[General] Valid Exam Microsoft AZ-140 Blueprint, Test AZ-140 Voucher
98
General Valid Exam Microsoft AZ-140 Blueprint, Test AZ-140 Voucher
Posted at 1/22/2026 03:32:09      View158 | Replies1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamTorrent AZ-140 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1dcthTERUPMw1XM7XVU6ONgJPLT4MCleb
Our company will promptly update our AZ-140 exam materials based on the changes of the times and then send it to you timely. 99% of people who use our learning materials have passed the exam and successfully passed their certificates, which undoubtedly show that the passing rate of our AZ-140 Test Torrent is 99%. If you fail the exam, we promise to give you a full refund in the shortest possible time. So our product is a good choice for you. Choosing our AZ-140 study tool can help you learn better. You will gain a lot and lay a solid foundation for success.
The ExamTorrent supports Microsoft AZ-140 exam candidates by listening to their worries, resolving their problems, and offering them actual exam questions. The exam candidate has several concerns before choosing any platform. They want a platform that satisfies them and promises to help them prepare for the AZ-140 test successfully on the first time.
Quiz Microsoft - Reliable Valid Exam AZ-140 BlueprintIf you buy our AZ-140 training quiz, you will find three different versions are available on our test platform. According to your need, you can choose the suitable version for you. The three different versions of our AZ-140 study materials include the PDF version, the software version and the online version. We can promise that the three different versions are equipment with the high quality. If you purchase our AZ-140 Preparation questions, it will be very easy for you to easily and efficiently find the exam focus and pass the AZ-140 exam.
Microsoft AZ-140 (Configuring and Operating Microsoft Azure Virtual Desktop) Certification Exam is a certification exam designed for individuals who are interested in acquiring the knowledge and skills required to configure and operate Microsoft Azure Virtual Desktop. AZ-140 exam is intended to validate the candidate's understanding of the various aspects of Microsoft Azure Virtual Desktop, including its architecture, deployment, security, management, and troubleshooting. AZ-140 Exam is an essential step towards becoming a certified Microsoft Azure Virtual Desktop Administrator.
Microsoft Configuring and Operating Microsoft Azure Virtual Desktop Sample Questions (Q92-Q97):NEW QUESTION # 92
You have the following:
A Microsoft 365 E5 tenant
An on-premises Active Directory domain
A hybrid Azure Active Directory (Azure AD) tenant
An Azure Active Directory Domain Services (Azure AD DS) managed domain
An Azure Virtual Desktop deployment
The Azure Virtual Desktop deployment contains personal desktops that are hybrid joined to the on-premises domain and enrolled in Microsoft Intune.
You need to configure the security settings for the Microsoft Edge browsers on the personal desktops.
Solution: You configure a compliance policy in Intune.
Does this meet the goal?
  • A. No
  • B. Yes
You need to configure a Configuration Profile in Intune or use Group Policy.
NEW QUESTION # 93
You have an Azure Virtual Desktop deployment that contains an Azure compute gallery. The Azure compute gallery contains an image definition named Definitions Definitionl contains the following image versions:
* 1.0.0
* 1.1.0
* 1.2.0
You need to ensure that when a virtual machine is created from the Azure compute gallery, the 1.1.0 image version is used by default.
What should you do?
  • A. Select Exclude from latest for image version 1.0.0.
  • B. Select Exclude from latest for image version 1.2.0.
  • C. Apply a tag named default to image version 1.1.0.
  • D. Apply a lock to image version 1.1.0.
Exclude from latest. You can keep a version from being used as the latest image version. https://learn.
microsoft.com/en-us/azure/virtual-machines/shared-image-galleries?tabs=azure-cli
NEW QUESTION # 94
You have an Azure Virtual Desktop deployment.
You are configuring the outbound firewall settings for the host pool.
Which outbound URL and outbound port should you configure to ensure that the host machines maintain Windows activation? To answer, select the appropriate options In the answer area.
https://docs.microsoft.com/en-us ... sktop/safe-url-list
NEW QUESTION # 95
You use the Start/Stop VMs during off-hours feature in Azure.
You need to configure which virtual machines must never be stopped by the solution.
What should you configure?
  • A. the Diagnostic settings of the host pool
  • B. an action group
  • C. the Start-Stop-VM task
  • D. an Azure Automation account variable
https://docs.microsoft.com/en-us ... ution-vm-management
https://docs.microsoft.com/en-us ... m-management-enable
NEW QUESTION # 96
You have a Windows Virtual Desktop deployment.
You need to provide external users with access to the deployment. The external users have computers that run Windows 10 Pro and Windows 10 Enterprise. The users do not have the ability to install applications.
What should you recommend that the users use to connect to the deployment?
  • A. Remote Desktop Manager
  • B. Remote Desktop Connection
  • C. Microsoft Edge
  • D. RemoteApp and Desktop Connection
NEW QUESTION # 97
There are a lot of advantages if you buy our AZ-140 training guide. And one of them is that you can enjoy free updates for one year after purchase. In order to avoid the omission of information, please check your email regularly. The content of AZ-140 Exam Materials is very comprehensive, and we are constantly adding new things to it. As long as you purchase AZ-140 practice prep, you will not need any other learning products.
Test AZ-140 Voucher: https://www.examtorrent.com/AZ-140-valid-vce-dumps.html
BTW, DOWNLOAD part of ExamTorrent AZ-140 dumps from Cloud Storage: https://drive.google.com/open?id=1dcthTERUPMw1XM7XVU6ONgJPLT4MCleb
Posted at 1/27/2026 06:09:42        Only Author  2#
Im genuinely grateful for your share, this article is fantastic! Valid dumps AP-220 ppt questions shared for free. Best of luck in your exam preparations!
