[General] Buy CWNP CWNA-109 TestPassKing Exam Questions Today Save Time and Money
95
General Buy CWNP CWNA-109 TestPassKing Exam Questions Today Save Time and Money
Posted at 1/21/2026 09:57:03      View163 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest TestPassKing CWNA-109 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1gpu34EvE2fLf4HNk1_HtTeaYWz4tifAY
Memorizing these CWNP Wireless Network Administrator (CWNA) CWNA-109 valid dumps will help you easily attempt the CWNP CWNA-109 exam within the allocated time. Thousands of aspirants have passed their CWNP CWNA-109 Exam, and they all got help from our CWNP Wireless Network Administrator (CWNA) CWNA-109 updated exam dumps. For successful preparation, you can also rely on CWNA-109 real questions.
Though our CWNA-109 training guide is proved to have high pass rate, but If you try our CWNA-109 exam questions but fail in the final exam, we can refund the fees in full only if you provide us with a transcript or other proof that you failed the exam. We believe that our business will last only if we treat our customers with sincerity and considerate service. So, please give the CWNA-109 Study Materials a chance to help you.
Best Way to Prepare For CWNP CWNA-109 Certification ExamOur company always lays great emphasis on service. All of our works have good sense of service. Once you browser our website and select the CWNA-109 exam questions, we have arrange all study materials separately and logically. You will know the details if you click the CWNA-109 practice quiz. You will find that it is easy, fast and convenient. And if you have something confused on our CWNA-109 learning braindumps, then you can contact with our service online or send email to us. We will help you in the first time.
CWNP Wireless Network Administrator (CWNA) Sample Questions (Q80-Q85):NEW QUESTION # 80
You are installing an AP to be used by 27 laptops. All laptops will connect on the 5 GHz frequency band. A neighbor network uses channels 1 and 6. What channel should be used for this AP and why?
  • A. Channel 11, because channels 1 and 6 are in use nearby
  • B. A 5 GHz channel, because channels 1 and 6 are 2.4 GHz channels they have no impact on the decision
  • C. Channel 1, because it is best to use the channel with the lowest frequency
  • D. Channel 6, because it is always best to use this channel
A 5 GHz channel should be used for this AP because channels 1 and 6 are 2.4 GHz channels and they have no impact on the decision. The 5 GHz frequency band offers more non-overlapping channels than the 2.4 GHz frequency band, which reduces interference and improves performance. The 5 GHz frequency band also supports higher data rates and wider channel bandwidths than the 2.4 GHz frequency band, which increases capacity and throughput. The 5 GHz frequency band also has less interference from other devices and sources than the 2.4 GHz frequency band, which enhances reliability and quality of service. Therefore, it is recommended to use the 5 GHz frequency band for WLANs whenever possible. Channels 1 and 6 are two of the three non-overlapping channels in the 2.4 GHz frequency band (the other one is channel 11). They are used by a neighbor network in this scenario, but they do not affect the channel selection for this AP because they operate in a different frequency band than the 5 GHz frequency band. Channel 6 is not always best to use; it depends on the interference and congestion level in the environment. Channel 1 is not best to use because it has a lower frequency than channel 6; frequency does not determine channel quality or performance. Channel 11 is not best to use because it is also a 2.4 GHz channel and it may interfere with channels 1 and 6. References: CWNA-109 Study Guide, Chapter 4: Antenna Systems and Radio Frequency (RF) Components, page 113
NEW QUESTION # 81
Your manager asked you to locate a solution that allows for centralized monitoring of WLAN performance over time. He wants a single pane of glass for administration and monitoring of the solution. What do you recommend?
  • A. Laptop-based spectrum analyzers
  • B. Laptop-based protocol analyzers
  • C. Overlay WLAN monitoring solution
  • D. AP-based spectrum analysis
The solution that you recommend is an Overlay WLAN monitoring solution. An Overlay WLAN monitoring solution is a system that uses dedicated sensors or probes to monitor the WLAN performance over time. The sensors are deployed throughout the WLAN coverage area and collect data on various metrics such as signal strength, noise level, channel utilization, interference, throughput, latency, packet loss, and QoS. The sensors send the data to a centralized server or appliance that analyzes the data and provides a single pane of glass for administration and monitoring of the solution. An Overlay WLAN monitoring solution can help to detect and troubleshoot WLAN issues, optimize WLAN performance, and generate reports and alerts. References: [CWNP Certified Wireless Network Administrator Official Study Guide:
ExamCWNA-109], page 538; [CWNA: Certified Wireless Network Administrator Official Study Guide:
ExamCWNA-109], page 508.
NEW QUESTION # 82
As an RF wave propagates through space, the wave front experiences natural expansion that reduces its signal strength in an area. What describes the rate at which this expansion happens?
  • A. Inverse square law
  • B. Ohm's law
  • C. Fresnel zone thinning
  • D. MU-MIMO
The inverse square law states that the signal strength of an RF wave is inversely proportional to the square of the distance from the source. This means that as the distance from the transmitter increases, the signal strength decreases rapidly.
References: Wireless Network Administrator Official Study Guide, Chapter 3, page 64.
NEW QUESTION # 83
What facts are true regarding controllers and APs in a Split MAC architecture?
  • A. An IP tunnel is established between the AP and controller for AP management and control functions.
  • B. Management and data frame types must be processed locally by the AP, while control frame types must be sent to the controller.
  • C. Using centralized data forwarding, APs never tag Ethernet frames with VLAN identifiers or 802.1p CoS.
  • D. With 802.1X/EAP security, the AP acts as the supplicant and the controller acts as the authenticator.
The fact that is true regarding controllers and APs in a Split MAC architecture is that an IP tunnel is established between the AP and controller for AP management and control functions. A Split MAC architecture is a WLAN architecture where some of the MAC layer functions are performed by the APs (such as encryption, decryption, and frame acknowledgement) and some are performed by the controllers (such as authentication, association, roaming, and QoS). To communicate with each other, the APs and controllers establish an IP tunnel that carries the management and control frames between them. The IP tunnel can use protocols such as Lightweight Access Point Protocol (LWAPP) or Control And Provisioning of Wireless Access Points (CAPWAP). References: [CWNP Certified Wireless Network Administrator Official Study Guide: ExamCWNA-109], page 372; [CWNA: Certified Wireless Network Administrator Official Study Guide: ExamCWNA-109], page 362.
NEW QUESTION # 84
What can cause excessive VSWR in RF cables used to connect a radio to an antenna?
  • A. High gain parabolic dish antenna
  • B. High gain yagi antenna
  • C. Impedance mismatch
  • D. Radio output power above 100 mW but below 400 mw
Impedance is the measure of opposition to the flow of alternating current (AC) in a circuit. Impedance mismatch occurs when the impedance of the radio does not match the impedance of the antenna or the cable.
This causes some of the transmitted or received signal to be reflected back, resulting in a loss of power and efficiency. The voltage standing wave ratio (VSWR) is a metric that indicates the amount of impedance mismatch in a transmission line. A higher VSWR means a higher impedance mismatch and a lower signal quality. A VSWR of 1:1 is ideal, meaning there is no impedance mismatch and no reflected power. A VSWR of 2:1 means that for every 2 units of forward power, there is 1 unit of reflected power12.
The other options are not correct because they do not affect the VSWR in RF cables. A high gain yagi antenna or a high gain parabolic dish antenna can increase the signal strength and directionality, but they do not cause impedance mismatch in the cable. Radio output power above 100 mW but below 400 mW is within the acceptable range for most WLAN devices and does not cause excessive VSWR in the cable3.: 1: CWNA-109 Official Study Guide, page 77 2: VSWR 3: CWNA-109 Official Study Guide, page 81
NEW QUESTION # 85
After cracking the CWNP Wireless Network Administrator (CWNA) (CWNA-109) exam you will receive the credential badge. It will pave your way toward well-paying jobs or promotions in any reputed tech company. At TestPassKing have customizable CWNP Wireless Network Administrator (CWNA) (CWNA-109) practice exams for the students to review and improve their preparation. The CWNP Wireless Network Administrator (CWNA) (CWNA-109) practice test material product of TestPassKing are created by experts with the dedication to help customers crack the CWNP Wireless Network Administrator (CWNA) (CWNA-109) exam on the first attempt.
CWNA-109 PDF VCE: https://www.testpassking.com/CWNA-109-exam-testking-pass.html
What Testing Engine does TestPassKing CWNA-109 PDF VCE provide, CWNP Valid CWNA-109 Test Guide Learning is a cumulative process, whereas passing an exam is not exactly the same thing, So your chance of getting success will be increased greatly by our CWNA-109 exam questions, TestPassKing CWNA-109 Exam Features Quality and Value for the CWNP CWNA-109 Exam TestPassKing Practice Exams for CWNP CWNA-109 are written by capable and expert IT researchers so that the exam material is up to the mark, CWNP Valid CWNA-109 Test Guide They are PDF Software and App versions.
Avoiding Death March Projects, Consider your career goals and your CWNA-109 experience: Maybe there is another organization that will recognize your value, What Testing Engine does TestPassKing provide?
CWNP CWNA-109 Dumps PDF - Pass Exam Immediately (2026)Learning is a cumulative process, whereas passing an exam is not exactly the same thing, So your chance of getting success will be increased greatly by our CWNA-109 exam questions!
TestPassKing CWNA-109 Exam Features Quality and Value for the CWNP CWNA-109 Exam TestPassKing Practice Exams for CWNP CWNA-109 are written by capable and expert IT researchers so that the exam material is up to the mark.
2026 Latest TestPassKing CWNA-109 PDF Dumps and CWNA-109 Exam Engine Free Share: https://drive.google.com/open?id=1gpu34EvE2fLf4HNk1_HtTeaYWz4tifAY
