESTION # 16
What information does the forwarding table require so that the device forwards traffic? (Choose three.)
  • A. OSPF metric value
  • B. outgoing interface name
  • C. BGP local preference value
  • D. next hop IP address
  • E. next hop MAC address
Answer: B,D,E
The forwarding table in a network device requires specific information to efficiently forward traffic toward its destination. This includes the next hop IP address, which indicates the next router or device in the path to the destination. The outgoing interface name identifies the physical or logical interface through which the packet should be sent to reach the next hop. Lastly, the next hop MAC address is crucial for Layer 2 forwarding decisions, allowing the device to encapsulate the IP packet in a frame that can be understood by Ethernet or other Layer 2 protocols. OSPF metric values and BGP local preference values are used in the routing decision process to select the best path and populate the forwarding table but are not directly used by the forwarding table to forward traffic.
NEW QUESTION # 17
You have configured some interfaces on a Junos device; however, you have not yet committed the configuration.
What happens if you issue the rollback 0 command in this scenario?
  • A. The factory default configuration is loaded.
  • B. The interface changes you made are discarded.
  • C. The Junos device is rebooted.
  • D. The messages.log file is deleted.
In Junos OS, issuing therollback 0command reverts the candidate configuration to the last committed configuration. If you have made changes to some interfaces but have not committed those changes, using rollback 0will discard these uncommitted changes, reverting to the state of the configuration at the time of the last commit. This command does not affect system files likemessages.log, reboot the device, or load the factory default configuration; it simply undoes uncommitted changes.
NEW QUESTION # 18
Which two fields are you required to enter when you create a new user account? (Choose two.)
  • A. user ID
  • B. full name
  • C. username
  • D. login class
In Junos OS, when creating a new user account, the minimum required fields are theusernameand thelogin class. The username is the identifier for the account, while the login class specifies the level of access or permissions the user has on the device. Login classes allow for the differentiation between various roles, such as read-only access or full administrative rights. Other information, such as full name or user ID, is optional and not strictly necessary for the creation of a functional user account.
NEW QUESTION # 19
What will the request system configuration rescue save command do?
  • A. It saves the most recently committed configuration as the rescue configuration.
  • B. It saves a configuration version prior to the configuration most recently committed as the rescue configuration.
  • C. It activates the rescue configuration.
  • D. It saves the candidate configuration as the rescue configuration.
The request system configuration rescue save command in Junos OS saves the most recently committed configuration as the rescue configuration. This rescue configuration can be used to recover the device if future configurations cause issues. It ensures there is a stable, known-good configuration to fall back on, which is crucial in network management and troubleshooting.
"rescue : save configurations as the rescue: request system configuration save .................( saves the current configs as a rescue configs )" from Useful Juniper Commands.txt.
Juniper official documentation: Configuring and Activating a Rescue Configuration.
NEW QUESTION # 20
DumpTorrent provides Juniper JN0-105 desktop-based practice software for you to test your knowledge and abilities. The JN0-105 desktop-based practice software has an easy-to-use interface. You will become accustomed to and familiar with the free demo for Juniper JN0-105 Exam Questions. Exam self-evaluation techniques in our JN0-105 desktop-based software include randomized questions and timed tests. These tools assist you in assessing your ability and identifying areas for improvement to pass the Juniper certification exam.
Valid JN0-105 Exam Notes: https://www.dumptorrent.com/JN0-105-braindumps-torrent.html
P.S. Free 2026 Juniper JN0-105 dumps are available on Google Drive shared by DumpTorrent: https://drive.google.com/open?id=1qP4IQMeaAb50Byzs7Qh1ByM8FQC8hAtZ
Posted at 1/22/2026 19:57:38        Only Author  2#
The article was truly stunning; thank you for sharing! Boost your IT knowledge with free FCP_FGT_AD-7.6 reliable exam dumps sheet. Wishing you success in your exams!
Posted at 1/22/2026 23:03:29        Only Author  3#
This article is a real treasure, thank you for sharing it with us. The Trustworthy CHRP-KE exam torrent content is very useful and totally free of charge.
Posted at 1/23/2026 04:34:10        Only Author  4#
Itexamdump의Huawei인증 H11-861_V4.0시험덤프공부가이드 마련은 현명한 선택입니다. Huawei인증 H11-861_V4.0덤프구매로 시험패스가 쉬워지고 자격증 취득율이 제고되어 공을 많이 들이지 않고서도 성공을 달콤한 열매를 맛볼수 있습니다.
Posted at 1/30/2026 10:08:01        Only Author  5#
That article was incredibly rich in knowledge. I owe my promotion and raise to the C-P2WWM-2023 reliable real exam questions and answers questions, and today I’m sharing them for free with all of you!
Posted at 2/22/2026 01:14:50        Only Author  6#
Such an extraordinary article, I deeply appreciate your sharing. Test InsuranceSuite-Developer dates offers amazing content, and it’s available to you without charge.
