[General] Pass Guaranteed Quiz 2026 Marvelous VMware 2V0-15.25 Valid Test Sample
108
【General】 Pass Guaranteed Quiz 2026 Marvelous VMware 2V0-15.25 Valid Test Sample
Posted at 1/20/2026 21:37:07      View:157 | Replies:2        Print      Only Author   [Copy Link] 1#
TrainingDumps has one of the most comprehensive and top-notch VMware 2V0-15.25 Exam Questions. We eliminated the filler and simplified the VMware Cloud Foundation 9.0 Support exam preparation process so you can ace the VMware exam on your first try. Our VMware 2V0-15.25 Questions include real-world examples to help you learn the fundamentals of the subject not only for the VMware exam but also for your future job.
VMware 2V0-15.25 Exam Syllabus Topics:
  • IT Architectures, Technologies, Standards: This domain covers fundamental frameworks, tools, and best practices for building scalable, secure, and interoperable enterprise IT systems.
  • Troubleshoot and Optimize the VMware by Broadcom Solution: This domain focuses on troubleshooting VCF deployment, upgrades, conversions, workload domains, fleet operations (certificates, passwords, identity), licensing, compute resources, storage (vSAN, supplemental storage), networking (VDS, NSX), VCF Operations tools, Identity Broker automation, and HCX workload migrations.
  • Plan and Design the VMware by Broadcom Solution: This domain addresses architectural planning and design principles for creating scalable, secure virtual environments aligned with business requirements.
  • Install, Configure, Administrate the VMware by Broadcom Solution: This area covers installing, configuring, and managing VMware solutions including VCF Fleet deployment, expansion, and reduction operations.
Topic 5
  • VMware by Broadcom Solution: This section focuses on understanding VMware by Broadcom's virtualization and cloud infrastructure platform for managing modern enterprise workloads.
2V0-15.25 Latest Test Practice, Study Guide 2V0-15.25 PdfNowadays the test 2V0-15.25 certificate is more and more important because if you pass it you will improve your abilities and your stocks of knowledge in some certain area and find a good job with high pay. If you buy our 2V0-15.25 exam materials you can pass the exam easily and successfully. Our product boosts many advantages and it is worthy for you to buy it. You can have a free download and tryout of our Professional Level Exams exam torrents before purchasing. After you purchase our product you can download our 2V0-15.25 Study Materials immediately. We will send our product by mails in 5-10 minutes. We provide free update and the discounts for the old client.
VMware Cloud Foundation 9.0 Support Sample Questions (Q34-Q39):NEW QUESTION # 34
An Administrator has been tasked with creating a new VMware Cloud Foundation (VCF) Automation Region named Region-2. The following information has been provided:
* The current environment has two workload domains named WLD1 and WLD2.
* The workload domains share one NSX Local Manager deployment.
* A VCF Automation Region named region-1 exists that uses the shared NSX Local Manager deployment.
When creating the second Region in VCF Automation, the administrator sees "No results" when attempting to select a NSX Local Manager for the Region. What should the Administrator do to resolve this issue?
  • A. Deploy an additional vSphere cluster in WLD1.
  • B. Add an additional NSX Edge Cluster In WLD1.
  • C. Ensure that that the NSX Manager is deployed in HA mode.
  • D. Deploy a third workload domain that includes a new, dedicated NSX Local Manager deployment.
In VMware Cloud Foundation (VCF) Automation, eachAutomation Regionmust be associated with a dedicated NSX Local Manager. A single NSX Local Manager instancecannot be reused across multiple Automation Regions.
In the provided scenario:
* The existing environment hasWLD1andWLD2, both sharingone NSX Local Manager.
* Region-1 in VCF Automation already consumes this shared NSX Local Manager.
* When creatingRegion-2, the interface shows"No results"when selecting an NSX Local Manager.
This behavior matches documented VCF Automation constraints:an NSX Local Manager can only be mapped to a single Automation Region. Once it is consumed by one region, it isnot availablefor any additional region.
To create a second region (Region-2), anew NSX Local Manager instancemust exist in the environment.
The only supported method to obtain a new NSX Local Manager is todeploy a new workload domain, because NSX Local Manager is deployed as part of every VI Workload Domain.
Thus, the administrator mustdeploy a new (third) workload domain, which includes its own NSX Local Manager package, allowing Region-2 to be created successfully.
NEW QUESTION # 35
An administrator has a vSphere 8.0 update 3 environment with the following configuration:
* A 3-node vSAN cluster
* A vSphere Standard Switch (VSS)
* Several standalone ESX hosts in the vCenter inventory
They want to convert this vSphere environment into a new VMware Cloud Foundation (VCF) 9.0 management domain.
Identify two changes they will need to make before converting this vSphere environment into a VMWare Cloud Foundation (VCF) Management domain? (Choose two.)
  • A. Upgrade vSphere 8.0 Update 3 to vSphere 9.0.
  • B. Remove the standalone hosts from the vCenter inventory.
  • C. Configure a vSphere Distributed Switch.
  • D. Remove the vSphere Standard Switch from the vCenter Inventory.
To convert an existing vSphere environment into aVMware Cloud Foundation (VCF) 9.0 Management Domain, several prerequisites must be met as defined in the VCF 9.x documentation.
First,VCF 9.0 requires vSphere 9.0as part of its Bill of Materials (BOM). The uploaded VCF 9.0 documentation confirms that VCF 9.0 is built onvSphere 9.0, vCenter 9.0, and NSX versions that align with the 9.x stack. A vSphere 8.0 Update 3 environment isnot supportedas a foundation for a VCF 9.0 management domain; therefore, the administrator mustupgrade the entire vSphere platform to vSphere 9.0 before VCF deployment.
(Reference: VCF 9.0 BOM - vSphere 9.0 is mandatory.)
Second, VCF management domain creation strictly requiresvSphere Distributed Switches (vDS). VCF does notsupportvSphere Standard Switches (VSS)for any management domain hosts. The VCF 9.0 design and deployment guides state that all ESXi hosts intended for a management domain must use vDS for management, vSAN, and vMotion networking. Therefore, the existence of a VSS must be corrected by deploying and configuring avSphere Distributed Switchand migrating host networking accordingly before Cloud Builder deployment.
Removing standalone hosts or removing a VSS from inventory isnot required. Only the hosts selected for the management domain need to be prepared.
Thus, the required changes are:
#B. Upgrade vSphere 8.0 Update 3 to vSphere 9.0
#C. Configure a vSphere Distributed Switch
These are the only changes explicitly required by VCF 9.0 documentation.
NEW QUESTION # 36
An administrator is responsible for a VMware Cloud Foundation (VCF) fleet. The administrator has been tasked with commissioning four ESX hosts for a new workload domain that uses vSAN Express Storage Architecture (ESA) as the primary storage solution.
During the host validation stage in vSphere client, the process fails with the following errors:
esx-l.wld.vcf.local. Failed to validate vSAN HCL status.
esx-2.wld.vcf. local. Failed to validate vSAN HCL status.
esx-3.wld.vcf.local. Failed to validate vSAN HCL status.
esx~4.wid.vcf. local. Failed to validate vSAN HCL status.
What Is the cause of the errors?
  • A. The ESX hosts are not using vSAN ESA certified storage devices.
  • B. The ESX hosts must have internet access to validate vSAN ESA compatibility.
  • C. The RAID controller in each ESX host is not configured to use RAID-O/Passthrough.
  • D. The RAID controller in each ESX host needs to be reconfigured to use Tri-mode.
VMware Cloud Foundation 9.0 requires strict vSAN ESA hardware compatibility when creating a workload domain that uses vSAN Express Storage Architecture (ESA). During host validation, SDDC Manager and vSphere Client check whether each ESXi host meets ESA requirements, including CPU generation, storage controller type, and-most importantly-ESA-certified NVMe storage devices. The validation errors provided:
"Failed to validate vSAN HCL status" for every host
indicate that the hosts do not meet the vSAN ESA HCL requirements.
VCF 9.0 documentation states that ESA uses a next-generation log-structured filesystem requiring certified NVMe devices only, with no RAID controller dependencies. Unlike OSA, ESA eliminates disk groups, but it requires certified devices listed on the vSAN ESA HCL to pass host validation. If non-certified or unsupported NVMe/SAS devices are present, validation fails exactly as described.
Option A is incorrect because RAID pass-through settings apply to OSA, not ESA.
Option C is incorrect because ESA compatibility validation is performed offline using the SDDC Manager BOM, not via internet lookup.
Option D is incorrect because ESA does not use tri-mode RAID controllers.
Therefore, the documented and verified cause is B: hosts are not using vSAN ESA certified storage devices.
NEW QUESTION # 37
An administrator logs into the VMware NSX Manage UI and observes a "Remote Logging Not Configured" alarm for each NSX Management node. What is a possible reason for this issue?
  • A. Update the NSX Node Profile to configure a remote logging server.
  • B. Update the NSX Uplink Profile to configure a remote logging server.
  • C. Update the NSX Edge Cluster Profile to configure a remote logging server.
  • D. Update the NSX Configuration Profile to configure a remote logging server.
The"Remote Logging Not Configured"alarm in NSX Manager is a system-health alert indicating that one or more Transport Nodes (Edges or Hypervisors) or Management Nodes do not have a Syslog server defined.
* NSX Node Profiles:In VMware NSX (and by extension VCF), the standard method to apply consistent administrative settings-such asSyslog Servers, NTP settings, and Core Dump configurations-across a fleet of nodes is to use anNSX Node Profile.
* Configuration Path:The administrator should navigate toSystem > Fabric > Profiles > Node Profiles
. Here, they can create or edit a profile that specifies the remote syslog server's IP/FQDN, port, and protocol.
* Application:Once the Node Profile is applied to the NSX Management Cluster or Edge Clusters, the configuration is pushed to all respective appliances, clearing the alarm.
* Why not A/B:Edge Cluster Profiles manage networking/BFD settings; Uplink Profiles manage NIC teaming and MTU.
NEW QUESTION # 38
An administrator created a new VPC with an associated subnet, configured with a DHCP Server.
When attaching virtual machines to the VPC subnet, an IP address is assigned, but the DNS and NTP settings are not configured.
How can the administrator update the DHCP server configuration to set DNS and NTP?
  • A. Enable DNS and NTP Passthrough on the DHCP Server.
  • B. Switch the DHCP Network mode from Distributed Connectivity to Centralized Connectivity.
  • C. Update the default VPC Service Profile to include the IP addresses for the DNS and NTP servers.
  • D. Change the DHCP Server mode from DHCP Server to DHCP Relay.
In VMware Cloud Foundation 9.0 Automation, each VPC is governed by aVPC Service Profile, which defines the default network services applied to the VPC's DHCP server-this includesDNS servers, NTP servers, DHCP lease values, and other network attributes. When a subnet is associated with a VPC and DHCP is enabled, the DHCP service inherits its DNS and NTP configuration from the VPC Service Profile.
In the scenario, virtual machines attached to the new VPC subnet receive an IP address, but not DNS or NTP settings. This indicates that the DHCP server is functioning correctly, but its service profile lacks DNS and NTP configuration. Updating thedefault VPC Service Profileallows the administrator to specify DNS resolver addresses and NTP time sources, which will then automatically be pushed to all DHCP-enabled subnets under that VPC.
Option B (changing to DHCP Relay) is incorrect because relay mode does not configure DNS/NTP-it delegates DHCP to an external DHCP server.
Option C (enable DNS/NTP passthrough) is not a feature of NSX DHCP.
Option D (changing connectivity mode) affects routing and service placement, not DHCP options.
NEW QUESTION # 39
No doubt the VMware Cloud Foundation 9.0 Support certification exam is one of the most difficult TrainingDumps VMware certification exams in the modern TrainingDumps world. This 2V0-15.25 exam always gives a tough time to their candidates. It is hard to pass without in-depth 2V0-15.25 exam preparation. The TrainingDumps understands this challenge and offers real, valid, and top-notch 2V0-15.25 Exam Dumps in three different formats. These formats are 2V0-15.25 PDF dumps files, desktop practice test software, and web-based practice test software.
2V0-15.25 Latest Test Practice: https://www.trainingdumps.com/2V0-15.25_exam-valid-dumps.html
Posted at 2/7/2026 05:35:13        Only Author  2#
This article is outstanding, I’m so grateful for your sharing. Get the Latest Data-Driven-Decision-Making exam questions and answers test questions for free—your key to the next level in your career!
Posted at 2/11/2026 02:27:39        Only Author  3#
Your article has truly stunned me, I appreciate you sharing it! The Latest SPI test forum helped me climb the career ladder and earn a raise. Now, I’m sharing it for free with all of you. Wishing you success!
