[General] JPNTestのVMware 2V0-16.25認定試験に対する最高の参考書
94
【General】 JPNTestのVMware 2V0-16.25認定試験に対する最高の参考書
Posted at 1/21/2026 00:54:32      View:144 | Replies:1        Print      Only Author   [Copy Link] 1#
さらに、JPNTest 2V0-16.25ダンプの一部が現在無料で提供されています:https://drive.google.com/open?id=1g0_HztgXT6_vwNNDLiPxokDwWbGDb1Bi
JPNTestは頼りが強い上にサービスもよくて、もし2V0-16.25試験に失敗したら全額で返金いたしてまた一年の無料なアップデートいたします。
VMware 2V0-16.25 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Troubleshoot and Optimize the VMware Solution: This section of the exam measures the ability of Systems Engineers to troubleshoot and optimize VMware-based environments. While no explicit testable objectives are listed, candidates are expected to apply their problem-solving skills to diagnose, resolve, and enhance VMware solutions for improved reliability and performance.
トピック 2
  • Deploy, Configure, and Operate VMware vSphere Foundation (VVF): This section of the exam measures the expertise of Data Center Administrators and emphasizes hands-on skills in deploying and configuring VMware vSphere Foundation environments. Candidates must understand the components of a VVF deployment, configure Supervisors within clusters, and manage identity, access control, licensing, and certificate management. The objectives also extend to lifecycle management within the vSphere Foundation. Furthermore, it explores operational tasks including monitoring and analyzing logs, configuring alerting, managing dashboards, and integrating with VMware Cloud Foundation (VCF) Operations. Candidates will also be tested on cost and pricing configuration, compliance monitoring, and security hardening practices. Finally, automation skills are validated through deploying services with Supervisors, running Kubernetes workloads, using VM services, and integrating VCF Operations Orchestrator to support enterprise automation.
トピック 3
  • IT Architectures, Technologies, Standards: This section of the exam measures the understanding of IT Infrastructure Architects and covers foundational concepts of architectures, emerging technologies, and industry standards. Although no testable objectives are listed here, it establishes the baseline knowledge needed to interpret and design VMware-related environments effectively.
トピック 4
  • VMware vSphere Foundation Fundamentals: This section of the exam measures the skills of Virtualization Engineers and focuses on the essentials of virtualization technology. It introduces the principles of virtualization, explores use cases, and highlights the value it brings to businesses. Candidates are expected to demonstrate knowledge of VMware compute components such as vCenter and ESX, cluster configuration, and lifecycle management of virtual machines. It also covers secure workload operations, encryption, and managing resources with content libraries. In addition, storage fundamentals are examined through configuring vSphere storage, deploying VMware vSAN clusters, defining storage policies, and ensuring data availability. Networking fundamentals are also introduced, requiring the ability to differentiate between VMware vSphere networking components.
トピック 5
  • Plan and Design the VMware by Broadcom Solution: This section of the exam measures the ability of VMware Solution Architects to plan and design solutions. While there are no specific testable objectives included, the focus is on preparing professionals to design VMware-based solutions that align with organizational goals and best practices.
VMware 2V0-16.25 試験を最良のVMware 2V0-16.25試験過去問で簡単に学びましょう2V0-16.25の実際のテストは、さまざまな分野の多くの専門家によって設計され、顧客のさまざまな状況を考慮し、顧客が時間を節約できるように実用的な2V0-16.25学習教材を設計しました。 学生であろうとオフィスワーカーであろうと、2V0-16.25試験の準備にすべての時間を費やすことはないと思います。専門知識の勉強、家事、子供の世話などに取り組んでいます。 簡素化された情報により、効率的に学習することができます。 そして、あなたは事前に本当の試験を感じたいですか? 2V0-16.25試験問題を購入するだけです!
VMware vSphere Foundation 9.0 Administrator 認定 2V0-16.25 試験問題 (Q51-Q56):質問 # 51
An administrator has successfully deployed the VMware Cloud Foundation (VCF) Installer appliance to begin a new VMware vSphere Foundation (VVF) deployment. The VMware ESX hosts are powered on and meet all hardware and connectivity prerequisites.
What is the next step to begin deploying vSphere Foundation?
  • A. Manually deploy the vCenter Server Appliance.
  • B. Launch the VCF Installer deployment wizard.
  • C. Enable SSH on all ESX hosts.
  • D. Install SDDC Manager using the VCF Installer.
After successfully deploying theVCF Installer appliance, and ensuring ESXi hosts are powered on and meet prerequisites, thenext stepis to:
* Launch the VCF Installer deployment wizard, which guides administrators through host onboarding, vCenter deployment, and cluster setup forvSphere Foundation.
Other options:
* A. Enable SSH on all ESX hosts# Not required unless troubleshooting.
* C. Install SDDC Manager using VCF Installer# Only applies to full Cloud Foundation, not vSphere Foundation deployment.
* D. Manually deploy vCenter Server Appliance# The Installer wizard automates this.
VMware Cloud Foundation 9.0 -Using VCF Installer for vSphere Foundation VMware Docs: VCF Installer Deployment Workflow
質問 # 52
An administrator must configure identity access for VMware vSphere Foundation (VVF) to allow admin accounts from the enterprise Active Directory domain corp.local to log in using domain credentials. Security requires authentication to use the default Active Directory protocol, without federation.
Which configuration step is required to enable Active Directory users to authenticate to vCenter?
  • A. Configure a trusted identity provider using OpenID Connect (OIDC).
  • B. Add Active Directory over LDAP as an identity source.
  • C. Configure Identity Federation using SAML with corp.local.
  • D. Add the domain controller certificate to the Trusted Root store in vCenter.
To allowActive Directory domain users(corp.local) to authenticate in vCenter with domain credentials:
* The correct method is configuringActive Directory over LDAP as an identity source. (D)
* This uses thedefault AD protocol (LDAP/Kerberos)without requiring SAML or OIDC federation.
Other options:
* A. Adding domain controller certificate# Needed for LDAPS but not the main step.
* B. Identity Federation with SAML# Requires federation, not allowed per requirements.
* C. OpenID Connect (OIDC)# Used for external IdPs, not traditional AD auth.
VMware vSphere 9.0 -Configuring Active Directory Identity Sources
VMware Docs: Add AD over LDAP as Identity Source
質問 # 53
An administrator is tasked to configure shared storage for a VMware vSphere Foundation (VVF) cluster at a remote location.
The following is available at the remote location:
* Two ESX servers.
* Two 1GbE network cards per ESX.
* One sixteen port 1GbE Switch.
* One NVMe per ESX for the Operating System.
* One storage system supporting network and fiber channel capabilities.
What storage protocol must the administrator use at the remote location?
  • A. Local Storage
  • B. NFS
  • C. vSAN
  • D. Fiber Channel
The scenario:
* Remote sitewith 2 ESXi servers, 1GbE networking only.
* Storage system supports both network (NAS/iSCSI/NFS) and Fiber Channel.
* Fiber Channel is not feasible (no FC switches/HBAs).
* vSAN requires more than 2 nodes (minimum 3 for standard vSAN, 2+Witness for 2-node), not mentioned here.
The most suitable solution:
* UseNFS storage over 1GbE. (D)
* Provides shared storage accessible to both ESXi hosts.
Other options:
* A. vSAN# Needs 3+ nodes or a witness, not supported in this config.
* B. Local storage# Not shared, fails HA/DRS requirements.
* C. Fiber Channel# Requires HBAs and FC switch, not available.
VMware vSphere 9.0 -Supported Storage Protocols
VMware Docs: Using NFS with ESXi Hosts
質問 # 54
An administrator has been tasked to create a virtual machine (VM) into a VMware vCenter Supervisor Namespace in an existing VMware vSphere Foundation (VVF) deployment.
How would the administrator create the VM?
  • A. Log in to VCF Automation Service Broker and select the "Create a VM" catalog item.
  • B. Create a YAML file and deploy using kubectl.
  • C. Deploy using the vSphere Client.
  • D. Use VCF CLI to deploy the VM.
In aVMware vSphere Foundation (VVF) deploymentwithvCenter Supervisor Namespaces enabled, the method for creating VMs inside a Supervisor Namespace relies on thevSphere VM Service.
* TheVM Serviceexposes VMs as Kubernetes-native objects that are managed usingkubectl.
* Administrators (or DevOps engineers with appropriate permissions) must write aVM YAML manifest file, which specifies parameters such as apiVersion, kind: VirtualMachine, spec.imageName, spec.
className, spec.storageClass, and spec.networkInterfaces.
* The YAML manifest is thenapplied with kubectlto the Supervisor context.
This approach is documented as the supported method:
"As a DevOps engineer, provision a VM and its guest OS in a declarative manner by writing VM deployment specifications in a Kubernetes YAML file." Why the other options are incorrect:
* B. Deploy using the vSphere Client##The vSphere Client is used to configure Namespaces, permissions, and VM classes, butactual VM creation in Supervisor Namespaces is done via kubectl
+ YAML.
* C. Use VCF CLI to deploy the VM##VCF CLI (kubectl vsphere login) is used only to authenticate and obtain context, not to create VMs.
* D. Log in to VCF Automation Service Broker##This is used for vRealize Automation/Aria Automation integration, not for direct Supervisor Namespace VM creation.
VMware Cloud Foundation 9.0.4 Documentation -Deploy a Virtual Machine on a Namespace in a Supervisor VMware Cloud Foundation 9.0.4 Documentation -Prepare a VM YAML file for Supervisor VMware Docs: VM Service in vSphere with Tanzu
質問 # 55
In VMware Cloud Foundation (VCF) Operations, which node type is responsible for providing fault tolerance for administrative functions within the VCF Operations cluster?
  • A. Replica Node
  • B. Data Node
  • C. Primary Node
  • D. Witness Node
InVCF Operations (vRealize Operations) cluster architecture:
* ThePrimary Nodehandles administration and management.
* TheReplica Nodeprovidesfault tolerance for the Primary Node, ensuring that administrative functions remain available in case of failure.
* Data Nodeshandle data collection and analytics.
* Witness Node# Not a role in VCF Operations; relevant to vSAN clusters.
Thus, the node type providingfault tolerance for administrative functionsis theReplica Node.
VMware Cloud Foundation 9.0 -Operations Cluster Roles
VMware Docs: vROps Node Types
質問 # 56
安全かつ最も信頼性の高いVMware 2V0-16.25問題集販売サイトとして、我々はお客様の個人情報を内緒し、支払いの安全性を保証しています。だから、我々社のVMware 2V0-16.25問題集のさまざまなバージョンを安心に購買できます。弊社は量豊かのIT試験資料を所有するから、あなたは別のVMware 2V0-16.25試験に関心を寄せるなら、JPNTestでは需要したい資料を尋ねたり、弊社の職員に問い合わせたりしています。
2V0-16.25認定試験: https://www.jpntest.com/shiken/2V0-16.25-mondaishu
P.S.JPNTestがGoogle Driveで共有している無料の2026 VMware 2V0-16.25ダンプ:https://drive.google.com/open?id=1g0_HztgXT6_vwNNDLiPxokDwWbGDb1Bi
Posted at 1/28/2026 22:31:04        Only Author  2#
I really appreciate your article, it was so thought-provoking. Free 1Y0-204 new exam collection free to help you enhance your IT expertise. Best of luck on your exams!
Posted at 2/10/2026 23:35:12        Only Author  3#
Thank you for your article, it truly broadened my mind and vision. This Valid C11 exam topics set helped me earn a promotion and raise. Now, I’m offering it for free. Best of luck with your career success!
