[General] AVIXA CTS-I Simulations Pdf | CTS-I Reliable Mock Test
92
【General】 AVIXA CTS-I Simulations Pdf | CTS-I Reliable Mock Test
Posted at 1/21/2026 09:33:15      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that LatestCram CTS-I dumps now are free: https://drive.google.com/open?id=1xdNk7Bv1KO59g2VZmHWmw7dQ4uRIMI-z
We provide all candidates with CTS-I test torrent that is compiled by experts who have good knowledge of exam, and they are very experience in compile CTS-I study materials. Once we have latest version, we will send it to your mailbox as soon as possible. our CTS-I exam questions just need students to spend 20 to 30 hours practicing can let them have the confidence to pass the CTS-I Exam, so little time great convenience for some workers. It must be your best tool to pass your CTS-I exam and achieve your target.
AVIXA CTS-I - Installation Exam Syllabus Topics:
TopicWeight
Duty A: Conducting Pre-Installation Activities20%
Task 1: Review Audiovisual Project Documentation4%
Task 2: Conduct Technical Site Survey4%
Task 3: Prepare for Audiovisual Installation4%
Task 4: Evaluate Overall Facility Readiness4%
Task 5: Conduct On-Site Preparations for Installation4%
Duty B: Conducting Site Rough-In/First-Fix10%
Task 1: Deinstallation of Existing Equipment and cabling2%
Task 2: Mount Substructure4%
Task 3: Pull Cable4%
Duty C: Installing Audiovisual Systems38%
Task 1: Assemble AV Rack4%
Task 2: Wire the AV Equipment Rack5%
Task 3: Distribute AV Equipment4%
Task 4: Mount AV Equipment4%
Task 5: Terminate Cables5%
Task 6: Configure Network Properties of Equipment4%
Task 7: Load Configuration and Control Programs4%
Task 8: Test the AV System4%
Task 9: Calibrate the AV System4%
Duty D: Perform Systems Close Out11%
Task 1: Demonstrate to Client or Client's Representative that System Performs to Specifications4%
Task 2rovide Training on System Operation4%
Task 3:Obtain Project Completion Sign Off from Client or Client's Representative3%
Duty E: Conducting Ongoing Project Responsibilities21%
Task 1: Complete Progress Reports3%
Task 2: Coordinate with Other Contractors4%
Task 3: Address Needed Field Modifications4%
AVIXA CTS-I Exam Certification Details:
Sample QuestionsAVIXA CTS-I Sample Questions
Duration150 mins
MemberExam Price$475(USD)
Passing Score350 / 500
Exam NameAVIXA Certified Technology Specialist - Installation (CTS-I)
Number of Questions110
CTS-I Reliable Mock Test, Latest Test CTS-I ExperienceIf you want to get a desirable opposition and then achieve your career dream, you are a right place now. Our CTS-I study tool can help you pass the exam. So, don't be hesitate, choose the CTS-I test torrent and believe in us. Let's strive to our dreams together. Life is short for us, so we all should cherish our life. Our CTS-I Guide Torrent can help you to save your valuable time and let you have enough time to do other things you want to do. Just buy our CTS-I exam questions, then you will pass the CTS-I exam easily.
AVIXA Certified Technology Specialist - Installation Sample Questions (Q434-Q439):NEW QUESTION # 434
When mounting equipment to a concrete substructure, which fastener is the most likely to be used?
Response:
  • A. Self tapping screw
  • B. Molly Bolt/hollow wall anchor
  • C. Drop in Anchor
  • D. Toggle Bolt/Spring Toggle
NEW QUESTION # 435
Attenuation occurs when the signal level is _________.
  • A. Faulty
  • B. Increased
  • C. 0 V
  • D. Decreased
NEW QUESTION # 436
What assumptions should you make about an audio system when there is no audio output?
(Choose all that apply.)
Response:
  • A. The user is a complete idiot and did not switch the microphone on.
  • B. Make no assumptions at all and select a troubleshooting strategy
  • C. The mixing desk channel for the microphone is switched to line input mode.
  • D. The gain on the main audio amplifier may be wound down to zero
NEW QUESTION # 437
What should you be aware of when installing an electric front-projection screen?
Select all that apply.
Response:
  • A. In a return-air plenum ceiling, local codes apply.
  • B. Some motorized screens have a motor inside the housing.
  • C. Keeping it horizontal when stored or transported.
  • D. Manufacturer's specification for setting physical switches.
Answer: A,B,C,D
NEW QUESTION # 438
For an ethernet cable (UTP) to meet certification standards, the maximum length is
  • A. 98' or 30m
  • B. 984' or 300m
  • C. 328' or 100m
  • D. 492' or 150m
NEW QUESTION # 439
We can claim that prepared with our CTS-I study materials for 20 to 30 hours, you can easy pass the CTS-I exam and get your expected score. Also we offer free demos of our CTS-I exam questions for you to check out the validity and precise of our CTS-I Training Materials. Just come and have a try! You will be surprised to find the high accuracy of our CTS-I training material. And as our high pass rate of CTS-I practice braindump is 99% to 100%, you will pass the exam easily.
CTS-I Reliable Mock Test: https://www.latestcram.com/CTS-I-exam-cram-questions.html
