PEGACPRSA22V1 Certification Exam Dumps & Test PEGACPRSA22V1 Objectives Pdf
Posted at 1/20/2026 23:48:40
View172
Replies2
P.S. Free 2026 Pegasystems PEGACPRSA22V1 dumps are available on Google Drive shared by Braindumpsqa: https://drive.google.com/open?id=1jGf3Vu2njqtYbh7xZGj0X2-6D9uEEQMC
The pass rate for PEGACPRSA22V1 training materials is 98.95%, and you can pass and get the certificate successfully if you buy PEGACPRSA22V1 training materials from us. Besides, we have experienced experts to compile and verify PEGACPRSA22V1 training materials, therefore quality and accuracy can be guaranteed. We are pass guarantee and money back guarantee if you buy PEGACPRSA22V1 Exam Dumps from us. We provide you with free update for one year for the PEGACPRSA22V1 training materials, so that you can know the latest information about the exam.
The PEGACPRSA22V1 Exam is a multiple-choice test, and candidates are given 90 minutes to complete it. The passing score for PEGACPRSA22V1 exam is 65%, and it is recommended that candidates have at least six months of experience working with Pega's RPA tools before attempting the exam.
Test PEGACPRSA22V1 Objectives Pdf | Valid Braindumps PEGACPRSA22V1 SheetThe PEGACPRSA22V1 training materials provide you with free demo, and you can have a try in our website. If you are satisfied with the free demo, you just need to add them to your shopping cart, and pay for it, please check the email address carefully, due to we will send the PEGACPRSA22V1 Exam Dumps to you by email. Besides, we support online payment with credit card, and the payment tools will change the currency of your country, and there is no necessary for you to exchange by yourself.
Pegasystems Certified Pega Robotics System Architect 22 Sample Questions (Q59-Q64):NEW QUESTION # 59
Match this robot activity completion status on the left to the unattended automation scenario on the right.
In Pega Robot Studio, when an automation (especially one invoked as a robot activity by Pega Platform) finishes execution, it must return a Completion Status. This status helps the Pega Platform determine the outcome of the automation and decide whether to continue the workflow, retry, or handle an exception.
According to the Pega Robotics System Design and Implementation Guide, section "Robot Activity Completion Status and Workflow Integration":
"Each robotic activity returns a Completion Status to the Pega Platform after execution.
The completion status communicates the final outcome of the automation's operation, indicating whether it successfully completed, encountered errors, or produced invalid data.
The most common statuses used are:
* Complete: The automation ran successfully, and data passed all validation checks.
* DidNotComplete: The automation ran to completion, but business validation failed or data was deemed invalid.
* CompletedWithErrors: The automation could not complete execution due to a system or process error." Detailed Reasoning:
* Complete
* Indicates that the robotic automation successfully executed and the resulting data passed all validation checks within Pega.
* This allows the Pega case flow to continue normally.
* Correct Match: "If data passes business validation, the processing flow continues."
* Used when the automation fails to complete due to a technical issue or system error (for example, an application did not load or a connector failed).
* This causes the flow to route as a failure in Pega.
* Correct Match: "If the automation fails to complete, it routes as a failure."
* DidNotComplete
* Indicates that the automation successfully executed technically but failed business validation, such as incorrect data, missing inputs, or business rule mismatches.
* Correct Match: "If the automation completes processing, but the data fails business validation." Final Correct Matching Order:
Completion Status
Automation Description
Complete
CompletedWithErrors
DidNotComplete
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Robot Activity Completion Status - RPA and RDA Integration Behavior section (Pega Robotics 19.1 and later).
NEW QUESTION # 60
The project you are working on has two applications: BankerInsight and Pega Finance. You are working on the BankerInsight application method. Which three elements are not available to be used on the application method's design surface? (Choose Three)
- A. Globals.
- B. External data sources.
- C. BankerInsight controls.
- D. Pega Finance controls.
- E. Automations that are not scoped within BankerInsight.
Answer: A,D,E
Comprehensive and Detailed Explanation From Pega Robotics System Exact Extract:
"After adding the application method, Pega Robot Studio includes the application in the Palette. External elements are not available underneath the application, such as:
* Globals
* Other applications
* Automations that are not scoped within the application"
In other words: when you are working within an application method under a specific application (such as BankerInsight), you cannot include items from the global scope (Globals), you cannot include items from other applications (such as Pega Finance controls belong to a different application), nor can you include automations that are not scoped to the same application (automations outside BankerInsight).
Why each option is correct/incorrect:
* A. Automations that are not scoped within BankerInsight - Not available (Correct). According to the extract, "Automations that are not scoped within the application" are listed as external elements that cannot be used.
* B. BankerInsight controls - Available. Controls belonging to the same application are within scope, so you can use these.
* C. External data sources - The documentation snippet does not explicitly list "external data sources" as unavailable under the application method. So by the extract we cannot verify it as not available - thus we do not choose it.
* D. Pega Finance controls - Not available. These belong to a different application (Pega Finance), so they fall under "Other applications" which are external to the current application and so cannot be used.
* E. Globals - Not available. Explicitly listed in the documentation as external elements not available underneath the application.
If you like, I can check whether "External data sources" are allowed or not in that context and provide a more detailed explanation with additional reference pages.
NEW QUESTION # 61
The variable varInput is a String that holds the value What is the output?
What is the outcome of the above automation?
- A. The variable varOutput ends with C.
- B. The variable varOutput ends with B.
- C. An exception is thrown.
- D. The variable varOutput ends with A.
NEW QUESTION # 62
You are developing a project for a financial company that implements a branding strategy for every application and webpage used by its customers. How do you ensure consistent formatting for all toast notifications in your project?
- A. Add a toast notification to the Globals tab and adjust the display settings in its property grid. To add a formatted toast notification to an automation, use a Show method from the Globals section of the Palette.
- B. In the project explorer, click the Information icon next to the project name, and adjust the toast notification settings in the project's property grid.
- C. In the Globals tab, expand the Utilities section of the Toolbox, select the Messages section and adjust the display settings in its property grid.
- D. Create an automation setting up the toast notification properties that runs automatically before proceeding to execute the project.
In Pega Robot Studio, toast notifications are used to display short, non-blocking messages to users during runtime. These notifications are highly customizable and can be globally managed to maintain consistent branding across an enterprise automation project.
According to the Pega Robotics System Design and Implementation Guide (UI Messaging and Toast Notifications section):
"Toast notifications can be added to the Globals tab of a project to maintain consistent visual and behavioral configuration throughout the solution.
The notification element placed in Globals allows setting properties such as title, duration, color, font, and position that are shared by all automations calling the Show() method.
Automations reference the global toast notification by invoking its Show method from the Globals section of the Palette." This means that:
* The best practice for ensuring uniform design and branding (consistent colors, layout, font, and position) for toast messages is to define one global toast notification in the Globals tab.
* Once the global toast notification is configured, all automations that require displaying toast messages will simply call its Show() method, inheriting the standardized display settings.
Option Analysis:
* A. Incorrect - Adjusting the Utilities section does not define reusable toast notifications.
* B. Incorrect - The project properties do not include toast formatting controls.
* C. Incorrect - Creating an automation to set these dynamically would not enforce consistent styling across all notifications and is not recommended.
* D. Correct - Placing a toast notification in the Globals tab allows defining display parameters once and reusing them via the Show() method in automations, ensuring global consistency in branding and formatting.
Therefore, the correct and Pega-recommended approach is Option D.
References:Extracted and verified from Pega Robotics System Design and Implementation Guide, UI Messaging and Toast Notifications section (Pega Robotics 19.1 and later).
NEW QUESTION # 63
our project for a customer service department contains a Windows form with a btnUpdateAccount button.
Users click btnUpdateAccount to automate the updates of other customer account systems at the end of the call. You create the UpdateAccount automation to ensure that the Windows form is still accessible after clicking the button.
Which option represents the UpdateAccount automation with this requirement?
* Pega Robotics Studio - Automation Design Concepts (Events and UI Responsiveness)
"Automations started from a Windows Form Click event run on the UI thread. To keep the form responsive, long-running work should be started by calling other automations asynchronously. When an automation is executed synchronously, the UI thread is blocked until the call completes. Executing the child automation asynchronously allows users to continue interacting with the form."
* Pega Robotics Studio - Calling Automations (Run method)
"The Run method includes a synchronous parameter.
True - the caller waits for completion (blocks the UI).
False - the automation starts asynchronously and control returns immediately to the caller (UI remains available).
Default follows the project setting."
* Pega Robotics Studio - Windows Form Controls (Avoid self-triggering)
"Invoking PerformClick from within an automation that is already handling the button's click should be avoided. It re-triggers the button click and can lead to reentrancy or recursion and does not improve UI responsiveness."
* Pega Robotics Studio - Message Dialogs
"Displaying a MessageDialog during processing is modal and prevents interaction with the form until the dialog is closed. Use only for completion or error notifications, not while long-running work is executing." Why Option B is correct:
* Option B starts from the btnUpdateAccount.Click event (so no self-trigger via PerformClick).
* It launches the downstream automations (UpdateBankerInsight and UpdatePegasFinance) using Run with the synchronous parameter set to False (asynchronous), which keeps the Windows form responsive and accessible to the user while updates run.
* It does not introduce a modal MessageBox before or during the updates (dialogs are only used for completion/notification), so it avoids blocking the UI.
Why the other options are not correct:
* Option A: Uses PerformClick on the button, which re-triggers the click and can lead to recursion without improving responsiveness.
* Option C: Inserts a MessageDialog during the middle of processing, which is modal and blocks the form.
* Option D: Calls the update automations synchronously (or leaves them at the blocking default), which holds the UI thread until completion and makes the form inaccessible during the run.
NEW QUESTION # 64
As we all know, if candidates fail to pass the exam, time and energy you spend on the practicing will be returned nothing. If you choose us, we will let your efforts be payed off. PEGACPRSA22V1 learning materials are edited and reviewed by professional experts who possess the professional knowledge for the exam, and therefore you can use them at ease. Besides, we are pass guarantee and money back guarantee for PEGACPRSA22V1 Exam Materials. If you fail to pass the exam, we will give you full refund. We offer you free update for 365 days for PEGACPRSA22V1 exam materials, and the update version will be sent to you automatically.
Test PEGACPRSA22V1 Objectives Pdf: https://www.braindumpsqa.com/PEGACPRSA22V1_braindumps.html
- PEGACPRSA22V1 Latest Exam Online ✡ Test PEGACPRSA22V1 Engine Version 🎩 Valid PEGACPRSA22V1 Exam Materials 🎩 Copy URL ▛ [url]www.prepawaypdf.com ▟ open and search for PEGACPRSA22V1 to download for free 🔃
EGACPRSA22V1 VCE Exam Simulator[/url] - PEGACPRSA22V1 Real Testing Environment 📪 PEGACPRSA22V1 Exam Forum 📚 Valid PEGACPRSA22V1 Exam Materials 🏑 Search for PEGACPRSA22V1 and download it for free on ▛ [url]www.pdfvce.com ▟ website 📰
EGACPRSA22V1 Exam Engine[/url] - Pegasystems PEGACPRSA22V1 Certification Exam Dumps - [url]www.troytecdumps.com - Leader in Qualification Exams - PEGACPRSA22V1: Certified Pega Robotics System Architect 22 👸 Copy URL ➤ www.troytecdumps.com ⮘ open and search for ➤ PEGACPRSA22V1 ⮘ to download for free 🚊Latest PEGACPRSA22V1 Exam Duration[/url]
- HOT PEGACPRSA22V1 Certification Exam Dumps 100% Pass | High Pass-Rate Pegasystems Test Certified Pega Robotics System Architect 22 Objectives Pdf Pass for sure ☁ Download ➠ PEGACPRSA22V1 🠰 for free by simply searching on ➡ [url]www.pdfvce.com ️⬅️ 🍭
EGACPRSA22V1 Reliable Dumps Files[/url] - Pegasystems PEGACPRSA22V1 Exam Dumps - Pass Exam in One Go 🍕 Search for ➤ PEGACPRSA22V1 ⮘ and download it for free immediately on ⮆ [url]www.torrentvce.com ⮄ 💦
EGACPRSA22V1 Exam Engine[/url] - Quiz 2026 PEGACPRSA22V1: Updated Certified Pega Robotics System Architect 22 Certification Exam Dumps 🦁 The page for free download of ▷ PEGACPRSA22V1 ◁ on [ [url]www.pdfvce.com ] will open immediately 😇
EGACPRSA22V1 Exam Forum[/url] - Quiz 2026 PEGACPRSA22V1: Updated Certified Pega Robotics System Architect 22 Certification Exam Dumps ☔ Immediately open ➤ [url]www.testkingpass.com ⮘ and search for ✔ PEGACPRSA22V1 ️✔️ to obtain a free download 🤝
EGACPRSA22V1 Reliable Dumps Files[/url] - Pegasystems PEGACPRSA22V1 Exam Dumps - Pass Exam in One Go 🥝 Copy URL [url]www.pdfvce.com open and search for PEGACPRSA22V1 to download for free 🟫
EGACPRSA22V1 Valid Practice Materials[/url] - PEGACPRSA22V1 Exam Engine 👊 Valid Exam PEGACPRSA22V1 Registration 🤭 PEGACPRSA22V1 Valid Practice Materials 📷 Search for ☀ PEGACPRSA22V1 ️☀️ and download it for free on ▛ [url]www.examdiscuss.com ▟ website 👗
EGACPRSA22V1 Reliable Dumps Files[/url] - Pegasystems PEGACPRSA22V1 Certification Exam Dumps - Pdfvce - Leader in Qualification Exams - PEGACPRSA22V1: Certified Pega Robotics System Architect 22 🐦 Download { PEGACPRSA22V1 } for free by simply searching on ☀ [url]www.pdfvce.com ️☀️ 💢Accurate PEGACPRSA22V1 Study Material[/url]
- Quiz 2026 PEGACPRSA22V1: Updated Certified Pega Robotics System Architect 22 Certification Exam Dumps 🥯 Search for ▶ PEGACPRSA22V1 ◀ and easily obtain a free download on ▛ [url]www.examcollectionpass.com ▟ ⛰Dumps PEGACPRSA22V1 Free Download[/url]
- bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest Braindumpsqa PEGACPRSA22V1 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1jGf3Vu2njqtYbh7xZGj0X2-6D9uEEQMC
