[General] Reliable Oracle 1Z0-106 Exam Pdf | Top 1Z0-106 Exam Dumps
86
【General】 Reliable Oracle 1Z0-106 Exam Pdf | Top 1Z0-106 Exam Dumps
Posted at 1/22/2026 14:04:26      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Oracle 1Z0-106 dumps are available on Google Drive shared by VCEEngine: https://drive.google.com/open?id=1SaMr0uhntYsNNcCa7FDou8-PPFfw28OW
Now is not the time to be afraid to take any more difficult certification exams. Our 1Z0-106 learning quiz can relieve you of the issue within limited time. Our website provides excellent learning guidance, practical questions and answers, and questions for your choice which are your real strength. You can take the 1Z0-106 Training Materials and pass it without any difficulty. As long as you can practice 1Z0-106 study guide regularly and persistently your goals of making progress and getting certificates smoothly will be realized just like a piece of cake.
Following is the info about the Passing Score, Duration & Questions for the Oracle 1Z0-106 Exam
  • Time Duration: 90 Minutes
  • The passing score: 60%
  • Languages: English
  • Number of Questions: 60 Questions
The Oracle 1Z0-106 exam consists of 80 multiple-choice questions that must be completed within 120 minutes. To pass the exam, candidates must score at least 63%. The questions are designed to test the candidate's knowledge of various aspects of Oracle Linux 8, including system installation and configuration, user and group management, file systems and storage, network configuration, security, and troubleshooting.
1Z0-106 Exam Study Questions & 1Z0-106 Vce Training Material & 1Z0-106 Latest Pdf VceThe VCEEngine 1Z0-106 Practice Questions are designed and verified by experienced and renowned 1Z0-106 exam trainers. They work collectively and strive hard to ensure the top quality of 1Z0-106 exam practice questions all the time. The 1Z0-106 Exam Questions are real, updated, and error-free that helps you in Oracle 1Z0-106 exam preparation and boost your confidence to crack the upcoming 1Z0-106 exam easily.
Oracle 1Z0-106 certification exam is an excellent way for IT professionals to validate their knowledge and skills in Linux system administration. Oracle Linux 8 Advanced System Administration certification is recognized globally and is highly regarded in the industry. By passing 1Z0-106 Exam, candidates can demonstrate their expertise in advanced system administration concepts and take their careers to the next level.
Oracle Linux 8 Advanced System Administration Sample Questions (Q21-Q26):NEW QUESTION # 21
Which two statements are true about systemd system and service manager?
  • A. systemd is backward-compatible with the System V init scripts that were used in earlier versions of Oracle Linux.
  • B. systemd service units expose kernel devices and can be used to implement device-based activation.
  • C. systemd reads /etc/system to determine which services to start.
  • D. The service command is used to start and stop system service units.
  • E. systemd is the first process that starts after the system boots and is the final process left running before the system shuts down.
Answer: A,E
Explanation of Answer B:systemdis the first process to start (PID 1) after the Linux kernel has booted and is responsible for initializing the user space and managing system services throughout the system's runtime. It is also the last process to stop during shutdown.
Explanation of Answer C:systemdmaintains backward compatibility with older System V init scripts. It can run and manage these scripts, ensuring legacy services are supported while providing newer functionalities through nativesystemdunit files.
NEW QUESTION # 22
Examine this udev device naming rule which gets processed successfully:
makefile
KERNEL=="hdb", DRIVER=="ide-disk", SYMLINK+="sparedisk"
Which two statements are true?
  • A. Symbolic link /dev/sparedisk is created linking to /dev/hdb and with an ide-disk device driver, thus overwriting existing symbolic links.
  • B. Symbolic link /dev/sparedisk is created for a device named /dev/hdb or one that has an ide-disk device driver, whichever is discovered first.
  • C. The matching device will have the kernel device name /dev/hdb.
  • D. Symbolic link /dev/sparedisk is created for a device named /dev/hdb which has an ide-disk device driver if such a device is discovered.
  • E. The matching device will be named /dev/sparedisk.
Option C (Correct):If a device named/dev/hdbwith theide-diskdriver is discovered, a symbolic link/dev
/sparediskwill be created, pointing to/dev/hdb.
Option D (Correct):TheKERNEL=="hdb"match specifies that the device will have the kernel device name
/dev/hdb.
Option A (Incorrect):This is incorrect because existing symbolic links are not overwritten unless explicitly defined.
Option B (Incorrect):The device itself is not renamed to/dev/sparedisk; rather, a symbolic link is created.
Option E (Incorrect):The rule specifically requires bothKERNEL=="hdb"andDRIVER=="ide-disk"to match; it is not an either/or condition.
NEW QUESTION # 23
Examine /etc/anacrontab:
SHELL=/bin/sh
PATH=/sbin:/bin:/usr/sbin:/usr/bin
MAILTO=root
# the maximal random delay added to the base delay of the jobs
RANDOM_DELAY=45
# the jobs are started during the following hours only
START_HOURS_RANGE=3-22
# period in days delay in minutes job-identifier command
1 5 dailyjob nice run-parts /etc/cron.daily
7 25 weeklyjob nice run-parts /etc/cron.weekly
@monthly 45 monthlyjob nice run-parts /etc/cron.monthly
Which two statements are true about the jobs scheduled in this file?
  • A. Jobs defined in this anacrontab file can be executed between 15:00 and 22:00
  • B. Scripts run by the third job are delayed between 45 and 90 minutes.
  • C. Scripts run by the second job are delayed between 31 and 70 minutes.
  • D. Jobs defined in this anacrontab file are randomly delayed by up to 51 minutes.
  • E. Scripts run by the first job are delayed between 11 and 45 minutes.
NEW QUESTION # 24
Which two default user account settings are contained in /etc/login.defs?
  • A. User hashed passwords.
  • B. Encryption method used to encrypt passwords.
  • C. Group hashed passwords.
  • D. Password aging controls.
  • E. Decryption method used to decrypt passwords.
Explanation of Answer D:The/etc/login.defsfile in Oracle Linux contains configuration settings related to user account policies, including password aging controls. This includes settings such asPASS_MAX_DAYS, PASS_MIN_DAYS, andPASS_WARN_AGE, which define the maximum number of days a password is valid, the minimum number of days between password changes, and the number of days before password expiration to warn users, respectively.
Explanation of Answer E:The/etc/login.defsfile also contains settings for the encryption method used to encrypt user passwords. TheENCRYPT_METHODparameter specifies the hashing algorithm, such as SHA512, that is used to encrypt user passwords stored in/etc/shadow.
NEW QUESTION # 25
The ss command was invoked with options to:
limit output to all listening and non-listening TCP ports
display ports instead of the protocols that typically use those ports
display all available internal TCP information
display only connections whose source or destination port is 80
Which two results are produced by the command?
  • A. icmp6 UNCONN 0 0 *:58 *:*
  • B. UNCONN 0 0 [::1]:323 [::]:*
  • C. LISTEN 0 511 *:80 *:* cubic cwnd:10
  • D. ESTAB 0 0 10.12.18.92:50384 169.254.169.254:80 cubic wscale:9,7 rto:201 rtt: 0.226/0.113 ato:40 mss:8948 pmtu:9000 rcvmss:1728 advmss:8948 cwnd:10 bytes_sent:142 bytes_acked:143 bytes_received:1728 segs_out:4 segs_in:3 data_segs_out:1 data_segs_in:1 send 3167433628bps lastsnd:11351 lastrcv: 11351 lastack:11351 pacing_rate 6334867256bps delivery_rate 504112672bps delivered:2 app_limited rcv_space:62720 rcv_ssthresh:56588 minrtt:0.142
  • E. tcp CLOSE-WAIT 32 0 server.example.com:44732 12.21.0.15:https
NEW QUESTION # 26
Top 1Z0-106 Exam Dumps: https://www.vceengine.com/1Z0-106-vce-test-engine.html
BTW, DOWNLOAD part of VCEEngine 1Z0-106 dumps from Cloud Storage: https://drive.google.com/open?id=1SaMr0uhntYsNNcCa7FDou8-PPFfw28OW
