[General] CTFL-AT 100% Accuracy & CTFL-AT Valid Test Voucher
112
【General】 CTFL-AT 100% Accuracy & CTFL-AT Valid Test Voucher
Posted at 1/22/2026 18:14:19      View:178 | Replies:3        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of TrainingDumps CTFL-AT dumps for free: https://drive.google.com/open?id=1TkKbVaTEJjfbB1dk_2KRsnilhTMyskH-
With our ISQI CTFL-AT practice materials, and your persistence towards success, you can be optimistic about your CTFL-AT real dumps. Even you have bought our ISQI CTFL-AT learning braindumps, and we will send the new updates to you one year long. On one hand, all content can radically give you the best backup to make progress.
ISQI CTFL-AT Exam is a certification exam that tests the proficiency of individuals in the field of Agile Testing. CTFL-AT exam is designed for individuals who have already obtained their ISTQB Certified Tester - Foundation Level certification and wish to expand their knowledge in Agile Testing. The CTFL-AT Exam is an internationally recognized certification that demonstrates the knowledge and skills required for Agile Testing.
The CTFL-AT Exam is designed to test the candidate's knowledge and understanding of agile testing methodologies, as well as their ability to apply that knowledge in real-world scenarios. CTFL-AT exam consists of 40 multiple-choice questions and has a duration of 60 minutes. To pass the exam, candidates must score a minimum of 65%.
High-quality CTFL-AT 100% Accuracy & Useful Tips to help you pass CTFL-AT: ISTQB Certified Tester - Foundation Level Extension - Agile TesterWhile attempting the exam, take heed of the clock ticking, so that you manage the ISQI CTFL-AT Questions in a time-efficient way. Even if you are completely sure of the correct answer to a question, first eliminate the incorrect ones, so that you may prevent blunders due to human error.
The CTFL-AT exam is designed to test the proficiency of testers in agile development processes and methodologies. CTFL-AT exam covers topics such as agile principles and values, agile testing practices, testing in agile projects, and tools and techniques used in agile testing. CTFL-AT Exam is challenging and requires a deep understanding of the agile testing process, making it a highly respected certification among employers.
ISQI ISTQB Certified Tester - Foundation Level Extension - Agile Tester Sample Questions (Q80-Q85):NEW QUESTION # 80
Which of the following is a risk that continuous integration introduces?
  • A. Teams no longer have the ability to run manual tests, as all tests must be automated.
  • B. Developer's workload is increased, which can result in a reduction of output.
  • C. Teams sometimes over-rely on unit tests and exclude some important system and acceptance tests.
  • D. Testers sometimes have too many builds to test, which reduces the quality of testing.
Continuous integration is a practice of integrating code changes frequently and automatically into a shared repository, and running automated tests to verify the integration. Continuous integration can introduce some risks to the testing process, such as:
* Testers sometimes have too many builds to test, which reduces the quality of testing. This can happen when the code changes are too frequent or too large, and the testers do not have enough time or resources to test each build thoroughly. This can lead to missed defects, incomplete test coverage, and reduced confidence in the product quality.
* Testers sometimes have to deal with unstable or broken builds, which affects the testability of the product. This can happen when the code changes introduce errors or conflicts that cause the build to fail or malfunction. This can waste the testers' time and effort, and delay the feedback cycle.
* Testers sometimes have to cope with changing requirements and priorities, which affects the test planning and execution. This can happen when the stakeholders or customers provide new or modified requirements or feedback during the development cycle. This can require the testers to adapt their test strategy, test cases, and test data accordingly, and to balance the testing of new features and regression testing of existing features. References: ISTQB Foundation Level Agile Tester Syllabus1, Section
2.2.3, page 14; ISTQB Glossary of Testing Terms2, version 4.0, page 15.
NEW QUESTION # 81
Which of the following describes the main purpose of a task management tool in agile projects?
  • A. A task management tool is used to store source code and automated tests.
  • B. A task management tool is used by team members to share ideas and collaborate on assigned tasks.
  • C. A task management tool allows developers to continuously integrate their code.
  • D. A task management tool is used to manage and track user stories, tests and other tasks.
A task management tool is a software application that helps agile teams plan, organize, and monitor their work. A task management tool typically allows the team to create, assign, prioritize, update, and track user stories, tests, and other tasks that are part of the agile project. A task management tool can also provide various views and reports to visualize the progress and status of the project, such as Kanban boards, burndown charts, velocity charts, etc. Some examples of task management tools are Jira, Trello, Asana, and Monday.com12345. References: ISTQB Foundation Level Agile Tester Syllabus, Section 2.1.1, page 13; ASTQB Agile Tester Certification Resources, Section 2.1.1, page 13.
NEW QUESTION # 82
Which of the following is the BEST way for a test team to keep its independence when working in an Agile development environment?
  • A. Locate the team that develops the test automation framework in a different location to the Agile development team.
  • B. Co-locate only some of the testers with the Agile development team, while the rest of the testers are in a different location.
  • C. Assign testers to be members of the Agile team, but ensure the testers report to a different manager than the developers.
  • D. Share the Test Strategy with the Agile development team, but not the details of the Test Cases.
NEW QUESTION # 83
NEW QUESTION # 84
Which of the following statements is FALSE regarding early and frequent feedback?
  • A. Early feedback promotes early discovery and resolution of quality problems.
  • B. Early feedback provides the Agile team with information on its productivity.
  • C. Early feedback decreases the amount of time needed for system testing.
  • D. Early feedback helps to deliver a product that better reflects what the customer wants.
Early and frequent feedback is one of the core values of Agile development. It helps the Agile team to deliver features with the highest business value first, to discover and resolve quality problems as soon as possible, to provide information on the team's productivity and progress, and to ensure that the product meets the customer's expectations and needs. However, early feedback does not necessarily decrease the amount of time needed for system testing, as system testing is still an important activity in Agile projects to verify the integration and functionality of the whole system. Early feedback may reduce the number of defects found in system testing, but it does not eliminate the need for system testing. References: ISTQB Foundation Level Agile Tester Extension Syllabus1, page 10; ISTQB Agile Tester Sample Exam2, question 11.
NEW QUESTION # 85
CTFL-AT Valid Test Voucher: https://www.trainingdumps.com/CTFL-AT_exam-valid-dumps.html
DOWNLOAD the newest TrainingDumps CTFL-AT PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1TkKbVaTEJjfbB1dk_2KRsnilhTMyskH-
Posted at 1/27/2026 08:35:39        Only Author  2#
It’s truly amazing, thank you for the fantastic share! Improve your IT skills and get free New DA0-001 exam registration access. Wishing you the best of luck!
Posted at 2/4/2026 00:49:12        Only Author  3#
Your article really opened my eyes, I’m so grateful for it. I earned a promotion and salary increase using this examcollection FCSS_CDS_AR-7.6. Now, I’m sharing it for free. Wishing you success in your career progress!
Posted at 2/5/2026 11:35:08        Only Author  4#
Testpdf是一個為參加C-THR82-2505認證考試的考生提供C-THR82-2505認證考試培訓工具的網站。Testpdf提供的培訓工具很有針對性,可以幫他們節約大量寶貴的時間和精力。我們的練習題及答案和真實的考試題目很接近。短時間內使用Testpdf的模擬測試題你就可以100%通過考試。這樣花少量的時間和金錢換取如此好的結果,是值得的。快將Testpdf提供的培訓工具放入你的購物車中吧。
