[Hardware] IPC-M10R800-A3568J AI Industrial Tablet PC
66
Hardware IPC-M10R800-A3568J AI Industrial Tablet PC
Posted at 6/22/2024 14:34:53      View4046 | Replies7        Print      Only Author   [Copy Link] 1#
Hello staff
I have a question about the pin connections of the HIMAX chipset in the DTS for the board in the 'IPC-M10R800-A3568J
AI Industrial Tablet PC' (AIO-3568J Board) . In the DTS only the RESET PIN is connected to the PCA9555 extender chip and the IRQ PIN is connected to the RK3568 pin "RK_PC1". The kernel reports that "himax,gpio_3v3_en" is not valid. My application turns off the backlight after 30 minutes (/sys/class/backlight/backlight/brightness == 0). After a few hours I noticed that the touchscreen stopped responding (froze) but my QT application continued to work normally (log output of the background jobs). I used a simple C program to read the device /dev/input/event2. This C test program also doesn't respond when I tap the touchscreen with my fingers.
So my question is:
1) Is the HX83102-B built into the tablet?
2) How is the HIMAX chip supplied with power.
3) Is there a schematic plan for the IPC-M10R800-A3568J tablet (AIO-3568J board)?
Greetings
log.txt.gz
504 Bytes, Down times: 0
Posted at 6/23/2024 19:05:11        Only Author  2#
HIMAX Touchpanel Driver Firefly Linux Kernel
So, after a long analysis of the HIMAX driver, I found the cause. The driver registers event handlers for 'screen blank' in the FB/DRM subsystem. So far so good. But some 'grr' thinks that you have to switch off the power supply of the touch panel (3v3 GPIO) in the 'Screen Blank' event. The big question is, how high is the probability that the chip will realize without power that the user is tapping the touch panel with their finger?
The answer: Never!!!!
I love programmers who seem to switch off their brains when they 'hack'.
After I DIDN'T call himax_common_suspend() and himax_common_resume(), the panel responds immediately when tapped with my finger. By the way: xx_supend and xx_resume are intended for the kernel PM subsystem, not for blank screen events!
Since HIMAX is not listed in the maintainers list, I strongly assume that some 'grr' from FF put the driver including code for the MCU FW programming in the kernel tree.
Greetings
Posted at 12/9/2024 14:25:45        Only Author  3#
Thanks! I can share wordle unlimited and strategies with friends or social media, creating a shared experience and friendly rivalry.
Posted at 12/9/2024 14:34:16        Only Author  4#
Good
Posted at 8/22/2025 11:57:11        Only Author  5#
I am also looking for the exact answer to this topic and am wordle nyt very unhappy that till now I have not found a solution to it, I would be very happy if someone here can give a best solution to solve it.
restricted members
Posted at 1/17/2026 01:17:10        Only Author  6#
It was such a valuable learning experience. The SOA-C03 reliable test pattern was my key to successpromotion and salary raise. Its now free for everyone. Wishing you all a fast track to promotions!
Posted at 1/24/2026 07:38:37        Only Author  7#
Your article has made a lasting impression, thank you for it. Im sharing the DEP-2025 new braindumps ebook exam materialsbest of luck to everyone!
Posted at 3/5/2026 17:40:22        Only Author  8#
I feel much more informed after reading that piece. The Test AZ-400 name questions are shared for free. Good luck on your exams!
