[General] FCP_FMG_AD-7.4ȥ`󥰥ץ & FCP_FMG_AD-7.4ƥȲο
105
General FCP_FMG_AD-7.4ȥ`󥰥ץ & FCP_FMG_AD-7.4ƥȲο
Posted at 1/20/2026 19:08:54      View288 | Replies4        Print      Only Author   [Copy Link] 1#
oϤǥ饦ɥȥ`¤It-Passports FCP_FMG_AD-7.4 PDFפ`ɤ룺https://drive.google.com/open?id=1JnJ0WxAycADZlgV_ld_1c69JuTFCDV_Y
ʤϤ⤦Fortinet FCP_FMG_AD-7.4YJԇYꤷzǤޤޤΤʤɽȤʤFCP_FMG_AD-7.4̲ĤȾ}椷^ʹȸФޤIt-PassportsϽ~ˤʤmǤ륦֥ȤʤΤǡʤΆ}QIt-Passports򤪄ᤤޤĤɤYϤˤޤतrg򤫤ꡢ礯It-PassportsΥ`ӥYƤPʤЄӤޤ礦
यˡϡҰǤ¤Ǥ뤳ȤǤ֪R򤢤bIǤΌgH¤ˏäΤ쾚ܤˤˤʤꤿ˼äƤޤˤˤȤäƤϺgʤȤǤϤʤĿˤ_ɤ뤿˶यŬҪǤƥFCP_FMG_AD-7.4J˺ϸ񤹤ȡˤϤΤ褦ˡˤʤޤʤˤ1ˤǤСFCP_FMG_AD-7.4ѧُ̲뤹뤳Ȥǡ٤ʤǥ`˥ƥȤ˺ϸǤޤ FCP_FMG_AD-7.4ԇY|ρꡢäǤuƷُ뤹ȡߤΥ`ӥṩƜ㤹뤳ȤǤޤ
Fortinet FCP_FMG_AD-7.4ƥȲο & FCP_FMG_AD-7.4һĤˤϡMĤʥڥ`󥷥ƥǤꡢ٤ٶȤ^Ǥ͘΂ϱΥڥ`󥷥ƥˤäԄӵĤ˰ŻޤޤFCP_FMG_AD-7.4ΌgHԇYΥ饤󥢥ץЩ`ʹäȡNӥǥХvȥ`˥YϤ|X˾ǤޤˡFCP_FMG_AD-7.4ԇY}ơ͘κϸʤ98〜100_ޤʤѧѩ`ȥʩ`ˤʤ뤳ȤSߤˤƤޤ
Fortinet FCP - FortiManager 7.4 Administrator J FCP_FMG_AD-7.4 ԇY} (Q27-Q32):| # 27
Given the configuration shown in the exhibit, which two conclusions can you draw from the installation targets in the Install On column? (Choose two.)
  • A. Policy seq.# 2 will not be installed on the Local-FortiGate root VDOM because there is no root VDOM in the Installation Target
  • B. Policy seq.# 1 will be installed on the ISFW device root[NAT] and Student[NAT] VDOMs only.
  • C. Policy seq.# 3 will be skipped because no installation targets are specified.
  • D. Policy seq.S will be installed on all managed devices and VDOMs that are listed under Installation Targets
⣺BD
h
* Option A: Policy seq.S will be installed on all managed devices and VDOMs that are listed under Installation Targets.This is correct. The "Install On" column indicates that the policy is targeted for installation on all listed managed devices and VDOMs under Installation Targets.
* Option D: Policy seq.# 1 will be installed on the ISFW device root[NAT] and Student[NAT] VDOMs only.This is correct. Policy sequence #1 specifies that it will be installed only on the ISFW device and the VDOMs 'root[NAT]' and 'Student[NAT]' as indicated by the "Install On" column.
Explanation of Incorrect Options:
* Option B: Policy seq.# 3 will be skipped because no installation targets are specifiedis incorrect because it is clearly listed under "Installation Targets," which means it will be installed according to the specified configuration.
* Option C: Policy seq.# 2 will not be installed on the Local-FortiGate root VDOM because there is no root VDOM in the Installation Targetis incorrect as the exhibit does not show any specific exclusion for seq.# 2 on the Local-FortiGate root VDOM.
FortiManager References:
* Refer to the FortiManager Administration Guide sections on "Policy Packages" and "Policy Installation Targets" for more details.
| # 28
Exhibit.
An administrator would like to create three ADOMs on FortiManager with different access levels based on departments. What two conclusions can you draw from the design shown in the exhibit? (Choose two.)
  • A. Policies and objects databases can be shared between the Financial and HR ADOMs.
  • B. The FortiManager administrator must set the ADOM device mode to Advanced
  • C. The administrator must configure FortiManager in workspace normal mode.
  • D. An administrator with the super user profile can access all theVDOMs.
⣺BD
| # 29
Exhibit.
What is true about the objects highlighted in the image?
  • A. They are available across all ADOMs by default.
  • B. They cannot be created in the global database ADOM.
  • C. They can be used as variables in scripts.
  • D. They can be set to optional or required.
⣺C
h
The objects highlighted in the image (DMZ_SUBNET, ISP1_SUBNET, LAN_SUBNET) aremetadata variables.
* C.They can be used as variables in scripts.
* These metadata variables are placeholders that can be used in FortiManager scripts to dynamically insert specific values, enabling script flexibility and scalability across multiple devices or ADOMs.
Options A, B, and D are incorrect because:
* Asuggests optional or required settings, which do not apply to metadata variables.
* Bimplies they are available across all ADOMs by default, which is not always the case.
* Dstates they cannot be created in the global database ADOM, but metadata variables are typically managed within ADOMs and can be utilized globally based on specific configurations.
* Refer to FortiManager 7.4 Administrator Guide: Using Metadata Variables and Script Management.
| # 30
Which API method is used to create objects or overwrite existing ones?
  • A. Add
  • B. Update
  • C. Exec
  • D. Set
⣺D
| # 31
An administrator, Trainer, who is assigned the Super_User profile, is trying to approve a workflow session that was submitted by another administrator, Student. However, Trainer is unable to approve the workflow session.
What can prevent an admin account that has Super_User rights over the device from approving a workflow session?
  • A. Trainer must close Student's workflow session before approving the request.
  • B. Trainer must first create their own workflow session to approve student session.
  • C. Trainer does not have full rights over this ADOM.
  • D. Trainer is not a part of workflow approval group.
⣺D
h
An administrator must be part of an approval group, and have rights over the ADOM in which the session was created.
| # 32
FCP_FMG_AD-7.4ѧɤϡǷdz˄ʵĤʥĩ`Ǥ˽֪Ƥ褦ˡ˽άFǤϡl⤬٤ꥹީ`Ȥ¤ФȤƤΤǡbԥϥåŤʤۤ˚ݤ​​Τⲻ˼hǤϤޤ󡣤Τᡢѧĩ`ҪԤJRҪޤ͘ѧʤߤ뤿ˡFCP_FMG_AD-7.4ȥ`˥YϡζयΌTҤˤäOӋޤ FCP_FMG_AD-7.4ѧ̲Ĥϡ٤ƤˡѧʤϤΤ˷dzޤ
FCP_FMG_AD-7.4ƥȲο: https://www.it-passports.com/FCP_FMG_AD-7.4.html
It-PassportsFortinetFCP_FMG_AD-7.4ԇYȥ`˥YϤIt-PassportsITTҤоơg_k줿ΤǤFortinetFCP_FMG_AD-7.4ȥ`˥󥰥֥쥤פϸƷ|ǡϸʤȥҥåʤϤ98򳬤Ƥޤ_Ά}ȽFortinet FCP_FMG_AD-7.4ȥ`󥰥ץ ƣƵǤ뤳Ȥ֤ʤˤΤߤϳɹäޤFCP_FMG_AD-7.4ԇY}ʹäȡFCP_FMG_AD-7.4ԇY˺g˺ϸǤޤ͘Τޤޤʥ˩`ˤꤨ뤿ˡFCP_FMG_AD-7.4ԇYYϤ3ĤΥЩ`ɤޤʤϸ߄ʤΏFortinetFCP_FMG_AD-7.4ԇYγɹUYҪФǤ
ɾФϳȻȤףҤӣͤ󣩤Ƥ롢ʤʼοդϤˎڤäơƣ줿LȥƩ`„Ƥ_ĵؤ褫äIt-PassportsFortinetFCP_FMG_AD-7.4ԇYȥ`˥YϤIt-PassportsITTҤоơg_k줿ΤǤ
mĤFCP_FMG_AD-7.4ȥ`󥰥ץ & ϸ񥹥`FCP_FMG_AD-7.4ƥȲο | FCP_FMG_AD-7.4FortinetFCP_FMG_AD-7.4ȥ`˥󥰥֥쥤פϸƷ|ǡϸʤȥҥåʤϤ98򳬤Ƥޤ_Ά}ȽƣƵǤ뤳Ȥ֤ʤˤΤߤϳɹäޤFCP_FMG_AD-7.4ԇY}ʹäȡFCP_FMG_AD-7.4ԇY˺g˺ϸǤޤ
ʤߤˡIt-Passports FCP_FMG_AD-7.4һ򥯥饦ɥȥ``ɤǤޤhttps://drive.google.com/open?id=1JnJ0WxAycADZlgV_ld_1c69JuTFCDV_Y
Posted at 1/23/2026 06:05:53        Only Author  2#
Your article has truly stunned me, I appreciate you sharing it! Grab your free Plat-Admn-201 valid study questions ebook exam questionscareer growth and salary boosts are within reach!
Posted at 1/26/2026 22:15:19        Only Author  3#
I really appreciate your article, it has made a big impression on me. The Authorized OGEA-102 certification exam is coming up fast. Wish me the best!
Posted at 2/7/2026 10:37:25        Only Author  4#
Im really thankful for your article, its truly unforgettable. The FCSS_NST_SE-7.4 practice exam fee exam questions are freeessential for career advancement and salary increase!
Posted at 3/7/2026 06:05:57        Only Author  5#
I feel so much more enlightened after reading it. Thanks to the H13-511_V5.5 valid study guide book, I received a promotion and raise. Now, its free for everyone. Wishing you all rapid career growth!
