[General] Top Vce ADA-C01 Format | Pass-Sure Relevant ADA-C01 Exam Dumps: SnowPro Advanced
101
【General】 Top Vce ADA-C01 Format | Pass-Sure Relevant ADA-C01 Exam Dumps: SnowPro Advanced
Posted at 1/21/2026 02:26:54      View:123 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Snowflake ADA-C01 dumps are available on Google Drive shared by PrepAwayTest: https://drive.google.com/open?id=1U6UTEwjBmGXDErQPma5vbnpjfUB23K94
Experts before starting the compilation of " the ADA-C01 latest questions ", has put all the contents of the knowledge point build a clear framework in mind, though it needs a long wait, but product experts and not give up, but always adhere to the effort, in the end, they finished all the compilation. So, you're lucky enough to meet our ADA-C01 Test Guide l, and it's all the work of the experts. If you want to pass the qualifying ADA-C01 exam with high quality, choose our ADA-C01 exam questions. We are absolutely responsible for you. Don't hesitate!
If you are going to purchase ADA-C01 Study Materials online, you may pay attention to your money safety. With applying the international recognition third party for the payment, your money and account safety can be guaranteed if you choose us. And the third party will protect your interests. In addition, ADA-C01 training materials are high-quality, for we have a professional team to research the latest information, and you can use them at ease. Besides if you have little time to prepare for your exam, you can also choose us, you just need to spend 48 to 72 hours on studying, you can pass the exam. Choose us, and you will never regret!
Free PDF Snowflake - ADA-C01 Perfect Vce FormatPrepAwayTest are supposed to help you pass the ADA-C01 exam smoothly. Don't worry about channels to the best ADA-C01 study materials so many exam candidates admire our generosity of offering help for them. Up to now, no one has ever challenged our leading position of this area. The existence of our ADA-C01 learning guide is regarded as in favor of your efficiency of passing the exam. Over time, our company is becoming increasingly obvious degree of helping the exam candidates with passing rate up to 98 to 100 percent. All our behaviors are aiming squarely at improving your chance of success on ADA-C01 Exam.
Snowflake SnowPro Advanced Administrator Sample Questions (Q19-Q24):NEW QUESTION # 19
A Snowflake account is configured with SCIM provisioning for user accounts and has bi-directional synchronization for user identities. An Administrator with access to SECURITYADMIN uses the Snowflake UI to create a user by issuing the following commands:
use role USERADMIN;
create or replace role DEVELOPER_ROLE;
create user PTORRES PASSWORD = 'hello world!' MUST_CHANGE_PASSWORD = FALSE default_role = DEVELOPER_ROLE; The new user named PTORRES successfully logs in, but sees a default role of PUBLIC in the web UI. When attempted, the following command fails:
use DEVELOPER_ROLE;
Why does this command fail?
  • A. USERADMIN needs to explicitly grant the DEVELOPER_ROLE to the new USER.
  • B. The new role can only take effect after USERADMIN has logged out.
  • C. The DEVELOPER_ROLE needs to be granted to SYSADMIN before user PTORRES will be able to use the role.
  • D. The new role will only take effect once the identity provider has synchronized by way of SCIM with the Snowflake account.
According to the Snowflake documentation1, creating a user with a default role does not automatically grant that role to the user. The user must be explicitly granted the role by the role owner or a higher-level role. Therefore, the USERADMIN role, which created the DEVELOPER_ROLE, needs to explicitly grant the DEVELOPER_ROLE to the new user PTORRES using the GRANT ROLE command. Otherwise, the user PTORRES will not be able to use the DEVELOPER_ROLE and will see the default role of PUBLIC in the web UI. Option A is incorrect because the DEVELOPER_ROLE does not need to be granted to SYSADMIN before user PTORRES can use the role. Option B is incorrect because the new role can take effect immediately after it is created and granted to the user, and does not depend on the USERADMIN role logging out. Option D is incorrect because the new role will not be affected by the identity provider synchronization, as it is created and managed in Snowflake.
NEW QUESTION # 20
A large international company with many operating regions requires data to be shared bi-directionally among all offices (head office to regional offices and regional offices among themselves). This company is a Snowflake account holder with European operations deployed in Microsoft Azure (single region) while North American regional offices are using AWS (single region) as their deployment cloud. This setup is required to comply with Personal Identifiable Information (PII) regulations in some of the European countries. The corporate head office is in Europe.
How can this data be shared bi-directionally, while MINIMIZING costs?
  • A. Move all the Snowflake accounts to a single region, and implement data sharing.
  • B. Use the PUT command to move files to an Amazon S3 bucket and Azure Blobs, and use an external file management application to move files within the corporate VPC.
  • C. Use bi-directional data sharing among offices in the same region and replication among offices across the continents.
  • D. Use data replication everywhere to reduce costs associated with same-region sharing.
According to the Snowflake documentation1, data sharing is a feature that allows sharing selected objects in a database in one account with other accounts in the same organization, without copying or transferring any data. Data sharing is supported across regions and across cloud platforms, but it requires enabling account database replication for both the source and target accounts2. Data replication is a feature that allows replicating objects from a source account to one or more target accounts in the same organization, providing read-only access for the replicated objects. Data replication is also supported across regions and across cloud platforms, but it incurs additional storage costs for the replicated data2. Therefore, the best way to share data bi-directionally among all offices, while minimizing costs, is to use data sharing among offices in the same region, which does not require replication or additional storage, and use replication among offices across the continents, which provides near real-time access to the shared data. Option A is incorrect because using data replication everywhere would increase the costs associated with additional storage and compute resources for the replicated data. Option B is incorrect because using the PUT command to move files to an Amazon S3 bucket and Azure Blobs, and using an external file management application to move files within the corporate VPC, would not leverage the benefits of Snowflake's data sharing and replication features, and would also incur additional costs and complexity for data transfer and synchronization. Option C is incorrect because moving all the Snowflake accounts to a single region would violate the PII regulations in some of the European countries, and would also incur additional costs and complexity for data migration and consolidation.
NEW QUESTION # 21
A Snowflake Administrator wants to create a virtual warehouse that supports several dashboards, issuing various queries on the same database.
For this warehouse, why should the Administrator consider setting AUTO_SUSPEND to 0 or NULL?
  • A. To keep the data cache warm to support good performance of similar queries
  • B. To save costs on warehouse shutdowns and startups for different queries
  • C. To save costs by running the warehouse as little as possible
  • D. To keep the query result cache warm for good performance on repeated queries
According to the Snowflake documentation1, the AUTO_SUSPEND property specifies the number of seconds of inactivity after which a warehouse is automatically suspended. If the property is set to 0 or NULL, the warehouse never suspends automatically. For a warehouse that supports several dashboards, issuing various queries on the same database, setting AUTO_SUSPEND to 0 or NULL can help to keep the data cache warm, which means that the data used by the queries is already loaded into the warehouse memory and does not need to be fetched from the storage layer. This can improve the performance of similar queries that access the same data. Option A is incorrect because setting AUTO_SUSPEND to 0 or NULL does not save costs on warehouse shutdowns and startups, but rather increases the costs by keeping the warehouse running continuously. Option B is incorrect because setting AUTO_SUSPEND to 0 or NULL does not run the warehouse as little as possible, but rather runs the warehouse as much as possible. Option D is incorrect because setting AUTO_SUSPEND to 0 or NULL does not affect the query result cache, which is a separate cache that stores the results of previous queries for a period of time. The query result cache is not dependent on the warehouse state, but on the query criteria2.
NEW QUESTION # 22
When a role is dropped, which role inherits ownership of objects owned by the dropped role?
  • A. The SECURITYADMIN role
  • B. The role above the dropped role in the RBAC hierarchy
  • C. The role executing the command
  • D. The SYSADMIN role
According to the Snowflake documentation1, when a role is dropped, ownership of all objects owned by the dropped role is transferred to the role that is directly above the dropped role in the role hierarchy. This is to ensure that there is always a single owner for each object in the system.
1: Drop Role | Snowflake Documentation
NEW QUESTION # 23
The ACCOUNTADMIN of Account 123 works with Snowflake Support to set up a Data Exchange. After the exchange is populated with listings from other Snowflake accounts, what roles in Account 123 are allowed to request and get data?
  • A. Any role with USAGE privilege on the Data Exchange
  • B. Any role that the listing provider has designated as authorized
  • C. Any role with IMPORT SHARE and CREATE DATABASE privileges
  • D. Only the ACCOUNTADMIN role, and no other roles
To request and get data from a Data Exchange, the role in Account 123 must have the USAGE privilege on the Data Exchange object. This privilege allows the role to view the listings and request access to the data.
According to the Snowflake documentation, "To view the listings in a data exchange, a role must have the USAGE privilege on the data exchange object. To request access to a listing, a role must have the USAGE privilege on the data exchange object and the IMPORT SHARE privilege on the account." The other options are either incorrect or not sufficient to request and get data from a Data Exchange. Option A is incorrect, as the ACCOUNTADMIN role is not the only role that can request and get data, as long as other roles have the necessary privileges. Option C is incorrect, as the IMPORT SHARE and CREATE DATABASE privileges are not required to request and get data, but only to create a database from a share after the access is granted.
Option D is incorrect, as the listing provider does not designate the authorized roles in Account 123, but only approves or denies the requests from Account 123.
NEW QUESTION # 24
Our ADA-C01 study questions are suitable for a variety of levels of users, no matter you are in a kind of cultural level, even if you only have high cultural level, you can find in our ADA-C01 training materials suitable for their own learning methods. So, for every user of our ADA-C01 Study Materials are a great opportunity, a variety of types to choose from, more and more students also choose our ADA-C01 test guide, then why are you hesitating? Just choose our SnowPro Advanced Administrator study questions!
Relevant ADA-C01 Exam Dumps: https://www.prepawaytest.com/Snowflake/ADA-C01-practice-exam-dumps.html
Snowflake Vce ADA-C01 Format Just think that you just need to spend certain money, you can obtain the certification, it’s quite cost-efficiency, Snowflake Vce ADA-C01 Format However, since competition for these high-paying jobs is intense, you need to prove what you need to work in the IT Express lane, Our Snowflake Relevant ADA-C01 Exam Dumps experts keep updating the dumps every day to ensure candidates get the latest information and dumps.
The Secondary Animation, PrepAwayTest ADA-C01 Dumps Download - SnowPro Advanced Administrator You can always extend the to update subscription time, so that you will get more time to fully prepare for the exam.
Just think that you just need to spend certain Reliable ADA-C01 Exam Materials money, you can obtain the certification, it’s quite cost-efficiency, However, since competition for these high-paying Vce ADA-C01 Format jobs is intense, you need to prove what you need to work in the IT Express lane.
SnowPro Advanced Administrator Free Valid Torrent & ADA-C01 Actual Practice Pdf & SnowPro Advanced Administrator Exam Training PdfOur Snowflake experts keep updating the dumps ADA-C01 every day to ensure candidates get the latest information and dumps, Now, many customers prefer online payment, Once you have submitted your practice time, ADA-C01 study tool system will automatically complete your operation.
P.S. Free & New ADA-C01 dumps are available on Google Drive shared by PrepAwayTest: https://drive.google.com/open?id=1U6UTEwjBmGXDErQPma5vbnpjfUB23K94
Posted at 2/8/2026 03:36:38        Only Author  2#
What a thought-provoking and inspiring read, thank you for sharing! Upgrade your IT skills with free Exam EX200 revision plan. Wishing you all the best!
