[Hardware] New FSCP Test Online - New FSCP Test Format
84
【Hardware】 New FSCP Test Online - New FSCP Test Format
Posted at 1/22/2026 15:25:13      View:185 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4sures FSCP PDF Dumps and FSCP Exam Engine Free Share: https://drive.google.com/open?id=1jtwPwHgZ8ge_myh_GOLZlF5g31J2D1qw
Looking for top-notch Implementing and Operating Forescout Certified Professional Exam (FSCP) exam questions? You've come to the right place! Pass4sures offers a comprehensive and affordable solution for all your FSCP exam needs. Our FSCP Exam Questions are regularly updated, and we provide a range of attractive features to enhance your preparation, including PDF format, an online practice test engine.
These Forescout Certified Professional Exam (FSCP) mock tests will give you real FSCP exam experience. This feature will boost your confidence when taking the Forescout Certified Professional Exam (FSCP) certification exam. The 24/7 support system has been made for you so you don't feel difficulty while using the product. In addition, we offer free demos and up to 1 year of free Forescout Dumps updates. Buy It Now!
FSCP Exam Resources & FSCP Actual Questions & FSCP Exam GuideAdvancement in FSCP information and communications technology generates huge potential for moving business and production up the value-chain, and improving the quality of life of citizens. And there is no doubt that you can get all kinds of information in cyber space now, FSCP latest torrent is not an exception. I strongly recommend the FSCP Study Materials compiled by our company for you, the advantages of our FSCP exam questions are too many to enumerate. And if you have a try on our FSCP exam questions, you will love to buy it.
Forescout Certified Professional Exam Sample Questions (Q10-Q15):NEW QUESTION # 10
What is true of the "Use as directory" selection configured below?
Select one:
  • A. It allows for Guest Registration when Approvals are required
  • B. It allows resolution of user information via RADIUS
  • C. It allows resolution of User information via LDAP
  • D. It allows resolution of user information via TACACS
  • E. It enables HTTP authentication and resolves HTTP login status
According to the Forescout User Directory Plugin Configuration Guide and the RADIUS Plugin Configuration Guide Version 4.3, the "Use as directory" selection allows resolution of user information via LDAP. The documentation explicitly states:
"Use as directory: Select this option to use the server as a directory to retrieve user information. This option is not available for RADIUS and TACACS servers." What "Use as directory" Does:
According to the User Directory Plugin documentation:
When "Use as directory" is selected on a User Directory server configuration:
* LDAP Query Capability - The server can be queried via LDAP to retrieve user information
* User Resolution - User details are resolved by querying the LDAP directory
* Directory Lookups - User properties (group membership, attributes, contact info) are retrieved from the directory
* Policy Matching - Users can be matched in policies based on directory group membership Supported Server Types for "Use as directory":
According to the configuration guide:
The "Use as directory" option is available for:
* Microsoft Active Directory (via LDAP protocol)
* OpenLDAP (via LDAP protocol)
* Other LDAP-compatible directory servers
The "Use as directory" option is NOT available for:
* RADIUS servers - Cannot be used as a directory
* TACACS servers - Cannot be used as a directory
Why RADIUS/TACACS Cannot Be Directories:
According to the documentation:
* RADIUS and TACACS are authentication and authorization protocols, NOT directory protocols
* They do not support directory-style lookups and user attribute queries
* They only provide authentication (username/password verification) and authorization (what the user can do)
* They cannot provide the rich user information that LDAP directories can provide LDAP as a Directory Protocol:
LDAP (Lightweight Directory Access Protocol) provides:
* User Information Storage - Stores user objects with multiple attributes
* Directory Queries - Can query for specific users and their properties
* Group Membership - Can retrieve LDAP group information
* Attribute Resolution - Can access user attributes for policy conditions Three Critical Checkboxes:
According to the RADIUS Plugin Configuration Guide:
"Make sure that both the Use as directory option and the Use for authentication option are enabled." This indicates that a single User Directory server can have multiple roles:
* Use as directory - For LDAP queries and user information resolution
* Use for authentication - For user login authentication
* Use for Console Login - For access to the Forescout Console
Example Configuration:
When you have an Active Directory server:
* # "Use as directory" is CHECKED - Enables LDAP queries for user info and group membership
* # "Use for authentication" is CHECKED - Allows users to authenticate with their AD credentials
* # "Use for Console Login" is CHECKED - Allows administrators to log into Forescout Console with AD credentials Why Other Options Are Incorrect:
* B. It allows resolution of user information via TACACS - Explicitly NOT available for TACACS; TACACS cannot function as a directory
* C. It allows for Guest Registration when Approvals are required - This is a separate User Directory feature unrelated to "Use as directory"
* D. It enables HTTP authentication and resolves HTTP login status - This is not related to directory usage; HTTP authentication is a separate feature
* E. It allows resolution of user information via RADIUS - Explicitly NOT available for RADIUS; RADIUS servers cannot function as directories Referenced Documentation:
* User Directory Plugin Configuration - Define User Directory Servers
* User Directory Plugin - Name and Type Step documentation
* RADIUS Plugin Configuration Guide Version 4.3 - User Directory Readiness section
NEW QUESTION # 11
What should be done after the Managed Windows devices are sent to a policy to determine the Windows 10 patch delivery optimization setting?
  • A. Push out the proper DWORD setting via GPO
  • B. Write sub-rules to check for each of the DWORD values used in patch delivery optimization
  • C. Non Windows 10 devices must be called out in sub-rules since they will not have the relevant DWORD
  • D. Manageable Windows devices are not required by this policy
  • E. Non Windows 10 devices must be called out in sub-rules so that the relevant DWORD value may be changed
Comprehensive and Detailed Explanation From Exact Extract of Forescout Platform Administration and Deployment:
After managed Windows devices are sent to a policy to determine the Windows 10 patch delivery optimization setting, the best practice is to write sub-rules to check for each of the DWORD values used in patch delivery optimization.
Windows 10 Patch Delivery Optimization DWORD Values:
Windows 10 patch delivery optimization is configured through DWORD registry settings in the following registry path:
* ComputerHKEY_LOCAL_MACHINESOFTWAREPoliciesMicrosoftWindowsDeliveryOptimization The primary DWORD value is DODownloadMode, which supports the following values:
* 0 = HTTP only, no peering
* 1 = HTTP blended with peering behind the same NAT (default)
* 2 = HTTP blended with peering across a private group
* 3 = HTTP blended with Internet peering
* 63 = HTTP only, no peering, no use of DO cloud service
* 64 = Bypass mode (deprecated in Windows 11)
Why Sub-Rules Are Required:
When implementing a policy to manage Windows 10 patch delivery optimization settings, administrators must create sub-rules for each possible DWORD configuration value because:
* Different Organizational Requirements - Different departments or network segments may require different delivery optimization modes (e.g., value 1 for some devices, value 0 for others)
* Compliance Checking - Each sub-rule verifies whether a device has the correct DWORD value configured according to organizational policy
* Enforcement Actions - Once each sub-rule identifies a specific DWORD value, appropriate remediation actions can be applied (e.g., GPO deployment, messaging, notifications)
* Granular Control - Sub-rules allow for precise identification of devices with non-compliant delivery optimization settings Implementation Workflow:
* Device is scanned and identified as Windows 10 managed device
* Policy queries the DODownloadMode DWORD registry value
* Multiple sub-rules evaluate the current DWORD value:
* Sub-rule for value "0" (HTTP only)
* Sub-rule for value "1" (Peering behind NAT)
* Sub-rule for value "2" (Peering across private group)
* Sub-rule for value "3" (Internet peering)
* Sub-rule for value "63" (No peering, no cloud)
* Matching sub-rule triggers appropriate policy actions
* A. Push out the proper DWORD setting via GPO - This is what you do AFTER checking via sub-rules, not what you do after sending devices to the policy
* B. Non Windows 10 devices must be called out in sub-rules since they will not have the relevant DWORD - While non-Windows 10 devices should be excluded, the answer doesn't address the core requirement of checking each DWORD value
* C. Manageable Windows devices are not required by this policy - This is incorrect; managed Windows devices are the focus of this policy
* D. Non Windows 10 devices must be called out in sub-rules so that the relevant DWORD value may be changed - This misses the point; you check the DWORD values first, not change them in sub-rules Referenced Documentation:
* Microsoft Delivery Optimization Reference - Windows 10 Deployment
* Forescout Administration Guide - Defining Policy Sub-Rules
* How to use Group Policy to configure Windows Update Delivery Optimization
NEW QUESTION # 12
Which of the following properties can be determined by the HPS Plugin? (Choose two)
  • A. External Device on Windows
  • B. AD group membership
  • C. Operating System
  • D. HTTP banner
  • E. Application installed on Mac OS
According to the Forescout HPS Inspection Engine Configuration Guide and HPS Applications Plugin documentation, the properties that can be determined by the HPS Plugin are: Operating System (C) and HTTP banner (E).
HPS Plugin Capabilities:
According to the HPS Inspection Engine guide:
"The HPS (Host Property Scanner) Inspection Engine provides host properties for detecting endpoint characteristics including operating system, services, and applications." The HPS plugin determines:
* Operating System - OS type, version, service pack level
* HTTP Banner - Service versions from HTTP banner scanning
* Services and Applications - Running processes and installed software
* System Information - Hardware vendor, NIC vendor, etc.
Operating System Detection:
According to the HPS Applications Plugin guide:
"Windows operating system information is detected by the HPS Applications Plugin, including: Release, Package/flavor, Service Pack" The plugin detects:
* Windows OS versions (XP, Vista, 7, 8, 10, etc.)
* Server editions (2003, 2008, 2012, 2016, etc.)
* Service pack levels
* OS build information
HTTP Banner Detection:
"Service Banner: Indicates the service and version information, as determined by Nmap. HTTP banner scanning returns service identification information." The HTTP banner property is resolved by NMAP scanning with the -sV parameter, which is part of the HPS plugin's classification capabilities.
* A. Application installed on Mac OS - The HPS Applications Plugin is for Windows applications only; it does not detect Mac OS applications
* B. External Device on Windows - External Device detection is a separate property unrelated to HPS plugin discovery
* D. AD group membership - This is determined by the User Directory plugin via LDAP, not the HPS plugin HPS Plugin vs. Other Plugins:
Property
HPS Plugin
Other Plugins
Operating System
#Yes
N/A
HTTP Banner
#Yes (NMAP)
N/A
Windows Applications
#Yes
N/A
AD Group Membership
#No
User Directory
Mac OS Applications
#No
macOS-specific
External Devices
#No
Network discovery
* CounterACT Endpoint Module HPS Inspection Engine Configuration Guide v10.8
* CounterACT HPS Applications Plugin Configuration Guide v2.1.4
* About the HPS Applications Plugin
NEW QUESTION # 13
Which field is NOT editable in the User Directory plugin once it is configured?
  • A. Administrator
  • B. Port
  • C. Password
  • D. Address
  • E. Server Name
Answer: E
According to the Forescout User Directory Plugin Configuration Guide and YouTube tutorial for User Directory integration, the Server Name field is NOT editable once the User Directory server is configured.
Once a server configuration is saved, the Server Name cannot be changed; it can only be modified by deleting and reconfiguring the server entry.
User Directory Server Configuration Fields:
According to the User Directory plugin configuration documentation:
When initially adding a server, these fields are configured:
* Server Name - Identifier for the server (e.g., "lab", "production-ad")
* Address - IP address or FQDN (e.g., 192.168.1.100)
* Port - Connection port (e.g., 389, 636)
* Domain - Domain name (e.g., example.com)
* Administrator - Account credentials for authentication
* Password - Password for the administrator account
Editable Fields After Configuration:
According to the configuration workflow:
After the User Directory server is initially configured, the following fields CAN be edited:
* Administrator - Can be changed to update authentication credentials
* Password - Can be updated if credentials change
* Port - Can be modified if the connection port changes
* Address - Can be changed to point to a different server
* Domain - Can be updated if domain name changes
Non-Editable Field:
According to the User Directory plugin behavior:
The Server Name is used as the primary identifier for the User Directory server configuration in Forescout.
Once created, this identifier cannot be modified because it:
* Serves as the unique identifier in the Forescout database
* Is referenced by other configurations and policies
* Changing it would break existing policy references
* Must be deleted and recreated to change
Verification Workflow:
According to the tutorial documentation:
After creating a User Directory server configuration with:
* Server Name: "lab"
* Address: 192.168.1.50
* Port: 389
* Domain: example.com
* Administrator: domainadmin
* Password: [configured]
Once saved and applied, the Server Name "lab" cannot be edited. To change it, you would need to delete the entire configuration and create a new one with a different name.
Why Other Fields Are Editable:
* A. Administrator -#Editable; credentials may need to be updated
* C. Password -#Editable; security practice requires periodic password changes
* D. Address -#Editable; server may move to a different IP
* E. Port -#Editable; port configuration may change based on security requirements Referenced Documentation:
* Forescout User Directory Plugin - Integration tutorial
* Configure server settings documentation
* User Directory Plugin Configuration - Initial Setup documentation
NEW QUESTION # 14
How can a specific event detected by CounterACT (such as a P2P compliance violation event) be permanently recorded with a custom message for auditing purposes?
  • A. Customize the message in the Reports Portal
  • B. Increase the "Purge Inactivity Timeout" setting
  • C. Configure a custom SNMP trap to be sent
  • D. Customize the message in the syslog configuration in Options > Core Ext > Syslog
  • E. Customize the message on the send syslog action
Answer: E
According to the Forescout Administration Guide and Syslog Plugin Configuration Guide, specific events detected by CounterACT can be permanently recorded with a custom message for auditing purposes by customizing the message on the send syslog action.
Send Message to Syslog Action:
According to the official documentation:
"You can send customized messages to Syslog for specific endpoints using the Forescout eyeSight Send Message to Syslog action, either manually or based on policies." How to Configure Custom Messages:
According to the Syslog Plugin Configuration Guide:
* Create or Edit a Policy - Select a policy and edit the Main Rule section
* Add an Action - In the Actions section, select "Add"
* Select Send Message to Syslog - From the Audit folder, select "Send Message to Syslog"
* Customize the Message - Specify the custom message to send when the policy is triggered Custom Message Configuration:
When configuring the "Send Message to Syslog" action, you specify:
* Message to syslog - Type a custom message to send to the syslog server when the policy is triggered
* Message Identity - Free-text field for identifying the syslog message
* Syslog Server Address - The syslog server to receive the message
* Syslog Server Port - Typically port 514
* Syslog Server Protocol - TCP or UDP
* Syslog Facility - Message facility classification
* Syslog Priority - Severity level (e.g., Info)
Example Implementation for P2P Compliance Violation:
For a P2P compliance violation event, you would:
* Create a policy that detects P2P traffic violations
* Add a "Send Message to Syslog" action
* Customize the message to something like: "P2P VIOLATION: Endpoint [IP] detected unauthorized P2P application traffic"
* Configure the syslog server details
* When the condition is triggered, CounterACT sends the custom message to syslog for permanent auditing Permanent Recording:
The messages sent to syslog are:
* Permanently recorded on the syslog server
* Timestamped automatically by Forescout and/or the syslog server
* Available for audit trails and compliance reports
* Can be forwarded to SIEM systems like Splunk or EventTracker for further analysis Why Other Options Are Incorrect:
* B. Increase the "Purge Inactivity Timeout" setting - This relates to device timeout, not event recording or custom messages
* C. Customize the message in the Reports Portal - The Reports Portal displays reports but does not customize messages for syslog events
* D. Configure a custom SNMP trap - SNMP traps are for network device management, not for recording Forescout events
* E. Customize the message in the syslog configuration in Options > Core Ext > Syslog - While syslog configuration is done here, the actual custom messages are configured in the "Send Message to Syslog" action within policies Referenced Documentation:
* How-To Guide: ForeScout CounterAct to forward logs to EventTracker
* Audit Actions documentation
* How to Work with the Syslog Plugin
* Send Message to Syslog Action documentation
NEW QUESTION # 15
Firstly, our company always feedbacks our candidates with highly-qualified FSCP study guide and technical excellence and continuously developing the most professional FSCP exam materials. Secondly, our FSCP study materials persist in creating a modern service oriented system and strive for providing more preferential activities for your convenience. Come and buy our FSCP Exam Materials, you will get more than you can imagine!
New FSCP Test Format: https://www.pass4sures.top/Forescout-Certified-Professional/FSCP-testking-braindumps.html
The experts in our company have been focusing on the FSCP examination for a long time and they never overlook any new knowledge, Forescout New FSCP Test Online Of course, if you unluckily fail to pass your exam, don't worry, because we have created a mechanism for economical compensation, Pass4sures New FSCP Test Format has been offering services for last 10 years and helped up to 90,000+ satisfied users globally, by making them pass New FSCP Test Format - Forescout Certified Professional Exam Exam, So you need to learn our FSCP study materials carefully after you have paid for them.
A light source hits the paper, the image or text is reflected FSCP into your eyes, and something is lost in the processâ?namely brilliant colors, Inserts and updates are not supported;
The experts in our company have been focusing on the FSCP examination for a long time and they never overlook any new knowledge, Of course, if you unluckily fail to pass your FSCP Reliable Test Blueprint exam, don't worry, because we have created a mechanism for economical compensation.
Valid Forescout Certified Professional Exam Exam Dumps 100% Guarantee Pass Forescout Certified Professional Exam Exam - Pass4suresPass4sures has been offering services for last 10 years and helped up to 90,000+ satisfied users globally, by making them pass Forescout Certified Professional Exam Exam, So you need to learn our FSCP study materials carefully after you have paid for them.
One has to pass an FSCP exam of that particular Forescout Certified Professional Exam certification Exam in order to excel in the field of IT.
BTW, DOWNLOAD part of Pass4sures FSCP dumps from Cloud Storage: https://drive.google.com/open?id=1jtwPwHgZ8ge_myh_GOLZlF5g31J2D1qw
