[General] Quiz DOP-C02 - AWS Certified DevOps Engineer - Professional Useful Latest Test E
93
【General】 Quiz DOP-C02 - AWS Certified DevOps Engineer - Professional Useful Latest Test E
Posted at 1/21/2026 08:22:53      View:124 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of TestPDF DOP-C02 dumps for free: https://drive.google.com/open?id=1FnWeUbjQqV2UnosDPdBp6oGqKuyaMqQv
The Amazon DOP-C02 questions PDF questions are portable and printable, making it simple for you to prepare for the AWS Certified DevOps Engineer - Professional (DOP-C02) test in a short time. Smart devices such as smartphones, tablets, and laptops all support the Amazon DOP-C02 Exam PDF dumps format of our study material.
To be eligible for the Amazon DOP-C02 exam, candidates must have already earned the AWS Certified Developer - Associate or AWS Certified SysOps Administrator - Associate certification. They must also have at least two years of experience using AWS technologies for deploying and managing applications, as well as experience working with DevOps methodologies.
Amazon DOP-C02 (AWS Certified DevOps Engineer - Professional) certification exam is a highly sought after certification that validates the skills and knowledge required to manage and deploy applications on the AWS platform. AWS Certified DevOps Engineer - Professional certification is designed for DevOps engineers who have experience in developing, provisioning, operating and managing applications on the AWS platform. DOP-C02 Exam Tests the candidate's ability to design, deploy, manage, and maintain AWS-based applications using DevOps practices and principles.
DOP-C02 Practice Mock - Test DOP-C02 Cram PdfIn order to let you have a deep understanding of our DOP-C02 learning guide, our company designed the trial version for our customers. We will provide you with the trial version of our study materials before you buy our products. If you want to know our DOP-C02 training materials, you can download the trial version from the web page of our company. If you use the trial version of our DOP-C02 Study Materials, you will find that our products are very useful for you to pass your exam and get the certification. If you buy our DOP-C02 exam questions, we can promise that you will enjoy a discount.
Amazon AWS Certified DevOps Engineer - Professional Sample Questions (Q51-Q56):NEW QUESTION # 51
A DevOps engineer manages a web application that runs on Amazon EC2 instances behind an Application Load Balancer (ALB). The instances run in an EC2 Auto Scaling group across multiple Availability Zones.
The engineer needs to implement a deployment strategy that:
Launches a second fleet of instances with the same capacity as the original fleet.
Maintains the original fleet unchanged while the second fleet is launched.
Transitions traffic to the second fleet when the second fleet is fully deployed.
Terminates the original fleet automatically 1 hour after transition.
Which solution will satisfy these requirements?
  • A. Use an AWS CloudFormation template with a retention policy for the ALB set to 1 hour. Update the Amazon Route 53 record to reflect the new ALB.
  • B. Use AWS CodeDeploy with a deployment group configured with a blue/green deployment configuration Select the option Terminate the original instances in the deployment group with a waiting period of 1 hour.
  • C. Use AWS Elastic Beanstalk with the configuration set to Immutable. Create an .ebextension using the Resources key that sets the deletion policy of the ALB to 1 hour, and deploy the application.
  • D. Use two AWS Elastic Beanstalk environments to perform a blue/green deployment from the original environment to the new one. Create an application version lifecycle policy to terminate the original environment in 1 hour.
https://docs.aws.amazon.com/code ... minationOption.html The original revision termination settings are configured to wait 1 hour after traffic has been rerouted before terminating the blue task set.https://docs.aws.amazon.com/Amaz ... erguide/deployment- type-bluegreen.html
NEW QUESTION # 52
A development team is using AWS CodeCommit to version control application code and AWS CodePipeline to orchestrate software deployments. The team has decided to use a remote main branch as the trigger for the pipeline to integrate code changes. A developer has pushed code changes to the CodeCommit repository, but noticed that the pipeline had no reaction, even after 10 minutes.
Which of the following actions should be taken to troubleshoot this issue?
  • A. Check that the CodePipeline service role has permission to access the CodeCommit repository.
  • B. Check to see if the pipeline failed to start because of CodeCommit errors in Amazon CloudWatch Logs.
  • C. Check that the developer's IAM role has permission to push to the CodeCommit repository.
  • D. Check that an Amazon EventBridge rule has been created for the main branch to trigger the pipeline.
NEW QUESTION # 53
A company is storing 100 GB of log data in csv format in an Amazon S3 bucket SQL developers want to query this data and generate graphs to visualize it. The SQL developers also need an efficient automated way to store metadata from the csv file.
Which combination of steps will meet these requirements with the LEAST amount of effort? (Select THREE.)
  • A. Use the AWS Glue Data Catalog as the persistent metadata store.
  • B. Filter the data through Amazon QuickSight to visualize the data.
  • C. Fitter the data through AWS X-Ray to visualize the data.
  • D. Query the data with Amazon Redshift.
  • E. Use Amazon DynamoDB as the persistent metadata store.
  • F. Query the data with Amazon Athena.
Answer: A,B,F
https://docs.aws.amazon.com/glue ... nents-overview.html
NEW QUESTION # 54
A company has deployed an application in a production VPC in a single AWS account. The application is popular and is experiencing heavy usage. The company's security team wants to add additional security, such as AWS WAF, to the application deployment. However, the application's product manager is concerned about cost and does not want to approve the change unless the security team can prove that additional security is necessary.
The security team believes that some of the application's demand might come from users that have IP addresses that are on a deny list. The security team provides the deny list to a DevOps engineer. If any of the IP addresses on the deny list access the application, the security team wants to receive automated notification in near real time so that the security team can document that the application needs additional security. The DevOps engineer creates a VPC flow log for the production VPC.
Which set of additional steps should the DevOps engineer take to meet these requirements MOST cost- effectively?
  • A. Create an Amazon S3 bucket for log files. Configure the VPC flow log to capture accepted traffic and to send the data to the S3 bucket. Configure an Amazon OpenSearch Service cluster and domain for the log files. Create an AWS Lambda function to retrieve the logs from the S3 bucket, format the logs, and load the logs into the OpenSearch Service cluster. Schedule the Lambda function to run every 5 minutes. Configure an alert and condition in OpenSearch Service to send alerts to the security team through an Amazon Simple Notification Service (Amazon SNS) topic when access from the IP addresses on the deny list is detected.
  • B. Create a log group in Amazon CloudWatch Logs. Configure the VPC flow log to capture accepted traffic and to send the data to the log group. Create an Amazon CloudWatch metric filter for IP addresses on the deny list. Create a CloudWatch alarm with the metric filter as input. Set the period to 5 minutes and the datapoints to alarm to 1. Use an Amazon Simple Notification Service (Amazon SNS) topic to send alarm notices to the security team.
  • C. Create an Amazon S3 bucket for log files. Configure the VPC flow log to capture all traffic and to send the data to the S3 bucket. Configure Amazon Athena to return all log files in the S3 bucket for IP addresses on the deny list. Configure Amazon QuickSight to accept data from Athena and to publish the data as a dashboard that the security team can access. Create a threshold alert of 1 for successful access.
    Configure the alert to automatically notify the security team as frequently as possible when the alert threshold is met.
  • D. Create a log group in Amazon CloudWatch Logs. Create an Amazon S3 bucket to hold query results.
    Configure the VPC flow log to capture all traffic and to send the data to the log group. Deploy an Amazon Athena CloudWatch connector in AWS Lambda. Connect the connector to the log group.
    Configure Athena to periodically query for all accepted traffic from the IP addresses on the deny list and to store the results in the S3 bucket. Configure an S3 event notification to automatically notify the security team through an Amazon Simple Notification Service (Amazon SNS) topic when new objects are added to the S3 bucket.
NEW QUESTION # 55
A DevOps engineer is building an application that uses an AWS Lambda function to query an Amazon Aurora MySQL DB cluster. The Lambda function performs only read queries. Amazon EventBridge events invoke the Lambda function.
As more events invoke the Lambda function each second, the database's latency increases and the database's throughput decreases. The DevOps engineer needs to improve the performance of the application.
Which combination of steps will meet these requirements? (Select THREE.)
  • A. Implement the database connection opening outside the Lambda event handler code.
  • B. Connect to the proxy endpoint from the Lambda function.
  • C. Implement database connection pooling inside the Lambda code. Set a maximum number of connections on the database connection pool.
  • D. Use Amazon RDS Proxy to create a proxy. Connect the proxy to the Aurora cluster reader endpoint. Set a maximum connections percentage on the proxy.
  • E. Implement the database connection opening and closing inside the Lambda event handler code.
  • F. Connect to the Aurora cluster endpoint from the Lambda function.
Answer: A,B,D
Verified answer: A, C, and E.
Short Explanation: To improve the performance of the application, the DevOps engineer should use Amazon RDS Proxy, implement the database connection opening outside the Lambda event handler code, and connect to the proxy endpoint from the Lambda function.
* Amazon RDS Proxy is a fully managed, highly available database proxy for Amazon Relational Database Service (RDS) that makes applications more scalable, more resilient to database failures, and more secure1.By using AmazonRDS Proxy, the DevOps engineer can reduce the overhead of opening and closing connections to the database, which can improve latency and throughput2.
* The DevOps engineer should connect the proxy to the Aurora cluster reader endpoint, which allows read-only connections to one of the Aurora Replicas in the DB cluster3.This can help balance the load across multiple read replicas and improve performance for read-intensive workloads4.
* The DevOps engineer should implement the database connection opening outside the Lambda event handler code, which means using a global variable to store the database connection object5. This can enable connection reuse across multiple invocations of the Lambda function, which can reduce latency and improve performance.
* The DevOps engineer should connect to the proxy endpoint from the Lambda function, which is a unique URL that represents the proxy. This can allow the Lambda function to access the database through the proxy, which can provide benefits such as connection pooling, load balancing, failover handling, and enhanced security.
* The other options are incorrect because:
* Implementing database connection pooling inside the Lambda code is unnecessary and redundant when using Amazon RDS Proxy, which already provides connection pooling as a service.
* Implementing the database connection opening and closing inside the Lambda event handler code is inefficient and costly, as it can increase latency and consume more resources for each invocation of the Lambda function.
* Connecting to the Aurora cluster endpoint from the Lambda function is not optimal for read-only queries, as it can direct traffic to either the primary instance or one of the Aurora Replicas in the DB cluster. This can result in inconsistent performance and potential conflicts with write operations on the primary instance.
NEW QUESTION # 56
TestPDF Amazon DOP-C02 exam training materials are provided in PDF format and software format. It contains Amazon DOP-C02 exam questions and answers. These issues are perfect, Which can help you to be successful in the Amazon DOP-C02 Exam. TestPDF Amazon DOP-C02 exam comprehensively covers all syllabus and complex issues. The TestPDF Amazon DOP-C02 exam questions and answers is the real exam challenges, and help you change your mindset.
DOP-C02 Practice Mock: https://www.testpdf.com/DOP-C02-exam-braindumps.html
DOWNLOAD the newest TestPDF DOP-C02 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1FnWeUbjQqV2UnosDPdBp6oGqKuyaMqQv
