[General] 2026 Fantastic MB-820: Microsoft Dynamics 365 Business Central Developer Valid T
104
【General】 2026 Fantastic MB-820: Microsoft Dynamics 365 Business Central Developer Valid T
Posted at 1/20/2026 21:28:35      View:176 | Replies:2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PrepPDF MB-820 dumps for free: https://drive.google.com/open?id=1fCeTIheFB9gC79Uc7W93oKeEhCU0VyTm
The exam time is coming, while you are not prepared well for MB-820 real test. Please do not be tense and worried, you can pass your MB-820 actual exam very simply and easily with PrepPDF MB-820 free pdf dumps. With the help of Microsoft MB-820 free pdf practice, you can not only get high score in your actual test, but also can get more technology knowledge and be more professional.
Boring life will wear down your passion for life. It is time for you to make changes. Our MB-820 training materials are specially prepared for you. In addition, learning is becoming popular among all age groups. After you purchase our MB-820 Study Guide, you can make the best use of your spare time to update your knowledge. For we have three varied versions of our MB-820 learning questions for you to choose so that you can study at differents conditions.
Valid MB-820 Test Review, MB-820 Latest Braindumps EbookOur MB-820 test questions provide free trial services for all customers so that you can better understand our products. You can experience the effects of outside products in advance by downloading clue versions of our MB-820 exam torrent. In addition, it has simple procedure to buy our learning materials. After your payment is successful, you will receive an e-mail from our company within 10 minutes. After you click on the link and log in, you can start learning using our MB-820 test material. You can download our MB-820 test questions at any time. If you encounter something you do not understand, in the process of learning our MB-820 exam torrent, you can ask our staff. We provide you with 24-hour online services to help you solve the problem. Therefore we can ensure that we will provide you with efficient services.
Microsoft MB-820 Exam Syllabus Topics:
  • Develop by using AL objects: Building and extending tables and reports is discussed in this topic. It also explains Designing and creating an XMLport. Lastly, it discusses how to work with entitlement and permission set objects.
  • Install, develop, and deploy for Business Central: It delves into the installation and configuration of a Business Central development environment. Moreover, it discusses creating, debugging, and deploying an extension in Business Central.
  • Integrate Business Central with other applications: Accessing Representational State Transfer (REST) services is discussed in this topic.  It also explains implementation of APIs.
  • Develop by using AL: How to Customize the UI experience and Use AL for business central extension is discussed here. It also delves into explaining the essential development standards.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q20-Q25):NEW QUESTION # 20
You create the following Vendor table and Item table in Business Central.
You require the following data set to assign vendors to items.
You need to create a query to assign the vendors.
Which three code blocks should you use to develop the solution? To answer, move the appropriate code blocks from the list of code blocks to the answer area and arrange them in the correct order.
NOTE: More than one order of answer choices is correct. You will receive credit for any of the correct orders you select.
1 - dataitem(Vendor; Vendor)
2 - dataitem(Item; Item)
3 - DataItemLink = "Vendor No." = Item.Vendor_No;
NEW QUESTION # 21
You are developing an XMLport to export data from the parent Item table and a related child "Item Unit of Measure' table. The XMLport configuration must provide the following:
* Link the child table to its parent.
* Display a confirmation message after the XMLport runs.
You need to generate the XMLport.
What should you do? To answer, move the appropriate triggers to the correct requirements. You may use each trigger once, more than once, or not at all. You may need to move the split bar between panes or scroll to view content.
NEW QUESTION # 22
Case Study 2 - Alpine Ski House
Company Background
Alpine Ski House is a company that owns and operates hotels, restaurants, and stores.
Currently, the company uses the following software and interface:
- Property management software (PMS) to manage hotel rooms
- On-premises accounting software to generate sales invoices and create purchase orders
- An API that allows restaurants and stores to obtain necessary information Restaurants and stores use standalone software for point of sale (POS) devices. Each day, the POS terminals generate a text file of sales data and save the files in a server folder. An account assistant must manually import the files to the current software tables to be processed by the system.
The general manager receives several reports monthly from department managers. The reports take too much time to prepare.
Planned improvements
The company is moving from a different system to Business Central online to manage the whole company.
The company plans to increase efficiency in every department by using APIs to obtain or share information between the different systems.
Each department involved in purchasing must be able to make purchase requests automatically and easily. The departments do not need access to the full ERP management system.
Technical specifications
Alpine Ski House requires the development of several extensions for the planned improvements.
Business Central design patterns must be used to develop all extensions.
Alpine Ski House must develop the following pages:
- Pages that provide multiple configurations in a multistep dialog, like a wizard, to provide required information when the extensions are first installed
- Department-specific Role Center pages to show relevant information and pages with additional information The IT department plans to use Power BI to analyze departmental information. The database must be configured to provide optimal performance.
Department-specific requirements
Housekeeping department
The housekeeping department requires the following to increase efficiency and help avoid data entry errors:
- A Housekeeping Role Center to minimize navigation to relevant areas in Business Central online and to show relevant information in it
- Pages to embed into a new Room page to show additional information about the Room entity
- A table named Room Incident for the housekeeping team to enter room issue information
- A Housekeeping canvas app that connects to an extension
- The department requires the development of an extension with a new API page named RoomsAPI.
- The housekeeping team will use RoomsAPI to publish room details, update when work is complete, or provide repair notifications from the canvas app.
- This custom API page must expose a custom table named Rooms and have an ID 50000. The table must be able to update from the PMS. The PMS team must know the endpoint to connect to the custom API.
- A developer provides the following details for the API page:
- The extension must be published in Business Central online and include a list page named Room List that includes all hotel rooms.
- Installation or updates to this extension must meet the following requirements:
o Some web services must be published automatically.
o The version of the specified application's metadata must be obtained in AL language, o The code required to perform tasks cannot be accessible from other parts of the application.
The Room Incident table information must include the following fields:
- Incident entry: An incremental number
- Room No.: A room from the Room table
- Incident Date: The work date
o The table definition in the Room Incident table must autofill the Incident Date when the housekeeping team inserts a new record, o The value for Incident Date must be the work date configured in the Business Central online client.
- Status: Includes the following options to identify the status of the incident:
o Open: When the Room Incident is created
o In Progress: When someone starts repair work
o Closed: When the incident is solved
- Incident Closing Date: Auto-updating field (when the status passes to Closed, the field will update with the work date)
- Incident Description: Text
- Image: Media data type
o The stored picture must be downloadable from a menu action,
o A Room Incident page must be developed to contain the download action.
- To increase efficiency, the new system must manage the generated data from the restaurants and stores directly by using the API on the POS terminals.
- The company requires a codeunit called from a job queue to read the information from the POS terminal APIs.
- The POS terminal information must be stored in a table named POS Information, have an ID
50100, and be editable on a page.
- The account manager requires an option on the menu of the page to run the process manually.
- To analyze the information received from the POS terminals, the company requires:
- A custom API named ticketAPI to export the information to Power BI
- Use of the Read Scale-Out feature to improve database performance
Purchasing department and non-conformity handling
The purchasing department requires a new entity in Business Central online to log non- conformities of goods received from vendors. The entity must be set up as follows:
- The non-conformity entity must have two tables:
o a header with common information
o one or more lines with the detailed received items that are non-conforming
- The entity requires a page named Non-conformity and a subpage named Non-conformity Lines to store the information.
When a purchase order with incorrect quantity or quality issues is received, the entity must create a non-conformity document in the system. The following information must be included in the document:
o Non-conformity Number: must use the No. Series table from Business Central online to manage this field and use these features:
o Alphanumeric values
o Number format that includes "NC" and the year as part of the number; for example, NC24-001
- Non-conformity Date: stores only the creation date
- Vendor No.: stores the number of the vendor that sent the items; only vendors from the company must be included
- Owner: code of an employee defined in the company
- Receipt No.: must meet the following conditions:
o Be an existing receipt No.
o Be received from the vendor indicated in the Vendor No. field
- Comments: can include comments with rich text and pictures to illustrate quality problems
- Status: includes non-conformity statuses, such as:
o Open
o Notified
o Closed
- Lines must contain the following details:
o Item No.: item received (for existing inventory items only)
o Description: item description
o Quantity: non-conforming quantity
- Non-conformity Type:
o Quality
o Quantity
o Delivery date
The serial numbers of the non-conformities and the period in which they can be created must be in a configuration table and its corresponding page to allow them to be modified for the users.
Hotspot Question
You need to select the appropriate page types to solve the reporting requirements.
Which page types should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 23
You are treating an app tor Business Central.
You plan to specify the following parameters and properties of the server and app.
* Startup object type and object ID
* Runtime
* Dependencies
You need to configure the JSON file for the specified parameters and properties Which JSON files should you configure? To answer, move the appropriate files to the correct object purposes You may use each file once, more than once, or not at all You may need to move the split bar between panes or scroll to view content NOTE Each correct selection is worth one point.
NEW QUESTION # 24
You need to create the API page according to the requirements.
How should you complete the code segment? To answer, select the appropriate options in the answer area.
NEW QUESTION # 25
When you decide to pass the MB-820 exam and get relate certification, you must want to find a reliable exam tool to prepare for exam. That is the reason why I want to recommend our MB-820 prep guide to you, because we believe this is what you have been looking for. Moreover we are committed to offer you with data protect act and guarantee you will not suffer from virus intrusion and information leakage after purchasing our MB-820 Guide Torrent. The last but not least we have professional groups providing guidance in terms of download and installment remotely.
Valid MB-820 Test Review: https://www.preppdf.com/Microsoft/MB-820-prepaway-exam-dumps.html
2026 Latest PrepPDF MB-820 PDF Dumps and MB-820 Exam Engine Free Share: https://drive.google.com/open?id=1fCeTIheFB9gC79Uc7W93oKeEhCU0VyTm
Posted at 2/14/2026 15:28:32        Only Author  2#
Testpdf 考题大师始终致力与为客户提供 Managing-Cloud-Security 认证的全真考题及认证学习资料,該模擬試題可以在不同的電腦中使用,這對於考生來說沒有任何限制。我們的 Managing-Cloud-Security 權威考試題庫軟體是 WGU 認證廠商的授權產品,全新的收錄了 WGU 認證考試的所有試題,並根據認證的不斷變化而動態更新,參考資料的考試試題都是最新推出的。能够帮助你一次通过 WGU Managing-Cloud-Security 认证考试。
Posted at 2/16/2026 22:03:43        Only Author  3#
Your article is outstanding, thank you for sharing! Free C-P2W12-2311 interactive practice exam exam papers for you to download. Best of luck in your exams!
