Salesforce ADM-201ԇVADM-201T}
Posted at 1/21/2026 01:27:45
View273
Replies1
2026 NewDumpsµADM-201 PDF濼ԇ}ADM-201ԇ}ʹMhttps://drive.google.com/open?id=1FiUbJW3HbRvi2zgmbEUBT3yBZm0G6vfg
SalesforceADM-201ĿԇJCÿλITʿfǷdzҪģֻҪõ@JCһر̭K㌢н@ЩFĖ|㌢õҪһУfͨ^SalesforceADM-201ĿԇJC͵˳ɹ]e@ģҪһоdzɹıF֮һNewDumps SalesforceADM-201Ŀ}YゃɹԴȪ@ӖYϣֻӿゃɹIJゃɹĸţҲDZCゃɹa
Salesforce ADM-201JCԇ60x}105犃ɡԇļ֔65ԇMÞ200ԪԇṩӢZZZZķNZ汾һͨ^ԇͳɞSalesforceJCT@ǘIdzصYJCSalesforce쾚Ă˴_˱ICKչʾԓIЌIlչijZ
Salesforce ADM-201SalesforceJCTJCԇITИIйJĸ߶JɵJCҪɞSalesforceTĂˡԓJCC˂ڹúԶxSalesforce֪RͼܡԓԇּڜyԇxˌSalesforceƽ̨쾚̶ȣԡܺ
ܚgӭADM-201ԇVǰSalesforce Certified Administrator ADM-201ԇÜʂSalesforce ADM-201 }wµĿԇָϣ挍 ADM-201 ԇ}ӆ_ÿλͨ^ ADM-201 ԇڿԇ^׃}ˣMһĿ}գ˿ęADM-201 ԇm Salesforce gʿ_lĿǞ˜y춸Nƽ_OӋ_l֪RܡҪȡ ADM-201 JCҪЃ_lgI
µ Salesforce Certified Administrator ADM-201 Mԇ} (Q128-Q133):} #128
Cloud Kicks users are seeing error messages when they use one of their screen flows. The error messages are confusing but could be resolved if the users entered more information on the account before starting the flow.
How should the administrator address this issue?
- A. Uncheck the End User Flow Errors box in Setup.
- B. Remove validation rules so that the users are able to proceed without complete records.
- C. Create a permission set to allow users to bypass the error.
- D. Use a fault connector and display a screen with text explaining what went wrong and how to correct it.
𰸣D
} #129
When working on opportunities, sales representatives at Universal Containers need to understand how their peers have successfully managed other opportunities with comparable products, competing against the same competitors.
Which two features should an administrator use to facilitate this? (Choose two.)
- A. Big deal alerts
- B. Chatter groups
- C. Opportunity update reminders
- D. Opportunity Dashboard
𰸣C,D
} #130
Universal Container wants to prevent its service team from accessing deal records. While service users are unable to access deal list views, they are able to find the deal records via a search.
What options should the administrator adjust to fully restrict access?
- A. App permissions and search terms
- B. Record setting and search index
- C. Permissions and tab visibility
- D. Page layouts and field- level security
𰸣D
} #131
To enable Field History Tracking for an object, the system administrator must also add the related list to the page layout.
𰸣B
} #132
The administrator at Cloud Kicks has a Custom picklist field on Lead, Which is missing on the Contact when leads are converted.
Which two items should the administrator do to make sure these values are populated?
Choose 2 answers
- A. Update the picklist value with a validation rule.
- B. Map the picklist field on the Lead to the Contact.
- C. Create a custom picklist field on Contact.
- D. Set the picklist field to be required on the Lead Object.
𰸣B,C
}f
To make sure the custom picklist field values are populated on contact when leads are converted, you need to create a custom picklist field on contact and map it to the corresponding field on lead.
References: https://help.salesforce.com/s/ar ... ping.htm&type=5
https://help.salesforce.com/s/ar ... elds.htm&type=5
} #133
NewDumpslµADM-201JCԇиµĆ}𰸣_ԇɹͨ^҂ṩµPDFܛ汾Ć}ʹ𰸣ԱCADM-201ԇ100%ͨ^҂ľWվϣ@҂ṩSalesforce ADM-201MPDF汾DEMOԇãlF@^ֵهČWYϡړиʵSalesforce ADM-201}߀ڵʲôsdµ}Yρʂ俼ԇɣ
ADM-201T}: https://www.newdumpspdf.com/ADM-201-exam-new-dumps.html
- ADM-201CYӍ 🔀 ADM-201 🥺 ADM-201}d 🐒 Ո➤ [url]www.newdumpspdf.com ⮘WվMd▛ ADM-201 ▟}ADM-201ԇV[/url]
- ADM-201}b ✏ ADM-201ͨ^ԇ 🕣 ADM-201¿C 🦜 ▶ [url]www.newdumpspdf.com ◀WվdM☀ ADM-201 ️☀️}ռADM-201ͨ^ԇ[/url]
- ADM-201ԇV |ͨ^ʵĿԇ|ʴ_ADM-201T} 🧁 ➠ [url]www.vcesoft.com 🠰ь➠ ADM-201 🠰KMdADM-201}[/url]
- ADM-201ԇV |ͨ^ʵĿԇ|ʴ_ADM-201T} 😵 _Wվ▶ [url]www.newdumpspdf.com ◀{ ADM-201 }MdADM-201CYӍ[/url]
- ADM-201ԇVSalesforce Certified AdministratorҼͨ^ԇSalesforce ADM-201T} 🤒 ▛ [url]www.newdumpspdf.com ▟WվdM➥ ADM-201 🡄}ռADM-201ԇ[/url]
- |ADM-201ԇVYԇеIȲϹߺֵهSalesforce Salesforce Certified Administrator 🏸 { [url]www.newdumpspdf.com }ϵMd[ ADM-201 ]_ADM-201ԇ[/url]
- ADM-201} 🈵 ADM-201 🍆 ADM-201CYӍ 🍚 ⮆ [url]www.vcesoft.com ⮄ ADM-201 K@ȡMdADM-201TC[/url]
- |ADM-201ԇVYԇеIȲϹߺֵهSalesforce Salesforce Certified Administrator 🤝 _➽ [url]www.newdumpspdf.com 🢪K ADM-201 ԫ@ȡMdADM-201ͨ^ԇ[/url]
- ADM-201}b 🕖 ADM-201} 🐜 ADM-201 🕗 Md ADM-201 ֻM{ [url]www.kaoguti.com }WվADM-201yԇ[/url]
- ADM-201 🐳 ADM-201 💮 ADM-201}d 📉 ⇛ [url]www.newdumpspdf.com ⇚ь ADM-201 KMdADM-201yԇ[/url]
- ЧADM-201ԇV-¿ԇ}Ҽͨ^ԇADM-201Salesforce Certified Administrator 📻 Md✔ ADM-201 ️✔️ֻڡ [url]www.newdumpspdf.com ADM-201ָ[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, drnesmaelsersawy.com, www.stes.tyc.edu.tw, Disposable vapes
Google DriveMdµNewDumps ADM-201 PDF濼ԇ}죺https://drive.google.com/open?id=1FiUbJW3HbRvi2zgmbEUBT3yBZm0G6vfg
