[General] Pass-Sure Well Salesforce-Certified-Administrator Prep | 100% Free Exam Salesfor
97
【General】 Pass-Sure Well Salesforce-Certified-Administrator Prep | 100% Free Exam Salesfor
Posted at 1/22/2026 01:12:27      View:124 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free & New Salesforce-Certified-Administrator dumps are available on Google Drive shared by BraindumpStudy: https://drive.google.com/open?id=1cg3x_DTuZWv9qrEe_WCUyS3zXBnWBlYr
Most IT workers prefer to choose our online test engine for their Salesforce-Certified-Administrator exam prep because online version is more flexible and convenient. With the help of our online version, you can not only practice our Salesforce-Certified-Administrator Exam PDF in any electronic equipment, but also make you feel the atmosphere of Salesforce-Certified-Administrator actual test. The exam simulation will mark your mistakes and help you play well in Salesforce-Certified-Administrator practice test.
Our company deeply knows that product quality is very important, so we have been focusing on ensuring the development of a high quality of our Salesforce-Certified-Administrator test torrent. All customers who have purchased our products have left deep impression on our Salesforce-Certified-Administrator guide torrent. Of course, the customer not only has left deep impression on the high quality of our products but also the efficiency of our products. Our Salesforce-Certified-Administrator Exam Questions can help you save much time, if you use our Salesforce-Certified-Administrator study prep, you just need to spend 20-30 hours on learning, and you will pass your Salesforce-Certified-Administrator exam successfully.
2026 Salesforce Salesforce-Certified-Administrator –Trustable Well PrepWe can resort to electronic Salesforce-Certified-Administrator exam materials, which is now a commonplace, and the electronic materials with the highest quality which consists of all of the key points required for the Salesforce-Certified-Administrator exam can really be considered as the royal road to learning. Fortunately, the Salesforce-Certified-Administrator practice test compiled by our company are the best choice for you, you just lucky enough to click into this website, since you are sure to pass the Salesforce-Certified-Administrator Exam as well as getting the related certification under the guidance of our Salesforce-Certified-Administrator study guide which you can find in this website easily.
Salesforce Certified Administrator certification exam tests your knowledge of various aspects of Salesforce administration, such as managing users, security and access, data management, workflow automation, and more. Salesforce-Certified-Administrator Exam consists of 60 multiple-choice questions, and you have 90 minutes to complete it. To pass the exam, you need to score at least 65%.
Salesforce Certified Administrator certification is an excellent way to demonstrate your expertise in Salesforce administration and advance your career in this exciting field. Whether you are an experienced Salesforce Administrator or just starting your career in the field, the certification can help you gain the skills and knowledge needed to succeed in this fast-growing industry.
Salesforce Certified Administrator Sample Questions (Q28-Q33):NEW QUESTION # 28
The administrator at Ursa Major Solar has created a custom report type and built a report for sales operation team. However, none of the user are able to access the report.
Which two options could cause this issue?
Choose 2 Answers
  • A. The org has reached its limit of custom report types.
  • B. The report is saved in a private folder
  • C. The custom report type is in development.
  • D. The user's profile is missing view access.
There are two possible reasons why users are unable to access a report based on a custom report type created by an administrator. One is that the custom report type is in development mode, which means that it is not deployed and available for use by other users except for administrators and users with manage custom report types permission. The other is that the report is saved in a private folder, which means that it is visible only to its owner and not shared with other users or groups. References:
https://help.salesforce.com/s/ar ... ypes.htm&type=5
https://help.salesforce.com/s/ar ... ders.htm&type=5
NEW QUESTION # 29
Northern Trail Outfitters has hired interns to enter Leads Into Salesforce and has requested a way to identify these new records from existing Leads.
What approach should an administrator take to meet this requirement?
  • A. Create a separate Lead Lightning App.
  • B. Set up Web-to-Lead for the interns' use.
  • C. Update the active Lead Assignment Rules.
  • D. Define a record type and assign it to the interns.
To identify new leads entered by interns from existing leads, the administrator should define a record type and assign it to the interns. This will allow them to select a different record type when creating leads, and distinguish them from other leads based on record type. Creating a separate Lead Lightning App or updating the active Lead Assignment Rules will not affect lead identification. Setting up Web-to-Lead form will not work if the interns are entering leads manually in Salesforce. References:
https://help.salesforce.com/s/ar ... type.htm&type=5
NEW QUESTION # 30
Cloud Kicks needs to change the owner of a case when it has been open for more than 7 days.
How should the administrator complete this requirement?
  • A. Validation Rule
  • B. Auto - Response Rules
  • C. Assignment Rule
  • D. Escalation Rule
An escalation rule is a tool that allows administrators to automatically escalate cases based on certain criteria and time triggers. For example, an escalation rule can change the owner of a case, send anemail notification, or update a field value when a case has been open for more than 7 days. An escalation rule consists of multiple rule entries that define the criteria and actions for each escalation scenario.
References:https://help.salesforce.com/s/ar ... tion.htm&type=5
NEW QUESTION # 31
Cloud Kicks wants to track shoe designs by products. Shoe designs should be unable to be deleted, and there can be multiple designs for one product across various stages.
Which two steps should the administrator configure to meet this requirement?
Choose 2 answers
  • A. Add a custom master-detail field for shoe designs on the Product object,
  • B. Configure a custom lookup field for shoe designs on the Product object.
  • C. Create a custom object for shoe designs.
  • D. Use the standard object for designs.
NEW QUESTION # 32
Universal Containers introduced a new product and wants to track all associated cases that get logged. They are looking for an automated solution that would give the product's two lead engineers read/write access to all new cases that reference the new product.
What should an administrator do to satisfy this requirement?
  • A. Create a queue and a criteria-based sharing rule.
  • B. Create a user-based sharing rule and an ad-hoc case team.
  • C. Create a predefined case team and an assignment rule.
  • D. Create an auto-response rule and a public group.
NEW QUESTION # 33
If you want to progress and achieve their ideal life, if you are not satisfied with life now, if you still use the traditional methods by exam, so would you please choose the Salesforce-Certified-Administrator test materials, it will surely make you shine at the moment. Our Salesforce-Certified-Administrator latest dumps provide users with three different versions, including a PDF version, a software version, and an online version. Although involved three versions of the teaching content is the same, but for all types of users can realize their own needs, whether it is which version of Salesforce-Certified-Administrator Learning Materials, believe that can give the user a better learning experience. Below, I would like to introduce you to the main advantages of our research materials, and I'm sure you won't want to miss it.
Exam Salesforce-Certified-Administrator PDF: https://www.braindumpstudy.com/Salesforce-Certified-Administrator_braindumps.html
What's more, part of that BraindumpStudy Salesforce-Certified-Administrator dumps now are free: https://drive.google.com/open?id=1cg3x_DTuZWv9qrEe_WCUyS3zXBnWBlYr
Posted at 1/22/2026 06:34:51        Only Author  2#
I really appreciate your article, it opened my eyes to new possibilities. Get free 1Z0-947 100% correct answers to boost your IT knowledge. Wishing you the best of luck!
