[General] 312-38 Sample Questions | New 312-38 Exam Duration
94
General 312-38 Sample Questions | New 312-38 Exam Duration
Posted at 1/21/2026 00:42:48      View213 | Replies3        Print      Only Author   [Copy Link] 1#
2026 Latest ExamPrepAway 312-38 PDF Dumps and 312-38 Exam Engine Free Share: https://drive.google.com/open?id=1g7QUGruh1bIYzYGYKG0RhiTHAk6CkEuP
Our 312-38 guide torrent through the analysis of each subject research, found that there are a lot of hidden rules worth exploring, this is very necessary, at the same time, our 312-38 training materials have a super dream team of experts, so you can strictly control the proposition trend every year. In the annual examination questions, our 312-38 study questions have the corresponding rules to summarize, and can accurately predict this year's test hot spot and the proposition direction. This allows the user to prepare for the 312-38 test full of confidence.
The EC-Council 312-38 Exam is an ideal option for IT professionals, network administrators, and security practitioners who are looking to gain an in-depth understanding of network security concepts, methodologies, and techniques. The EC-Council Certified Network Defender (CND) certification is globally recognized and demonstrates a candidates commitment towards network security excellence. With the expansion of the digital landscape, network security professionals are in high demand, and earning an EC-Council Certified Network Defender (CND) certification can help candidates stand out from the crowd and advance their career in the network security field.
Pass Guaranteed 312-38 - Fantastic EC-Council Certified Network Defender CND Sample QuestionsGood product can was welcomed by many users, because they are the most effective learning tool, to help users in the shortest possible time to master enough knowledge points, so as to pass the qualification test, and our 312-38 study materials have always been synonymous with excellence. Our 312-38 Study Materials can help users achieve their goals easily, regardless of whether you want to pass various qualifying examinations, our products can provide you with the learning materials you want.
EC-COUNCIL EC-Council Certified Network Defender CND Sample Questions (Q201-Q206):NEW QUESTION # 201
Adam, a malicious hacker, has just succeeded in stealing a secure cookie via a XSS attack. He is able to replay the cookie even while the session is valid on the server. Which of the following is the most likely reason of this cause?
  • A. No encryption is applied.
  • B. Encryption is performed at the application layer (single encryption key).
  • C. Two way encryption is applied.
  • D. Encryption is performed at the network layer (layer 1 encryption).
Single key encryption uses a single word or phrase as the key. The same key is used by the sender to encrypt and the receiver to decrypt. Sender and receiver initially need to have a secure way of passing the key from one to the other. With TLS or SSL this would not be possible. Symmetric encryption is a type of encryption that uses a single key to encrypt and decrypt data. Symmetric encryption algorithms are faster than public key encryption. Therefore, it is commonly used when a message sender needs to encrypt a large amount of data.
Data Encryption Standard (DES) uses the symmetric encryption key algorithm to encrypt data.
NEW QUESTION # 202
An enterprise recently moved to a new office and the new neighborhood is a little risky. The CEO wants to monitor the physical perimeter and the entrance doors 24 hours. What is the best option to do this job?
  • A. Use fences in the entrance doors
  • B. Use an IDS in the entrance doors and install some of them near the corners
  • C. Use lights in all the entrance doors and along the company's perimeter
  • D. Install a CCTV with cameras pointing to the entrance doors and the street
NEW QUESTION # 203
James, a network admin in a large US based IT firm, was asked to audit and implement security controls over all network layers to achieve Defense-in-Depth. While working on this assignment, James has implemented both blacklisting and whitelisting ACLs. Which layer of defense-in-depth architecture is Jason working on currently?
  • A. Perimeter Layer
  • B. Internal Network Layer
  • C. Host Layer
  • D. Application Layer
James is working on the Perimeter Layer of the Defense-in-Depth architecture. This layer is responsible for protecting the network's boundaries from unauthorized access and attacks. The implementation of blacklisting and whitelisting Access Control Lists (ACLs) is a common practice at this layer. Blacklisting ACLs block known malicious entities, while whitelisting ACLs allow only approved entities to access the network. These measures are part of the perimeter defenses that include firewalls, intrusion detection systems, and other boundary security mechanisms designed to prevent attackers from gaining initial access to the network infrastructure.
NEW QUESTION # 204
Which of the following is a communication protocol that multicasts messages and information among all member devices in an IP multicast group?
  • A. IGMP
  • B. BGP
  • C. EGP
  • D. ICMP
NEW QUESTION # 205
Which of the following are provided by digital signatures?
  • A. Authentication and identification
  • B. Identification and validation
  • C. Security and integrity
  • D. Integrity and validation
NEW QUESTION # 206
The EC-COUNCIL 312-38 practice material of ExamPrepAway came into existence after consultation with many professionals and getting their positive reviews. The majority of aspirants are office professionals, and we recognize that you don't have enough time to prepare for the EC-COUNCIL 312-38 Certification Exam. As a result, several versions of the EC-Council Certified Network Defender CND (312-38) exam questions will be beneficial to you.
New 312-38 Exam Duration: https://www.examprepaway.com/EC-COUNCIL/braindumps.312-38.ete.file.html
Posted at 1/23/2026 22:38:16        Only Author  2#
The article is very content-rich and has given me many practical insights. Free access to the New C_THR88_2505 exam syllabus test materials. Best of luck on your exams!
Posted at 1/25/2026 07:10:41        Only Author  3#
This article gave me new motivation, thank you for sharing! The PCNSE latest test questions pdf questions were the turning point in my careernow, Im sharing them with you for free!
Posted at 2/23/2026 23:03:39        Only Author  4#
The article is truly inspiring, thank you for sharing! The A1000-182 reliable exam collection sheet content is fantastic, and you can access it freely.
