[General] 400-007 Valid Exam Questions - Valid 400-007 Learning Materials
100
【General】 400-007 Valid Exam Questions - Valid 400-007 Learning Materials
Posted at 1/21/2026 17:38:14      View:135 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of SurePassExams 400-007 dumps for free: https://drive.google.com/open?id=1eIZt_0l1YG2FzfaPFyQ6brsvqFlWvwUz
Our 400-007 prep torrent will provide customers with three versions: PDF,soft and APP versions, each of them has its own advantages. Now I am going to introduce you the PDF version of 400-007 test braindumps. It is well known to us that the PDF version is very convenient and practical. The PDF version of our 400-007 Test Braindumps provide demo for customers. At the same time, if you use the PDF version, you can print our 400-007 exam torrent by the PDF version; it will be very easy for you to take notes. I believe our 400-007 test braindumps will bring you great convenience.
Cisco 400-007 exam is a challenging exam that requires extensive preparation and study. Candidates are encouraged to take training courses and practice exams to help them prepare for the exam. Cisco offers a variety of training courses and study materials to help candidates prepare for the exam, including self-paced e-learning courses, instructor-led training courses, and practice exams.
Cisco 400-007 certification exam is designed to test the knowledge and expertise of candidates in the field of network design. 400-007 Exam is part of the Cisco Certified Design Expert (CCDE v3.0) certification program, which is a highly respected and sought-after certification in the IT industry. The CCDE program is intended for network designers, architects, and engineers who are responsible for designing complex network infrastructure solutions.
Valid Cisco 400-007 Learning Materials, 400-007 Download Free DumpsNever stop challenging your limitations. If you want to dig out your potentials, just keep trying. Repeated attempts will sharpen your minds. Maybe our 400-007 study materials are suitable for you. We strongly advise you to have a brave attempt. You will own a wonderful experience after you learning our 400-007 Study Materials. Our study materials are different from common study materials, which can motivate you to concentrate on study.
Cisco Certified Design Expert (CCDE) Written Exam Sample Questions (Q441-Q446):NEW QUESTION # 441
An MPLS service provider is offering a standard EoMPLS-based VPLS service to Customer A. providing Layer 2 connectivity between a central site and approximately 100 remote sites. Customer A wants to use the VPLS network to carry its internal multicast video feeds which are sourced at the central site and consist of 20 groups at Mbps each. Which service provider recommendation offers the most scalability?
  • A. Enable snooping mechanisms on the provider PE routers.
  • B. EoMPLS-based VPLS can carry multicast traffic in a scalable manner
  • C. Replace VPLS with a Layer 3 MVPN solution to carry the streams between sites
  • D. Use a mesh of GRE tunnels to carry the streams between sites
NEW QUESTION # 442
Which design benefit of bridge assurance is true?
  • A. It prevents switch loops caused by unidirectional point-to-point link condition on Rapid PVST + and MST
  • B. It allows small, unmanaged switches to be plugged into ports of access switches without the risk of switch loops.
  • C. It prevents switched traffic from traversing suboptimal paths on the network.
  • D. It supposes a spanning-tee topology change upon connecting and disconnecting a station on a port
NEW QUESTION # 443
An enterprise that runs numerous proprietary applications has major issues with its on-premises server estate hardware, to the point where business-critical functions are compromised. The enterprise accelerates plans to migrate services to the cloud.
Which cloud service should be used if the enterprise wants to avoid hardware issues yet have control of its applications and operating system?
  • A. hybrid cloud
  • B. laaS
  • C. PaaS
  • D. SaaS
NEW QUESTION # 444
Which two statements describe network automation and network orchestration? (Choose two.)
  • A. Network automation does not provide governance or policy management.
  • B. Network orchestration is done through programmatic REST APIs enabling automation across devices and management platforms.
  • C. Network automation spans multiple network services, vendors, and environments.
  • D. Network orchestration is used to run single, low-level tasks without human intervention.
  • E. Provisioning network services is an example of network automation.
Answer: C,E
* B (Automation spans multiple vendors and services):Automation tools can handle provisioning, configuration, monitoring, and integration across heterogeneous vendor networks.
* D (Provisioning services = automation):Routine tasks like service provisioning, device onboarding, or configuration are handled by automation systems to reduce operational workload.
Other options explained:
* A: Automation can absolutely include policy enforcement if integrated properly.
* C: Orchestration governs higher-level workflows across multiple domains and uses APIs but is not limited to basic automation tasks.
* E: Orchestration coordinates complex workflows, not just single low-level tasks.
NEW QUESTION # 445
Refer to the exhibit. An enterprise underwent a DoS attack sourced from the Internet on their web servers. Their existing firewall failed to handle the attack resulting in services being unavailable for several hours. The enterprise has decided to add a second firewall layer that will act as a back-end firewall. Both sets of firewalls will be set up to handle DoS attacks, so an identical situation is unlikely to happen again in the future. The current firewall hardware supports virtualization, meaning the same physical hardware can be used as both front-end and back-end firewall.
What provides an optimal solution to ensure highest level of security?
  • A. Procure an identical set of physical firewalls and deploy as back-end firewalls.
  • B. Use a single firewall as both front-end and back-end firewalls through virtualization.
  • C. Deploy separate logical firewalls from different vendors as front-end and back-end firewalls.
  • D. Acquire a firewall from a different vendor and deploy as back-end firewalls.
Using firewalls from different vendors in a layered design (defense in depth) avoids a single point of failure due to vendor-specific vulnerabilities or limitations. This ensures higher resilience and stronger protection against future DoS attacks compared to relying on the same hardware or virtualized instances of one vendor's firewall.
NEW QUESTION # 446
SurePassExams believes in customer satisfaction and strives hard to make the entire 400-007 exam preparation process simple, smart, and successful. To achieve this objective SurePassExams is offering the top-rated and real Cisco Certification Exams preparation material in three different Cisco 400-007 Exam study material formats. These Cisco Certified Design Expert (CCDE) Written Exam exam questions formats are 400-007 PDF dumps file, desktop practice test software and web-based practice test software.
Valid 400-007 Learning Materials: https://www.surepassexams.com/400-007-exam-bootcamp.html
BTW, DOWNLOAD part of SurePassExams 400-007 dumps from Cloud Storage: https://drive.google.com/open?id=1eIZt_0l1YG2FzfaPFyQ6brsvqFlWvwUz
Posted at 2/10/2026 15:32:59        Only Author  2#
This article has given me many new ways of thinking, and it’s really useful. MB-280 latest real test questions offers premium content, and it's available to you at no charge.
