JN0-336 Reliable Test Online, JN0-336 Exam Dumps Free
105
Posted at 1/22/2026 15:18:11      View:120 | Replies:2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest SureTorrent JN0-336 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1bQO7774aSL5qzUW2lo0hxOM4qVse3vih
The SureTorrent Security, Specialist (JNCIS-SEC) (JN0-336) exam dumps are being offered in three different formats. The names of these formats are SureTorrent JN0-336 PDF questions file, desktop practice test software, and web-based practice test software. All these three SureTorrent JN0-336 Exam Dumps formats contain the real Juniper JN0-336 exam questions that will help you to streamline the JN0-336 exam preparation process.
If you want to through the Juniper JN0-336 certification exam to make a stronger position in today's competitive IT industry, then you need the strong expertise knowledge and the accumulated efforts. And pass the Juniper JN0-336 exam is not easy. Perhaps through Juniper JN0-336 exam you can promote yourself to the IT industry. But it is not necessary to spend a lot of time and effort to learn the expertise. You can choose SureTorrent's Juniper JN0-336 Exam Training materials. This is training product that specifically made for IT exam. With it you can pass the difficult Juniper JN0-336 exam effortlessly.
Juniper JN0-336 Exam Dumps Free - JN0-336 Test Vce FreeAs a matter of fact, since the establishment, we have won wonderful feedback and ceaseless business, continuously working on developing our JN0-336 test prep. We have been specializing JN0-336 exam dumps many years and have a great deal of long-term old clients, and we would like to be a reliable cooperator on your learning path and in your further development. While you are learning with our JN0-336 Quiz guide, we hope to help you make out what obstacles you have actually encountered during your approach for JN0-336 exam torrent through our PDF version, only in this way can we help you win the JN0-336 certification in your first attempt.
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q52-Q57):NEW QUESTION # 52
You are asked to determine how much traffic a popular gaming application is generating on your network.
Which action will you perform to accomplish this task?
  • A. Enable APBR on the proper security zones
  • B. Enable AppTrack on the proper security zones.
  • C. Enable screen options on the proper security zones
  • D. Enable AppQoS on the proper security zones
AppTrack is a feature of Juniper Networks firewall solutions that allows administrators to track applications, users, and the amount of traffic generated by those applications on the network. AppTrack can be enabled on specific security zones of the network to monitor traffic on those zones. This feature can be used to determine how much traffic a popular gaming application isgenerating on the network.
For more information, please refer to the Juniper Networks JNCIS-SEC Study Guide.
NEW QUESTION # 53
Click the Exhibit button.
Which two statements describe the output shown in the exhibit? (Choose two.)
  • A. Redundancy group 1 experienced an operational failure.
  • B. Redundancy group 1 was administratively failed over.
  • C. Node 0 is controlling traffic for redundancy group 1.
  • D. Node 1 is controlling traffic for redundancy group 1.
The output indicates that node1 has a priority of 200 and is marked as "Primary," which means it is currently the active node controlling traffic for redundancy group 1. The "Primary" status designates that this node is handling the traffic for the specified redundancy group.
According to the exhibit, node0 is listed with a priority of 0 and is marked as "Secondary." This status indicates that node0 is currently not controlling traffic for redundancy group 1, serving instead in a standby role ready to take over should node1 fail or become unavailable.
NEW QUESTION # 54
Which two statements are correct about the cSRX? (Choose two.)
  • A. The cSRX only supports Layer 2 "bump-in-the-wire" deployments.
  • B. The cSRX supports firewall, NAT, IPS, and UTM services.
  • C. The cSRX has three default zones: trust, untrust, and management
  • D. The cSRX supports BGP, OSPF. and IS-IS routing services.
The two statements that are correct about the cSRX are that it supports firewall, NAT, IPS, and UTM services, and that it has three default zones: trust, untrust, and management. The cSRX is a software- defined security solution that provides comprehensive network security capabilities and is designed for virtualized environments. It supports firewall, NAT, IPS, and UTM services to protect against threats, as well as BGP, OSPF, and IS-IS routing services for routing functionality. Additionally, the cSRX has three default zones: trust, untrust, and management. The trust zone is used to define traffic that is allowed to enter the network, the untrust zone is used to define traffic that should be blocked from entering the network, and the management zone is used to manage the device itself. The cSRX does not support Layer 2 "bump-in-the-wire" deployments.
NEW QUESTION # 55
Which two statements about the DNS ALG are correct? (Choose two.)
  • A. The DNS ALG supports VPN tunnels.
  • B. The DNS ALG does not support NAT.
  • C. The DNS ALG performs DNS doctoring.
  • D. The DNS ALG supports DDNS.
The DNS Application Layer Gateway (ALG) is designed to manage and facilitate the successful passage of DNS traffic through a network device such as a firewall or NAT. Here are the correct statements regarding DNS ALG:
DNS doctoring is indeed a function of the DNS ALG where it modifies the payload of DNS responses to ensure that the information is aligned with the NAT policy. For example, it can rewrite the IP addresses in DNS responses to match the internal or external NAT'd IP address that the client should use.
DNS ALG can function across VPN tunnels by managing DNS traffic that traverses the tunnel, ensuring that the DNS queries and responses are correctly handled in environments where IP address translation occurs due to the VPN.
NEW QUESTION # 56
Which two statements about the log output shown in the exhibit are correct? (Choose two)
  • A. AppTrack is enabled on the trast zone.
  • B. Traffic destined to the HTTP server is placed in an IPsec tunnel
  • C. Source NAT is performed
  • D. AppTrack is enabled on the untrust zone.
NEW QUESTION # 57
Our professionals have gained an in-depth understanding of the fundamental elements that combine to produce world class JN0-336 practice materials for all customers. So we can promise that our study materials will be the best study materials in the world. Our products have a high quality. If you decide to buy our JN0-336 Exam Braindumps, we can make sure that you will have the opportunity to enjoy the JN0-336 study guide from team of experts.
JN0-336 Exam Dumps Free: https://www.suretorrent.com/JN0-336-exam-guide-torrent.html
According to the different demands of many customers, they have designed the three different versions of the JN0-336 study materials for all customers, We are offering excellent and valid Juniper JN0-336 practice questions and exam simulation inside, Even if you still failed the JN0-336 certification exam, we will full refund to reduce your economic loss as much as possible, We will not only do our best to help you pass the JN0-336 exam torrent for only one time, but also help you consolidate your IT expertise.
Entrepreneurship and Planning, Here are the JN0-336 typical areas I focus on when I want to edit an image, According to the differentdemands of many customers, they have designed the three different versions of the JN0-336 Study Materials for all customers.
Use Juniper JN0-336 Questions - Best Strategy To Beat The Exam StressWe are offering excellent and valid Juniper JN0-336 practice questions and exam simulation inside, Even if you still failed the JN0-336 certification exam, we will full refund to reduce your economic loss as much as possible.
We will not only do our best to help you pass the JN0-336 exam torrent for only one time, but also help you consolidate your IT expertise, We never circumvent the difficulties of our JN0-336 study materials happened on the road as long as there is bright at the end, and it is the satisfactory results you want.
Posted at 1/25/2026 19:02:07        Only Author  2#
This content is gold, liking it right now. Don’t miss your chance to get the free Valid test ISTQB-CTFL questions vce questions—the key to promotion and salary growth!
Posted at 1/26/2026 18:00:02        Only Author  3#
I was really impressed by the depth of the article. Strengthen your IT skills with free Workday-Pro-Talent-and-Performance latest exam questions. Wishing you success!
