[General] Useful Latest AP-219 DumpsCPass AP-219 First Attempt
93
General Useful Latest AP-219 DumpsCPass AP-219 First Attempt
Posted at 1/21/2026 01:49:13      View190 | Replies2        Print      Only Author   [Copy Link] 1#
If you want to be the talent the society actually needs you must apply your knowledge into the practical working and passing the test AP-219 certification can make you become the talent the society needs. If you buy our AP-219 study materials you will pass the exam successfully and realize your goal to be the talent. We have been in this career for over ten years and we have been the leader in the market. Our AP-219 Exam Question are always the latest and valid for you to pass the exam.
To want to pass Salesforce AP-219 certification test can't be done just depend on the exam related books. Instead of blindly studying relevant knowledge the exam demands, you can do some valuable questions. The efficient exam dumps is essential tool to prepare for AP-219 test. Come on and purchase TestPassKing Salesforce AP-219 Practice Test dumps. This braindump's hit accuracy is high and it works best the other way around. TestPassKing Salesforce AP-219 questions and answers are a rare material which can help you pass you exam first time.
Obtain Latest AP-219 Dumps PDF New VersionPeople always tend to neglect the great power of accumulation, thus the AP-219 study materials can not only benefit ones learning process but also help people develop a good habit of preventing delays. We have full confidence to ensure that you will have an enjoyable study experience with our AP-219 Study Materials, which are designed to arouse your interest and help you pass the exam more easily. You will have a better understanding after reading the following advantages.
Salesforce AP-219 Exam Syllabus Topics:
  • Data Model: Core objects (Order, Order Summary, Fulfillment Orders, Return Orders), B2C Commerce integrations, and tracing data flow including custom attributes.
  • User Experience and Customization: Customizing Lightning UI for different user roles using declarative tools like Lightning Page Editor and Report Builder.
  • Order Management Basics: Foundation of Order Management within Salesforce ecosystem, platform architecture, integration capabilities with third-party systems, and native Salesforce functionality.
  • Advanced Topics: Troubleshooting configuration issues, diagnosing system integration problems, and resolving deployment obstacles.
Topic 5
  • Process Automation and Integrations: Configuring end-to-end Order Management processes and external system integrations using declarative tools and clicks-based configuration.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q72-Q77):NEW QUESTION # 72
Which two APIs can an admin suggest so that customers can initiate order cancellations and returns from the B2C Commerce storefront and have their action carry out the cancel and returnoperations in Order Management?
  • A. Streaming APIs
  • B. REST APIs
  • C. Connect APIs
  • D. Bulk APIs
Two APIs that an admin can suggest so that customers can initiate order cancellations and returns from the B2C Commerce storefront and have theiraction carry out the cancel and return operations in Order Management are:
Connect APIs. These are RESTful APIs that expose resources in Order Management, such as orders, payments, shipments, etc. They allow customers to perform CRUD (create, read, update,delete) operations on these resources from external systems, such as B2C Commerce.
REST APIs. These are HTTP-based APIs that enable developers to access data in Order Management using standard HTTP methods, such as GET, POST, PUT, PATCH, and DELETE. Theyallow customers to interact with Order Management resources using JSON or XML formats.
Verified Reference: https://help.salesforce.com/s/ar ... _api.htm&type=5 https://help.salesforce.com/s/ar ... _api.htm&type=5
NEW QUESTION # 73
When can an Invoice be created?
  • A. At any point after the Fulfillment Order is created, by customizing flow "Create Invoice'
  • B. At any point before the Fulfillment Order is created, by customizing flow "Create invoice"
  • C. At anypoint before the Fulfillment Order is created, by customizing flow "Create Invoice and Ensure Funds"
  • D. At any point after the Fulfillment Order is created, by customizing flow 'Create Invoice and Ensure Funds*
The correct time and way for creating an Invoice is at any point after the Fulfillment Order is created, by customizing flow "Create Invoice". This flow is a core action that creates an Invoice record from a Fulfillment Order record, and updates the status of both records accordingly. The administrator can customize this flow to suit their business needs,such as adding conditions, actions, or subflows. Verified Reference:https://help.salesforce.com/s/ar ... oice.htm&type=5
NEW QUESTION # 74
Universal Containers (UC) has a flow which performs some custom logic in order todetermine a least-cost shipping location. Some of the variables should be reset at the beginning of each loop iteration. Which design element in Flow allows the Admin to do this?
  • A. Reset
  • B. Reassignment
  • C. Preset
  • D. Assignment
The designelement in Flow that allows the admin to reset some variables at the beginning of each loop iteration is Assignment. An Assignment element lets the admin assign new values to one or more variables or sObject fields in a flow. The admin can use an Assignment element before a Loop element to initialize the variables that are used in the loop, and then use another Assignment element inside the loop to reset the variables for each iteration. Verified Reference: https://help.salesforce.com/s/ar ... ment.htm&type=5[/url]
NEW QUESTION # 75
What two tools can an administrator use to debug an issue with an Apex trigger?
  • A. Apex Logs in Setup
  • B. Error Logs in the Developer Console
  • C. Debug Logs in Setup
  • D. Log Inspector in the Developer Console
The administrator can use two tools to debug an issue with an Apex trigger: Log Inspector in the Developer Console and Debug Logs in Setup. The Log Inspector is a tool that displays agraphical representation of a debug log, which is a record of database operations, system processes, and errors that occur when executing a transaction or running unit tests. The Log Inspector helps you analyze and troubleshoot your code by highlighting errors, checkpoints, and execution times. The Debug Logs page in Setup lets you monitor and retain debug logs for users, Apex classes, Apex triggers, and Lightning components. You can view, download, or delete debug logs from this page.
NEW QUESTION # 76
An administrator is attempting to automatically create process exceptions for the Fulfillment Order object. When does the Create Process Exception flow get triggered?
  • A. A Process Exception Event is fired
  • B. A Fulfillment Order or Order Summary object are modified and any modification meets the error criteria
  • C. On a daily basis using Schedule Jobs in Setup
NEW QUESTION # 77
The Salesforce Order Management Administrator Accredited Professional (AP-219) certification exam is one of the hottest and most industrial-recognized credentials that has been inspiring beginners and experienced professionals since its beginning. With the AP-219 certification exam successful candidates can gain a range of benefits which include career advancement, higher earning potential, industrial recognition of skills and job security, and more career personal and professional growth.
New AP-219 Exam Prep: https://www.testpassking.com/AP-219-exam-testking-pass.html
Posted at 1/22/2026 05:48:23        Only Author  2#
Im sincerely grateful for your article, it really stood out to me. Free Valid test DP-900 fee questions for everyone. Wishing you success in your exams!
Posted at 3/7/2026 09:24:32        Only Author  3#
VCESoftǂԞPITJCԇṩYϵľWվVCESoftԞṩµĿԇYԴxVCESoft԰ĵĜʂCompTIA 220-1201ԇ҂ӖϿԱC100%ͨ^CompTIA 220-1201JCԇ]ͨ^҂ȫ~˿KҕѸٵĸ¿ԇ}ʹ𰸣@׺DzܰlġVCESoftԞͨ^CompTIA 220-1201JCԇṩҲԞĹṩmȻкܶ෽Ԏ_@ЩĿģxVCESoftǵxVCESoftʹ㻨rg̽XفKҸаյͨ^ԇ҂߀ṩһMա
