[General] Pass Guaranteed Oracle - Newest Valid Braindumps 1z0-1046-24 Book
107
【General】 Pass Guaranteed Oracle - Newest Valid Braindumps 1z0-1046-24 Book
Posted at 1/21/2026 15:45:15      View:141 | Replies:3        Print      Only Author   [Copy Link] 1#
2026 Latest ValidDumps 1z0-1046-24 PDF Dumps and 1z0-1046-24 Exam Engine Free Share: https://drive.google.com/open?id=10pL0l2zxu0Ik8MRzTwmq4A8bso8IqIOm
The Platform Oracle Global Human Resources Cloud 2024 Implementation Professional 1z0-1046-24 Exam credential makes it simple to renew your skills and knowledge to keep up with the latest trends. The Platform Oracle Global Human Resources Cloud 2024 Implementation Professional 1z0-1046-24 exam certification is a worthwhile, internationally accepted industry credential. You can become a recognized specialist in addition to learning new technological needs and honing your abilities.
In order to let you have a deep understanding of our 1z0-1046-24 learning guide, our company designed the free demos for our customers. We will provide you with free demos of our study materials before you buy our products. If you want to know our 1z0-1046-24 training materials, you can download them from the web page of our company. If you use the free demos of our 1z0-1046-24 study engine, you will find that our products are very useful for you to pass your 1z0-1046-24 exam and get the certification.
Valid Braindumps 1z0-1046-24 Book Will Be Your Trusted Partner to Pass Oracle Global Human Resources Cloud 2024 Implementation ProfessionalMore and more people look forward to getting the 1z0-1046-24 certification by taking an exam. However, the exam is very difficult for a lot of people. Especially if you do not choose the correct study materials and find a suitable way, it will be more difficult for you to pass the exam and get the 1z0-1046-24 related certification. If you want to get the related certification in an efficient method, please choose the 1z0-1046-24 study materials from our company.
Oracle Global Human Resources Cloud 2024 Implementation Professional Sample Questions (Q157-Q162):NEW QUESTION # 157
Geography framework in HCM Cloud is used for the following purpose:
  • A. To display the geographies of a given country accessible through a lookup value versus entering each geography in a free form field
  • B. To determine the address fields that display on a page when entering an address
  • C. To define all work locations for your organization
Full Detailed in Depth Explanation:
The Geography framework in Oracle HCM Cloud is designed to standardize and streamline the management of geographical data. Its primary purpose is to provide a structured, validated list of geographies (e.g., countries, states, cities) accessible via lookup values, rather than allowing free-form text entry, which reduces errors and ensures consistency. Option B (determining address fields) relates to address styles, not the geography framework itself. Option C (defining work locations) is a downstream use of geographies but not the framework's primary purpose. According to the Oracle HCM Cloud "Geographies Setup" documentation, the framework's key role is to enable lookup-based geography selection, makingAthe correct answer.
NEW QUESTION # 158
A Human Resource Specialist is hiring a new employee in the application. While creating the employee record, he enters personal information and employment details and, when submitting the transaction, encounters an error. Part of the error message reads: "NewPersonEmploymentApproval to NewPersonEmploymentApproval Rules NewPersonRuleSet failed with Business Fault: null. Check the underlying fault. Check target SOA component for cause." The Human Resource Specialist raises a service request with the internal support team. What is the cause of this error?
  • A. The Update Person Keyword Search process must be run before hiring a person.
  • B. The Human Resource Specialist does not have the required privilege for the New Person Employment process.
  • C. A security profile needs to be defined for the Human Resource Specialist to hire a person.
  • D. The BPM task NewPersonEmploymentApproval is not set up properly.
Full Detailed In-Depth Explanation:
The error message indicates a failure in the approval process during the "New Person Employment" transaction, pointing to an issue with the BPM (Business Process Management) workflow rather than security or pre-process requirements.
Option A: Security profiles control data visibility, not approval process execution. Thiswouldn't cause a BPM fault.
Option B: Correct. The error references "NewPersonEmploymentApproval," a BPM task. A "Business Fault:
null" suggests a misconfiguration in the approval ruleset (e.g., missing approver, invalid rule) within BPM Worklist, preventing the transaction from completing.
Option C: Lack of privilege would typically block access to the hire action entirely, not trigger a mid-process BPM fault.
Option D: The "Update Person Keyword Search" process enhances search functionality but is unrelated to hiring approvals.
The correct answer isB, as detailed in "Implementing Global Human Resources" under Approval Configuration.
NEW QUESTION # 159
Your customer has confirmed that their organization needs Job Codes to be autogenerated for the Job creation task.
As an implementation consultant, how do you achieve this?
  • A. This configuration option is not currently available; an enhancement request needs to be submitted to Oracle.
  • B. On the Enterprise HCM Information task, select either of the Automatic options in the Job Code Generation Method field.
  • C. On the Job task, as you create a Job, select Automatic Upon Final Save in the Job Code Generation Method field.
The customer requires job codes to be autogenerated during the job creation task in Oracle Global Human Resources Cloud. Job codes uniquely identify jobs (e.g., "ENG001" for an Engineer role) and are typically entered manually or configured with specific rules. The question asks how to achieve autogeneration of job codes as an implementation consultant.
* Option A: On the Enterprise HCM Information task, select either of the Automatic options in the Job Code Generation Method field.This option is incorrect. TheEnterprise HCM Informationtask is used to configure enterprise-level settings, such as name, location, and employment model defaults, but Oracle documentation does not list aJob Code Generation Methodfield or any automatic options for job code generation within this task. While other codes (e.g., person numbers or position codes) can be autogenerated in specific tasks, job codes are not supported for autogeneration at the enterprise level, making this option invalid.
* Option B: On the Job task, as you create a Job, select Automatic Upon Final Save in the Job Code Generation Method field.This option is incorrect. In theManage Jobstask, when creating a job, fields likeJob Code,Name,Family, andSetare available, but there is noJob Code Generation Methodfield or anAutomatic Upon Final Saveoption. Oracle requires users to manually enter job codes or use predefined values, and no standard functionality supports automatic job code generation during job creation, as confirmed by documentation.
* Option C: This configuration option is not currently available; an enhancement request needs to be submitted to Oracle.This is the correct answer. Oracle Global Human Resources Cloud does not currently offer a built-in feature to autogenerate job codes during job creation. Job codes must bemanually specified in theManage Jobstask or imported via HCM Data Loader with predefined values. For example, creating a job like "Software Engineer" requires entering a code like "SE001" manually. If the customer requires autogeneration (e.g., sequential codes like JOB001, JOB002), this would necessitate custom development or a product enhancement. Oracle's Idea Lab or support portal allows customers to submit enhancement requests for new features, making this the appropriate solution.
* Why this answer?Oracle's job management functionality is robust but lacks native support for autogenerating job codes, unlike other entities (e.g., person numbers or requisition numbers). The absence of this feature in theManage Jobs,Enterprise HCM Information, or related tasks, as per 24C and 25A documentation, confirms that an enhancement request is the only path to meet the customer's need.
References
* Oracle Global Human Resources Cloud: Implementing Global Human Resources, Document ID:
docs.oracle.com, Published: 2023-12-12
* Section: Manage Jobs: "You create jobs using the Manage Jobs task. Specify a job code, name, and other attributes manually."
* Section: Enterprise HCM Information: "Configure enterprise settings, but no options exist for job code generation."
* Oracle Global Human Resources Cloud: Using Global Human Resources, Document ID: docs.
oracle.com, Published: 2024-07-02
* Section: Job Creation: "Job codes are unique identifiers for jobs and must be provided during job creation."
* Oracle Fusion Cloud Human Resources 24C What's New, Document ID: docs.oracle.com, Published: 2024-08-27
* Section: Workforce Structures: "No mention of job code autogeneration; focus on job attributes and Redwood UI."
* Oracle Support Portal, Document ID: docs.oracle.com
* Section: Enhancement Requests: "Customers can submit enhancement requests via My Oracle Support or Idea Lab for missing functionality."
NEW QUESTION # 160
As part of a client's configuration requirements, they have indicated that they want to create divisions by Line of Business in HCM Cloud. After creating them, in which two ways can you associate workers with a specific division?
  • A. Division is a delivered field on a position. If you are using Positions, when you associate a worker with a position, they will be associated with the division tied to that position.
  • B. You configure and deploy an assignment descriptive flexfield that has a table value set that references the Division object. When you complete a worker's assignment, you select the appropriate division through that flexfield segment.
  • C. Division is a delivered field on the worker assignment. Therefore, when a worker is hired, the correct division would be selected by the user entering the information.
  • D. You have configured an Organization Tree, listing the hierarchy of your Legal Entities, Divisions, Business Units, and Departments. You associate a worker with a department that falls within a division to associate the worker with that division.
Divisions in Oracle HCM Cloud are organizational units often aligned with lines of business. Associating workers with divisions requires leveraging existing structures or custom fields.
Option B ("You configure and deploy an assignment descriptive flexfield that has a table value set that references the Division object"): True. A Descriptive Flexfield (DFF) on the assignment can be configured with a value set linked to the Division object, allowing manual selection during assignment updates, as per the
"Implementing Global Human Resources" guide.
Option D ("You have configured an Organization Tree, listing the hierarchy of your Legal Entities, Divisions, Business Units, and Departments"): True. By associating a worker with a department within a division via the organization hierarchy, the worker is indirectly linked to that division, a standard practice in workforce structures.
Option A ("Division is a delivered field on a position"): False. Position has fields like Department, but Division is not a standard delivered field.
Option C ("Division is a delivered field on the worker assignment"): False. Assignment includes fields like Department, not Division directly.
NEW QUESTION # 161
When creating a checklist task, you must assign a task performer. What values are supported?
  • A. Worker, Manager, Initiator, Area of Responsibility
  • B. Worker, Manager, Initiator, User, Area of Responsibility
  • C. Worker, Manager, Initiator, User, HR Specialist Data Role
  • D. Worker, Manager, Initiator, User, Area of Responsibility, HR Specialist Job Role
When configuring checklist tasks in Oracle Global Human Resources Cloud, a task performer must be assigned to indicate who is responsible for completing the task. The "Using Global Human Resources" guide under "Checklists" specifies the supported performer types as: Worker (the individual the checklist pertains to), Manager (the worker's line manager), Initiator (the person who triggered the checklist), User (a specific named user), and Area of Responsibility (a group defined by responsibility criteria, such as HR representatives). Option A lists all five supported values accurately. Option B adds "HR Specialist Job Role," which is not a directly supported performer type for checklists (job roles are used in security, not task assignment). Option C omits "User," and Option D incorrectly includes "HR Specialist Data Role" instead of
"Area of Responsibility." Thus, A is the correct answer.
NEW QUESTION # 162
The time and energy are all very important for the office workers. In order to get the 1z0-1046-24 certification with the less time and energy investment, you need a useful and valid Oracle study material for your preparation. 1z0-1046-24 free download pdf will be the right material you find. The comprehensive contents of 1z0-1046-24 practice torrent can satisfied your needs and help you solve the problem in the actual test easily. Now, choose our 1z0-1046-24 study practice, you will get high scores.
Training 1z0-1046-24 Solutions: https://www.validdumps.top/1z0-1046-24-exam-torrent.html
Our 1z0-1046-24 practice pdf dump is compiled according to the original exam questions and will give you the best valid study experience, It is really the greatest choice that choosing our Training 1z0-1046-24 Solutions latest study notes as your partner on the path of learning, After decades of hard work, our products are currently in a leading position in the same kind of education market, our 1z0-1046-24 learning materials, with their excellent quality and constantly improved operating system, In many areas won the unanimous endorsement of many international customers, Oracle Valid Braindumps 1z0-1046-24 Book You can practice the real test questions and answers before the test.
The New Customer Contract: Authenticity, Relevance, Valid Braindumps 1z0-1046-24 Book and Transparency, In this chapter: → Adding Users to Your Chromebook, Our 1z0-1046-24 practice pdf dump is compiled according 1z0-1046-24 to the original exam questions and will give you the best valid study experience.
1z0-1046-24 Exam Braindumps & 1z0-1046-24 Exam Simulation & 1z0-1046-24 Reliable Questions and AnswersIt is really the greatest choice that choosing our Oracle Global Human Resources Cloud latest study Valid Braindumps 1z0-1046-24 Book notes as your partner on the path of learning, After decades of hard work, our products are currently in a leading position in the same kind of education market, our 1z0-1046-24 learning materials, with their excellent quality and constantly improved operating system, In many areas won the unanimous endorsement of many international customers.
You can practice the real test questions and answers before the Valid Braindumps 1z0-1046-24 Book test, The 24/7 support system is there for the students to assist them in the right way and solve their real issues quickly.
BTW, DOWNLOAD part of ValidDumps 1z0-1046-24 dumps from Cloud Storage: https://drive.google.com/open?id=10pL0l2zxu0Ik8MRzTwmq4A8bso8IqIOm
Posted at 1/24/2026 05:51:18        Only Author  2#
Thank you for sharing this inspiring article with us! Wishing everyone the best of luck—free JS-Dev-101 test dump materials available now!
Posted at 2/17/2026 06:26:35        Only Author  3#
No delay, just liking this awesome content. Free Latest CHFM test prep materials—unlock promotions and higher salary potential!
Posted at 2/19/2026 01:39:31        Only Author  4#
This article is excellent, I truly appreciate you sharing it with us. Free NSE5_SSE_AD-7.6 valid test questions answers exam papers to help you prepare. Best of luck to all!
