[Linux] rk3588 av1 codec is not activated in Ubuntu
36
Linux rk3588 av1 codec is not activated in Ubuntu
Posted at 5/9/2024 15:17:48      View3668 | Replies3        Print      Only Author   [Copy Link] 1#
developing a media player in Ubuntu using ITX-3588J.
The firmware is receiving and using itx-3588j_ubuntu20.04-xfce-r3115_v1.0c_240131.7z.
But the h264 and h265 codecs are hardware-accelerated
Av1 codec is not hardware accelerated.
I would appreciate it if you could tell me how av1 codec is hardware acceleration in qt.
test.zip
930 Bytes, Down times: 0
Posted at 9/12/2024 15:05:19        Only Author  2#
[size=10.6667px]If your codec is not activated in Ubuntu, you might need comcast customer support billing to install or enable the necessary multimedia packages. Use the terminal to install codecs by running commands like `sudo apt install ubuntu-restricted-extras` for common codecs. Ensure your system is up to date, and check software settings or repositories if issues persist. Proper installation will enable playback of various media formats.
Posted at 1/21/2026 21:18:35        Only Author  3#
I deeply appreciate your share, this article is simply astonishing! The CLF-C02 new practice questions content is truly valuable, and its free.
Posted at 2/13/2026 22:00:53        Only Author  4#
यYߤCertShikenƷԇY˺ϸ񤷤ޤΤǡҡҡNSE7_CDS_AR-7.6}]ޤҡmǤ놖}_kơԘϤΤ褦ʆ}äFortinetNSE7_CDS_AR-7.6ԇY˺ϸ񤹤ΤҡϲӤǤҡAƷ|ΤŬޤ
