Updated PL-300 Demo, PL-300 Latest Dumps Book
Posted at 1/22/2026 19:06:56
What's more, part of that Free4Torrent PL-300 dumps now are free: https://drive.google.com/open?id=1HPXZ1ncEgym-ND7ntkVdtGxMBKZTXwMA
Regularly updated material content to ensure you are always practicing with the most up-to-date preparation material which covers all the changes that are made to the Microsoft Power BI Data Analyst (PL-300) exam questions from Free4Torrent. Our preparation material is built in such a way that it will help everyone even a beginner to reach his goal of clearing the Microsoft PL-300 Exam Dumps from Free4Torrent just in one attempt.
Microsoft PL-300 Exam is a vendor-neutral certification, which means that it is not tied to any specific hardware or software platform. This makes it a great option for professionals from different industries who may be using various technologies and platforms. Furthermore, the exam is also accessible to individuals who are new to the field of data and analytics, providing them with a solid foundation to build their skills and career from.
Microsoft PL-300 exam is a great opportunity for professionals who want to enhance their career prospects in business intelligence and data analytics. Microsoft Power BI Data Analyst certification is recognized globally and is highly sought after by organizations that use Power BI to make data-driven decisions. By passing PL-300 Exam, you can demonstrate your expertise in using Power BI to transform data into insights that can help organizations make informed decisions.
Microsoft PL-300 exam is an excellent opportunity for individuals who want to validate their skills and knowledge in using Power BI to analyze and visualize data. With the demand for data analysts increasing across industries, earning this certification can help individuals stand out in a competitive job market and open up new career opportunities.
PL-300 Latest Dumps Book | Valid PL-300 Exam ExperienceThe web-based PL-300 practice test is accessible via any browser. This PL-300 mock exam simulates the actual Microsoft PL-300 exam and does not require any software or plugins. Compatible with iOS, Mac, Android, and Windows operating systems, it provides all the features of the desktop-based PL-300 Practice Exam software.
Microsoft Power BI Data Analyst Sample Questions (Q378-Q383):NEW QUESTION # 378
Note: This question is part of a series of questions that use the same scenario. For your convenience, the scenario is repeated in each question. Each question presents a different goal and answer choices, but the text of the scenario is the same in each question in this series.
You have a Microsoft SQL Server database that contains the following tables.
The following columns contain date information:
- Date[Month] in the mmyyyy format
- Date[Date_ID] in the ddmmyyyy format
- Date[Date_name] in the mm/dd/yyyy format
- Monthly_returns[Month_ID] in the mmyyyy format
The Order table contains more than one million rows.
The Store table has a relationship to the Monthly_returns table on the Store_ID column. This is the only relationship between the tables.
You plan to use Power BI Desktop to create an analytics solution for the data.
You need to create a relationship between the Monthly_returns table and Date[Date_ID].
What should you do before you create the relationship?
- A. In the Date table, create a new calculated column named MonthJD that uses the yyyydd format.
- B. To the Order table, add a calculated column that uses the RELATED(Monthly_returns[Month_ID]) DAX formula.
- C. To the Date table, add a calculated column that uses the RE LATE D(Monthly_ret urns [MonthJD]) DAX formula.
- D. In the Monthly_returns table, create a new calculated column named DateJD that uses the ddmmyyyy format.
https://docs.microsoft.com/en-us ... anage-relationships
NEW QUESTION # 379
You are creating a quick measure as shown in the following exhibit.
You need to create a monthly rolling average measure for Sales over time-How should you configure the quick measure calculation? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... ktop-quick-measures
NEW QUESTION # 380
You have a Microsoft Power BI data model that contains three tables named Sales, Product, and Date.
The Sales table has an existing measure named [Total Sales] that sums the total sales from the Sales table.
You need to write a calculation that returns the percentage of total sales that a selected ProductCategoryName value represents. The calculation must respect any slicers on ProductCategoryName and must show the percentage of visible total sales. For example, if there are four ProductCategoryName values, and a user filters one out, a table showing ProductCategoryName and the calculation must sum up to 100 percent.
How should you complete the calculation? To answer, drag the appropriate values to the correct targets. Each value may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Divide, Calculate, AllSelected.
https://docs.microsoft.com/en-us/dax/allselected-function-dax
NEW QUESTION # 381
You have a Power Bl query named Sates that imports the columns shown in the following table.
Usees only use the dale part of the Sales.Date field. Only rows with a Status of Finished are used in analysis.
You need to reduce the load times of the query without affecting the analysis.
Which two actions achieve this goal? Each correct answer presents a complete solution.
NOTL Each correct selection is worth one pant.
- A. Removes (Canceled Date).
- B. Remove the rows in which sales [status] has a value of Canceled.
- C. Remove sales [Sales_Date].
- D. Split Sales [Sale_Date] into separate date and time columns.
- E. Change the data type of sale [Delivery_Time] to Integer
NEW QUESTION # 382
You open powerbi.com as shown in the following exhibit.
NEW QUESTION # 383
We can provide you with efficient online services during the whole day, no matter what kind of problems or consultants about our PL-300 quiz torrent; we will spare no effort to help you overcome them sooner or later. First of all, we have professional staff with dedication to check and update out PL-300 Exam Torrent materials on a daily basis, so that you can get the latest information from our PL-300 exam torrent at any time. Besides our after-sales service engineers will be always online to give remote guidance and assistance for you on PL-300 study questions if necessary.
PL-300 Latest Dumps Book: https://www.free4torrent.com/PL-300-braindumps-torrent.html
- PL-300 Pass Rate 💽 PL-300 Advanced Testing Engine 🔭 PL-300 Latest Study Plan ✊ Go to website ➠ [url]www.troytecdumps.com 🠰 open and search for ⏩ PL-300 ⏪ to download for free 🍏
L-300 Latest Study Plan[/url] - Famous PL-300 Training Brain Dumps present the most useful Exam Materials - Pdfvce 👺 Search for ⇛ PL-300 ⇚ and download exam materials for free through 「 [url]www.pdfvce.com 」 💾
L-300 Latest Study Plan[/url] - Study PL-300 Demo ⏸ Pdf PL-300 Version 🙇 Latest PL-300 Test Question 🎵 Easily obtain ▷ PL-300 ◁ for free download through 《 [url]www.examdiscuss.com 》 🤬
ass PL-300 Exam[/url] - PL-300 Visual Cert Exam 🍔 PL-300 Visual Cert Exam 🍅 PL-300 Visual Cert Exam 🚪 Simply search for ⇛ PL-300 ⇚ for free download on ⏩ [url]www.pdfvce.com ⏪ 🕗
L-300 Paper[/url] - PL-300 Exam Engine 🎁 PL-300 Exam Questions Fee ⚓ Study PL-300 Demo 🍓 Immediately open 《 [url]www.testkingpass.com 》 and search for “ PL-300 ” to obtain a free download 🍬
L-300 Advanced Testing Engine[/url] - Latest PL-300 Exam Notes 📉 PL-300 Official Study Guide 🧁 PL-300 Valid Exam Format 🥮 Search for ➡ PL-300 ️⬅️ and obtain a free download on ⮆ [url]www.pdfvce.com ⮄ 🚦
L-300 Pass Rate[/url] - Valid Microsoft PL-300 - Tips To Pass PL-300 Exam 🔐 Search for ▶ PL-300 ◀ and easily obtain a free download on ⏩ [url]www.prepawaypdf.com ⏪ 📗Latest PL-300 Test Question[/url]
- [url=https://www.tirocinicrui.it/?s=Microsoft%20PL-300%20Questions%20%e2%80%93%20Best%20Way%20To%20Clear%20The%20Exam%20[2026]%20%f0%9f%90%b7%20The%20page%20for%20free%20download%20of%20%e2%8f%a9%20PL-300%20%e2%8f%aa%20on%20%e2%8f%a9%20www.pdfvce.com%20%e2%8f%aa%20will%20open%20immediately%20%e2%ad%95PL-300%20Pass%20Rate]Microsoft PL-300 Questions – Best Way To Clear The Exam [2026] 🐷 The page for free download of ⏩ PL-300 ⏪ on ⏩ www.pdfvce.com ⏪ will open immediately ⭕
L-300 Pass Rate[/url] - PL-300 Official Study Guide 👲 PL-300 Exam Outline 🤨 PL-300 Pass Rate 🛅 Download ☀ PL-300 ️☀️ for free by simply entering ➽ [url]www.examcollectionpass.com 🢪 website 🐢
L-300 Exam Engine[/url] - Valid Microsoft PL-300 - Tips To Pass PL-300 Exam 🦔 Simply search for 【 PL-300 】 for free download on ( [url]www.pdfvce.com ) 📼
L-300 Free Download Pdf[/url] - Microsoft PL-300 Dumps [2026] –PL-300 Exam Questions ▛ The page for free download of ▛ PL-300 ▟ on ➤ [url]www.validtorrent.com ⮘ will open immediately ➿Latest PL-300 Test Question[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, iibat-academy.com, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New PL-300 dumps are available on Google Drive shared by Free4Torrent: https://drive.google.com/open?id=1HPXZ1ncEgym-ND7ntkVdtGxMBKZTXwMA
