[Hardware] HPE7-A01 Training Pdf Material & HPE7-A01 Latest Study Material & HPE7-A
48
Hardware HPE7-A01 Training Pdf Material & HPE7-A01 Latest Study Material & HPE7-A
Posted at 1/21/2026 21:17:46      View138 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest ITdumpsfree HPE7-A01 PDF Dumps and HPE7-A01 Exam Engine Free Share: https://drive.google.com/open?id=1Co24hHUtMkMYYVj4a0pwhQeMD89JC4KA
ITdumpsfree has been designing and offering real HP Aruba Certified Campus Access Professional Exam exam dumps for many years. We regularly update our valid HP HPE7-A01 certification test preparation material to keep them in line with the current Aruba Certified Campus Access Professional Exam (HPE7-A01) exam content and industry standards. Professionals from different countries give us their valuable feedback to refine HPE7-A01 actual dumps even more.
HP HPE7-A01 exam, also known as the Aruba Certified Campus Access Professional exam, is designed to test an individuals knowledge and skills in implementing and managing enterprise-level wireless networks. Aruba Certified Campus Access Professional Exam certification is ideal for individuals who work in IT departments or those who are planning to pursue a career in networking. The HPE7-A01 Exam is designed to assess an individuals ability to plan, design, implement, and manage complex wireless networks using Aruba technology.
Pass Guaranteed Quiz 2026 HPE7-A01: Aruba Certified Campus Access Professional Exam High Hit-Rate Exam Collection PdfIn compliance with syllabus of the exam, our HPE7-A01 practice materials are determinant factors giving you assurance of smooth exam. Our HPE7-A01 practice materials comprise of a number of academic questions for your practice, which are interlinked and helpful for your exam. So, they are specified as one of the most successful HPE7-A01 practice materials in the line. They can renew your knowledge with high utility with Favorable prices. So, they are reliably rewarding HPE7-A01 practice materials with high utility value.
HP HPE7-A01 (Aruba Certified Campus Access Professional) Exam is a certification exam designed for individuals who want to demonstrate their knowledge and skills in implementing and managing Aruba wireless networks. HPE7-A01 exam is intended for IT professionals who work with Aruba wireless LAN technologies and solutions in enterprise environments. Aruba Certified Campus Access Professional Exam certification validates that the candidate has the expertise to design, implement, and manage Aruba wireless networks in a campus environment.
HP Aruba Certified Campus Access Professional Exam Sample Questions (Q57-Q62):NEW QUESTION # 57
Match the topics with the underlying technologies (Options may be used more than once or not at all.)
NEW QUESTION # 58
In AOS 10. which session-based ACL below will only allow ping from any wired station to wireless clients but will not allow ping from wireless clients to wired stations"? The wired host ingress traffic arrives on a trusted port.
  • A. ip access-list session pingFromWired any any svc-icmp permit user any svc-icmp deny
  • B. ip access-list session pingFromWired any user any permit
  • C. ip access-list session pingFromWired user any svc-icmp deny any any svc-icmp permit
  • D. ip access-list session pingFromWired any any svc-icmp deny any user svc-icmp permit
A session-based ACL is applied to traffic entering or leaving a port or VLAN based on the direction of the session initiation. To allow ping from any wired station to wireless clients but not vice versa, a session-based ACL should be used to deny icmp echo traffic from any source to any destination, and then permit icmp echo-reply traffic from any source to user destination. The user role represents wireless clients in AOS 10.
https://techhub.hpe.com/eginfoli ... FE4C-4B9B-BE1D-FE7D
NEW QUESTION # 59
Which standard supported by some HPE Aruba Networking APs can enable a customer to accurately locate wireless client devices within a few meters?
  • A. 807.11ah
  • B. 802.11v
  • C. 802.1 Imc
  • D. 802.11be
NEW QUESTION # 60
Which method is used to onboard a new UXI in an existing environment with 802 1X authentication? (The sensor has no cellular connection)
  • A. Connect the new UXI from an already installed one and adjust the initial configuration.
  • B. Use the Aruba installer app on your smartphone to scan the barcode
  • C. Use the CLI via the serial cable and adjust the initial configuration.
  • D. Use the UXI app on your smartphone and connect the UXI via Bluetooth
To onboard a new UXI in an existing environment with 802.1X authentication, you need to use the UXI app on your smartphone and connect the UXI via Bluetooth. The UXI app allows you to scan the QR code on the UXI sensor and configure its network settings, such as SSID, password, IP address, etc. The Bluetooth connection allows you to communicate with the UXI sensor without requiring any network access or cellular connection. The other options are incorrect because they either do not use the UXI app or do not use Bluetooth. References:
https://www.arubanetworks.com/pr ... ring/user-experienc
NEW QUESTION # 61
A customer wants to deploy a Gateway and take advantage of all the SD-WAN features.
Which persona role option should be selected?
  • A. ArubaOS 10 Mobility
  • B. ArubaOS 10 Branch
  • C. ArubaOS 10 VPN Concentrator
  • D. ArubaOS 10 Wireless
The persona role option that should be selected to deploy a Gateway and take advantage of all the SD- WAN features is A. ArubaOS 10 Branch.
ArubaOS 10 Branch is a persona that enables the Gateway to provide both LAN and WAN functionality for branch networks. The Gateway can act as a wireless controller, a router, a firewall, and an SD-WAN device. The SD-WAN features include route and tunnel orchestration, dynamic path steering, forward error correction, SaaS traffic optimization, SASE orchestration, and more1.
The other options are incorrect because:
B) ArubaOS 10 VPN Concentrator: This is a persona that enables the Gateway to act as a VPN concentrator for remote access or site-to-site VPN connections. It does not provide SD-WAN features2.
C) ArubaOS 10 Wireless: This is a persona that enables the Gateway to act as a wireless controller for campus networks. It does not provide SD-WAN features3.
D) ArubaOS 10 Mobility: This is a persona that enables the Gateway to act as a mobility controller for campus networks. It does not provide SD-WAN features.
NEW QUESTION # 62
New HPE7-A01 Dumps Ppt: https://www.itdumpsfree.com/HPE7-A01-exam-passed.html
What's more, part of that ITdumpsfree HPE7-A01 dumps now are free: https://drive.google.com/open?id=1Co24hHUtMkMYYVj4a0pwhQeMD89JC4KA
Posted at 1/22/2026 10:37:24        Only Author  2#
Truly a remarkable piece of writing, Im so thankful for your share. Im about to sit my MCE-Con-201 valid test sample questions exam. Hope I do well!
