Certification 1z0-1065-25 Test Questions | Latest 1z0-1065-25 Exam Online
99
Posted at 1/20/2026 20:49:58      View125 | Replies2        Print      Only Author   [Copy Link] 1#
What's more, part of that Test4Sure 1z0-1065-25 dumps now are free: https://drive.google.com/open?id=1ogB9F2or6-vZHopOSW93OpgSg8Eqec7r
Users using our 1z0-1065-25 study materials must be the first group of people who come into contact with new resources. When you receive an update reminder from 1z0-1065-25 practice questions, you can update the version in time and you will never miss a key message. If you use our study materials, you must walk in front of the reference staff that does not use valid 1z0-1065-25 Real Exam. And you will get the according 1z0-1065-25 certification more smoothly.
This is the 1z0-1065-25 PDF format which contains real 1z0-1065-25 exam questions. You can print it and make a hard copy of this PDF file as well which helps you to prepare on the go. It comes in handy format and helps you prepare well with updated Oracle Fusion Cloud Procurement 2025 Implementation Professional exam questions. Moreover, this PDF has questions that are according to the present content of the test. This PDF format helps you to enhance your understanding of each topic which you need to self-evaluate to boost your Oracle 1z0-1065-25 Exam Score.
Quiz 2026 Oracle 1z0-1065-25: Oracle Fusion Cloud Procurement 2025 Implementation Professional Newest Certification Test QuestionsMany exam candidates feel hampered by the shortage of effective 1z0-1065-25 practice materials, and the thick books and similar materials causing burden for you. Serving as indispensable choices on your way of achieving success especially during this exam, more than 98 percent of candidates pass the exam with our 1z0-1065-25 practice materials and all of former candidates made measurable advance and improvement. All 1z0-1065-25 practice materials fall within the scope of this exam for your information. The content is written promptly and helpfully because we hired the most processional experts in this area to compile the 1z0-1065-25 practice materials. Our 1z0-1065-25 practice materials will be worthy of purchase, and you will get manifest improvement.
Oracle Fusion Cloud Procurement 2025 Implementation Professional Sample Questions (Q23-Q28):NEW QUESTION # 23
When creating OTBI reports for supplier eligibility, in which subject area do you find Supplier Eligibility attributes? (Double check answer)
  • A. Supplier Portal
  • B. Supplier Registration
  • C. Supplier Qualification
  • D. Supplier
  • E. Supplier Profile
NEW QUESTION # 24
When companies are evolving, there are often mergers or acquisitions. You want the supplier contacts of the parent company to be able to only respond to the negotiations of the subsidiaries to which they have access to.
What is the setup to achieve this?
  • A. Subsidiary company supplier must request for the company supplier contact to be added to the negotiation.
  • B. Subsidiary company must forward the negotiation to the parent company supplier to respond.
  • C. Parent company supplier must be added to the negotiation.
  • D. Parent company supplier must be added to the supplier profile of the subsidiary company.
NEW QUESTION # 25
Your customer needs to be able to process negotiations, some have few lines, and some have many hundreds of lines.
Which two options would help them effectively handle the negotiations that have many lines?
  • A. Integration with Purchasing to generate purchasing documents
  • B. Invite additional suppliers post publish
  • C. Award lines spreadsheet
  • D. Proxy-bidding
  • E. File-based data import (FBDI)
Answer: C,E
NEW QUESTION # 26
Challenge 7
Manage Qualification Areas
Scenario
Your procurement organization needs to group and organize qualification questions into a hierarchical structure.
Task
Create an active Qualification Area to hold the qualification question created previously, where:
. Name of the area is PRCXX Area 1 (Replace xx with 01, which is your allocated User ID.)
. Description references company history
. Owning procurement BU is US1 Business Unit
  Expiration period is 10 days
. Questions and outcomes contain three options: Excellent, Average, Poor
See below in Explanation for each Step.
Task 7: Create a Qualification Area for Supplier Questions
Following the scenario, we need to create a new Qualification Area in Oracle Procurement Cloud named
"RCXX Area 1" (replace xx with 01) to organize the previously created supplier question.
Here are the steps to create the Qualification Area:
* Navigate to Manage Qualification Areas:
* Go to the Global Navigation Menu.
* Click on Procurement.
* Click on Setup and Maintenance.
* Click on Supplier Qualification.
* Click on Areas.
* Create the Qualification Area:
* Click on the Create icon (+ icon).
* Enter the Qualification Area Information:
* Name: Enter "RCXX Area 1" (replace xx with 01).
* Description: Enter a brief description, such as "Company History and Experience".
* Owning Procurement BU: Select "US1 Business Unit".
* Expiration Period: Enter "10" in the Days field. This defines how long a supplier's responses will be valid before requiring re-evaluation.
* Default Qualification Owner: (Optional) Select a user who will be automatically assigned as the owner for newly created qualifications associated with this area.
* Active: Select "Yes" to activate the area.
* Add Qualification Questions:
* Click on the Questions and Outcomes icon.
* Select the previously created supplier question "RCXX Q1" (replace xx with 01).
* Click on the Add icon (+ icon) to add it to the area.
* Define Outcomes:
* Click on the Outcomes tab.
* Click on the Create icon (+ icon) to define possible outcomes for the area.
* Enter three outcome options:
* Excellent
* Average
* Poor
* Assign a score or weight to each outcome if desired.
* Save the Qualification Area:
* Click on the Save button.
Verification:
* The Qualification Area "RCXX Area 1" (replace xx with 01) should now be listed in the Manage Qualification Areas page.
* You can verify the area details, description, and associated supplier question by clicking on it.
* The owning procurement BU, expiration period, default owner, active status, and defined outcomes should be displayed as specified above.
Additional Notes:
* Make sure to replace "xx" with your allocated User ID (01) in the area name for consistent naming convention.
* The expiration period determines how often suppliers need to update their information for this area.
* Adding a default qualification owner simplifies the assignment process for new qualifications.
* Defining outcomes allows you to evaluate the responses to the qualification questions and assign scores or weights based on their performance.
NEW QUESTION # 27
When you are creating your purchase orders, you want to be able to apply discounts to all purchase order lines with a single action and have opted in to the feature.
Which are the two conditions when the base price CANNOT be changed?
  • A. The purchase order line is received or billed, and the procurement business unit configuration does not allow manual price updates.
  • B. The purchase order line is for catalog items.
  • C. The purchase order tine is created from a punchout marketplace that does not allow the price to be changed.
  • D. The purchase order line is included on a Procurement Contract.
The base price of a purchase order line cannot be changed if the line is created from a punchout marketplace that does not allow the price to be changed, or if the line is included on a procurement contract. These are the two conditions that prevent the application of discounts to all purchase order lines with a single action.
Oracle Fusion Applications Procurement Implementation Guide, section "urchase Order Pricing", subsection
"rice Change Conditions".
PRCO: Purchase Order Price Is Not Updated After A Change Order ..., section "Cause", subsection
"Solution".
NEW QUESTION # 28
Up to 1 year of free updates of Oracle 1z0-1065-25 exam questions are also available at Test4Sure. To test the features of our product before buying, you may also try a free demo. It is not difficult to clear the 1z0-1065-25 certification exam if you have actual exam questions of at your disposal. Why then wait? Visit and download Oracle 1z0-1065-25 updated exam questions right away to start the process of cracking your test in one go.
Latest 1z0-1065-25 Exam Online: https://www.test4sure.com/1z0-1065-25-pass4sure-vce.html
The answers of Test4Sure's exercises is 100% correct and they can help you pass 1z0-1065-25 Questions Oracle Cloud exam successfully, Oracle Certification 1z0-1065-25 Test Questions Besides, all your information is under the umbrella of our technology services, and you do not need to worry about anything about your information issue, because we treat your benefits as our first issue, The braindumps of the testing engine is a simulation of the 1z0-1065-25 braindumps actual test that you can feel the atmosphere of the Oracle real exam, and the answer is not shown in the process of 1z0-1065-25 braindumps test.
Treat it as if it were a solid and a part of the experience 1z0-1065-25 being expressed in the photograph, These are the results of decades of research and engineering on exciting topics.
The answers of Test4Sure's exercises is 100% correct and they can help you pass 1z0-1065-25 Questions Oracle Cloud exam successfully, Besides, all your information is under the umbrella of our technology services, and you do not Valid 1z0-1065-25 Cram Materials need to worry about anything about your information issue, because we treat your benefits as our first issue.
Certification 1z0-1065-25 Test Questions | 100% Free High-quality Latest Oracle Fusion Cloud Procurement 2025 Implementation Professional Exam OnlineThe braindumps of the testing engine is a simulation of the 1z0-1065-25 braindumps actual test that you can feel the atmosphere of the Oracle real exam, and the answer is not shown in the process of 1z0-1065-25 braindumps test.
In most cases, we will have a good cooperation, Our 1z0-1065-25 quiz torrent was designed by a lot of experts and professors in different area in the rapid development world.
2026 Latest Test4Sure 1z0-1065-25 PDF Dumps and 1z0-1065-25 Exam Engine Free Share: https://drive.google.com/open?id=1ogB9F2or6-vZHopOSW93OpgSg8Eqec7r
Posted at 2/13/2026 10:57:30        Only Author  2#
Im grateful for your article, it really left a lasting impression. Wishing you success! Here are the free CDCS-001 new dumps book test materials.
Posted at 2/16/2026 22:36:15        Only Author  3#
Your article is so inspiring, thank you for sharing! Get your hands on the free 3V0-25.25 valid test topics exam questions. Wishing you the best of luck!
