Where To Start Your Oracle 1Z0-083 Exam Preparation?
Posted at 1/20/2026 20:03:25
View166
Replies2
BTW, DOWNLOAD part of UpdateDumps 1Z0-083 dumps from Cloud Storage: https://drive.google.com/open?id=1lDlo3qGgPHULscQLf02kPni9b_CLzxp_
The practice exams (desktop and web-based) are customizable, meaning you can set the Oracle Database Administration II (1Z0-083) questions and time according to your needs to improve your preparation for the Professional Oracle 1Z0-083 certification test. You can give multiple practice tests to improve yourself and even access the result of previously given tests from the history to avoid mistakes while taking the Oracle Database Administration II (1Z0-083) test. The practice tests have been made according to the latest pattern so you can practice in real Oracle Database Administration II (1Z0-083) exam environment and improve yourself daily.
Oracle 1Z1-083 (Oracle Database Administration II) Exam is designed for candidates who have already passed the Oracle Database SQL certification exam and have a solid understanding of SQL and database administration. 1Z0-083 exam is intended for professionals who want to advance their careers in the field of database administration and management. 1Z0-083 Exam Tests the candidate's knowledge and skills in managing and administering Oracle databases, including backup and recovery, performance tuning, security, and high availability solutions.
Oracle 1Z0-083 Dumps PDF To Gain Brilliant Result (2026)The best practice indicates that people who have passed the 1Z0-083 exam would not pass the exam without the help of the 1Z0-083 reference guide. So the study materials will be very important for all people. If you also want to pass the 1Z0-083 exam and get the related certification in a short, our 1Z0-083 Study Materials are the best choice for you. After studing with our 1Z0-083 exam questions, you will be able to pass the 1Z0-083 exam with confidence. We sincerely hope that our 1Z0-083 study materials will help you achieve your dream.
To take the exam, candidates must have a solid understanding of basic database administration concepts and practices, as well as experience working with Oracle Database technology. They must also have completed the Oracle Database Administration I exam (1Z0-082) or have equivalent knowledge and experience. 1Z0-083 Exam consists of 80 multiple-choice questions and has a time limit of 120 minutes.
Oracle Database Administration II Sample Questions (Q18-Q23):NEW QUESTION # 18
Which three capabilities require the use of the RMAN recovery catalog? (Choose three.)
- A. using the REPORT SCHEMA command to list a database's data files and tablespaces at times in the past
- B. creating customized reports about a single database's backups
- C. creating encrypted backups
- D. using the REPORT SCHEMA command to list a database's current data files and tablespaces
- E. using RMAN stored scripts
- F. using the KEEP FOREVER clause with the BACKUP command
Answer: A,E,F
A is correct:
https://docs.oracle.com/en/datab ... mrf/keepOption.html
"Specifies that the backup or copy never becomes obsolete (see Example 2-27). A recovery catalog is required when FOREVER is specified because the backup records eventually age out of the control file." B is correct:
https://docs.oracle.com/database/121/RCMRF/rcmsynta013.htm
"Execute CREATE SCRIPT only at the RMAN prompt. RMAN must be connected to a target database and a recovery catalog." F is correct:
https://docs.oracle.com/en/datab ... 9/rcmrf/REPORT.html
"atClause
This subclause specifies a point in time as a time, SCN, or log sequence number. You must be connected to a recovery catalog when issuing a REPORT SCHEMA command with an AT clause."
NEW QUESTION # 19
Which three are true about Automatic Workload Repository (AWR) and Automatic Database Diagnostic Monitor (ADDM) in an Oracle multitenant environment? (Choose three.)
- A. ADDM can run in a nonroot container.
- B. AWR snapshots can be created in a PDB.
- C. All AWR data is stored in the CDB$ROOT SYSAUX tablespace.
- D. AWR reports can be generated while connected to any container.
- E. No AWR data is stored in the CDB$ROOT SYSAUX tablespace.
- F. AWR snapshots can be created in CDB$ROOT.
Answer: B,D,E
NEW QUESTION # 20
- A. No AWR data is stored in the CDB$ROOT SYSAUX tablespace.
- B. ADDM can run in a nonroot container.
- C. AWR snapshots can be created in a PDB.
- D. All AWR data is stored in the CDB$ROOT SYSAUX tablespace.
- E. AWR reports can be generated while connected to any container.
Answer: C,D,F
NEW QUESTION # 21
Choose three. Which three are true about using an RMAN Recovery Catalog with a pluggable database (PDB) target connection in Oracle Database 19c and later releases?
- A. The base catalog must be enabled for Virtual Private Catalog use.
- B. The base catalog must be used by RMAN when performing point-in-time recovery for the PDB registered in the Virtual Private Catalog.
- C. The target PDB must be registered in both the base catalog and the Virtual Private Catalog.
- D. The target PDB must be registered in a Virtual Private Catalog.
- E. The base catalog owner must give the Virtual Private Catalog access to metadata for one or more PDBs.
- F. The target PDB must be registered in a base catalog.
Answer: A,B,E
NEW QUESTION # 22
The HR_ROOT application container must support the execution of a query on a table shared by application local PDBs PDB1 and PDB2, and remote PDB PDB3.
Which three are true? (Choose three.)
- A. A database link must exist in the remote CDB referring to the local CDB.
- B. The HR_ROOT replica must exist in the remote CDB.
- C. A proxy PDB must exist in the application root in the remote CDB.
- D. PDB3's application root replica must exist in the local CDB.
- E. A database link must exist in the local CDB root referring to the remote CDB.
- F. A proxy PDB must exist in the application root in the local CDB.
Answer: A,B,F
NEW QUESTION # 23
Fresh 1Z0-083 Dumps: https://www.updatedumps.com/Oracle/1Z0-083-updated-exam-dumps.html
- 1Z0-083 Exam Cost ⭕ New Exam 1Z0-083 Materials 🕕 New Exam 1Z0-083 Materials 🥶 Search on [url]www.prep4sures.top for 1Z0-083 to obtain exam materials for free download 📏Reliable Study 1Z0-083 Questions[/url]
- Free 1Z0-083 Test Questions 👫 Exam Vce 1Z0-083 Free 🕒 1Z0-083 Valid Test Answers 🤩 Open website ➤ [url]www.pdfvce.com ⮘ and search for ☀ 1Z0-083 ️☀️ for free download 🚊Reliable 1Z0-083 Exam Camp[/url]
- Updated Oracle Vce 1Z0-083 File Are Leading Materials - Effective 1Z0-083: Oracle Database Administration II 🕣 Immediately open ⮆ [url]www.practicevce.com ⮄ and search for ⏩ 1Z0-083 ⏪ to obtain a free download 🐻Exam Questions 1Z0-083 Vce[/url]
- Pdf 1Z0-083 Pass Leader 🥝 New Exam 1Z0-083 Materials 🦦 Reliable 1Z0-083 Exam Sample ⏩ Search for ➠ 1Z0-083 🠰 and download it for free immediately on [url]www.pdfvce.com 🃏1Z0-083 New Dumps Book[/url]
- Pass Guaranteed Oracle 1Z0-083 Fantastic Vce File 🛬 Search for 1Z0-083 and obtain a free download on ⮆ [url]www.verifieddumps.com ⮄ 🏃Exam 1Z0-083 Revision Plan[/url]
- 1Z0-083 Reliable Guide Files ↩ 1Z0-083 Reliable Guide Files 🤧 Pdf 1Z0-083 Pass Leader 📨 Search for [ 1Z0-083 ] and download exam materials for free through ➡ [url]www.pdfvce.com ️⬅️ 👧Reliable 1Z0-083 Exam Camp[/url]
- Latest 1Z0-083 Exam Questions 🛫 Trustworthy 1Z0-083 Exam Content 🎅 1Z0-083 Valid Test Answers 🔡 The page for free download of 1Z0-083 on ⏩ [url]www.dumpsquestion.com ⏪ will open immediately 💺New Exam 1Z0-083 Materials[/url]
- Valid Oracle Database Administration II test answers, valid 1Z0-083 exam dumps 🏇 Search on [url]www.pdfvce.com for ▶ 1Z0-083 ◀ to obtain exam materials for free download 🏊Latest 1Z0-083 Exam Questions[/url]
- Valid Oracle Database Administration II test answers, valid 1Z0-083 exam dumps 🎣 Download 1Z0-083 for free by simply searching on [ [url]www.dumpsmaterials.com ] 🍓1Z0-083 Valid Test Answers[/url]
- [url=https://restaurantpropertysellers.com/?s=100%%20Pass%20Quiz%20Oracle%20-%20Pass-Sure%201Z0-083%20-%20Vce%20Oracle%20Database%20Administration%20II%20File%20%e2%8f%b0%20Download%20[%201Z0-083%20]%20for%20free%20by%20simply%20entering%20%e2%98%80%20www.pdfvce.com%20%ef%b8%8f%e2%98%80%ef%b8%8f%20website%20%f0%9f%a4%bdReliable%201Z0-083%20Dumps%20Free]100% Pass Quiz Oracle - Pass-Sure 1Z0-083 - Vce Oracle Database Administration II File ⏰ Download [ 1Z0-083 ] for free by simply entering ☀ www.pdfvce.com ️☀️ website 🤽Reliable 1Z0-083 Dumps Free[/url]
- Reliable 1Z0-083 Exam Sample 🛫 Trustworthy 1Z0-083 Exam Content 🩳 1Z0-083 Exam Cost 💒 Easily obtain free download of ➽ 1Z0-083 🢪 by searching on ▷ [url]www.examdiscuss.com ◁ 🛶New Exam 1Z0-083 Materials[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, justpaste.me, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New 1Z0-083 dumps are available on Google Drive shared by UpdateDumps: https://drive.google.com/open?id=1lDlo3qGgPHULscQLf02kPni9b_CLzxp_
