"Firefly Zebra Screen effect
66
Posted at 2/4/2024 19:30:03      View3061 | Replies5        Print      Only Author   [Copy Link] 1#
Dear Firefly,
I have a question about the "Firefly Zebra Screen effect on my industrial tablet IPC-M10R800-A3568J. How or where can I deactivate this? The video shows the Firefly Zebra Screen effect on the screen of my industrial tablet. See this you Video on my Youtube channel: https://youtube.com/shorts/JEKNYEERp8g
Best regards
Posted at 2/4/2024 19:36:43        Only Author  2#
Dear Firefly,
I have a question about the Firefly Zebra screen effect on my industrial tablet IPC-M10R800-A3568J. How or where can I deactivate this? The video shows the Firefly Zebra effect on the screen of the industrial tablet. See this image
Firefly Zebra Screen Effekt
Posted at 2/7/2024 15:41:37        Only Author  3#
1 Try using the latest firmware on the official website
https://en.t-firefly.com/doc/download/108.html
2 If the latest firmware still has issues, please provide debugging serial port logs
https://wiki.t-firefly.com/en/Core-3568J/debug.html#senial-debug
Have you ever done any other special operations? A normal board shouldn't be like this? Of course, it cannot be ruled out whether there is any hardware damage
Posted at 2/10/2024 02:41:59        Only Author  4#
Hello,
The attached file is the dmesg boot log and the serial terminal log. I already used the latest FW image from your download page.-> Ubuntu20.04 2021-11-08
serial_terminal.log.tar.gz (28.44 KB, Down times: 0)
dmesg.log.tar.gz (24.06 KB, Down times: 0)
It doesn't matter whether the Android or Linux image is used. The result is the same in both cases. The kernel was compiled from your GitLab repository branch rk356x/firefly. This is currently in the log files. I built the kernel with the configuration from the original FW image and simply removed those stupid overlay FS options. In addition, the rootfs is booted on the built-in SSD. The rootfs also comes from the original FW image. I also fixed the Himax touchscreen driver error in the kernel, which shows up as a keyboard in userspace. This leads to problems with QT 5.15.2 QPA KMS/EVDEV. I saw the report_type property in the rk3568-firefly-aioj-ipc.dts file that supposedly should select the A/B/B_3PA report type, but the driver source does not reflect any changes. So I reworked the entire driver so that the property does what it's intended to do. The Mali Bifrost/Midgard DDK and the libMali libraries are unchanged.
BTW: ROFL -> Ubuntu18.04 2021-12-07
404. Dies ist ein Fehler.
(HTTP Error 404 at Google)
Best Regards
Posted at 1/10/2026 14:32:24        Only Author  5#
Im deeply thankful for your article, it really stood out to me. Get access to the New study guide C-ARSUM-2508 questions exam that helped me achieve a promotion and pay raise, now free for everyone today. Best wishes in your professional development!
Posted at 1/29/2026 00:43:11        Only Author  6#
@JN0-224JCѽɞITT@øùһNxȻS࿼һֱŬLԇsʧˡxʹ҂Juniper JN0-224}aƷ̶ȱCȡóɹJN0-224}㌢õһӵЧ@һᘌԏwV¿죬ČWYϣCһͨ^JN0-224ԇҪ挍ĿԇģMx҂ܛ汾Juniper JN0-224}죬bXMģMײ
