[Hardware] CPT最新試題 - CPT下載
93
【Hardware】 CPT最新試題 - CPT下載
Posted at 1/21/2026 09:20:10      View:168 | Replies:2        Print      Only Author   [Copy Link] 1#
從Google Drive中免費下載最新的NewDumps CPT PDF版考試題庫:https://drive.google.com/open?id=1ix6SQcRj8TUHfjJQ9wOEc022bJdxtuBc
如果你正準備參加 CPT 的考試,又苦於沒有精准的題庫或學習資料,NewDumps 絕對保證你第一次參加考試就可以順利通過。我們 CPT 認證考試的考題按照相同的教學大綱,其次是實際的 NASM 的 CPT 認證考試,另外也是不斷的升級我們的培訓資料,你得到的所有產品高達1年的免費更新,你也可以隨時延長更新訂閱時間,你將得到更多的時間來充分準備考試。
在如今人才濟濟的社會中,NASM專業人士是很受歡迎的,但競爭也很大。所以很多NASM專業人士通過一些比較難的權威的CPT認證考試來穩固自己,而我們NewDumps是專門為參加CPT認證考試的考生提供便利的。
CPT最新試題考題全覆蓋 – 高通過率的NASM NASM Certified Personal Trainer Exam我相信不論在哪個行業工作的人都希望自己有很好的職業前景。當然在競爭激烈的IT行業裏面也不例外。在IT行業中工作的專業人士也希望自己有個很好的提升機會和很大的提升空間。很多專業的IT人士都知道NASM CPT 認證考試可以幫你滿足這些願望的。而NewDumps是一個能幫助你成功通過NASM CPT 的網站。
最新的 Personal Trainer CPT 免費考試真題 (Q64-Q69):問題 #64
The NFPT-recommended recovery heart rate for a client with a size/strength goal is
  • A. 100 beats per minute (BPM)
  • B. 125 BPM
  • C. 115 BPM
  • D. 140 BPM
答案:B
問題 #65
Which of the following is one of the four P's of a marketing plan?
  • A. Product
  • B. Performance
  • C. Payroll
  • D. Profession
答案:A
解題說明:
The Four P's of marketing-Product, Price, Promotion, and Place-are a foundational business concept emphasized in the NASM CPT7 Study Guide. NASM states: "The Four Ps of marketing include product, price, promotion, and place". In a personal training context, the "product" refers to the actual service or program offered-such as private sessions, group training, or online coaching-and the value it brings to the client. It's the core of the marketing message because it defines what you're selling. The other Ps address cost (price), awareness (promotion), and delivery method/location (place). The options profession, performance, and payroll are not part of this established framework. Thus, "Product" is the correct choice.
問題 #66
Which of the following is included in lipids?
  • A. Glycine
  • B. Amino acids
  • C. Triglycerides
  • D. Polysaccharides
答案:C
解題說明:
Lipids-commonly referred to as fats-include triglycerides, phospholipids, and sterols. The NASM Study Guide specifies: "Lipids are commonly referred to as fats and include triglycerides, phospholipids, and sterols." Triglycerides are the primary form of fat stored in the body and a major energy reserve, especially for prolonged, lower-intensity activity. Each triglyceride molecule consists of glycerol bound to three fatty acids. In contrast, glycine and amino acids are protein components, and polysaccharides are complex carbohydrates (e.g., starches). Lipids are energy dense (9 kcal/gram) and serve not only as a long-term energy source but also play roles in cell membrane integrity, hormone production, and nutrient absorption. Including triglycerides in the definition of lipids aligns directly with NASM's nutritional science section.
問題 #67
When a client performs a rotation chest pass, what is the proper position for the pivoting back leg?
  • A. Hyperextension
  • B. Dorsiflexion
  • C. Triple flexion
  • D. Triple extension
答案:D
解題說明:
A rotation chest pass in a power training context uses a pivot of the back leg to generate rotational force.
Proper mechanics require triple extension-simultaneous extension at the hip, knee, and ankle-to produce maximum power from the lower body through the kinetic chain. This extension helps transfer force from the ground through the core to the upper body and into the throw. NASM emphasizes that triple extension is critical in movements involving force generation like sprints, jumps, and rotational throws. Triple flexion is the opposite movement (hip, knee, ankle flexion) and occurs during load absorption phases.
問題 #68
When working with a client in stabilization endurance training, which of the following exercises is appropriate?
  • A. Seated dumbbell shoulder press
  • B. Barbell squat
  • C. Single-leg squat to row
  • D. Seated two-arm dumbbell biceps curls
答案:C
解題說明:
In Phase 1: Stabilization Endurance Training, exercises should challenge balance, core stability, and muscular endurance. NASM categorizes the single-leg squat to row as an integrated stabilization exercise because it combines a balance challenge (single-leg stance) with an upper body pulling movement, requiring total-body coordination and postural control. By contrast, a seated dumbbell shoulder press or seated biceps curl eliminates stability demands by providing a fixed base, and a barbell squat is more of a strength-level movement. The stabilization phase often uses unstable environments (like balance pads, single-leg positions, or stability balls) to train the body's ability to control motion under load-exactly what the single-leg squat to row accomplishes.
問題 #69
言與行的距離到底有多遠?關鍵看人心,倘使心神明淨,意志堅強,則近在咫尺,垂手可及 。我想你應該就是這樣的人吧。既然選擇了要通過NASM的CPT認證考試,當然就得必須通過,NewDumps NASM的CPT考試培訓資料是幫助通過考試的最佳選擇,也是表現你意志堅強的一種方式,NewDumps網站提供的培訓資料在互聯網上那是獨一無二的品質好,如果你想要通過NASM的CPT考試認證,就購買NewDumps NASM的CPT考試培訓資料。
CPT下載: https://www.newdumpspdf.com/CPT-exam-new-dumps.html
因為我們可以提供領先的培訓技術幫助考生輕松通過 CPT下載 - NASM Certified Personal Trainer Exam 認證考試,這就說明NewDumps CPT下載提供的針對性培訓資料是很有效的,我們知道你的需求,我們將幫助得到 NASM 的 CPT 最新題庫考試認證的信心,讓你可以安然無憂的去參加考試,並順利通過獲得認證,NASM的NASM Certified Personal Trainer Exam - CPT考試題庫學習資料有兩個不同版本的以方便你的使用:PDF版的CPT考古題方便你的閱讀,為你真實地再現考試題目,NewDumps會為你的NASM CPT認證考試提供很好的培訓工具,有效的幫助你通過NASM CPT認證考試,NASM CPT最新試題 其實想要通過考試是有竅門的。
紐約時報的文章提供了一些示例,頗為精妙的補藥是既補氣又壯體,而頗為陰邪的毒藥則CPT是既損內在又傷肉身,因為我們可以提供領先的培訓技術幫助考生輕松通過 NASM Certified Personal Trainer Exam 認證考試,這就說明NewDumps提供的針對性培訓資料是很有效的。
最新免費的 CPT 考試題庫-免費下載試用體驗 CPT 考題我們知道你的需求,我們將幫助得到 NASM 的 CPT 最新題庫考試認證的信心,讓你可以安然無憂的去參加考試,並順利通過獲得認證,NASM的NASM Certified Personal Trainer Exam - CPT考試題庫學習資料有兩個不同版本的以方便你的使用:PDF版的CPT考古題方便你的閱讀,為你真實地再現考試題目;
NewDumps會為你的NASM CPT認證考試提供很好的培訓工具,有效的幫助你通過NASM CPT認證考試。
順便提一下,可以從雲存儲中下載NewDumps CPT考試題庫的完整版:https://drive.google.com/open?id=1ix6SQcRj8TUHfjJQ9wOEc022bJdxtuBc
Posted at 1/25/2026 16:10:53        Only Author  2#
This article is a masterpiece in its own right, thank you for sharing. I got promoted and earned a raise using this HPE1-H03 valid practice questions book. Now it’s available for free. Best of luck with your promotions!
Posted at 2/9/2026 17:13:26        Only Author  3#
This article is absolutely marvelous, thank you for sharing it with us. 305-300 latest study guide free exam questions are available for free—good luck to everyone!
