Oracle 1z0-076 Latest Braindumps Ppt | Latest 1z0-076 Exam Preparation
Posted at 1/22/2026 19:42:50
P.S. Free 2026 Oracle 1z0-076 dumps are available on Google Drive shared by Prep4cram: https://drive.google.com/open?id=1lwTt11hKmgwY8fmjBtcbNKRblssfAaLj
You won't be anxious because the available Oracle 1z0-076 exam dumps are structured instead of distributed. Oracle Database 19c: Data Guard Administration (1z0-076) certification exam candidates have specific requirements and anticipate a certain level of satisfaction before buying a Oracle 1z0-076 Practice Exam. The Oracle 1z0-076 practice exam applicants can rest assured that Prep4cram's round-the-clock support staff will answer their questions.
Prep4cram actual 1z0-076 exam questions in PDF format are ideal for individuals who prefer to study on their tablets, laptops, and smartphones. Since these 1z0-076 exam questions can be studied from any place at any time, making this format a perfect alternative for candidates who are frequently on the move and want to prepare for the exam in a short time. Questions in the Oracle 1z0-076 Pdf Format are printable, allowing you to prepare for the 1z0-076 test via hard copy. Our Oracle 1z0-076 PDF version is regularly updated to improve the 1z0-076 exam questions based on the 1z0-076 real certification test’s content.
Latest 1z0-076 Exam Preparation - 1z0-076 ExamcollectionWould you like to pass Oracle 1z0-076 test and to get 1z0-076 certificate? Prep4cram can guarantee your success. When you are preparing for 1z0-076 exam, it is necessary to learn test related knowledge. What's more important, you must choose the most effective exam materials that suit you. Prep4cram Oracle 1z0-076 Questions and answers are the best study method for you. The high quality exam dumps can produce a wonderful effect. If you fear that you cannot pass 1z0-076 test, please click Prep4cram.com to know more details.
Oracle Database 19c: Data Guard Administration Sample Questions (Q78-Q83):NEW QUESTION # 78
Examine this query and its output:
Which two statements are true?
- A. Cats is a bystander database.
- B. The master observer is not running, but should run on ol7.example.com.
- C. The master observer is not connected to the database on which the query was executed.
- D. The master observer is connected to the database on which the query was executed.
- E. The master observer is currently running on ol7.example.com.
D . The database role indicated by FS_FAILOVER_STATUS as BYSTANDER implies that the database is a standby database in the Data Guard configuration. This means the database is neither a primary database nor an active failover target.
E . Since the FS_FAILOVER_OBSERVER_HOST column shows cats, it suggests that this is the host on which the observer would run. However, because the FS_FAILOVER_OBSERVER_PRESENT column is not shown, we cannot definitively state if the observer is currently connected or not. If FS_FAILOVER_OBSERVER_PRESENT is 'YES', the observer is connected, if 'NO', then it's not. In the absence of this column's output, the best assumption based on the available data is that the observer is not connected.
The output shows that the FS_FAILOVER_STATUS is BYSTANDER, which indicates that the database in question is not actively involved in a fast-start failover configuration as a primary or standby. It is in a bystander role, meaning that while it is part of a Data Guard configuration, it is neither a target for failover nor actively participating in failover operations. Additionally, FS_FAILOVER_OBSERVER_HOST shows 'cats', which indicates the host where the observer process is expected to run. However, since there is no information about the observer being present, we can infer that although 'cats' is designated for the observer to run, the observer is not currently connected to this database.
Reference
Oracle documentation on Data Guard configurations and the V$DATABASE view which provides information about the fast-start failover status and observer host.
NEW QUESTION # 79
Which THREE statements are true........ open in real time query mode, which becomes a new.
- A. User sessions can be retained.
- B. User sessions and Current Buffers are maintained by default.
- C. All current buffers can be retained.
- D. Sessions that have long running queries can be retained.
- E. Sessions that are using database links
- F. All sessions are disconnected and all
Answer: A,C,F
When a physical standby database is opened in real-time query mode, which may be referred to as real-time apply when using Active Data Guard, certain operations can disrupt ongoing sessions. However, with features like Application Continuity and the proper configuration of initialization parameters such as STANDBY_DB_PRESERVE_STATES, user sessions and current buffers may be preserved during role transitions such as a switchover or failover. Specifically, the STANDBY_DB_PRESERVE_STATES parameter can be set to preserve none, all, or only user sessions during such transitions. This ensures that in-flight transactions are not lost and that users do not experience disruptions during the role transitions of a physical standby database.
References
* Oracle Data Guard Concepts and Administration
* Oracle Database Licensing Information User Manual
* Oracle Data Guard Broker User Manual
NEW QUESTION # 80
You must configure flashback database for your Oracle 19c databases that will be part of a Data Guard Broker configuration.
The databases are all in ARCHIVELOG mode.
You will execute the SQL statement:
ALTER DATABASE FLASHBACK ON;
Which three are true concerning this command?
- A. If executed successfully on an Oracle 19c primary database, flashback will also be enabled on all logical standby databases that are part of the configuration.
- B. If executed successfully on an Oracle 19c primary database, flashback will also be enabled on all physical standby databases that are part of the configuration.
- C. It will execute successfully on an Oracle 19c logical standby database while SQL apply is active.
- D. It will execute successfully on an Oracle 19c physical standby database while Real Time Query is active.
- E. It will execute successfully while an Oracle 19c primary database is open.
- F. It will execute successfully while an Oracle 19c primary database is mounted.
Answer: C,E,F
The command ALTER DATABASE FLASHBACK ON; enables the Flashback Database feature, which provides a way to quickly revert an entire Oracle database back to a previous point in time. This command can be executed while an Oracle 19c primary database is either open (option A) or mounted (option B). It is also applicable to an Oracle 19c logical standby database while SQL Apply is active (option E). However, it's important to note that enabling Flashback Database on the primary does not automatically enable it on all associated standby databases, whether they are physical or logical. Each database in a Data Guard configuration must have Flashback Database explicitly enabled if desired. Real Time Query being active on a physical standby does not directly relate to the ability to execute this command on the standby. Reference: The explanation is based on Oracle's concepts for Flashback Technology and Data Guard configurations as detailed in the Oracle Database Backup and Recovery User's Guide and the Oracle Data Guard Concepts and Administration guide.
NEW QUESTION # 81
You notice that the SQL apply lag on your logical standby database has increased but the redo transport lag has not.
Which four could be reasons for the increase in SQL apply lag?
- A. The standby redo log files are undersized on the primary database
- B. An undersized undo tablespace on the logical standby
- C. An undersized shared pool
- D. An increased number of bulk updates on the primary
- E. An increased number of bulk inserts on the primary
- F. Many SQL apply operations do full table scans
Answer: B,C,D,F
The SQL apply lag on a logical standby database can be caused by several factors:
A: An undersized undo tablespace can lead to delays in SQL apply operations as it may not be able to handle the volume of undo records generated by the SQL apply process.
B: SQL apply operations that do full table scans can consume significant system resources, potentially leading to higher apply lag.
C: An increased number of bulk updates on the primary database may generate a large volume of redo data, which can cause apply lag if the logical standby cannot apply the changes quickly enough.
F: An undersized shared pool may affect the parsing and execution of SQL statements by SQL apply, which can contribute to the apply lag.
Option D is less likely to be a direct cause of SQL apply lag compared to bulk updates, as inserts generate new data rather than modifying existing data, which SQL apply can typically handle more efficiently.
Option E is incorrect because the size of the standby redo log files on the primary database impacts redo transport lag, not SQL apply lag.
NEW QUESTION # 82
Your Data Guard configuration consists of these components and settings:
1. A primary database
2. A remote physical standby database
3. Real-time query is enabled
4. Redo transport mode is synchronous
5. Protection mode is maximum availability
6. The Data Guard broker is used
You notice that the standby destination fails to acknowledge reception of redo within net_timeout period of time.
Which is true in this scenario?
- A. The protection mode will automatically change to Maximum Performance.
- B. The physical standby database instance is shut down by the Data Guard broker.
- C. Real-time query will be disabled on the physical standby.
- D. Synchronous redo transport mode connections to the standby database are terminated.
In a Data Guard configuration where the protection mode is set to Maximum Availability and synchronous redo transport is enabled, if the standby destination fails to acknowledge the reception of redo within the net_timeout period, the primary database will terminate the synchronous redo transport mode connections to the standby database to protect the primary database from hanging (C). The primary database then operates in a Maximum Performance mode until the issue is resolved. This behavior ensures that the primary database can continue to process transactions even when the standby database is temporarily unavailable.
The Oracle Data Guard Broker documentation and Oracle Data Guard Concepts and Administration guide detail the behavior of different protection modes and the response to network timeouts, including the fallback to asynchronous redo transport to maintain primary database availability.
NEW QUESTION # 83
As long as you are willing to exercise on a regular basis, the 1z0-076 exam will be a piece of cake, because what our 1z0-076 practice materials include is quintessential points about the exam. And our high pass rate as 98% to 100% are all proved data form our customers who had attended the 1z0-076 Exam and got their success with the help of our 1z0-076 study dumps. So just come on and join our success!
Latest 1z0-076 Exam Preparation: https://www.prep4cram.com/1z0-076_exam-questions.html
Oracle 1z0-076 Latest Braindumps Ppt If you indeed fail the exam, money back will be guaranteed, Oracle 1z0-076 Latest Braindumps Ppt After you pass the exam you will gain a lot of benefits such as enter in the big company and double your wage, We try our best to renovate and update our 1z0-076 study materials in order to help you fill the knowledge gap during your learning process, thus increasing your confidence and success rate in the 1z0-076 exam, Oracle 1z0-076 Latest Braindumps Ppt Our company is willing to offer help 24/7 all the year round, so you can seek out our assistance as you wish.
Also, make sure you're using terms that people use, not the terms Exam 1z0-076 Online you would like them to use, It just didn't make sense, If you indeed fail the exam, money back will be guaranteed.
After you pass the exam you will gain a lot of benefits 1z0-076 such as enter in the big company and double your wage, We try our best to renovate and update our 1z0-076 study materials in order to help you fill the knowledge gap during your learning process, thus increasing your confidence and success rate in the 1z0-076 exam.
1z0-076: Oracle Database 19c: Data Guard Administration torrent & Testking 1z0-076 guideOur company is willing to offer help 24/7 all the year round, so you can seek out Latest 1z0-076 Exam Preparation our assistance as you wish, When you visit other sites or buy exam dumps from other vendors, you will find the free update have some restricted condition.
- 2026 High hit rate 1z0-076 Latest Braindumps Ppt Help You Pass 1z0-076 Easily 🚘 Search for ➠ 1z0-076 🠰 on ⏩ [url]www.examcollectionpass.com ⏪ immediately to obtain a free download 🔀1z0-076 Valid Test Voucher[/url]
- 1z0-076 PDF Questions 💑 1z0-076 Valid Test Voucher 🧲 Free 1z0-076 Practice 👇 Search for “ 1z0-076 ” and download it for free immediately on ⮆ [url]www.pdfvce.com ⮄ 🔦1z0-076 Reliable Cram Materials[/url]
- 1z0-076 Valid Study Materials 🖼 1z0-076 Test Collection Pdf 🌙 1z0-076 Valid Test Voucher 🚉 Enter ➡ [url]www.vceengine.com ️⬅️ and search for ➽ 1z0-076 🢪 to download for free 🎨1z0-076 Test Quiz[/url]
- 1z0-076 Relevant Exam Dumps 🍨 Latest 1z0-076 Dumps Sheet 🏜 1z0-076 PDF Questions 🔯 Open 【 [url]www.pdfvce.com 】 and search for 「 1z0-076 」 to download exam materials for free 🦊Latest 1z0-076 Exam Price[/url]
- 100% Success Guarantee by Using Oracle 1z0-076 Exam Questions and Answers 🥳 The page for free download of 「 1z0-076 」 on ➽ [url]www.testkingpass.com 🢪 will open immediately ☁1z0-076 Valid Test Voucher[/url]
- 1z0-076 Valid Study Materials 😤 1z0-076 Relevant Exam Dumps 🦦 Test 1z0-076 Engine 🈺 Search for ➡ 1z0-076 ️⬅️ and download exam materials for free through ▶ [url]www.pdfvce.com ◀ 🔩1z0-076 Reliable Cram Materials[/url]
- Latest 1z0-076 Exam Materials 🎿 1z0-076 Test Fee ▛ 1z0-076 Relevant Exam Dumps 🆔 Go to website ( [url]www.prepawayete.com ) open and search for 《 1z0-076 》 to download for free 💸1z0-076 Reliable Cram Materials[/url]
- 2026 High Hit-Rate 1z0-076 Latest Braindumps Ppt | 100% Free Latest Oracle Database 19c: Data Guard Administration Exam Preparation 🐕 Search for ⮆ 1z0-076 ⮄ and download it for free immediately on 【 [url]www.pdfvce.com 】 🃏1z0-076 Relevant Exam Dumps[/url]
- 1z0-076 Test Fee 🩳 Latest 1z0-076 Dumps Sheet ⏺ Latest 1z0-076 Exam Price 🚒 Download ➥ 1z0-076 🡄 for free by simply entering ➤ [url]www.testkingpass.com ⮘ website 🤽1z0-076 Relevant Exam Dumps[/url]
- 1z0-076 Valid Study Materials 🏝 Latest 1z0-076 Mock Test 👲 1z0-076 Cert 🏤 Search for ☀ 1z0-076 ️☀️ and download it for free immediately on 【 [url]www.pdfvce.com 】 🟥1z0-076 New Cram Materials[/url]
- Online Oracle 1z0-076 Practice Test Engine Designed by Experts 🐘 Enter ( [url]www.pdfdumps.com ) and search for 《 1z0-076 》 to download for free 🛥1z0-076 Test Collection Pdf[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.connectantigua.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
DOWNLOAD the newest Prep4cram 1z0-076 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1lwTt11hKmgwY8fmjBtcbNKRblssfAaLj
