[General] Valid Fortinet FCP_FGT_AD-7.6 Exam Topics, Valid FCP_FGT_AD-7.6 Test Vce
70
General Valid Fortinet FCP_FGT_AD-7.6 Exam Topics, Valid FCP_FGT_AD-7.6 Test Vce
Posted at 1/22/2026 10:28:15      View156 | Replies2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PassLeaderVCE FCP_FGT_AD-7.6 dumps from Cloud Storage: https://drive.google.com/open?id=1ARrUPPp-wZFJDI0cVD61LOiD5EgCYjuo
If you have a faith, then go to defend it. Gorky once said that faith is a great emotion, a creative force. My dream is to become a top IT expert. I think that for me is nowhere in sight. But to succeed you can have a shortcut, as long as you make the right choice. I took advantage of PassLeaderVCE's Fortinet FCP_FGT_AD-7.6 exam training materials, and passed the Fortinet FCP_FGT_AD-7.6 Exam. PassLeaderVCE Fortinet FCP_FGT_AD-7.6 exam training materials is the best training materials. If you're also have an IT dream. Then go to buy PassLeaderVCE's Fortinet FCP_FGT_AD-7.6 exam training materials, it will help you achieve your dreams.
Fortinet FCP_FGT_AD-7.6 Exam Syllabus Topics:
  • Content inspection: This section of the exam measures the skills of network security engineers and covers the setup and management of content inspection features on FortiGate. Candidates must demonstrate an understanding of encrypted traffic inspection using digital certificates, identify and apply FortiGate inspection modes, and configure web filtering policies. The ability to implement application control for monitoring and regulating network application usage, configure antivirus profiles to detect and block malware, and set up Intrusion Prevention Systems (IPS) to shield the network from threats and vulnerabilities is also assessed.
  • Deployment and system configuration: This section of the exam measures the skills of network security engineers and covers essential tasks for setting up a FortiGate device in a production environment. Candidates are expected to perform the initial configuration, establish basic connectivity, and integrate the device within the Fortinet Security Fabric. They must also be able to configure a FortiGate Cluster Protocol (FGCP) high availability setup and troubleshoot resource and connectivity issues to ensure system readiness and network uptime.
  • Firewall policies and authentication: This section of the exam measures the skills of firewall administrators and covers the implementation and management of security policies. It involves configuring basic and advanced firewall rules, applying Source NAT (SNAT) and Destination NAT (DNAT) options, and enforcing various firewall authentication methods. The section also includes deploying and configuring Fortinet Single Sign-On (FSSO) to streamline user access across the network.
  • VPN: This section of the exam measures the skills of network security engineers and covers the configuration and deployment of Virtual Private Network (VPN) solutions. Candidates are required to implement SSL VPNs to grant secure remote access to internal resources and configure IPsec VPNs in either meshed or partially redundant topologies to ensure encrypted communication between distributed network locations.
Topic 5
  • Routing: This section of the exam measures the skills of firewall administrators and covers the configuration of routing features on FortiGate devices. It includes defining and applying static routes for directing traffic within and outside the network, as well as setting up Software-Defined WAN (SD-WAN) to distribute and balance traffic loads across multiple WAN connections efficiently.
Valid FCP_FGT_AD-7.6 Test Vce & FCP_FGT_AD-7.6 Free Sample QuestionsContending for the success fruit of FCP_FGT_AD-7.6 exam questions, many customers have been figuring out the effective ways to pass it. And that is why we have more and more costomers and everyday the hot hit and high pass rate as well. It is all due to the advantage of our useful FCP_FGT_AD-7.6 practice materials, and we have these versions of our FCP_FGT_AD-7.6 study materials for our customers to choose according to their different study habbits:the PDF, the Software and the APP online.
Fortinet FCP - FortiGate 7.6 Administrator Sample Questions (Q77-Q82):NEW QUESTION # 77
What are two features of FortiGate FSSO agentless polling mode? (Choose two.)
  • A. FortiGate directs the collector agent to use a remote LDAP server.
  • B. FortiGate uses the SMB protocol to read the event viewer logs from the DCs.
  • C. FortiGate does not support workstation check.
  • D. FortiGate uses the AD server as the collector agent.
FortiGate uses the SMB protocol to read the event viewer logs from the DCs In agentless polling mode, FortiGate connects directly to the AD domain controllers using SMB to collect logon events.
FortiGate uses the AD server as the collector agent There is no external FSSO collector; instead, the FortiGate itself polls the AD servers, effectively treating them as the source of logon information.
NEW QUESTION # 78
Refer to the exhibit showing a FortiGuard connection debug output.
Based on the output, which two facts does the administrator know about the FortiGuard connection? (Choose two.)
  • A. One server was contacted to retrieve the contract information.
  • B. There is at least one server that lost packets consecutively.
  • C. A local FortiManager is one of the servers FortiGate communicates with.
  • D. FortiGate is using default FortiGuard communication settings.
The output shows that one server was contacted to retrieve FortiGuard contract information, as indicated under "Service : Web-filter" with "License : Contract" and "Num. of servers : 1." The entry "Default servers : Included" confirms that FortiGate is using the default FortiGuard communication settings, meaning it communicates directly with Fortinet's public FortiGuard servers instead of a custom or local override.
NEW QUESTION # 79
Refer to the exhibits.
The exhibits show a diagram of a FortiGate device connected to the network, and the firewall configuration.
An administrator created a Deny policy with default settings to deny Webserver access for Remote-User2.
The policy should work such that Remote-User1 must be able to access the Webserver while preventing Remote-User2 from accessing the Webserver.
Which additional configuration can the administrator add to a deny firewall policy, beyond the default behavior, to block Remote-User2 from accessing the Webserver?
  • A. Set the Destination address as Webserver in the Deny policy.
  • B. Set the Destination address as Deny_IP in the Allow_access policy.
  • C. Configure a One-to-One IP Pool object in a new policy.
  • D. Disable match-vip in the Allow_access policy
To block Remote-User2's access to the Webserver, the deny policy must explicitly specify the Webserver as the destination address; otherwise, it denies traffic to all destinations, which is not the desired behavior.
NEW QUESTION # 80
A network administrator enabled antivirus and selected an SSL inspection profile on a firewall policy. When downloading an EICAR test file through HTTP, FortiGate detects the virus and blocks the file. When downloading the same file through HTTPS, FortiGate does not detect the virus and does not block the file, allowing it to be downloaded.
The administrator confirms that the traffic matches the configured firewall policy. What are two reasons for the failed virus detection by FortiGate? (Choose two.)
  • A. The selected SSL inspection profile has certificate inspection enabled.
  • B. The El CAR test file exceeds the protocol options oversize limit.
  • C. The browser does not trust the FortiGate self-signed CA certificate.
  • D. The website is exempted from SSL inspection.
NEW QUESTION # 81
You are encountering connectivity problems caused by intermediate devices blocking IPsec traffic.
In which two ways can you effectively resolve the problem? (Choose two.)
  • A. You should use the protocol IKEv2.
  • B. You can use SSL VPN tunnel mode to prevent problems with blocked ESP and UDP ports (500 or
    4500).
  • C. You can configure a hub-and-spoke topology with SSL VPN tunnels to bypass blocked UDP ports.
  • D. You can turn on fragmentation to fix large certificate negotiation problems.
NEW QUESTION # 82
You always need actual and updated FCP_FGT_AD-7.6 exam questions to prepare the test successfully in less time. If you don't study with real FCP - FortiGate 7.6 Administrator (FCP_FGT_AD-7.6) questions, you will ultimately fail and waste your money and time. To save yourself from this loss, you just need to prepare with updated FCP - FortiGate 7.6 Administrator (FCP_FGT_AD-7.6) exam questions of PassLeaderVCE.
Valid FCP_FGT_AD-7.6 Test Vce: https://www.passleadervce.com/Network-Security/reliable-FCP_FGT_AD-7.6-exam-learning-guide.html
P.S. Free & New FCP_FGT_AD-7.6 dumps are available on Google Drive shared by PassLeaderVCE: https://drive.google.com/open?id=1ARrUPPp-wZFJDI0cVD61LOiD5EgCYjuo
Posted at 2/1/2026 18:25:03        Only Author  2#
Haben sie von Salesforce AP-216 Dumps von ExamFragen gehört? Aber, Haben Sie diese Dumps benutzt? Viele Leute haben gesagt, dass ExamFragen Dumps sehr gute Unterlagen sind, womit sie die Salesforce AP-216 Zertifizierungsprfung bestanden haben. Wir ExamFragen sind von vielen Leuten, die frher die Salesforce AP-216 Dumps benutzt haben, gut bewertet, weil sie wirklich viel Zeit fr die Salesforce AP-216 Prfungen sparen und den Erfolg fr die Teilnehmer garantieren.
Posted at 2/5/2026 16:38:02        Only Author  3#
Your article is a true gem, Im so grateful for your sharing! Heading into the CMMC-CCA latest study questions files exam soon. Pray for me!
