[General] How Splunk SPLK-3002 PDF Dumps is essential on your SPLK-3002 Exam Questions Cer
102
General How Splunk SPLK-3002 PDF Dumps is essential on your SPLK-3002 Exam Questions Cer
Posted at 1/22/2026 12:18:40      View174 | Replies2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest DumpsReview SPLK-3002 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1AcBHAi_NY7CUTUHMhIxxna7zUW4nYJvh
Our experts update the SPLK-3002 training materials every day and provide the latest update timely to you. If you have the doubts or the questions about our product and the purchase procedures you can contact our online customer service personnel at any time. We provide the discounts to the old client and you can have a free download and tryout of our SPLK-3002 Test Question before your purchase. So there are many merits of our product. You can know the characteristics and the functions of our SPLK-3002 practice test by free demo before you purchase our SPLK-3002 exam questions.
You just need to get DumpsReview's Splunk Certification SPLK-3002 Exam exercises and answers to do simulation test, you can pass the Splunk certification SPLK-3002 exam successfully. If you have a Splunk SPLK-3002 the authentication certificate, your professional level will be higher than many people, and you can get a good opportunity of promoting job. Add DumpsReview's products to cart right now! DumpsReview can provide you with 24 hours online customer service.
Test SPLK-3002 Book, SPLK-3002 Practice Exam FeeHowever, preparing for the SPLK-3002 exam is not an easy job until they have real Splunk IT Service Intelligence Certified Admin (SPLK-3002) exam questions that are going to help them achieve this target. They have to find a trusted source such as DumpsReview to reach their goals. Get SPLK-3002 Certified, and then apply for jobs or get high-paying job opportunities. If you think that SPLK-3002 certification exam is easy to crack, you are mistaken.
Splunk IT Service Intelligence Certified Admin Sample Questions (Q44-Q49):NEW QUESTION # 44
What is the default importance value for dependent services' health scores?
  • A. 0
  • B. 1
  • C. Unassigned
  • D. 2
By default, impacting service health scores have an importance value of 11.
A service template is a predefined set of KPIs and entity rules that you can apply to a service or a group of services. A service template helps you standardize the configuration and monitoring of similar services across your IT environment. A service template can also include dependent services, which are services that are required for another service to function properly. For example, a web server service might depend on a database service and a network service. The default importance value for dependent services' health scores is:
D) 10. This is true because the importance value indicates how much a dependent service contributes to the health score of the parent service. The default value is 10, which means that the dependent service has the highest impact on the parent service's health score. You can change the importance value of a dependent service in the service template settings.
The other options are not correct because:
A) 11. This is not true because 11 is an invalid value for importance. The valid range is from 1 (lowest) to 10 (highest).
B) 1. This is not true because 1 is the lowest value for importance, not the default value. A value of 1 means that the dependent service has the lowest impact on the parent service's health score.
C) Unassigned. This is not true because every dependent service has an assigned importance value, which defaults to 10.
NEW QUESTION # 45
Which index contains ITSI Episodes?
  • A. itsi_notable_archive
  • B. itsi_grouped_alerts
  • C. itsi_summary
  • D. itsi_tracked_alerts
B is the correct answer because ITSI episodes are stored in the itsi_grouped_alerts index. This index contains notable events that have been grouped together based on predefined aggregation policies. Episodes help you reduce alert noise and focus on resolving incidents faster. Reference: [Overview of episodes in ITSI]
NEW QUESTION # 46
When deploying ITSI on a distributed Splunk installation, which component must be installed on the search head(s)?
  • A. All ITSI components
  • B. ITSI app
  • C. SA-ITOA
  • D. SA-ITSI-Licensechecker
Install SA-ITSI-Licensechecker and SA-UserAccess on any license master in a distributed or search head cluster environment. If a search head in your environment is also a license master, the license master components are installed when you install ITSI on the search heads.
NEW QUESTION # 47
Which of the following are the default ports that must be configured on Splunk to use ITSI?
  • A. SplunkWeb (8088), SplunkD (8089), and HTTP Collector (8000)
  • B. SplunkWeb (8405), SplunkD (8519), and HTTP Collector (8628)
  • C. SplunkWeb (8000), SplunkD (8089), and HTTP Collector (8088)
  • D. SplunkWeb (8089), SplunkD (8088), and HTTP Collector (8000)
Reference: https://splunk.github.io/docker-splunk/ARCHITECTURE.html
C is the correct answer because ITSI uses the default ports of Splunk Enterprise for its communication and data collection. SplunkWeb uses port 8000, SplunkD uses port 8089, and HTTP Event Collector uses port
8088. These ports can be changed if needed, but they must match the configuration of Splunk Enterprise.
References: Ports used by ITSI
NEW QUESTION # 48
  • A. ITSI app
  • B. All ITSI components
  • C. SA-ITSI-Licensechecker
  • D. SA-ITOA
Reference: https://docs.splunk.com/Document ... 2/Install/InstallDD When deploying ITSI on a distributed Splunk installation, the component that must be installed on the search head(s) is the ITSI app. The ITSI app contains the main features and functionality of ITSI, such as service creation and management, KPI configuration, glass table creation and editing, episode review, deep dives, and so on. The ITSI app also contains some add-ons that provide additional functionality, such as SA-ITOA (IT Operations Analytics), SA-UserAccess (User Access Management), and SA-Utils (Utility Functions). The ITSI app must be installed on the search head(s) because it handles the search management and presentation functions for ITSI. References: Install IT Service Intelligence in a distributed environment
NEW QUESTION # 49
It's time to take the Splunk SPLK-3002 practice test for self-assessment once you have prepared with SPLK-3002 PDF questions. Taking DumpsReview's web-based Splunk SPLK-3002 practice test is the best method to feel the real Splunk SPLK-3002 Exam scenario. DumpsReview offers the customizable web-based Splunk SPLK-3002 practice test that is compatible with all browsers like MS Edge, Chrome, Firefox, etc.
Test SPLK-3002 Book: https://www.dumpsreview.com/SPLK-3002-exam-dumps-review.html
SPLK-3002 certifications are significant in this field, Similarly, this desktop Splunk IT Service Intelligence Certified Admin (SPLK-3002) practice exam software of DumpsReview is compatible with all Windows-based computers, DumpsReview SPLK-3002 exam PDF is usually updated frequently, Splunk SPLK-3002 Answers Free You can just look at the warm feedbacks to us on the website, Splunk SPLK-3002 Answers Free We make exam preparation a breeze as we provide our customers with real exam questions and verified answers to ensure their exam success.
This chapter describes the various troublemakers and offers some advice on dealing with them, Live Interlocking Objects, SPLK-3002 certifications are significant in this field.
Similarly, this desktop Splunk IT Service Intelligence Certified Admin (SPLK-3002) practice exam software of DumpsReview is compatible with all Windows-based computers, DumpsReview SPLK-3002 exam PDF is usually updated frequently.
Here's the Right Way to Pass Splunk SPLK-3002 ExamYou can just look at the warm feedbacks to us on the website, We make SPLK-3002 exam preparation a breeze as we provide our customers with real exam questions and verified answers to ensure their exam success.
BONUS!!! Download part of DumpsReview SPLK-3002 dumps for free: https://drive.google.com/open?id=1AcBHAi_NY7CUTUHMhIxxna7zUW4nYJvh
Posted at 1/27/2026 06:09:07        Only Author  2#
녢AdobeAD0-E137JCԇ᣿鿼ԇyl᣿ӿԇ֓ͨ^ˡF@ӵ᣿]PSĵ؈ɡֻҪNewDumpsYϣyĿԇҲdž}ʹ㌦ͨ^ԇһcҲ]УNewDumpsAD0-E137}ҲԱCһξpɹXò˼h᣿ԁNewDumpsľWվtYӍ⣬߀ԇAD0-E137}һ֡@ӵԒ϶͕֪@Yͨ^ԇıϡ
Posted at 2/20/2026 22:29:50        Only Author  3#
Thank you for sharing this breathtaking article, its truly amazing! Best wishes for your exams! Heres the free C_ARCON_2508 exam question material.
