UiPath-ABAv1ソフトウエア嗤慎弔UiPath Certified Professional Automation Business Analyst
92
Posted at 1/21/2026 09:17:30      View143 | Replies2        Print      Only Author   [Copy Link] 1#
o創でクラウドストレ`ジから恷仟のCertJuken UiPath-ABAv1 PDFダンプをダウンロ`ドするhttps://drive.google.com/open?id=19avx50aX-r-p7LRWDfsUAUrHZbWjyGlK
UiPath-ABAv1庁Mテストは、シラバスの筝とUiPath尖とg樹の恷仟のM婢に鬉犬萄琉挌砲發T社によって個された互瞳|のu瞳であり、光僥伏が嶷勣なコンテンツの僥を頼阻することができるように醜泣をgってタ`ゲットをgっています 恷玉rgで。 UiPath-ABAv1トレ`ニング笋任蓮UiPath-ABAv1Yを鞭ける念に20〜30rgのをするだけでgみます。 匯圭、UiPath-ABAv1Yの|を聞喘すると、UiPath Certified Professional Automation Business Analyst Professional v1.0Yの醜泣が払われることを伉塘する駅勣はありません。
UiPath UiPath-ABAv1 J協Yの竃}譯
トピック竃}
トピック 1
  • Integration Service: This topic explains Integration Service, use of integration service connectors, triggers, and the Integration Service Connector Builder.
トピック 2
  • Excel Automation: It explains Excel Automation principles and modern Excel integration including reading, writing, and manipulating Excel files. Additionally, the topic focuses on the usage of the Excel Workbook activities.
トピック 3
  • Workflow Analyzer: This topic covers the use of Workflow Analysis, along with configuring Workflow Analyzer settings.
トピック 4
  • Working with Files and Folders: Creating, managing, and iterating through local files and folders are covered here.
トピック 5
  • Control Flow: Control Flow activities, workflow types, and Flowchart layouts are discussed here, along with the usage of IF, Flow Decision, Switch activities, While, Do While, and For Each.
トピック 6
  • Debugging: Debugging modes, actions, breakpoints, and debugging panels are explained in this topic, along with using Profile Execution features to improve project execution performance.
トピック 7
  • UI Automation: UI Automation principles, including modern and classic design experiences, are discussed alongside utilizing modern recorder and input
  • output activities.
トピック 8
  • PDF Automation: It discusses extracting data from native and scanned PDFs. Moreover, the topic focuses on different techniques for working with PDF documents.
トピック 9
  • Email Automation: Handling emails via IMAP, POP3, SMTP, and integrating with Microsoft and Gmail are covered in this section. It also discusses the usage of Microsoft 365 and Gsuite packages.
トピック 10
  • Variables and Arguments: This topic explores data types and how they're utilized, along with creating, managing, and using variables and arguments. It also addresses the differences between variables, arguments, global constants, and global variables.
トピック 11
  • Version Control Integration: It focuses on utilizing Git integration in Studio to add a project, clone a repository is explained, including common Git operations.
トピック 12
  • Business Knowledge: This topic focuses on understanding business process automation (BPA) and its value proposition, as well as exploring key concepts related to business processes.
UiPath-ABAv1議嶄栽鯉}鹿、UiPath-ABAv1J協デベロッパ`謹くのrgと坐Δ鬚かってUiPathのUiPath-ABAv1J協Yに栽鯉するを丹にすると旗わりCertJukenが戻工した}鹿を旋喘してわずか匯業お署かかって栽鯉するのは、あるでしょう。書の芙氏の嶄でrgがそんなに嶷勣で恷も隠嬾できるCertJukenをxばましょう。
UiPath Certified Professional Automation Business Analyst Professional v1.0 J協 UiPath-ABAv1 Y} (Q83-Q88):| # 83
Which of the following are one of the three features offered by UiPath Process Mining within the Automation Potential dashboard?
  • A. Automation Rate, Avg. number of events, FTE
  • B. Automation Rate, Manual Processing Time, Number of cases
  • C. Automation Rate, Manual Processing Time, FTE
  • D. Automation Rate, Total case value, FTE
屎盾C
盾h
Understanding UiPath Process Mining:
UiPath Process Mining analyzes data from IT systems to generate insights about automation opportunities. The Automation Potential dashboard provides metrics like Automation Rate, Manual Processing Time, and FTE savings to help identify and prioritize processes for automation.
Why Option A is Correct:
Automation Rate: Indicates the proportion of tasks that can be automated.
Manual Processing Time: Reflects the time spent on tasks manually, highlighting potential savings.
FTE (Full-Time Equivalent): Measures the labor effort involved, showing the potential for resource optimization.
Why Other Options Are Incorrect:
Option B: Average number of events is not a specific feature of the Automation Potential dashboard.
Option C: Total case value is unrelated to Process Mining features.
Option D: Number of cases is not a metric in the Automation Potential dashboard.
By focusing on these key features, UiPath Process Mining provides actionable insights into process efficiency and automation readiness.
| # 84
When starting a project with UiPath Process Mining, you can leverage already created applications to shorten the delivery time of a project. What are three out-of-the-box app templates available in UiPath Process Mining repository that you can deploy for a project?
  • A. Lead Management for Salesforce Pardot, Data Warehouse for SAP, Incident Management for ServiceNow
  • B. Purchase-to-Pay for SAP, Order-to-Cash for Oracle JDE, Lead-to-Order for Salesforce
  • C. Incident Management for Service Now, TemplateOne-SingleFile for any source system, Mortgage Loans for Oracle Cloud
  • D. Purchase-to-Pay for any source system, Warehouse Management for SAP, Mortgage Loans for Oracle Cloud
屎盾B
盾h
UiPath Process Mining provides a variety of out-of-the-box app templates that can be used as a starting point for creating process applications. These templates are designed to work with specific source systems and can be customized to fit business needs. The templates include a set of dashboards and KPIs to enable business users to monitor and analyze the processes in detail. The correct options from the given choices are:
*Purchase-to-Pay for SAP: This app template is designed for the SAP source system and can be extracted using Theobald Xtract Universal1.
*Order-to-Cash for Oracle JDE: This template is suitable for the Oracle JDE source system and uses CData Sync for data extraction1.
*Lead-to-Order for Salesforce: This app template is tailored for the Salesforce source system and also relies on CData Sync for data extraction1.
These templates are part of the process-specific app templates for specific source systems available in the UiPath Process Mining repository.
References: The information is verified as per the UiPath Process Mining documentation on app templates available at the UiPath Documentation Portal1.
| # 85
What is the purpose of an AS-IS diagram?
  • A. Maps out all the processes that must be automated
  • B. Maps how the process should look after standardization
  • C. Maps out the current state of a business process
  • D. Maps how the process should look after being automated
屎盾C
盾h
An AS-IS diagram is a visual representation that maps out the current state of a business process. It is used to document the existing process as it is currently performed, step by step, screen by screen, usually by a human operator. The AS-IS diagram is crucial for understanding the current workflow, identifying inefficiencies, bottlenecks, and areas for improvement. It serves as the baseline for any process automation or optimization efforts, including those undertaken with UiPath's Robotic Process Automation (RPA) tools12.
References: The explanation is based on the UiPath Community Forum discussions and the UiPath Documentation Portal's information on AS-IS and TO-BE processes in RPA implementation12.
| # 86
What is a key feature of Orchestrator?
  • A. Monitoring and managing UiPath Robots.
  • B. Monitoring and managing documents used for labeling.
  • C. Monitoring and managing attended automation processes.
  • D. Monitoring and managing UiPath automation workflows.
屎盾A
盾h
The UiPath Orchestrator is a central component in the UiPath platform with the following key features:
Robot Management: Orchestrator is primarily designed to monitor, manage, and control UiPath Robots in both attended and unattended modes. This includes:
Deployment and scheduling of automation processes.
Monitoring robot performance and health.
Centralized logging and auditing of robot activities.
Workflow Integration: While it interacts with workflows, its primary focus is managing the robots that execute those workflows (not managing workflows directly).
Enterprise Capabilities: It offers advanced features like queue management, process tracking, and analytics to ensure efficient operations of RPA implementations.
| # 87
What is the recommended way to extract data from an Invoice?
  • A. Using the Form Extractor
  • B. Using the ML Extractor with the Invoices out-of-the-box ML model
  • C. Using the RegEx extractor
  • D. Using FormsAI
屎盾B
盾h
The recommended way to extract data from an Invoice is using the ML Extractor with the Invoices out-of-the- box ML model. This approach utilizes machine learning to automatically identify and extract relevant data fields from invoices, which are typically structured but vary in format, enhancing accuracy and efficiency in data extraction.
UiPath Documentation on Document Understanding at https://docs.uipath.com/.
| # 88
UiPath^苧を函誼することは、あなたのキャリアにおける仇了を互める殆這らしく儻堀な圭隈です。 UiPath-ABAv1Yに栽鯉するというこの朕砲鰡_撹するには、翌何の屶址が駅勣です。益芙が偏で恷も繁櫃里△襯戰鵐制`であるため、このリンクをクリックすると侑\です。暴たちはこのキャリアに10定參貧亊わっており、UiPath-ABAv1Y}では、瑤UiPathJ協を誼るための屶址を鞭けるだけでなく、オンラインで匯送のサ`ビスをSしむことができます。
UiPath-ABAv1議嶄栽鯉}鹿: https://www.certjuken.com/UiPath-ABAv1-exam.html
BONUS。。 CertJuken UiPath-ABAv1ダンプの匯何をo創でダウンロ`ドhttps://drive.google.com/open?id=19avx50aX-r-p7LRWDfsUAUrHZbWjyGlK
Posted at 1/23/2026 21:36:06        Only Author  2#
What a remarkable article, thank you for your generous sharing. The Exam NCP-CN-6.10 questions answers test helped me reach new heights in my career, and I¨m now offering it to you for free!
Posted at 2/21/2026 05:06:59        Only Author  3#
Your article is brilliant beyond words, I¨m thankful for your share! The Latest exam collection AD0-E124 materials exam questions are available for free!unlock your promotion and salary increase!
