Hardware
ADM-201}bADM-201ԇ俼
Posted at 1/21/2026 05:24:57
View174
Replies0
⣬@ЩVCESoft ADM-201ԇ}IJփݬFMģhttps://drive.google.com/open?id=1du7E5UawaiPoiLWA6DOnDs557LZbwKT1
@˲ŝ˂Լ֪R_ߵˮʣLJҌ˵ITˆT߀ڲUHϸˡԺܶͨ^SalesforceADM-201ԇJCͨ^K¡䌍ֻҪゃxһõӖYȫͨ^ҲDzܣ҂VCESoft SalesforceADM-201ԇJCӖYȫ@ゃͨ^JCVCESoftWվӖYͨ^Sʹ^Ŀ`C˵ģڇHһֱbbIȣҪͨ^SalesforceADM-201ԇJC͌VCESoft SalesforceADM-201ԇJCӖYϼُ܇ɣ
ԓԇ60x}MɣҪ105犃ɡ@Щ}wcSalesforcePĸN}电ÑȫLԄӻ͈档ԓԇھMУκεطӡԓJCȫȵõJɣ߶ҕ
ɞ Salesforce JCTɞ_µICK띓һЃrֵYɎڸҵľ͘IЈÓf⣬߀mW͌IlչijZͨ^ Salesforce ADM-201 JCԇԳɞ Salesforce ^һTK@êYԴ;WjC
õADM-201}bģM挍ԇhcܛVCE汾ʵADM-201Salesforce Certified AdministratorôܸɵͨSalesforceADM-201֤㷢־㲻֪ôĻ㡣䌍ͨ^ԇķкܶNŬWԇҪеP֪RеһNF@@MrgKҺܿܵòAڵЧķңÿ춼æ춹]Nrgʂ俼ԇɣNԇһVCESoftADM-201}ɡ@YϽ^õ벻ijɹ
Salesforce ADM-201Salesforce JCTJCԇּڞϣչʾ Salesforce 팣I֪RČIʿOӋ@һȫJɵJCC Salesforce ƽ̨ψиN΄յ
µ Salesforce Certified Administrator ADM-201 Mԇ} (Q25-Q30):} #25
What is the maximum length of the field type "Text Encrypted"?
𰸣A
}f
Section: Volume J
} #26
An administrator created a record trigger flow to update contacts.
How should the administrator reference the values of the active record the flow is running on?
- A. Use the {!Contact.Id} global variable.
- B. Use the{!Account.Id} record variable.
- C. Use the $Record global variable.
- D. Use the Get Records element to find the Id.
𰸣C
} #27
Multiple Approvers have received your request for approving a discount that was invoked by the approval process? Approver A rejects your request. Approver B accepts your request after Approver A rejects it. Is your request approved or denied. (Assume you need only one person to approve out of all the approvers)
- A. Approval process is revoked
- B. Approved
- C. Denied
- D. Approval changes to pending stage due to conflict within approvers
𰸣C
} #28
Universal Containers (UC) has a queue that is used for managing tasks that need to be worked by the UC customer support team. The same team will now be working some of UC's Cases.
Which two options should the administrator use to help the support team?
Choose 2 answers
- A. Configure a flow to assign the cases to the queue.
- B. Add Cass to the existing queue as available object.
- C. Use assignment rules to set the queue as the owner of the case.
- D. Createa new queue and add Cases as an available object.
𰸣B,C
}f
Assignment rules and queue configuration are two options that should be used to help the support team work on some of UC's cases. Assignment rules can be used to automatically assign cases to a queue based on certain criteria, such as case origin or priority. Queue configuration can be used to add Case as an available object to the existing queue and specify which users or groups can access the queue. References: https://help.
salesforce.com/s/articleView?id=sf.case_assignment_rules.htm&type=5https://help.salesforce.com/s
/articleView?id=sf.customize_queues.htm&type=5
} #29
When setting up an user, the first name of the user is not required.
𰸣B
} #30
ADM-201ԇ俼: https://www.vcesoft.com/ADM-201-pdf.html
- ADM-201Y 🌁 ADM-201ԇ俼 🛂 ADM-201ԇָ 🥯 M▶ [url]www.testpdf.net ◀ь ADM-201 MdADM-201¿}[/url]
- ADM-201TC 🌐 ADM-201 PDF} 🍩 ADM-201Y 🆑 [url]www.newdumpspdf.com ϵMd▶ ADM-201 ◀_ADM-201TC[/url]
- ɿADM-201}b |ͨ^ʵĿԇ|ֵهADM-201Salesforce Certified Administrator 🎦 [ [url]www.kaoguti.com ]✔ ADM-201 ️✔️pȡMdADM-201}YԴ[/url]
- ADM-201 M}D-ͨ^ ADM-201 - Salesforce Certified Administrator JCԇ 📻 [url]www.newdumpspdf.com ь ADM-201 ԫ@ȡMdԇYADM-201}[/url]
- ADM-201}d 🧫 ADM-201}d 🔢 ADM-201} 🧤 { [url]www.pdfexamdumps.com } ADM-201 ԫ@ȡMdADM-201JCָ[/url]
- ͨ^ʸߵADM-201}b挍߀ԭSalesforce ADM-201ԇ 💅 { [url]www.newdumpspdf.com }⏩ ADM-201 ⏪pȡMdADM-201ԇc[/url]
- ɿADM-201}b |ͨ^ʵĿԇ|ֵهADM-201Salesforce Certified Administrator ❤️ M▷ [url]www.pdfexamdumps.com ◁ь➡ ADM-201 ️⬅️MdADM-201ԇV[/url]
- ЧADM-201}bYԇеIȹƽ_MPDF Salesforce Salesforce Certified Administrator 🍪 ڣ [url]www.newdumpspdf.com ь ADM-201 KMdADM-201ԇ俼[/url]
- ADM-201} 🧁 ADM-201} 🔟 ADM-201} 🧩 Md➽ ADM-201 🢪ֻM루 tw.fast2test.com WվADM-201¿}
- ͨ^ʸߵADM-201}b挍߀ԭSalesforce ADM-201ԇ 🔗 [url]www.newdumpspdf.com ǫ@ȡ➤ ADM-201 ⮘MdѾWվADM-201ԇc[/url]
- ADM-201}YӍ 🤦 ADM-201} 🏕 ADM-201¿} 🍗 M⇛ [url]www.kaoguti.com ⇚ь➽ ADM-201 🢪MdADM-201¿}[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
혱һ£ԏ녴惦dVCESoft ADM-201ԇ}棺https://drive.google.com/open?id=1du7E5UawaiPoiLWA6DOnDs557LZbwKT1
