Bricked SoC ? Stuck in MaskROM mode, unable to update firmware
Posted at 4/23/2024 23:43:26
View21440
Replies22
I hope my mistake can be repaired. Some weeks ago I seemingly bricked my RK3399 SoC, because I followed an advice from some internet tutorial advising to erase some blocks using an upgrade_tool ws 0xsome_address /dev/null or something like that. It was a rather small address.
Since then I can only boot in MaskROM mode, but what worries me the most is that the size of the flash memory is displayed to be zero :
- sudo ./upgrade_tool rfi
- Flash Info:
- Manufacturer: SAMSUNG,value=00
- Flash Size: 0MB
- Block Size: 512KB
- Page Size: 2KB
- ECC Bits: 0
- Access Time: 40
- Flash CS:
Copy the code
Also I cannot simply wipe out / upgrade the emmc firmware like I used to do :
- sudo ./upgrade_tool uf ffly/stock/FIREFLY-RK3399_Ubuntu20.04-r240_v2.5.1d_230330.img
- Program Log will save in the /root/upgrade_tool/log/
- Loading firmware...
- Support Type:RK330C FW Ver:8.1.00 FW Time:2023-03-30 16:11:48
- Loader ver:1.1a Loader Time:2023-03-30 16:11:20
- Download Boot Fail
Copy the code
Is there a way to solve this and hard reset the SPI/emmc ? Probably using the electric pins ? Thank you.
PS I don't mind which platform to use, this is posted from Linux using manjaro live usb but I have a spare Windows computer among others.
