[Linux] I want to reduce the size of the "/" partition
17
Linux I want to reduce the size of the "/" partition
Posted at 7/23/2024 14:57:25      View2296 | Replies5        Print      Only Author   [Copy Link] 1#
I have reduced the size of the "/" partition in order to create a separate data partition. How can I do this?
firefly@firefly:~$ df
Filesystem          1K-blocks    Used Available Use% Mounted on
udev                   963268       8    963260   1% /dev
tmpfs                  193804     968    192836   1% /run
/dev/mmcblk1p7        2291336 2159884         0 100% /root-ro
/dev/mmcblk1p8       12307572 1201524  11089664  10% /userdata
overlayroot          12307572 1201524  11089664  10% /
/root/dev/mmcblk1p4    122835   38410     75251  34% /boot
tmpfs                  969004       0    969004   0% /dev/shm
tmpfs                    5120       4      5116   1% /run/lock
tmpfs                  969004       0    969004   0% /sys/fs/cgroup
tmpfs                  193800       8    193792   1% /run/user/1000
tmpfs                  193800       0    193800   0% /run/user/0
No_logs.zip
163 Bytes, Down times: 0
Posted at 1/10/2026 11:04:24        Only Author  2#
The article gave me so many new ideas. Wishing you success! Free Latest associate Workday-Pro-Integrations level test test papers are here.
Posted at 1/12/2026 01:19:26        Only Author  3#
그렇게 많은 IT인증덤프공부자료를 제공하는 사이트중DumpTOP의 인지도가 제일 높은 원인은 무엇일가요?그건DumpTOP의 제품이 가장 좋다는 것을 의미합니다. DumpTOP에서 제공해드리는 ISACA인증 CRISC덤프공부자료는ISACA인증 CRISC실제시험문제에 초점을 맞추어 시험커버율이 거의 100%입니다. 이 덤프만 공부하시면ISACA인증 CRISC시험패스에 자신을 느끼게 됩니다.
Posted at 1/26/2026 13:52:42        Only Author  4#
Your article is a work of art, thank you for letting us read it! Lets do this! Wishing for success in the C_THR95_2505 valid test dumps demo exam!
Posted at 2/13/2026 02:16:56        Only Author  5#
After reading this article, I feel I have grown a lot. Best of luck! Here are the free Plat-Arch-202 questions exam study resources for you.
Posted at 3/5/2026 21:36:44        Only Author  6#
This article is brilliant beyond words, thank you for sharing. The Certification C-BCSCX-2502 book torrent materials are excellent, and theyre totally free.
