PT-AM-CPE Interactive Practice Exam | PT-AM-CPE Lab Questions
Posted at 1/21/2026 16:19:13      View:90 | Replies:2        Print      Only Author   [Copy Link] 1#
Just as an old saying goes, it is better to gain a skill than to be rich. Contemporarily, competence far outweighs family backgrounds and academic degrees. One of the significant factors to judge whether one is competent or not is his or her PT-AM-CPE certificates. Generally speaking, PT-AM-CPE certificates function as the fundamental requirement when a company needs to increase manpower in its start-up stage. In this respect, our PT-AM-CPE practice materials can satisfy your demands if you are now in preparation for a PT-AM-CPE certificate.
In an increasingly competitive social life, we should keep up with the unpredictable world, regain our knowledge, and pursue decent work and a higher standard of living. If you have a PT-AM-CPE certificate, you will gain more competitive advantage and differentiate yourself from other job seekers. In this respect, PT-AM-CPE Study Guide is obviously your best choice. PT-AM-CPE certification training ' main advantage contains saving you a lot of time and improving your learning efficiency.
Free PDF Quiz 2026 High-quality PT-AM-CPE: Certified Professional - PingAM Exam Interactive Practice ExamOur PT-AM-CPE preparation materials can have such good reputation and benefit from their own quality. You really can't find a more cost-effective product than PT-AM-CPE learning quiz! Our company wants more people to be able to use our products. We also hope that our products are really worth buying. Therefore, the quality of PT-AM-CPE training engine is absolutely leading in the industry. And you can free download the demos of the PT-AM-CPE study guide to check it out.
Ping Identity Certified Professional - PingAM Exam Sample Questions (Q84-Q89):NEW QUESTION # 84
During the PingAM startup process, what is the location and name of the file that the PingAM bootstrap process uses to connect to the configuration Directory Services repository?
  • A. /path/to/tomcat/<tomcat-instance-dir>/webapps/<am-instance-dir>/boot.json
  • B. <user-home-dir>/.openam/config/boot.json
  • C. <user-home-dir>/<am-instance-dir>/config/boot.json
  • D. <user-home>/<am-instance-dir>/boot.json
In PingAM 8.0.2, especially when utilizing File-Based Configuration (FBC), the startup sequence relies on a "bootstrap" phase to locate the system's configuration. According to the "Installation Guide" and "Configuration Directory Structure," the primary file involved in this process is named boot.json.
The boot.json file contains the essential connection details required for the AM binaries to find and unlock the configuration store (usually PingDS). This includes the LDAP host, port, bind DN, and references to the secret stores needed to decrypt the configuration.
The location of this file is determined by the Configuration Directory path specified during the initial setup. By default, PingAM creates its configuration directory in the home directory of the user running the web container. The standard path structure is <user-home>/<am-instance-dir>/. Therefore, the boot.json file is located at the root of this instance directory: <user-home>/<am-instance-dir>/boot.json.
Options A and D are incorrect because they place the file inside a /config subdirectory; while AM has many config files in subdirectories, the boot.json sits at the root to be accessible as the first point of entry.
Option B is incorrect because it suggests the file is stored within the Tomcat webapps folder. PingAM specifically avoids storing configuration data within the web application binaries to ensure that configuration persists even if the .war file is deleted or redeployed.
Understanding the location of boot.json is vital for DevOps engineers who need to automate the deployment of PingAM using tools like Amster or when troubleshooting a "Failed to connect to the configuration store" error during server startup.
NEW QUESTION # 85
A customer wishes to customize the OpenID Connect (OIDC) id_token JSON Web Token (JWT) to include the subject's employee number. Which of the following scripts should be customized to meet this requirement?
  • A. OIDC JWT script
  • B. OIDC attributes script
  • C. OIDC claims script
  • D. OIDC parameters script
In PingAM 8.0.2, the OpenID Connect (OIDC) Claims Script is the specific extensibility point designed to govern how user information is mapped and transformed into claims within an OIDC ID token or the UserInfo response. While PingAM supports standard scopes like profile and email out of the box, specialized business requirements-such as including an "employee number" which might be stored as employeenumber in an LDAP directory-require a custom transformation.
According to the "OIDC Claims Script" reference in the PingAM documentation:
The script acts as a bridge between the Identity Store (the source of truth) and the OIDC Provider (the issuer). When a client requests a token, PingAM executes this script, providing it with a claimObjects map and the userProfile. The developer can then write Groovy or JavaScript logic to retrieve the employeeNumber attribute from the user's profile and add it to the resulting claims set.
The script typically follows this logical flow:
Identify the requested claims from the OIDC scope.
Fetch the corresponding raw attributes from the Identity Store (e.g., PingDS or AD).
Format and name the claim as per the OIDC specification or the specific client requirement (e.g., mapping LDAP employeenumber to OIDC claim emp_id).
Return the claims to be signed and embedded into the JWT.
Why other options are incorrect: Options A, C, and D reference script types that do not exist under those specific names in the standard PingAM 8.0.2 scripting engine. While there are "Access Token Modification" scripts and "Client Registration" scripts, the OIDC Claims Script is the only one authorized and designed to manage the payload of the id_token.
NEW QUESTION # 86
To protect against cross-site request forgery attacks, a default PingAM installation requires that some requests, such as POST requests, include:
  • A. X-OpenAM-Password header
  • B. If-Match: _rev header
  • C. X-OpenAM-Username header
  • D. X-Requested-With or Accept-API-Version header
Cross-Site Request Forgery (CSRF) is an attack where a malicious site sends a request to PingAM using the victim's authenticated browser session. Because standard HTML forms and cross-site requests cannot easily set custom HTTP headers, requiring a specific header is an effective defense for REST APIs.
According to the PingAM "Security" documentation and the "REST API" reference:
By default, PingAM 8.0.2 enforces a CSRF filter on its REST endpoints (such as /json/authenticate or /json/users). For any "state-changing" request (like a POST, PUT, or DELETE), the client must prove the request is intentional and not a forged browser-driven request. This is achieved by requiring at least one of the following headers:
X-Requested-With: Commonly used by AJAX libraries like jQuery. Its presence indicates the request was made via a script, which is generally not possible for a standard cross-site CSRF attack.
Accept-API-Version: This header serves two purposes. First, it ensures the client is targeting a specific version of the PingAM REST API (e.g., resource=2.0, protocol=1.0). Second, since custom headers cannot be set in simple cross-site <form> submissions, it acts as a CSRF token.
If a POST request is sent to the REST API without one of these headers, PingAM will reject the request with a 403 Forbidden error, even if the user has a valid session cookie.
Option B (If-Match: _rev) is used for concurrency control (preventing "lost updates" in IDM or AM configuration), but it is not the primary CSRF defense. Options A and D are headers sometimes used for "Zero-Page Login" or legacy authentication, but they do not provide protection against CSRF for the general REST API. Therefore, the combination of X-Requested-With or Accept-API-Version is the correct answer for default CSRF protection in PingAM 8.0.2.
NEW QUESTION # 87
An OpenID Connect application makes a request for an ID token with the openid and profile scope. Which set of claim attributes are available with the profile scope?
  • A. given_name, family_name, preferred_locale, name
  • B. givenname, family_name, locale, name
  • C. given_name, family_name, locale, name
  • D. givenName, familyName, preferredLocale, name
PingAM 8.0.2 adheres to the OpenID Connect Core 1.0 specification regarding standard scopes and claims. When a client requests the profile scope, the OpenID Provider (PingAM) is expected to return a specific set of claims that describe the user's basic profile.
According to the PingAM documentation on "Understanding OpenID Connect Scopes and Claims" and the default OIDC Claims Script (which maps internal LDAP attributes to OIDC claims):
The standard claims associated with the profile scope are strictly defined with lowercase, snake_case naming conventions. The default set includes:
name: The user's full name.
given_name: The user's first name.
family_name: The user's surname or last name.
middle_name: (Optional)
nickname: (Optional)
preferred_username: (Optional)
profile: URL to the profile page.
picture: URL to an image.
website: URL.
gender: (Optional)
birthdate: (Optional)
zoneinfo: Timezone.
locale: The user's preferred language/locale.
updated_at: Timestamp.
Option C is the only choice that correctly identifies the snake_case format (given_name, family_name, locale) required by the specification. Options A and B use camelCase or inconsistent naming that does not match the OIDC standard or PingAM's default mapping script. Option D includes preferred_locale, which is incorrect; the standard claim name for a user's language preference in OIDC is simply locale.
NEW QUESTION # 88
What is the purpose of HTTP-only cookies?
  • A. Cookies can only be transmitted over HTTP
  • B. Cookies can not be read by the server
  • C. Cookies can not be read by client-side scripts
  • D. Cookies can only be transmitted over HTTPS
In the "Additional Cookie Security" section of the PingAM 8.0.2 documentation, HttpOnly is described as a critical security attribute for session cookies (like iPlanetDirectoryPro). Its primary purpose is to mitigate the risk of session hijacking via Cross-Site Scripting (XSS) attacks.
When a cookie is marked with the HttpOnly flag, the browser is instructed to restrict access to that cookie. Specifically, it prevents client-side scripts-such as those written in JavaScript-from accessing the cookie through the document.cookie API. If an attacker successfully injects a malicious script into a page, the script will be unable to "read" the session token, even though the cookie is still automatically sent by the browser with every valid HTTP request to the server.
Option B describes the Secure flag, which ensures cookies are only sent over encrypted (HTTPS) connections.
Option C is incorrect because the server must be able to read the cookie to validate the user's session.
Option D is a common misconception; the HttpOnly flag does not restrict the transport to "HTTP-only" (non-secure) protocols; rather, it restricts the access method within the browser environment.
By default, PingAM 8.0.2 enables the HttpOnly flag for all session cookies. This is considered a best practice in modern identity management because it ensures that even if a web application has a vulnerability that allows for script injection, the user's primary authentication token remains protected from being exfiltrated by the attacker's script.
NEW QUESTION # 89
In order to ensure the quality of our PT-AM-CPE preparation materials, we specially invited experienced team of experts to write them. The content of our PT-AM-CPE practice engine comes from a careful analysis and summary of previous exam syllabus, so that you can accurately grasp the core test sites. At the same time, our proffesional experts are keeping a close eye on the changes of the exam questions and answers. So that our PT-AM-CPE Study Guide can be the latest and most accurate.
PT-AM-CPE Lab Questions: https://www.lead1pass.com/Ping-Identity/PT-AM-CPE-practice-exam-dumps.html
Ping Identity PT-AM-CPE Interactive Practice Exam Are you tired of working overtime, Compared with other vendors, you will find the prices of PT-AM-CPE exam dumps on Lead1Pass are reasonable and worthy, You can rest assured that using our PT-AM-CPE pdf exam training materials, Ping Identity PT-AM-CPE Interactive Practice Exam Just come and buy them, It copies the exact pattern and style of the real Ping Identity PT-AM-CPE exam to make your preparation productive and relevant.
This simultaneity may be truly concurrent execution on PT-AM-CPE separate cores, or simply the effectively concurrent form caused by time-sliced execution on the same core.
But within ten years, elementaryschool kids were producing PT-AM-CPE Interactive Practice Exam documents that looked better than some of the textbooks I used in college, Are you tired of working overtime?
The Best PT-AM-CPE Interactive Practice Exam & Authoritative PT-AM-CPE Lab Questions Ensure You a High Passing RateCompared with other vendors, you will find the prices of PT-AM-CPE Exam Dumps on Lead1Pass are reasonable and worthy, You can rest assured that using our PT-AM-CPE pdf exam training materials.
Posted at 2/7/2026 02:37:25        Only Author  2#
This article has given me a new understanding of this field, and it’s truly inspiring. Thanks to the Cuttin g-edge CCMP resources program, I secured a promotion and salary increase. It’s available for free now. Wishing you all quick promotions!
Posted at 2/16/2026 18:18:17        Only Author  3#
This article is a real treasure, thank you for sharing it with us. Here’s the C-BCBAI-2509 new test collection materials test that contributed to my career advancement and salary raise. It's open to everyone today at no cost. May you reach your career goals soon!
